cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : GeoNode.cpp 00003 // 00004 // Purpose : Node class used for geometry operations. See also GeoTet. 00005 // 00006 // Description : light-weight entity used for computational geometry 00007 // tools. Don't load this up with extra stuff! 00008 // 00009 // Creator : Steve Owen 00010 // 00011 // Creation Date : 8/13/2003 00012 // 00013 // Owner : Steve Owen 00014 //------------------------------------------------------------------------- 00015 00016 00017 #include "GeoNode.hpp" 00018 #include "GeoTet.hpp" 00019 00020 00021 //-------------------------------------------------------------------------- 00022 // Function: GeoNode 00023 // Description: constructor 00024 // Author: sjowen 00025 // Date: 8/13/2003 00026 //--------------------------------------------------------------------------- 00027 GeoNode::GeoNode( CubitVector &xx ) : ownerPtr(NULL) 00028 { 00029 mLocation = xx; 00030 isMarked = 0; 00031 } 00032 00033 //-------------------------------------------------------------------------- 00034 // Function: GeoNode 00035 // Description: destructor 00036 // Author: sjowen 00037 // Date: 8/13/2003 00038 //--------------------------------------------------------------------------- 00039 GeoNode::~GeoNode() 00040 { 00041 } 00042 00043 //-------------------------------------------------------------------------- 00044 // Function: edge_between 00045 // Description: returns whether an edge exists between the two GeoNodes 00046 // Author: sjowen 00047 // Date: 1/26/2004 00048 //--------------------------------------------------------------------------- 00049 CubitBoolean GeoNode::edge_between( GeoNode *other_node ) 00050 { 00051 int ii; 00052 GeoTet *gtet_ptr; 00053 for (ii=0; ii<mTetList.size(); ii++) 00054 { 00055 gtet_ptr = mTetList.get_and_step(); 00056 if (gtet_ptr->node_index( other_node ) >= 0) 00057 return CUBIT_TRUE; 00058 } 00059 return CUBIT_FALSE; 00060 } 00061 00062 //-------------------------------------------------------------------------- 00063 // Function: face_between 00064 // Description: returns whether a face exists between the three GeoNodes 00065 // Author: sjowen 00066 // Date: 1/27/2004 00067 //--------------------------------------------------------------------------- 00068 CubitBoolean GeoNode::face_between( GeoNode *other_node0, GeoNode *other_node1 ) 00069 { 00070 int ii; 00071 GeoTet *gtet_ptr; 00072 for (ii=0; ii<mTetList.size(); ii++) 00073 { 00074 gtet_ptr = mTetList.get_and_step(); 00075 if (gtet_ptr->node_index( other_node0 ) >= 0 && 00076 gtet_ptr->node_index( other_node1 ) >= 0) 00077 return CUBIT_TRUE; 00078 } 00079 return CUBIT_FALSE; 00080 } 00081 00082 //-------------------------------------------------------------------------- 00083 // Function: tets_at_edge 00084 // Description: get a list of tets shared by the two nodes 00085 // returns number of tets in list 00086 // Author: sjowen 00087 // Date: 1/27/2004 00088 //--------------------------------------------------------------------------- 00089 int GeoNode::tets_at_edge( GeoNode *other_node, 00090 DLIList<GeoTet *> >et_list ) 00091 { 00092 int ntets = 0; 00093 int ii; 00094 GeoTet *gtet_ptr; 00095 for (ii=0; ii<mTetList.size(); ii++) 00096 { 00097 gtet_ptr = mTetList.get_and_step(); 00098 if (gtet_ptr->node_index( other_node ) >= 0) 00099 { 00100 gtet_list.append( gtet_ptr ); 00101 ntets++; 00102 } 00103 } 00104 return ntets; 00105 } 00106 00107 //-------------------------------------------------------------------------- 00108 // Function: interior_edges 00109 // Description: get a list of opposite geonodes to this node 00110 // don't return nodes that are external to the domain 00111 // Author: sjowen 00112 // Date: 3/14/2004 00113 //--------------------------------------------------------------------------- 00114 int GeoNode::interior_edges( DLIList <GeoNode *> &node_list ) 00115 { 00116 int nedges = 0; 00117 int ii, jj; 00118 GeoNode *node[4]; 00119 GeoTet *gtet_ptr; 00120 for (ii=0; ii<mTetList.size(); ii++) 00121 { 00122 gtet_ptr = mTetList.get_and_step(); 00123 if (gtet_ptr->inside()) 00124 { 00125 gtet_ptr->tet_nodes(node[0], node[1], node[2], node[3]); 00126 for(jj=0; jj<4; jj++) 00127 node[jj]->marked(1); 00128 } 00129 } 00130 isMarked = 0; 00131 00132 for (ii=0; ii<mTetList.size(); ii++) 00133 { 00134 gtet_ptr = mTetList.get_and_step(); 00135 if (gtet_ptr->inside()) 00136 { 00137 gtet_ptr->tet_nodes(node[0], node[1], node[2], node[3]); 00138 for(jj=0; jj<4; jj++) 00139 { 00140 if (node[jj]->marked()) 00141 { 00142 node[jj]->marked(0); 00143 node_list.append(node[jj]); 00144 nedges++; 00145 } 00146 } 00147 } 00148 } 00149 return nedges; 00150 } 00151 00152 00153 // EOF 00154
