cgma
00001 //- Class: GetLongOpt 00002 //- Description: GetLongOpt manages the definition and parsing of 00003 //- long options. Long options can be abbreviated as long as there 00004 //- is no ambiguity. If an option requires a value, the value should 00005 //- be separated from the option either by whitespace or an "=". 00006 //- 00007 //- Other features: $ 00008 //- o GetLongOpt can be used to parse options given through environments.$ 00009 //- o GetLongOpt provides a usage function to print usage.$ 00010 //- o Flags & options with optional or mandatory values are supported.$ 00011 //- o The option marker ('-' in Unix) can be customized.$ 00012 //- o Parsing of command line returns optind (see getopt(3)).$ 00013 //- o Descriptive error messages.$ 00014 //- 00015 //- Author: S Manoharan. Advanced Computer Research Institute. Lyon. France 00016 //- Owner: Greg Sjaardema 00017 //- Checked By: 00018 //- Version $Id: 00019 00020 #ifndef GETLONGOPT_HPP 00021 #define GETLONGOPT_HPP 00022 00023 #include "CubitDefines.h" 00024 00025 #include <iostream> 00026 00027 #include <cstring> 00028 #include "CGMUtilConfigure.h" 00029 #include <vector> 00030 #include <map> 00031 #include "CubitString.hpp" 00032 00033 class CUBIT_UTIL_EXPORT GetLongOpt { 00034 public: 00035 enum OptType { 00036 Toggle, Valueless, OptionalValue, MandatoryValue 00037 }; 00038 00039 static const CubitString TOGGLE_ON; 00040 static const CubitString TOGGLE_OFF; 00041 00042 GetLongOpt(const char optmark = '-'); //- Constructor 00043 //- Constructor for GetLongOpt takes an optional argument: the option 00044 //- marker. If unspecified, this defaults to '-', the standard (?) 00045 //- Unix option marker. 00046 00047 ~GetLongOpt(); //- Destructor 00048 00049 int parse(const std::vector<CubitString>& args, const CubitString& p = CubitString()); 00050 //- A return 00051 //- value < 1 represents a parse error. Appropriate error messages 00052 //- are printed when errors are seen. {GetLongOpt::parse}, in its first 00053 //- form, takes two strings: the first one is the string to be 00054 //- parsed and the second one is a string to be prefixed to the 00055 //- parse errors. In ts second form, {GetLongOpt::parse} returns the 00056 //- the {optind} (see @i{getopt(3)}) if parsing is successful. 00057 00058 int parse(const CubitString& opt_string, const CubitString &p); 00059 00060 int enroll(const CubitString& opt, const OptType t, 00061 const CubitString& desc, const CubitString& val); 00062 //- Add an option to the list of valid command options.$ 00063 //- {GetLongOpt::enroll} adds option specifications to its internal 00064 //- database. The first argument is the option sting. The second 00065 //- is an enum saying if the option is a flag ({GetLongOpt::Valueless}), 00066 //- if it requires a mandatory value ({GetLongOpt::MandatoryValue}) or 00067 //- if it takes an optional value ({GetLongOpt::OptionalValue}). 00068 //- The third argument is a string giving a brief description of 00069 //- the option. This description will be used by {GetLongOpt::usage}. 00070 //- GetLongOpt, for usage-printing, uses {$val} to represent values 00071 //- needed by the options. {<$val>} is a mandatory value and {[$val]} 00072 //- is an optional value. The final argument to {GetLongOpt::enroll} 00073 //- is the default string to be returned if the option is not 00074 //- specified. For flags (options with {Valueless}), use "" (empty 00075 //- string, or in fact any arbitrary string) for specifying {TRUE} 00076 //- and 0 (null pointer) to specify {FALSE}. 00077 00078 CubitString retrieve(const CubitString& opt) const; 00079 //- Retrieve value of option$ 00080 //- The values of the options that are enrolled in the database 00081 //- can be retrieved using {GetLongOpt::retrieve}. This returns a string 00082 //- and this string should be converted to whatever type you want. 00083 //- See @i{atoi}, @i{atof}, @i{atol} etc. 00084 //- If a "parse" is not done before retrieving all you will get 00085 //- are the default values you gave while enrolling! 00086 //- Ambiguities while retrieving (may happen when options are 00087 //- abbreviated) are resolved by taking the matching option that 00088 //- was enrolled last. For example, -{v} will expand to {-verify}.$ 00089 //- If you try to retrieve something you didn't enroll, you will 00090 //- get a warning message. 00091 00092 void options(std::ostream &outfile = std::cout) const; 00093 //- Print command line options only. Called by usage(). 00094 00095 void usage(std::ostream &outfile, const CubitString &p, const CubitString& u = CubitString()) const; 00096 //- Print usage information to {outfile} 00097 00098 private: 00099 struct Cell { 00100 CubitString option; //- option name 00101 OptType type; //- option type 00102 CubitString description; //- a description of option 00103 CubitString value; //- value of option (string) 00104 int wasSet; //- 0 if not set by user, 1 if set 00105 00106 Cell() { option = description = value = 0; wasSet = 0; } 00107 }; 00108 00109 typedef std::map<CubitString, Cell> Table; 00110 Table mTable; 00111 00112 char optmarker; //- option marker 00113 00114 int setcell(Cell &c, const CubitString &valtoken, const CubitString &nexttoken, const CubitString &name); 00115 }; 00116 00117 #endif // GETLONGOPT_HPP 00118
