cgma
00001 00002 00003 #ifndef GFX_DEBUG_INTERFACE_HPP 00004 #define GFX_DEBUG_INTERFACE_HPP 00005 00006 // An interface for any tools, algorithms, etc... to draw things. 00007 // NOTE: this is an "interface" in the sense that using it will not 00008 // create additional depedencies in your code. If a subclass of GfxDebug 00009 // is not instantiated, then this class acts as a stub with empty implementation. 00010 // 00011 // any graphics primitives drawn with this interface are temporary primitives and 00012 // not permanent ones. Any primitive or window created with this class are 00013 // owned by this class (or the user of this class in a sense) 00014 // and not by any other graphics model (ie GGeomModel, GMeshModel, etc...). 00015 00016 00017 // We only have forward declarations and NO #includes !!! (except those already in the util folder) 00018 template <class X> class DLIList; 00019 class RefEntity; 00020 class MeshEntity; 00021 class CubitNode; 00022 class CubitEdge; 00023 class CubitFace; 00024 class CubitTri; 00025 class CubitTet; 00026 class CubitHex; 00027 class CubitPyramid; 00028 class CubitWedge; 00029 struct GPoint; 00030 class CubitFacet; 00031 class CubitFacetEdge; 00032 class GeoTet; 00033 class GeoNode; 00034 class CubitVector; 00035 class RefEntity; 00036 class RefVertex; 00037 class RefEdge; 00038 class RefFace; 00039 class RefVolume; 00040 class Body; 00041 class MRefEntity; 00042 class MRefVertex; 00043 class MRefEdge; 00044 class MRefFace; 00045 class MRefVolume; 00046 class MBody; 00047 class CubitTransformMatrix; 00048 class CubitBox; 00049 class Surface; 00050 00051 #include "CubitColor.hpp" 00052 #include "CGMUtilConfigure.h" 00053 00054 class CUBIT_UTIL_EXPORT GfxDebug 00055 { 00056 // the one instance of the Graphics Debug object 00057 // creating a second instance will delete and replace the first instance. 00058 protected: 00059 static GfxDebug* mInstance; 00060 00061 public: 00062 GfxDebug(); 00063 virtual ~GfxDebug(); 00064 00065 static bool is_initialized(); 00066 00067 // this will clear out all temporary data and delete any graphics windows created 00068 // with this interface. It'll restore the persistent geom/mesh model. 00069 //static void reset(); 00070 00071 // this will clear out the geom/mesh model and only subsequent drawing 00072 // will be visible 00073 static void clear(); 00074 00075 // same as DrawingTool::display_all 00076 static void display_all(bool flush_highlight = true, bool import_mesh_display = false); 00077 00078 // clear out the highlighted 00079 static void clear_highlight(); 00080 00081 // set the drawing mode 00082 static void drawing_mode(int mode); 00083 00084 // rebuild all 00085 //static void rebuild_all(); 00086 00087 // Window Related Functions 00088 00089 // creates a graphics window 00090 // not creating a window will use an existing current window 00091 // all drawing goes only into all windows created here or an existing window 00092 static int create_window(); 00093 // deletes a window created by this interface 00094 static void delete_window(int window_id); 00095 00096 // switches a window created by this interface into a 2D drawing mode. 00097 static void set_2D_mode(int window_id); 00098 00099 // causes the window(s) to be redrawn 00100 static void flush(); 00101 00102 // give control to the window(s) to handle mouse events 00103 static void mouse_xforms(); 00104 00105 static void display_to_world_length(double pixels, double& length); 00106 00107 // Geometry Drawing Functions 00108 static void draw_ref_entity(RefEntity* entity, int color = CUBIT_DEFAULT_COLOR_INDEX, 00109 CubitTransformMatrix* trans_mat = 0); 00110 static void draw_ref_vertex(RefVertex* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00111 static void draw_ref_edge(RefEdge* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00112 static void draw_ref_face(RefFace* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00113 static void draw_ref_face_edges(RefFace* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00114 static void draw_ref_volume(RefVolume* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00115 static void draw_ref_body(Body* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00116 00117 //static void highlight_ref_entity(RefEntity* entity); 00118 static void highlight_ref_vertex(RefVertex* entity); 00119 static void highlight_ref_edge(RefEdge* entity); 00120 static void highlight_ref_face(RefFace* entity); 00121 static void highlight_ref_volume(RefVolume* entity); 00122 static void highlight_ref_body(Body* entity); 00123 00124 static void draw_mref_entity(MRefEntity* entity, int color = CUBIT_DEFAULT_COLOR_INDEX, 00125 bool draw_geom = true, bool draw_mesh = true, 00126 CubitTransformMatrix* trans_mat = 0); 00127 static void draw_mref_vertex(MRefVertex* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00128 static void draw_mref_edge(MRefEdge* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00129 static void draw_mref_face(MRefFace* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00130 static void draw_mref_volume(MRefVolume* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00131 static void draw_mref_body(MBody* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00132 static void draw_mref_entity_mesh(MRefEntity* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00133 static void draw_mref_volume_faces(MRefVolume* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00134 00135 //static void highlight_mref_entity(MRefEntity* entity); 00136 static void highlight_mref_vertex(MRefVertex* entity); 00137 static void highlight_mref_edge(MRefEdge* entity); 00138 static void highlight_mref_face(MRefFace* entity); 00139 static void highlight_mref_volume(MRefVolume* entity); 00140 static void highlight_mref_body(MBody* entity); 00141 00142 00143 // Mesh Drawing Functions 00144 00145 // draws mesh entities with a color from the cubit color table 00146 // prefer these functions to a loop drawing each entity separately 00147 //static void draw_mesh_entities(DLIList<MeshEntity*>* entities, int color); 00148 static void draw_nodes(DLIList<CubitNode*>* entities, int color); 00149 static void draw_edges(DLIList<CubitEdge*>* entities, int color); 00150 static void draw_quads(DLIList<CubitFace*>* entities, int color); 00151 static void draw_tris(DLIList<CubitTri*>* entities, int color); 00152 static void draw_tets(DLIList<CubitTet*>* entities, int color); 00153 static void draw_hexes(DLIList<CubitHex*>* entities, int color); 00154 //static void draw_pyramids(DLIList<CubitPyramid*>* entities, int color); 00155 static void draw_wedges(DLIList<CubitWedge*>* entities, int color); 00156 00157 static void draw_mesh_entity(MeshEntity* entity, int color); 00158 static void draw_node(CubitNode* entity, int color); 00159 static void draw_edge(CubitEdge* entity, int color); 00160 static void draw_quad(CubitFace* entity, int color); 00161 static void draw_tri(CubitTri* entity, int color); 00162 static void draw_tet(CubitTet* entity, int color); 00163 static void draw_hex(CubitHex* entity, int color); 00164 static void draw_pyramid(CubitPyramid* entity, int color); 00165 static void draw_wedge(CubitWedge* entity, int color); 00166 //static void draw_node_array(CubitNode* nodes[], int color, bool ink_edges = true); 00167 00168 static void highlight_node(CubitNode* entity); 00169 static void highlight_edge(CubitEdge* entity); 00170 static void highlight_quad(CubitFace* entity); 00171 static void highlight_tri(CubitTri* entity); 00172 static void highlight_tet(CubitTet* entity); 00173 static void highlight_hex(CubitHex* entity); 00174 static void highlight_pyramid(CubitPyramid* entity); 00175 static void highlight_wedge(CubitWedge* entity); 00176 00177 00178 // Facet Drawing Functions 00179 static void draw_facet(CubitFacet* facet, int color, int draw_uv = 0); 00180 static void draw_facet_edge(CubitFacetEdge* facet_edge, int color); 00181 static void draw_geotet( GeoTet *tet, int color ); 00182 static void draw_geonode( GeoNode *node, int color ); 00183 00184 // Generic Primitive Drawing Functions 00185 00186 static void draw_box(CubitBox& box, int color); 00187 00188 // draw point x,y,z of color 00189 static void draw_point(float x, float y, float z, int color); 00190 static void draw_point(const CubitVector& vector, int color); 00191 static void draw_point(CubitVector* vector, int color); 00192 static void draw_points( DLIList<CubitVector> &points, int color ); 00193 00194 // draw line of points {x,y,z}, {x,y,z} of color 00195 static void draw_line(float x1, float y1, float z1, 00196 float x2, float y2, float z2, int color); 00197 00198 static void draw_line(const CubitVector& x, const CubitVector& y, int color); 00199 00200 // draw a polyline with a number of points of a color 00201 static void draw_polyline(const GPoint* points, int num_points, int color); 00202 00203 // draw a polygon with a number of points of a color and filled or not 00204 static void draw_polygon(const GPoint* points, int num_points, int color, int border_color, bool filled = true); 00205 00206 // draw a quad of a color 00207 static void draw_quad(const GPoint* points, int color); 00208 00209 // draw a tri of a color 00210 static void draw_tri(const GPoint* points, int color); 00211 00212 // draw a vector (tail -> head) of color 00213 static void draw_vector(const GPoint* tail, const GPoint* head, int color); 00214 static void draw_vector(const CubitVector& tail, const CubitVector& head, int color); 00215 00216 // draw a shell (num points, point list, num faces, face list) of color 00217 static void draw_shell(int num_pts, const GPoint* points, 00218 int num_faces, const int* face_list, int color); 00219 00220 // draw a shell (num points, point list, num faces, face list) with point colors 00221 static void draw_shell(int num_pts, const GPoint* points, 00222 int num_faces, const int* face_list, const int* colors); 00223 00224 // draw a label at position x,y,z of color 00225 static void draw_label(const char* label, float x, float y, float z, int color); 00226 static void draw_label(int label, float x, float y, float z, int color); 00227 00228 // zoom to specified bounding box 00229 static void zoom(CubitBox &box); 00230 00231 // highlight simple primitives 00232 static void highlight_points(int num_points, const double* xyzs); 00233 static void highlight_polylines(int num_points, const double* xyzs, int num_line_points, const int* line_list); 00234 static void highlight_polygons(int num_points, const double* xyzs, int num_face_points, const int* face_list ); 00235 00236 static void draw_surface(Surface *surf, int color); 00237 00238 protected: 00239 00240 // p is for protected in case you were wondering :) 00241 00242 //virtual void p_reset() = 0; 00243 virtual void p_clear() = 0; 00244 virtual void p_display_all(bool,bool) = 0; 00245 virtual void p_clear_highlight() = 0; 00246 virtual void p_drawing_mode(int) = 0; 00247 //virtual void p_rebuild_all() = 0; 00248 00249 virtual int p_create_window() = 0; 00250 virtual void p_delete_window(int) = 0; 00251 virtual void p_set_2D_mode(int) = 0; 00252 virtual void p_flush() = 0; 00253 virtual void p_mouse_xforms() = 0; 00254 virtual void p_display_to_world_length(double pixels, double& length) = 0; 00255 00256 virtual void p_draw_ref_entity(RefEntity* entity, int color, CubitTransformMatrix* mat) = 0; 00257 virtual void p_draw_ref_vertex(RefVertex* entity, int color) = 0; 00258 virtual void p_draw_ref_edge(RefEdge* entity, int color) = 0; 00259 virtual void p_draw_ref_face(RefFace* entity, int color) = 0; 00260 virtual void p_draw_ref_face_edges(RefFace* entity, int color) = 0; 00261 virtual void p_draw_ref_volume(RefVolume* entity, int color) = 0; 00262 virtual void p_draw_ref_body(Body* entity, int color) = 0; 00263 virtual void p_draw_mref_entity(MRefEntity* entity, int color, bool geom, bool mesh, CubitTransformMatrix* mat) = 0; 00264 virtual void p_draw_mref_vertex(MRefVertex* entity, int color) = 0; 00265 virtual void p_draw_mref_edge(MRefEdge* entity, int color) = 0; 00266 virtual void p_draw_mref_face(MRefFace* entity, int color) = 0; 00267 virtual void p_draw_mref_volume(MRefVolume* entity, int color) = 0; 00268 virtual void p_draw_mref_body(MBody* entity, int color) = 0; 00269 virtual void p_draw_mref_entity_mesh(MRefEntity* entity, int color) = 0; 00270 virtual void p_draw_mref_volume_faces(MRefVolume* entity, int color) = 0; 00271 00272 //virtual void p_highlight_ref_entity(RefEntity* entity) = 0; 00273 virtual void p_highlight_ref_vertex(RefVertex* entity) = 0; 00274 virtual void p_highlight_ref_edge(RefEdge* entity) = 0; 00275 virtual void p_highlight_ref_face(RefFace* entity) = 0; 00276 virtual void p_highlight_ref_volume(RefVolume* entity) = 0; 00277 virtual void p_highlight_ref_body(Body* entity) = 0; 00278 //virtual void p_highlight_mref_entity(MRefEntity* entity) = 0; 00279 virtual void p_highlight_mref_vertex(MRefVertex* entity) = 0; 00280 virtual void p_highlight_mref_edge(MRefEdge* entity) = 0; 00281 virtual void p_highlight_mref_face(MRefFace* entity) = 0; 00282 virtual void p_highlight_mref_volume(MRefVolume* entity) = 0; 00283 virtual void p_highlight_mref_body(MBody* entity) = 0; 00284 00285 00286 //virtual void p_draw_mesh_entities(DLIList<MeshEntity*>*, int) = 0; 00287 virtual void p_draw_nodes(DLIList<CubitNode*>*, int) = 0; 00288 virtual void p_draw_edges(DLIList<CubitEdge*>*, int) = 0; 00289 virtual void p_draw_quads(DLIList<CubitFace*>*, int) = 0; 00290 virtual void p_draw_tris(DLIList<CubitTri*>*, int) = 0; 00291 virtual void p_draw_tets(DLIList<CubitTet*>*, int) = 0; 00292 virtual void p_draw_hexes(DLIList<CubitHex*>*, int) = 0; 00293 //virtual void p_draw_pyramids(DLIList<CubitPyramid*>*, int) = 0; 00294 virtual void p_draw_wedges(DLIList<CubitWedge*>*, int) = 0; 00295 virtual void p_draw_mesh_entity(MeshEntity*, int) = 0; 00296 virtual void p_draw_node(CubitNode*, int) = 0; 00297 virtual void p_draw_edge(CubitEdge*, int) = 0; 00298 virtual void p_draw_quad(CubitFace*, int) = 0; 00299 virtual void p_draw_tri(CubitTri*, int) = 0; 00300 virtual void p_draw_tet(CubitTet*, int) = 0; 00301 virtual void p_draw_hex(CubitHex*, int) = 0; 00302 virtual void p_draw_pyramid(CubitPyramid*, int) = 0; 00303 virtual void p_draw_wedge(CubitWedge*, int) = 0; 00304 virtual void p_highlight_node(CubitNode* entity) = 0; 00305 virtual void p_highlight_edge(CubitEdge* entity) = 0; 00306 virtual void p_highlight_quad(CubitFace* entity) = 0; 00307 virtual void p_highlight_tri(CubitTri* entity) = 0; 00308 virtual void p_highlight_tet(CubitTet* entity) = 0; 00309 virtual void p_highlight_hex(CubitHex* entity) = 0; 00310 virtual void p_highlight_pyramid(CubitPyramid* entity) = 0; 00311 virtual void p_highlight_wedge(CubitWedge* entity) = 0; 00312 00313 virtual void p_draw_facet(CubitFacet*, int,int) = 0; 00314 virtual void p_draw_facet_edge(CubitFacetEdge*, int) = 0; 00315 virtual void p_draw_geotet(GeoTet*, int) = 0; 00316 virtual void p_draw_geonode(GeoNode *, int) = 0; 00317 00318 virtual void p_draw_box(CubitBox& box, int color) = 0; 00319 00320 virtual void p_draw_point(float, float, float, int) = 0; 00321 virtual void p_draw_point(const CubitVector& vector, int color) = 0; 00322 virtual void p_draw_line(float, float, float, float, float, float, int) = 0; 00323 virtual void p_draw_line(const CubitVector& x, const CubitVector& y, int color) = 0; 00324 virtual void p_draw_polyline(const GPoint*, int, int) = 0; 00325 virtual void p_draw_polygon(const GPoint* points, int num_points, int color, int border_color, bool filled) = 0; 00326 virtual void p_draw_quad(const GPoint*, int) = 0; 00327 virtual void p_draw_tri(const GPoint*, int) = 0; 00328 virtual void p_draw_vector(const CubitVector&, const CubitVector&, int) = 0; 00329 virtual void p_draw_shell(int, const GPoint*, int, const int*, int) = 0; 00330 virtual void p_draw_shell(int, const GPoint*, int, const int*, const int*) = 0; 00331 virtual void p_draw_label(const char*, float, float, float, int) = 0; 00332 virtual void p_draw_label(int, float, float, float, int) = 0; 00333 virtual void p_zoom(CubitBox &box) = 0; 00334 00335 virtual void p_highlight_points(int num_points, const double* xyzs) = 0; 00336 virtual void p_highlight_polylines(int num_points, const double* xyzs, int num_line_points, const int* line_list) = 0; 00337 virtual void p_highlight_polygons(int num_points, const double* xyzs, int num_face_points, const int* face_list ) = 0; 00338 00339 virtual void p_draw_surface(Surface *surf, int color) = 0; 00340 00341 }; 00342 00343 #endif 00344 00345
