cgma
00001 00002 00003 #ifndef GFX_PREVIEW_INTERFACE_HPP 00004 #define GFX_PREVIEW_INTERFACE_HPP 00005 00006 // An interface for any tools, algorithms, etc... to draw preview objects. 00007 // NOTE: this is an "interface" in the sense that using it will not 00008 // create additional depedencies in your code. If a subclass of GfxPreview 00009 // is not instantiated, then this class acts as a stub with empty implementation. 00010 // CGM users may implement preview code by deriving from this class and implementing 00011 // graphics code in the pure virtual p_* methods. Creating an instance of the 00012 // derived class will result in the correct methods being called by this interface. 00013 00014 // PLEASE!!! use this interface to implement any graphical preview code in CGM. 00015 // This will identify graphics code that must be maintained for end users. 00016 00017 // 00018 // any graphics primitives drawn with this interface are temporary primitives and 00019 // not permanent ones. All items are draw into a single drawing set owned by the 00020 // 00021 00022 00023 // We only have forward declarations and NO #includes !!! (except those already in the util folder) 00024 template <class X> class DLIList; 00025 class RefEntity; 00026 struct GPoint; 00027 class CubitVector; 00028 class RefEntity; 00029 class RefVertex; 00030 class RefEdge; 00031 class RefFace; 00032 class RefVolume; 00033 class Body; 00034 class CubitTransformMatrix; 00035 class CubitBox; 00036 class Curve; 00037 class Surface; 00038 class TBPoint; 00039 00040 #include "CubitColor.hpp" 00041 #include "CGMGeomConfigure.h" 00042 #include "DrawingToolDefines.h" 00043 00044 class CUBIT_GEOM_EXPORT GfxPreview 00045 { 00046 // the one instance of the Graphics Preview object 00047 // creating a second instance will delete and replace the first instance. 00048 static GfxPreview* mInstance; 00049 00050 public: 00051 GfxPreview(); 00052 virtual ~GfxPreview(); 00053 00054 // this will clear out all temporary data and delete any graphics windows created 00055 // with this interface. It'll restore the persistent geom/mesh model. 00056 //static void reset(); 00057 00058 // this will clear out any objects drawn using preview graphics. 00059 // no other graphics will be affected so you can now do something like 00060 // draw vol 4 00061 // webcut vol all plane x preview 00062 // and then clear the preview and you will still only have vol 4 displaye. 00063 static void clear(); 00064 00065 // causes the window(s) to be redrawn 00066 static void flush(); 00067 00068 // Geometry Drawing Functions 00069 static void draw_ref_entity(RefEntity* entity, int color = CUBIT_DEFAULT_COLOR_INDEX, 00070 CubitTransformMatrix* trans_mat = 0); 00071 static void draw_ref_vertex(RefVertex* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00072 static void draw_ref_edge(RefEdge* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00073 static void draw_ref_face(RefFace* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00074 static void draw_ref_face_edges(RefFace* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00075 static void draw_ref_volume(RefVolume* entity, int color = CUBIT_DEFAULT_COLOR_INDEX, int mode = CUBIT_SMOOTH_SHADING); 00076 static void draw_ref_volume_edges(RefVolume* entity, int color = CUBIT_DEFAULT_COLOR_INDEX); 00077 static void draw_ref_body(Body* entity, int color = CUBIT_DEFAULT_COLOR_INDEX, int mode = CUBIT_SMOOTH_SHADING); 00078 00079 static void draw_point(TBPoint *pt, int color); 00080 static void draw_curve(Curve *curve, int color); 00081 static void draw_surface(Surface *surf, int color); 00082 static void draw_surface_facets_shaded(Surface *surf, int color); 00083 00084 // Generic Primitive Drawing Functions 00085 00086 static void draw_box(CubitBox& box, int color); 00087 00088 // draw point x,y,z of color 00089 static void draw_point(float x, float y, float z, int color); 00090 static void draw_point(const CubitVector& vector, int color); 00091 static void draw_point(CubitVector* vector, int color); 00092 00093 // draw line of points {x,y,z}, {x,y,z} of color 00094 static void draw_line(float x1, float y1, float z1, 00095 float x2, float y2, float z2, int color); 00096 00097 static void draw_line(const CubitVector& x, const CubitVector& y, int color); 00098 00099 // draw a polyline with a number of points of a color 00100 static void draw_polyline(const GPoint* points, int num_points, int color); 00101 00102 // draw a polygon with a number of points of a color and filled or not 00103 static void draw_polygon(const GPoint* points, int num_points, int color, int border_color, bool filled = true); 00104 // draw a list of polygons (much more efficent than drawing a single polygon multiple times.) 00105 // pass in the coordinates and the connectivity 00106 // the face_list is comprised of a list num_points_in_face, face_pt1, face_pt2, face_pt3, ... 00107 static void draw_polygons(int num_points, const double *xyzs, int num_face_points, 00108 const int* face_list, int color, int mode); 00109 00116 static void draw_cylinder(const CubitVector& axis, const CubitVector& origin, 00117 CubitBox& bounding_box, float radius, int color); 00118 00119 static void draw_frustum( const CubitVector axis , const CubitVector origin1, const CubitVector origin2,double dRad1 , double dRad2, 00120 CubitBox& bounding_box ,int color); 00121 // draw a quad of a color 00122 static void draw_quad(const GPoint* points, int color); 00123 00124 // draw a tri of a color 00125 static void draw_tri(const GPoint* points, int color); 00126 00127 // draw a vector (tail -> head) of color 00128 static void draw_vector(const GPoint* tail, const GPoint* head, int color); 00129 static void draw_vector(const CubitVector& tail, const CubitVector& head, int color); 00130 00131 // draw a label at position x,y,z of color 00132 static void draw_label(const char* label, float x, float y, float z, int color); 00133 static void draw_label(int label, float x, float y, float z, int color); 00134 00135 protected: 00136 00137 // p is for protected in case you were wondering :) 00138 00139 virtual void p_clear() = 0; 00140 virtual void p_flush() = 0; 00141 00142 virtual void p_draw_ref_entity(RefEntity* entity, int color, CubitTransformMatrix* mat) = 0; 00143 virtual void p_draw_ref_vertex(RefVertex* entity, int color) = 0; 00144 virtual void p_draw_ref_edge(RefEdge* entity, int color) = 0; 00145 virtual void p_draw_ref_face(RefFace* entity, int color) = 0; 00146 virtual void p_draw_ref_face_edges(RefFace* entity, int color) = 0; 00147 virtual void p_draw_ref_volume(RefVolume* entity, int color, int mode) = 0; 00148 virtual void p_draw_ref_volume_edges(RefVolume* entity, int color) = 0; 00149 virtual void p_draw_ref_body(Body* entity, int color, int mode) = 0; 00150 virtual void p_draw_box(CubitBox& box, int color) = 0; 00151 virtual void p_draw_point(float, float, float, int) = 0; 00152 virtual void p_draw_point(const CubitVector& vector, int color) = 0; 00153 virtual void p_draw_line(float, float, float, float, float, float, int) = 0; 00154 virtual void p_draw_line(const CubitVector& x, const CubitVector& y, int color) = 0; 00155 virtual void p_draw_polyline(const GPoint*, int, int) = 0; 00156 virtual void p_draw_polygon(const GPoint* points, int num_points, int color, int border_color, bool filled) = 0; 00157 virtual void p_draw_polygons(int num_points, const double* xyzs, int num_face_points, 00158 const int* face_list, int color, int mode) = 0; 00159 virtual void p_draw_cylinder(const CubitVector& axis, const CubitVector& origin, 00160 CubitBox& bounding_box, float radius, int color) = 0; 00161 virtual void p_draw_frustum(const CubitVector axis, const CubitVector origin1, const CubitVector origin2, 00162 double radius1 , double radius2 ,CubitBox bounding_box , int color) = 0; 00163 virtual void p_draw_quad(const GPoint*, int) = 0; 00164 virtual void p_draw_tri(const GPoint*, int) = 0; 00165 virtual void p_draw_vector(const CubitVector&, const CubitVector&, int) = 0; 00166 virtual void p_draw_label(const char*, float, float, float, int) = 0; 00167 virtual void p_draw_label(int, float, float, float, int) = 0; 00168 }; 00169 00170 #endif 00171 00172
