cgma
00001 //----------------------------------------------------------------- 00002 //- Class: KDDTreeNode 00003 //- Author: Kevin Albrecht 00004 //- Created: 13 May 2003 00005 //- Updated: 8 Feb 2004 00006 //- 00007 //- Description: 00008 //- Node for dynamic version of the k-d tree, where k=3. 00009 //- 00010 //- References: 00011 //- 00012 //- Hanan Samet. Design and Analysis of Spatial Data Structures. 00013 //- Addison-Wesley, Reading, MA, 1990. 00014 //- 00015 //- Jon Louis Bentley. Multidimensional binary search trees used 00016 //- for associative searching. In Communications of the ACM, 00017 //- 18(9), pages 509-517, September 1975. 00018 //----------------------------------------------------------------- 00019 00020 //--------------------------------- 00021 // Include Files 00022 //--------------------------------- 00023 00024 #include "KDDTreeNode.hpp" 00025 #include "DLIList.hpp" 00026 00027 //--------------------------- 00028 // Initialize Static Members 00029 //--------------------------- 00030 00031 #ifdef INLINE_TEMPLATES 00032 #define MY_INLINE inline 00033 #else 00034 #define MY_INLINE 00035 #endif 00036 00037 //- Constructor 00038 template <class Y> MY_INLINE KDDTreeNode<Y>::KDDTreeNode 00039 ( Y aData, DIMENSION aDisc ) 00040 { 00041 parent = left = right = NULL; 00042 data = aData; 00043 00044 boundingBox = data->bounding_box(); 00045 x = boundingBox.center().x(); 00046 y = boundingBox.center().y(); 00047 z = boundingBox.center().z(); 00048 00049 myDist = CUBIT_DBL_MAX; 00050 myDistData = DD_SAFETY; 00051 00052 myDisc = aDisc; 00053 00054 valid = CUBIT_TRUE; 00055 } 00056 00057 //- Destructor 00058 template <class Y> MY_INLINE KDDTreeNode<Y>::~KDDTreeNode () 00059 { 00060 } 00061 00062 template <class Y> MY_INLINE KDDTreeNode<Y> *KDDTreeNode<Y>::get_child (DIRECTION dir) const 00063 { 00064 if (dir == DIR_LEFT) return left; 00065 return right; 00066 } 00067 00068 template <class Y> MY_INLINE void KDDTreeNode<Y>::set_child 00069 ( KDDTreeNode<Y> *node, 00070 DIRECTION dir ) 00071 { 00072 if (dir == DIR_LEFT) 00073 { 00074 left = node; 00075 } 00076 else 00077 { 00078 right = node; 00079 } 00080 } 00081 00082 template <class Y> MY_INLINE DIMENSION KDDTreeNode<Y>::next_disc () const 00083 { 00084 switch (myDisc) 00085 { 00086 case DIMX: return DIMY; 00087 case DIMY: return DIMZ; 00088 default: return DIMX; 00089 } 00090 } 00091 00092 //- The KD_COMPARE function as defined by Samet 00093 template <class Y> MY_INLINE DIRECTION KDDTreeNode<Y>::compare (KDDTreeNode<Y> *Q) const 00094 { 00095 if (Q->myDisc == DIMX) 00096 { 00097 if (x <= Q->x) return DIR_LEFT; 00098 else return DIR_RIGHT; 00099 } 00100 else if (Q->myDisc == DIMY) 00101 { 00102 if (y <= Q->y) return DIR_LEFT; 00103 else return DIR_RIGHT; 00104 } 00105 else if (z <= Q->z) 00106 { 00107 return DIR_LEFT; 00108 } 00109 else 00110 { 00111 return DIR_RIGHT; 00112 } 00113 } 00114 00115 //- The KD_COMPARE function as defined by Samet 00116 template <class Y> MY_INLINE DIRECTION KDDTreeNode<Y>::compare_with_equality (KDDTreeNode<Y> *Q) const 00117 { 00118 if (Q->myDisc == DIMX) 00119 { 00120 if (x < Q->x) return DIR_LEFT; 00121 else if (x == Q->x) return DIR_EITHER; 00122 else return DIR_RIGHT; 00123 } 00124 else if (Q->myDisc == DIMY) 00125 { 00126 if (y < Q->y) return DIR_LEFT; 00127 else if (y == Q->y) return DIR_EITHER; 00128 else return DIR_RIGHT; 00129 } 00130 else if (z < Q->z) 00131 { 00132 return DIR_LEFT; 00133 } 00134 else if (z == Q->z) 00135 { 00136 return DIR_EITHER; 00137 } 00138 else 00139 { 00140 return DIR_RIGHT; 00141 } 00142 } 00143
