cgma
00001 //----------------------------------------------------------------- 00002 //- Class: KDDTreeNode 00003 //- Author: Kevin Albrecht 00004 //- Created: 13 May 2003 00005 //- Updated: 8 Feb 2004 00006 //- 00007 //- Description: 00008 //- Node for dynamic version of the k-d tree, where k=3. 00009 //- 00010 //- References: 00011 //- 00012 //- Hanan Samet. Design and Analysis of Spatial Data Structures. 00013 //- Addison-Wesley, Reading, MA, 1990. 00014 //- 00015 //- Jon Louis Bentley. Multidimensional binary search trees used 00016 //- for associative searching. In Communications of the ACM, 00017 //- 18(9), pages 509-517, September 1975. 00018 //----------------------------------------------------------------- 00019 00020 #ifndef KDDTREENODE_HPP 00021 #define KDDTREENODE_HPP 00022 00023 #include "CubitDefines.h" 00024 #include "GeometryDefines.h" 00025 #include "CubitBox.hpp" 00026 00027 //- constants that show the direction of discrimination 00028 enum DIMENSION 00029 { 00030 DIMX, DIMY, DIMZ 00031 }; 00032 00033 //- constants used to determine left vs. right 00034 enum DIRECTION 00035 { 00036 DIR_NULL, DIR_EITHER, DIR_LEFT, DIR_RIGHT 00037 }; 00038 00039 enum DISTDATA 00040 { 00041 DD_SAFETY, DD_LEAF 00042 }; 00043 00044 template <class X> class DLIList; 00045 00046 template <class Y> class KDDTreeNode 00047 { 00048 private: 00049 DIMENSION myDisc; // dimension in which this node discriminates 00050 double myDist; // used for nearest neigbhor searches 00051 DISTDATA myDistData; // also used for nearest neigbhor searches 00052 00053 public: 00054 KDDTreeNode<Y> *parent; // parent of this node 00055 KDDTreeNode<Y> *left; // left subtree 00056 KDDTreeNode<Y> *right; // right subtree 00057 double x, y, z; // coordinates of center point 00058 Y data; // data with bounding box centered on this node 00059 CubitBoolean valid; // false if this node should be deleted 00060 00061 CubitBox safetyBox; // bounding box of myData and the safetyBox's of children 00062 CubitBox boundingBox; // bounding box of myData 00063 00064 //- Constructor/Destructor 00065 KDDTreeNode (Y aData, DIMENSION aDisc = DIMX); 00066 ~KDDTreeNode (); 00067 00068 //- Get/set the child in the direction of "dir" 00069 KDDTreeNode<Y> *get_child (DIRECTION dir) const; 00070 void set_child (KDDTreeNode<Y> *node, DIRECTION dir); 00071 00072 //- Get/set the "myDist" value 00073 double get_dist () const { return myDist; } 00074 void set_dist (double dist) { myDist = dist; } 00075 00076 //- Get/set the "myDistData" value 00077 DISTDATA get_dist_data () const { return myDistData; } 00078 void set_dist_data (DISTDATA distData) { myDistData = distData; } 00079 00080 //- Get/set the discriminating dimension of this node 00081 DIMENSION get_disc () const { return myDisc; } 00082 void set_disc (DIMENSION dim) { myDisc = dim; } 00083 00084 //- Get the discriminator for the depth below this node 00085 DIMENSION next_disc () const; 00086 00087 //- The KD_COMPARE function as defined by Samet 00088 DIRECTION compare (KDDTreeNode<Y> *Q) const; 00089 DIRECTION compare_with_equality (KDDTreeNode<Y> *Q) const; 00090 }; 00091 00092 #include "KDDTreeNode.cpp" 00093 00094 #endif
