cgma
00001 //----------------------------------------------------------------- 00002 //- Class: KDDTree 00003 //- Author: Kevin Albrecht 00004 //- Created: 13 May 2003 00005 //- Updated: 8 Feb 2004 00006 //- 00007 //- Description: 00008 //- Dynamic version of the k-d tree, where k=3. 00009 //- 00010 //- References: 00011 //- 00012 //- Hanan Samet. Design and Analysis of Spatial Data Structures. 00013 //- Addison-Wesley, Reading, MA, 1990. 00014 //- 00015 //- Jon Louis Bentley. Multidimensional binary search trees used 00016 //- for associative searching. In Communications of the ACM, 00017 //- 18(9), pages 509-517, September 1975. 00018 //----------------------------------------------------------------- 00019 00020 #ifndef KDDTREE_HPP 00021 #define KDDTREE_HPP 00022 00023 // this value is a percentage 00024 #define KDDTREE_DEFAULT_SELF_BALANCING_DELETION_TOLERANCE 0.0 00025 00026 #include "CubitDefines.h" 00027 #include "GeometryDefines.h" 00028 #include "KDDTreeNode.hpp" 00029 #include "PriorityQueue.hpp" 00030 #include "AbstractTree.hpp" 00031 00032 class CubitBox; 00033 class CubitVector; 00034 00035 template <class X> class DLIList; 00036 template <class Y> class KDDTreeNode; 00037 00038 template <class Z> class KDDTree : public AbstractTree<Z> 00039 { 00040 private: 00041 CubitBoolean mySelfBalancingOn; 00042 double myTolerance; 00043 DLIList<KDDTreeNode<Z>*> myAddList; // nodes added but not on tree 00044 KDDTreeNode<Z> *myDeepestLeaf; // used by "recursiveRemove" to hold the deepest leaf node 00045 int myMarkedNodes; // number of nodes marked for deletion 00046 double myDeletionTolerance; // the deletion tolerance (floating point percentage between 0 and 1) 00047 CubitBoolean myRandomOn; // randomness switch 00048 00049 double min_dist_sq (CubitVector &q, CubitBox &b_box); 00050 00051 //- Find the depth of the tree recursively 00052 void recursive_find_max_height (KDDTreeNode<Z> *root, int depth, int *maxdepth); 00053 00054 //- Balance the tree recursively 00055 KDDTreeNode<Z> *recursive_balance (DIMENSION dim, int left, int right, 00056 KDDTreeNode<Z>* array[], KDDTreeNode<Z>* parent); 00057 00058 //- Recursively find members intersecting this range box (called by "find") 00059 void recursive_find ( KDDTreeNode<Z> *rect_tree, const CubitBox &range_box, 00060 DLIList <Z> &range_members ); 00061 00062 //- Return a pointer to the node containing the specified data 00063 KDDTreeNode<Z> *find_node_containing_data (KDDTreeNode<Z> *subtreeRoot, Z data); 00064 00065 //- Find the node with the minimum value in the D dimension (used by 00066 //- "recursiveRemove") 00067 KDDTreeNode<Z> *find_minimum_node_of_dimension (KDDTreeNode<Z> *P, DIMENSION D); 00068 00069 //- Insert the node on the tree 00070 CubitStatus insert_node (KDDTreeNode<Z>* P); 00071 00072 //- Immediately put all nodes on list onto the tree 00073 CubitStatus dump_list (); 00074 00075 //- Rearrange the array around the median point 00076 int modifind (DIMENSION dim, int left, int right, KDDTreeNode<Z>* array[]); 00077 00078 public: 00079 DLIList<KDDTreeNode<Z>*> myNodeList; // nodes on tree 00080 KDDTreeNode<Z> *root; 00081 00082 //- Constructors/Destructor 00083 KDDTree (double tol = GEOMETRY_RESABS, CubitBoolean selfBalancingOn = CUBIT_TRUE, 00084 double selfBalancingDeletionTolerance = KDDTREE_DEFAULT_SELF_BALANCING_DELETION_TOLERANCE, 00085 CubitBoolean randomOn = CUBIT_FALSE); 00086 ~KDDTree(); 00087 00088 //- Methods for finding the maximum height of the tree and the size 00089 //- of the tree 00090 int find_max_height (); 00091 00092 //- Sets/gets the tolerance used for the bounding box overlap test, 00093 //- which is used during the range search 00094 void set_tol (double tol) { myTolerance = tol; } 00095 double get_tol () { return myTolerance; } 00096 00097 //- Add a node with the data to the list 00098 CubitStatus add (Z data); 00099 00100 //- Remove the data member's entry in the tree. Returns CUBIT_TRUE 00101 //- if item removed, CUBIT_FALSE if item not in tree 00102 CubitBoolean remove (Z data); 00103 00104 //- Balance the tree manually 00105 //- Note: this is also called by the find method when self-balancing is on 00106 CubitStatus balance (); 00107 00108 //- Find members intersecting this range box 00109 CubitStatus find (const CubitBox &range_box, DLIList <Z> &range_members); 00110 00111 //- Distance method used by k_nearest_neighbor 00112 typedef double (*DistSqFunc)(CubitVector &a, Z& b); 00113 00114 //- Find the k nearest neighbors 00115 CubitStatus k_nearest_neighbor (CubitVector &q, int k, double &closest_dist, 00116 DLIList<Z> &nearest_neighbors, 00117 DistSqFunc dist_sq_point_data 00118 ); 00119 00120 //- Function to use with the priority queue for sorting. 00121 static bool less_than_func (KDDTreeNode<Z> *&node_a, 00122 KDDTreeNode<Z> *&node_b); 00123 }; 00124 00125 #include "KDDTree.cpp" 00126 00127 #endif
