cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : MidPlaneTool.hpp 00003 // 00004 // Purpose : Create a mide surface between the two planar 00005 // surfaces passed in by the tool. 00006 // 00007 // Special Notes : 00008 // 00009 // Creator : David White 00010 // 00011 // Creation Date : 9/30/00 00012 //------------------------------------------------------------------------- 00013 00014 #include "MidPlaneTool.hpp" 00015 #include "CubitVector.hpp" 00016 #include "CubitPlane.hpp" 00017 #include "RefFace.hpp" 00018 #include "RefEdge.hpp" 00019 #include "Loop.hpp" 00020 #include "Body.hpp" 00021 #include "CubitMessage.hpp" 00022 #include "GeometryModifyTool.hpp" 00023 #include "GeometryQueryTool.hpp" 00024 #include "DLIList.hpp" 00025 00026 CubitStatus MidPlaneTool::sort_surfaces(RefFace* base_face, 00027 RefFace* predecessor, 00028 DLIList <RefFace*> &mid_surfaces) 00029 { 00030 DLIList <Loop*> loop_list; 00031 DLIList <RefEdge*> loop_edges; 00032 DLIList <RefFace*> edge_faces; 00033 RefFace *next_face; 00034 RefEdge *temp_edge; 00035 Loop* temp_loop; 00036 00037 base_face->ordered_loops( loop_list ); 00038 00039 if(loop_list.size() == 1) 00040 { 00041 if(surfIndex%2==1) 00042 { 00043 mid_surfaces.append(base_face); 00044 } 00045 if ( predecessor == NULL ) 00046 { 00047 PRINT_ERROR("Bad logic in mid-plane extraction of sorting surfaces.\n"); 00048 return CUBIT_SUCCESS; 00049 } 00050 //Now test to see if there are other surfaces attached to this 00051 //single loop (other than predecessor) 00052 DLIList <RefFace*> other_surfs; 00053 CubitStatus tmp_stat = get_other_surfs(base_face, predecessor, other_surfs); 00054 if ( tmp_stat != CUBIT_SUCCESS ) 00055 return CUBIT_FAILURE; 00056 int jj; 00057 for ( jj = other_surfs.size(); jj > 0; jj-- ) 00058 { 00059 next_face = other_surfs.get_and_step(); 00060 surfIndex++; 00061 sort_surfaces(next_face,base_face,mid_surfaces); 00062 surfIndex--; 00063 } 00064 00065 return CUBIT_SUCCESS; 00066 } 00067 00068 if(surfIndex%2==1) 00069 { 00070 mid_surfaces.append(base_face); 00071 } 00072 loop_list.reset(); 00073 loop_list.remove(); 00074 for ( int ii = loop_list.size(); ii > 0; ii-- ) 00075 { 00076 temp_loop = loop_list.get_and_step(); 00077 loop_edges.clean_out(); 00078 edge_faces.clean_out(); 00079 temp_loop->ref_edges( loop_edges ); 00080 temp_edge = loop_edges.get(); 00081 temp_edge->ref_faces( edge_faces ); 00082 if( edge_faces.size() > 2 ) 00083 { 00084 PRINT_ERROR("Bad Logic.\n"); 00085 return CUBIT_FAILURE; 00086 } 00087 00088 if(edge_faces.size() == 2) 00089 { 00090 if(edge_faces.get() == base_face) 00091 { 00092 next_face = edge_faces.next(); 00093 } else 00094 { 00095 next_face = edge_faces.get(); 00096 } 00097 00098 surfIndex++; 00099 00100 sort_surfaces(next_face,base_face,mid_surfaces); 00101 00102 surfIndex--; 00103 00104 } 00105 } 00106 return CUBIT_SUCCESS; 00107 } 00108 00109 CubitStatus MidPlaneTool::get_other_surfs(RefFace* base_face, 00110 RefFace* predecessor, 00111 DLIList <RefFace*> &other_surfs) 00112 { 00113 DLIList <Loop*> loop_list; 00114 DLIList <RefEdge*> loop_edges; 00115 DLIList <RefFace*> edge_faces; 00116 RefFace *temp_face; 00117 RefEdge *temp_edge; 00118 Loop* temp_loop; 00119 00120 base_face->loops( loop_list ); 00121 00122 for ( int ii = loop_list.size(); ii > 0; ii-- ) 00123 { 00124 temp_loop = loop_list.get_and_step(); 00125 loop_edges.clean_out(); 00126 temp_loop->ref_edges( loop_edges ); 00127 for ( int jj = loop_edges.size(); jj > 0; jj-- ) 00128 { 00129 temp_edge = loop_edges.get_and_step(); 00130 edge_faces.clean_out(); 00131 temp_edge->ref_faces( edge_faces ); 00132 for ( int kk = edge_faces.size(); kk > 0; kk-- ) 00133 { 00134 temp_face = edge_faces.get_and_step(); 00135 if ( ( temp_face != base_face ) && ( temp_face != predecessor ) ) 00136 { 00137 other_surfs.append_unique( temp_face ); 00138 } 00139 } 00140 } 00141 } 00142 return CUBIT_SUCCESS; 00143 } 00144
