cgma
00001 //------------------------------------------------------------------------- 00002 // Copyright Notice 00003 // 00004 // Copyright (c) 1996 00005 // by Malcolm J. Panthaki, DBA, and the University of New Mexico. 00006 //------------------------------------------------------------------------- 00007 00008 //------------------------------------------------------------------------- 00009 // Filename : ModelEntity.cc 00010 // 00011 // Purpose : 00012 // 00013 // Special Notes : 00014 // 00015 // Creator : Raikanta Sahu 00016 // 00017 // Creation Date : 10/15/96 00018 // 00019 // Owner : Malcolm J. Panthaki 00020 //------------------------------------------------------------------------- 00021 00022 // ********** BEGIN STANDARD INCLUDES ********** 00023 // ********** END STANDARD INCLUDES ********** 00024 00025 // ********** BEGIN MOTIF INCLUDES ********** 00026 // ********** END MOTIF INCLUDES ********** 00027 00028 // ********** BEGIN OPEN INVENTOR INCLUDES ********** 00029 // ********** END OPEN INVENTOR INCLUDES ********** 00030 00031 // ********** BEGIN CUBIT INCLUDES ********** 00032 00033 #include "ModelEntity.hpp" 00034 #include "ModelQueryEngine.hpp" 00035 #include "GeometryQueryTool.hpp" 00036 #include "CastTo.hpp" 00037 #include "CubitObservable.hpp" 00038 #include "CubitObserver.hpp" 00039 #include "DAG.hpp" 00040 #include "RefVolume.hpp" 00041 #include "Loop.hpp" 00042 #include "RefEdge.hpp" 00043 #include "AppUtil.hpp" 00044 00045 // ********** END CUBIT INCLUDES ********** 00046 00047 // ********** BEGIN EXTERN DECLARATIONS ********** 00048 // ********** END EXTERN DECLARATIONS ********** 00049 00050 // ********** BEGIN STATIC DECLARATIONS ********** 00051 // ********** END STATIC DECLARATIONS ********** 00052 00053 // ********** BEGIN PUBLIC FUNCTIONS ********** 00054 00055 //------------------------------------------------------------------------- 00056 // Purpose : The default constructor 00057 // 00058 // Special Notes : 00059 // 00060 // Creator : Raikanta Sahu 00061 // 00062 // Creation Date : 10/15/96 00063 //------------------------------------------------------------------------- 00064 00065 ModelEntity::ModelEntity() : 00066 deactivatedStatus_(CUBIT_FALSE), 00067 encountered_(CUBIT_FALSE) 00068 { 00069 } 00070 00071 //------------------------------------------------------------------------- 00072 // Purpose : The destructor 00073 // 00074 // Special Notes : 00075 // 00076 // Creator : Raikanta Sahu 00077 // 00078 // Creation Date : 10/15/96 00079 //------------------------------------------------------------------------- 00080 00081 ModelEntity::~ModelEntity() 00082 { 00083 // Make sure that the ModelEntity class does not have a pointer to this 00084 // ModelEntity in its list. If it does, then remove the instances 00085 // of the pointer 00086 DAG::instance()->remove(this); 00087 00088 } 00089 00090 00091 //------------------------------------------------------------------------- 00092 // Purpose : Determine whether this object can be deleted from 00093 // memory or not. 00094 // 00095 // Special Notes : This function will recursively remove all the 00096 // removable child entities from the DAG and call their 00097 // destructors. Destructors of other objects, like 00098 // GeometryEntity, need to be called from the destructors 00099 // of different ModEnts. Virtual destructors put to use :) :) 00100 // 00101 // Creator : Raikanta Sahu 00102 // 00103 // Creation Date : 11/05/96 00104 //------------------------------------------------------------------------- 00105 00106 CubitStatus ModelEntity::remove_from_DAG(CubitBoolean recurse_flag) 00107 { 00108 // This counter will be used in the recursion to test whether 00109 // the call is from outside or from the function itself. When 00110 // the call comes from outside, the counter should always be 00111 // zero. 00112 00113 CubitBoolean this_recurse = recurse_flag; 00114 if (recurse_flag == CUBIT_FALSE) recurse_flag = CUBIT_TRUE; 00115 00116 DLIList<ModelEntity*> childModEntList; 00117 00118 // Check to see if there are no parents of this object. 00119 if ( get_parents() == 0 ) 00120 { 00121 if (this_recurse == CUBIT_FALSE) 00122 { 00123 // Since we are not recursing, this is a top-level entity. 00124 // Notify the static observers that a top-level entity is being 00125 // destructed. This must be done before children are disconnected. 00126 CubitObservable *top_level = CAST_TO(this, CubitObservable); 00127 AppUtil::instance()->send_event(top_level, TOP_LEVEL_ENTITY_DESTRUCTED); 00128 } 00129 00130 // Go through all the children and remove their link to 00131 // the current object. 00132 00133 ModelEntity* tempModEntPtr = NULL ; 00134 ModelEntity* childModEntPtr = NULL ; 00135 00136 childModEntList.clean_out(); 00137 disconnect_all_children(&childModEntList); 00138 00139 // The following while conditional may not work...it depends on 00140 // what is_at_end does when you step over the end...CHECK THIS 00141 int i; 00142 for( i = 0 ; i < childModEntList.size() ; i++ ) 00143 { 00144 // Get the next ModelEnti in the child list and make sure its 00145 // pointer to its parent is removed. 00146 tempModEntPtr = childModEntList.get_and_step(); 00147 00148 // Try remove() on the child ModEnt. If it comes back with 00149 // a success, then delete it. 00150 childModEntPtr = tempModEntPtr; 00151 00152 if ( childModEntPtr->remove_from_DAG(recurse_flag) == CUBIT_SUCCESS ) 00153 { 00154 // Now deactivate the child ModEnt 00155 childModEntPtr->deactivated(CUBIT_TRUE) ; 00156 00157 // remove it from observables, just before we go to delete it 00158 CubitObservable *observable = CAST_TO(childModEntPtr, CubitObservable); 00159 if (observable) 00160 { 00161 AppUtil::instance()->send_event(observable, MODEL_ENTITY_DESTRUCTED ); 00162 } 00163 } 00164 } 00165 00166 00167 // If this is the top of the recursion, then clean out all the deactivated 00168 // entities. 00169 if (this_recurse == CUBIT_FALSE) 00170 { 00171 this->deactivated(CUBIT_TRUE) ; 00172 00173 // remove it from observables, just before we go to delete it 00174 CubitObservable *observable = CAST_TO(childModEntPtr, CubitObservable); 00175 if (observable) 00176 { 00177 AppUtil::instance()->send_event(observable, MODEL_ENTITY_DESTRUCTED ); 00178 } 00179 GeometryQueryTool::instance()->cleanout_deactivated_geometry() ; 00180 } 00181 00182 return CUBIT_SUCCESS ; 00183 } 00184 else 00185 { 00186 return CUBIT_FAILURE ; 00187 } 00188 } 00189 00190 void ModelEntity::disconnect_from_DAG() 00191 { 00192 // disconnects this entity from any others 00193 // to which it is connected in the DAG; does not delete the DAGNode 00194 00195 disconnect_all_children(); 00196 disconnect_all_parents(); 00197 } 00198 00199 //------------------------------------------------------------------------- 00200 // Purpose : Get and set functions for the deactivated flag. 00201 // 00202 // Special Notes : 00203 // 00204 // Creator : Raikanta Sahu 00205 // 00206 // Creation Date : 12/02/96 00207 //------------------------------------------------------------------------- 00208 00209 void ModelEntity::deactivated(CubitBoolean flag) 00210 { 00211 if (deactivatedStatus_ != flag) 00212 { 00213 deactivatedStatus_ = flag ; 00214 if (flag == CUBIT_TRUE) 00215 { 00216 DAG::instance()->add_deactivated_DAG_node(this) ; 00217 } 00218 else 00219 { 00220 DAG::instance()->remove_deactivated_DAG_node(this) ; 00221 } 00222 } 00223 } 00224 00225 CubitBoolean ModelEntity::deactivated() const 00226 { 00227 return (CubitBoolean)deactivatedStatus_ ; 00228 } 00229 00230 00231 00232 00233 // ********** END PUBLIC FUNCTIONS ********** 00234 // ********** BEGIN PROTECTED FUNCTIONS ********** 00235 // ********** END PROTECTED FUNCTIONS ********** 00236 // ********** BEGIN PRIVATE FUNCTIONS ********** 00237 00238 00239 00240 00241 00242 00243 00244 00245 00246 00247 00248 00249 00250 00251 00252 00253 // ********** END PRIVATE FUNCTIONS ********** 00254 00255 // ********** BEGIN HELPER CLASSES ********** 00256 // ********** END HELPER CLASSES ********** 00257 00258 // ********** BEGIN EXTERN FUNCTIONS ********** 00259 // ********** END EXTERN FUNCTIONS ********** 00260 00261 // ********** BEGIN STATIC FUNCTIONS ********** 00262 // ********** END STATIC FUNCTIONS ********** 00263
