cgma
00001 00002 // Class Name: RStarTreeNode 00003 // Description: Node of R*Tree. 00004 // The algorithm was taken from the following paper: 00005 // Norbert Beckmann, H. Kriegel, R. Schnieder, and B. Seegar, 00006 // "The R*-tree: An Efficient and Robust Access Method 00007 // for Points and Rectangles", Proceedings of ACM SIGMOD 00008 // Int'l. Conf. on Management of Data, pp. 322-331, 1990. 00009 // Creation Date: 7/21/02 00010 // Owner: David R. White 00012 #ifndef RSTARTREENODE_HPP 00013 #define RSTARTREENODE_HPP 00014 00015 #include "CubitDefines.h" 00016 #include "GeometryDefines.h" 00017 #include "CubitBox.hpp" 00018 00019 template <class X> class DLIList; 00020 const int UNSET_RSTARNODE = -1; 00021 const int DATA_RSTARNODE = 0; 00022 const int LEAF_RSTARNODE = 1; 00023 00024 template <class Y> class RStarTreeNode 00025 { 00026 private: 00027 //Data. 00028 IttyBit markedFlag : 1; 00032 IttyBit distIsBox : 1; 00033 int myId; 00034 00040 RStarTreeNode<Y>** myChildrenNodes; 00041 int nextChildIndex; 00042 CubitBox *myBoundingBox; 00043 Y myData; 00044 int maxChildren, minChildren; //max/min number of children. 00045 RStarTreeNode<Y> *myParent; 00046 int myLevel; 00053 double myDist; 00057 00058 00059 00060 //Functions. 00061 RStarTreeNode<Y>* choose_sub_tree( RStarTreeNode<Y> *n, RStarTreeNode<Y> *e ); 00067 00068 CubitStatus overflow_treatment( RStarTreeNode<Y>* l, 00069 RStarTreeNode<Y>* e, 00070 RStarTreeNode<Y> *&ll, 00071 RStarTreeNode<Y> *root, 00072 RStarTreeNode<Y> *&new_root, 00073 int *overflow_flags, int levels); 00082 00083 CubitStatus reinsert(RStarTreeNode<Y>* l, 00084 RStarTreeNode<Y>* e, 00085 RStarTreeNode<Y> *root, 00086 RStarTreeNode<Y> *&new_root, 00087 int *overflow_flags, int levels); 00092 00093 00094 CubitStatus adjust_tree(RStarTreeNode<Y> *l, RStarTreeNode<Y> *ll, 00095 RStarTreeNode<Y> *root_node, 00096 RStarTreeNode<Y> *&new_root, 00097 int *overflow_flags, 00098 int levels); 00103 00104 CubitStatus split_node( RStarTreeNode<Y> *l, 00105 RStarTreeNode<Y> *e, 00106 RStarTreeNode<Y> *&ll ); 00114 double calc_overlap( RStarTreeNode<Y> *current, 00115 RStarTreeNode<Y> *add_to); 00121 00122 double calc_enlargement( RStarTreeNode<Y> *current, RStarTreeNode<Y> *add_to ); 00123 double calc_enlargement( CubitBox ¤t, 00124 CubitBox &add_to ); 00130 00131 CubitStatus find_leaf( Y e, 00132 CubitBox &e_box, 00133 RStarTreeNode<Y> *t, 00134 RStarTreeNode<Y> *&l ); 00140 00141 CubitStatus condense_tree(RStarTreeNode<Y> *l, 00142 RStarTreeNode<Y> *root, 00143 RStarTreeNode<Y> *&new_root ); 00150 00151 00152 double volume(CubitBox &box); 00156 double volume(RStarTreeNode<Y>* curr); 00160 00161 static int sort_high_x(RStarTreeNode<Y> *&n_1, 00162 RStarTreeNode<Y> *&n_2 ); 00163 static int sort_high_y(RStarTreeNode<Y> *&n_1, 00164 RStarTreeNode<Y> *&n_2 ); 00165 static int sort_high_z(RStarTreeNode<Y> *&n_1, 00166 RStarTreeNode<Y> *&n_2 ); 00167 static int sort_low_x(RStarTreeNode<Y> *&n_1, 00168 RStarTreeNode<Y> *&n_2); 00169 static int sort_low_y(RStarTreeNode<Y> *&n_1, 00170 RStarTreeNode<Y> *&n_2); 00171 static int sort_low_z(RStarTreeNode<Y> *&n_1, 00172 RStarTreeNode<Y> *&n_2); 00178 00179 static int sort_center_distance( RStarTreeNode<Y> *&n_1, 00180 RStarTreeNode<Y> *&n_2 ); 00186 00187 00188 00189 double margin(CubitBox &bounding_box); 00194 00195 CubitBox super_box(DLIList<RStarTreeNode<Y>*> &node_list); 00199 00200 public: 00201 RStarTreeNode(Y data, double tol, int max_children, int min_children ); 00205 RStarTreeNode(CubitBox &bounding_box, int max_children, int min_children); 00209 00210 ~RStarTreeNode(); 00212 00213 void validate_tree(int print); 00215 00216 CubitStatus insert(RStarTreeNode<Y> *e, RStarTreeNode<Y> *&new_root, 00217 int *overflow_flags, int levels); 00228 00229 void set_leaf_level(int r_type) 00230 {myLevel = r_type;} 00234 int get_leaf_level() 00235 {return myLevel;} 00239 00240 CubitBoolean is_leaf() 00241 {return (myLevel == LEAF_RSTARNODE)? CUBIT_TRUE : CUBIT_FALSE;} 00245 00246 CubitBoolean is_data() 00247 {return (myLevel == DATA_RSTARNODE)? CUBIT_TRUE : CUBIT_FALSE;} 00251 00252 Y get_data() 00253 {return myData;} 00257 00258 void add_child(RStarTreeNode<Y>* child_node, CubitBoolean recalc_b_box); 00264 00265 CubitBoolean can_add(); 00269 00270 int space_left(); 00274 00275 int num_children() 00276 {return nextChildIndex;} 00280 00281 RStarTreeNode<Y>* get_child(int i) 00282 {return ((i < nextChildIndex) ? myChildrenNodes[i] : (RStarTreeNode<Y>*)NULL) ;} 00283 00284 00285 void flush(CubitBox &new_box); 00290 00291 void recalc_b_box(); 00296 00297 RStarTreeNode<Y> *get_parent() 00298 {return myParent;} 00299 void set_parent(RStarTreeNode<Y> *parent) 00300 {myParent = parent;} 00301 00302 CubitBoolean remove_child(RStarTreeNode<Y> *child); 00308 00309 CubitBoolean remove(Y e, RStarTreeNode<Y> *&new_root, CubitBoolean &delete_root); 00315 00316 CubitBox& bounding_box() 00317 {return *myBoundingBox;} 00321 00322 double get_dist(); 00323 void set_dist(double dis); 00330 00331 int dist_is_box(); 00332 void set_dist_is_box(int val); 00338 00339 00340 }; 00341 template <class Y> inline int RStarTreeNode<Y>::dist_is_box() 00342 { 00343 return distIsBox; 00344 } 00345 template <class Y> inline void RStarTreeNode<Y>::set_dist_is_box(int val) 00346 { 00347 if ( val ) 00348 distIsBox = 1; 00349 else 00350 distIsBox = 0; 00351 } 00352 00353 template <class Y> inline double RStarTreeNode<Y>::get_dist() 00354 { 00355 return myDist; 00356 } 00357 template <class Y> inline void RStarTreeNode<Y>::set_dist(double dist) 00358 { 00359 myDist = dist; 00360 } 00361 00362 //Calculate the volume of the box. 00363 template <class Y> inline double RStarTreeNode<Y>::volume(CubitBox &box) 00364 { 00365 return box.x_range()*box.y_range()*box.z_range(); 00366 } 00367 //Calculate the volume of the RStarTreeNode. 00368 template <class Y> inline double RStarTreeNode<Y>::volume(RStarTreeNode<Y>* curr) 00369 { 00370 CubitBox box = curr->bounding_box(); 00371 return box.x_range()*box.y_range()*box.z_range(); 00372 } 00373 00374 #include "RStarTreeNode.cpp" 00375 00376 #endif 00377
