cgma
00001 //--------------------------------------------------------------------------- 00002 // Class Name: RStarTree 00003 // Description: Rectangle tree. A tree for multidimensional access methods. 00004 // The algorithm was taken from the following paper: 00005 // Norbert Beckmann, H. Kriegel, R. Schnieder, and B. Seegar, 00006 // "The R*-tree: An Efficient and Robust Access Method 00007 // for Points and Rectangles", Proceedings of ACM SIGMOD 00008 // Int'l. Conf. on Management of Data, pp. 322-331, 1990. 00009 // Creation Date: 7/20/02 00010 // Owner: David R. White 00011 //--------------------------------------------------------------------------- 00012 #ifndef RSTARTREE_HPP 00013 #define RSTARTREE_HPP 00014 00015 #include "CubitDefines.h" 00016 #include "GeometryDefines.h" 00017 00018 class CubitBox; 00019 class CubitVector; 00020 00021 template <class X> class DLIList; 00022 template <class Y> class RStarTreeNode; 00023 00024 template <class Z> class RStarTree 00025 { 00026 private: 00027 double myTolerance; 00028 int maxChildren; 00029 int minChildren; 00030 RStarTreeNode<Z> *myRoot; 00031 CubitStatus recursive_find(RStarTreeNode<Z> *rect_tree, 00032 const CubitBox &range_box, 00033 DLIList <Z> &range_members); 00034 //- recurses down the rtree to find all all the data members 00035 //- that fall in the range of the range_box. 00036 00037 void to_list(DLIList <RStarTreeNode<Z>*> &member_list, 00038 RStarTreeNode<Z> *top); 00039 //- converts the tree under top to a list. Note, top is NOT in the list 00040 //- at the end. 00041 double min_dist_sq(CubitVector &q, 00042 CubitBox &b_box); 00043 //- Calculates the distance between a point and a box, this is 00044 //- for the nearest neighbor point search. 00045 00046 00047 class LessThan 00048 { 00049 public: 00050 bool operator()(const Z& x, const Z& y) const 00051 { 00052 return x->get_dist() < y->get_dist(); 00053 } 00054 00055 }; 00056 00057 00058 00059 public: 00060 00061 RStarTree(double tol = GEOMETRY_RESABS); 00062 RStarTree(double tol, int max_c, int min_c); 00063 ~RStarTree(); 00064 //- Constructor/Destructor 00065 00066 typedef double (*DistSqFunc)(CubitVector &a, Z& b); 00067 00068 void set_tol(double tol) 00069 {myTolerance = tol;} 00070 double get_tol() 00071 {return myTolerance;} 00072 //- Sets/Gets the tolerance used for the bounding box overlap test, 00073 //- which is used during the range search. 00074 00075 }; 00076 00077 #include "RStarTree.cpp" 00078 00079 #endif 00080 00081
