cgma
00001 #include "TDCAGE.hpp" 00002 #include "RefGroup.hpp" 00003 #include "RefEntity.hpp" 00004 #include "DLIList.hpp" 00005 #include "CastTo.hpp" 00006 00007 int TDCAGE::is_cage(const ToolData* td) 00008 { 00009 return (CAST_TO(const_cast<ToolData*>(td), TDCAGE) != NULL); 00010 } 00011 00012 00013 int TDCAGE::td_sequence_number(const RefGroup *group) 00014 { 00015 // go through the group list and get the sequence number; 00016 // return -1 if the group isn't in the list 00017 00018 groupList.reset(); 00019 sequenceList.reset(); 00020 for (int i = groupList.size(); i > 0; i--) { 00021 if (group == groupList.get_and_step()) return sequenceList.get(); 00022 00023 else sequenceList.step(); 00024 } 00025 00026 return -1; 00027 } 00028 00029 void TDCAGE::insert_entity(RefEntity *entity, const int seq_num, 00030 RefGroup *into_group) 00031 { 00032 //- insert the entity into the group following the sequence number 00033 //- given 00034 TDCAGE *td_cage; 00035 CubitBoolean inserted = CUBIT_FALSE; 00036 DLIList<RefEntity*> copy_group_list; 00037 copy_group_list = into_group->entityList; 00038 00039 into_group->entityList.last(); 00040 for (int i = into_group->entityList.size(); i > 0; i--) { 00041 RefEntity *into_entity = into_group->entityList.get(); 00042 td_cage = (TDCAGE *) into_entity->get_TD(&TDCAGE::is_cage); 00043 if (td_cage && td_cage->td_sequence_number(into_group) < seq_num) { 00044 if ( !copy_group_list.move_to(entity) ) 00045 into_group->entityList.insert(entity); 00046 inserted = CUBIT_TRUE; 00047 break; 00048 } 00049 else into_group->entityList.back(); 00050 } 00051 00052 // if we got here and didn't insert, either the list is empty 00053 // or it isn't and our seq_num is less than all items; either 00054 // way, we insert at beginning 00055 if (inserted == CUBIT_FALSE){ 00056 if ( !copy_group_list.move_to(entity) ) 00057 into_group->entityList.insert_first(entity); 00058 } 00059 00060 // now register the observable entity in the group 00061 into_group->register_observable(entity); 00062 00063 // now, make sure the inserted entity has a td_cage and this group 00064 // and seq number are registered 00065 td_cage = (TDCAGE *) entity->get_TD(&TDCAGE::is_cage); 00066 if (!td_cage) { 00067 td_cage = new TDCAGE(-1); 00068 entity->add_TD(td_cage); 00069 } 00070 00071 td_cage->insert_group(into_group, seq_num); 00072 } 00073 00074 int TDCAGE::group_sequence_number(RefGroup *group, const RefEntity *entity) 00075 { 00076 //- return the sequence number of the given entity in the given group 00077 00078 // built for speed; don't accumulate index, use loop counter for that 00079 group->entityList.reset(); 00080 for (int i = group->entityList.size(); i > 0; i--) { 00081 if (group->entityList.get_and_step() == entity) 00082 // index in reverse direction, so subtract to get real index 00083 return group->entityList.size() - i; 00084 } 00085 00086 return -1; 00087 } 00088 00089 void TDCAGE::initialize_group_sequence_list(RefEntity *entity) 00090 { 00091 //- get the groups owning entity and build the sequence lists 00092 DLIList<RefGroup*> ref_groups; 00093 RefGroup::get_groups_within(entity, ref_groups, CUBIT_FALSE); 00094 00095 groupList.clean_out(); 00096 sequenceList.clean_out(); 00097 00098 for (int i = ref_groups.size(); i > 0; i--) { 00099 RefGroup *ref_group = ref_groups.get_and_step(); 00100 groupList.append(ref_group); 00101 sequenceList.append(group_sequence_number(ref_group, entity)); 00102 } 00103 } 00104 00105 00106
