cgma
00001 //- Class: TDCAGE 00002 //- Descpription: Stores data used in the CAGenesisEntity attribute 00003 //- Owner: Tim Tautges 00004 //- Checked by: 00005 //- Version: 00006 00007 #ifndef TDCAGE_HPP 00008 #define TDCAGE_HPP 00009 00010 #include "ToolData.hpp" 00011 #include "MemoryManager.hpp" 00012 #include "DLIList.hpp" 00013 #include "CGMGeomConfigure.h" 00014 00015 class RefGroup; 00016 class RefEntity; 00017 00018 class CUBIT_GEOM_EXPORT TDCAGE : public ToolData 00019 { 00020 private: 00021 00022 static MemoryManager memoryManager; 00023 //- memory management object 00024 00025 int uniqueId; 00026 00027 DLIList<RefGroup *> groupList; 00028 //- keeps group pointers for group/sequence # pairs 00029 00030 DLIList<int> sequenceList; 00031 //- keeps sequence #'s for group/sequence # pairs 00032 00033 public: 00034 00035 TDCAGE(int unique_id); 00036 00037 ~TDCAGE(); 00038 00039 static int is_cage(const ToolData* td); 00040 00041 int unique_id() {return uniqueId;} 00042 void unique_id(int id) {uniqueId = id;} 00043 //- get/set unique id 00044 00045 SetDynamicMemoryAllocation(memoryManager) 00046 //- class specific new and delete operators 00047 00048 static void set_memory_allocation_increment( int increment = 0 ) 00049 {memoryManager.set_memory_allocation_increment(increment);} 00050 //- set block memory size increment 00051 00052 static void destroy_memory() 00053 {memoryManager.destroy_memory();} 00054 //- destroy all memory allocated to this object 00055 00056 static int group_sequence_number(RefGroup *group, const RefEntity *entity); 00057 //- return the sequence number of the given entity in the given group 00058 00059 int td_sequence_number(const RefGroup *group); 00060 //- given a group, return the sequence number paired with that group 00061 00062 void insert_group(RefGroup *group, const int seq_num); 00063 //- add the group/sequence number pair to the lists 00064 00065 static void insert_entity(RefEntity *entity, const int seq_num, 00066 RefGroup *into_group); 00067 //- insert the entity into the group following the sequence number 00068 //- given 00069 00070 void initialize_group_sequence_list(RefEntity *entity); 00071 //- get the groups owning entity and build the sequence lists 00072 }; 00073 00074 inline TDCAGE::TDCAGE(int unique_id) : ToolData() 00075 { 00076 uniqueId = unique_id; 00077 } 00078 00079 inline TDCAGE::~TDCAGE() 00080 { 00081 //- empty 00082 } 00083 00084 inline void TDCAGE::insert_group(RefGroup *group, const int seq_num) 00085 { 00086 groupList.append(group); 00087 sequenceList.append(seq_num); 00088 } 00089 00090 #endif // TD_CAGE_HPP 00091
