cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : VGLoopTool.hpp 00003 // 00004 // Purpose : Loop Modification Code 00005 // 00006 // Special Notes : Provides common functionality for composite and 00007 // partition geometry. 00008 // 00009 // Creator : Jason Kraftcheck 00010 // 00011 // Creation Date : 08/08/02 00012 //------------------------------------------------------------------------- 00013 00014 #ifndef VG_LOOP_TOOL 00015 #define VG_LOOP_TOOL 00016 00017 00018 #include "CubitDefines.h" 00019 #include "DLIList.hpp" 00020 #include <vector> 00021 00022 class CubitVector; 00023 00024 template <class SURFACE, class LOOP, class COEDGE,class CURVE, class POINT> 00025 class VGLoopTool 00026 { 00027 public: 00028 /* 00029 static CubitStatus remove_curve( COEDGE* coedge1, 00030 COEDGE* coedge2, 00031 DLIList<COEDGE*>& new_loop_coedges ); 00032 //- Remove a curve from loop topology 00033 //- coedge1/2: The two coedges of a curve 00034 //- If the passed coedges are in different loops, the loops 00035 //- will be combined into a single loop and new_loop_coedges will 00036 //- be empty. 00037 //- If the passed coedges are in the same loop, unless the coedges 00038 //- are adjacent in that loop, the loop will be split into two 00039 //- loops and the coedges for the new loop passed back in 00040 //- new_loop_coedges. 00041 00042 static CubitStatus insert_curve( COEDGE* new_coedge1, 00043 COEDGE* new_coedge2, 00044 SURFACE* surface, 00045 LOOP*& new_loop1, 00046 LOOP*& new_loop2 ); 00047 //- Insert a curve into the loop topology 00048 //- new_coedge1/2: The two new coedges of the curve to be inserted 00049 //- loop1/2_coedge: Any coedges of the existing loops in which the 00050 //- new coedges are to be inserted. (May be NULL). 00051 //- new_loop_coedges: The ordered list of coedges from which the 00052 //- caller should create a new loop. The loops 00053 //- are specified with a coedge to avoid the need 00054 //- for this class to also be a template of the 00055 //- loop type. 00056 //- Note: In the comments below, when it is stated that a new loop 00057 //- is created, this means that the coedges for the new loop 00058 //- are passed back in new_loop_coedges. This function does 00059 //- not do the actual loop creation. 00060 //- 00061 //- If both loop1_coedge and loop2_coedge are null, both coedges 00062 //- are passed back in new_loop_coedges without any topology 00063 //- modification. The caller should create either one or two 00064 //- new loops (a curve imprinted on the interior of the surface 00065 //- or a hole in the surface and a new surface in the hole) 00066 //- depending on the curve having the same start and end vertices. 00067 //- 00068 //- If one of loop1_coedge and loop2_coedge is NULL, or both 00069 //- are part of the same loop, both new coedges are inserted in 00070 //- the same loop. This will result in either a sipe or the 00071 //- loop being split into two loops. If the loop is split, the 00072 //- coedges for the new loop are passed back in new_loop_coedges. 00073 //- 00074 //- If both loop1_coedge and loop2_coedge are non-null and part 00075 //- of different loops, the loops are joined using the new 00076 //- coedges as a bridge. 00077 */ 00078 static double loop_angle_metric( COEDGE* first_coedge ); 00079 /* 00080 static bool is_position_within_loop( const CubitVector& position, 00081 COEDGE* first_coedge, 00082 CubitVector* closest_on_loop = 0, 00083 CubitVector* normal = 0 ); 00084 00085 static double loop_area( COEDGE* first_coedge ); 00086 00087 static CubitStatus closest_point_trimmed( 00088 DLIList<COEDGE*>& surface_coedges, 00089 const CubitVector& from_pt, 00090 CubitVector& result_pt, 00091 CubitPointContainment* cont = 0 ); 00092 */ 00093 static void get_loop_polyline( COEDGE* first_coedge, 00094 std::vector<CubitVector>& result_set ); 00095 00096 private: 00097 /* 00098 static CubitStatus previous_coedge( COEDGE* coedge, SURFACE* surface, 00099 COEDGE*& result ); 00100 //- Find the coedge in the passed surface after which the passed 00101 //- coedge will be inserted. The returned coedge will share its 00102 //- start point (end point of the curve if the coedge sense is 00103 //- reversed) with the end point (start point of the curve if the 00104 //- coedge sense is reversed) of the passed coedge. If the coedge 00105 //- has no points in common with any loops in the passed surface, 00106 //- the result is NULL and CUBIT_SUCCESS is returned. CUBIT_FAILURE 00107 //- is returned if something is wrong with the topology. 00108 00109 static COEDGE* closest_loop_coedge( const CubitVector& from_pt, 00110 COEDGE* first_coedge, 00111 COEDGE*& other_coedge, 00112 CubitVector* closest_pt = 0 ); 00113 00114 static CubitStatus closest_surface_coedge( SURFACE* surface, 00115 const CubitVector& from_pt, 00116 COEDGE*& coedge1, 00117 COEDGE*& coedge2, 00118 CubitVector* pt_on_curve = 0 ); 00119 00120 static bool inside_of_curve( const CubitVector& curve_tangent, 00121 const CubitVector& curve_position, 00122 const CubitVector& surface_position, 00123 const CubitVector& surface_normal ); 00124 00125 static bool odd_coedge_count( COEDGE* coedge ); 00126 */ 00127 static CubitStatus get_loop_polygon( COEDGE* first_coedge, 00128 DLIList<CubitVector*>& polygon_points ); 00129 00130 }; 00131 00132 #include "VGLoopTool.cpp" 00133 00134 #endif 00135
