, including all inherited members.
| add(CompositeLump *lump) | CompositeBody | |
| add(BodySM *body) | CompositeBody | |
| append_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeBody | [virtual] |
| bodysm() | TopologyBridge | |
| BodySM() | BodySM | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() | BodySM | |
| bridge_destroyed(TopologyBridge *bridge) | TBOwner | [inline, virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| combine(CompositeBody *other) | CompositeBody | |
| CompositeBody() | CompositeBody | |
| contains_bridge(TopologyBridge *bridge) const | CompositeBody | [virtual] |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| firstLump | CompositeBody | [private] |
| get_body(int index) const | CompositeBody | [inline] |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &children) | CompositeBody | [virtual] |
| get_geometry_query_engine() const | CompositeBody | [virtual] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &parents) | CompositeBody | [virtual] |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &attrib_list) | CompositeBody | [virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &attrib_list) | CompositeBody | [virtual] |
| get_transforms(CubitTransformMatrix &tfm) | CompositeBody | [virtual] |
| index_of(BodySM *body) const | CompositeBody | [inline] |
| layer() const | CompositeBody | [inline, virtual] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| mass_properties(CubitVector ¢roid, double &volume) | CompositeBody | [virtual] |
| MAX_TB_LAYER enum value | TopologyBridge | |
| next_lump(CompositeLump *after_this=0) const | CompositeBody | |
| notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_reversed(TopologyBridge *bridge) | CompositeBody | [virtual] |
| notify_split(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_topology_modified(TopologyBridge *) | TBOwner | [inline, virtual] |
| num_bodies() const | CompositeBody | [inline] |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| point_containment(const CubitVector &pos, double tolerance=-1.0) | CompositeBody | [virtual] |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| realBodies | CompositeBody | [private] |
| remove(CompositeLump *lump) | CompositeBody | |
| remove(BodySM *body) | CompositeBody | |
| remove_all_simple_attribute_virt() | CompositeBody | [virtual] |
| remove_body(int index) | CompositeBody | |
| remove_bridge(TopologyBridge *bridge) | CompositeBody | [virtual] |
| remove_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeBody | [virtual] |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| swap_bridge(TopologyBridge *old_tb, TopologyBridge *new_tb, bool reversed) | CompositeBody | [virtual] |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| ~BodySM() | BodySM | [virtual] |
| ~CompositeBody() | CompositeBody | |
| ~TBOwner() | TBOwner | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
