, including all inherited members.
| add(Lump *lump) | CompositeLump | |
| add(CompositeShell *shell) | CompositeLump | |
| append_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeLump | [virtual] |
| bodysm() | TopologyBridge | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() const | CompositeLump | [virtual] |
| bridge_destroyed(TopologyBridge *bridge) | TBOwner | [inline, virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| ChildType typedef | Lump | |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| combine(CompositeLump *dead_vol) | CompositeLump | |
| compGeom | CompositeLump | [private] |
| CompositeBody class | CompositeLump | [friend] |
| CompositeLump(Lump *real_lump) | CompositeLump | |
| CompositeLump(CompositeGeom *geom) | CompositeLump | |
| contains_bridge(TopologyBridge *bridge) const | CompositeLump | [virtual] |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| first_shell() const | CompositeLump | [inline] |
| firstShell | CompositeLump | [private] |
| geometry_type() | Lump | [inline, virtual] |
| GeometryEntity() | GeometryEntity | [inline] |
| get_body() const | CompositeLump | [inline] |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &children) | CompositeLump | [virtual] |
| get_geometry_query_engine() const | CompositeLump | [virtual] |
| get_hidden_surfaces(DLIList< Surface * > &surfaces) | CompositeLump | |
| get_lump(int index) const | CompositeLump | [inline] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &parents) | CompositeLump | [virtual] |
| get_saved_id() const | GeometryEntity | [inline] |
| get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &attrib_list) | CompositeLump | [virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &attrib_list) | CompositeLump | [virtual] |
| has_hidden_entities() const | CompositeLump | |
| hidden_entities() | CompositeLump | [inline] |
| hiddenSet | CompositeLump | [private] |
| index_of(Lump *) const | CompositeLump | [inline] |
| layer() const | CompositeLump | [inline, virtual] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| Lump() | Lump | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| mass_properties(CubitVector ¢roid, double &volume) | CompositeLump | [virtual] |
| Lump::mass_properties(CubitVector[3], CubitVector &, CubitVector &, double &) | Lump | [inline, virtual] |
| MAX_TB_LAYER enum value | TopologyBridge | |
| measure() | CompositeLump | [virtual] |
| myBody | CompositeLump | [private] |
| next_shell(CompositeShell *after_this) const | CompositeLump | [inline] |
| nextLump | CompositeLump | [private] |
| notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_reversed(TopologyBridge *bridge) | CompositeLump | [virtual] |
| notify_split(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_topology_modified(TopologyBridge *) | TBOwner | [inline, virtual] |
| num_lumps() const | CompositeLump | [inline] |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| print_debug_info(const char *line_prefix=0, bool brief=false) | CompositeLump | |
| remove(Lump *lump) | CompositeLump | |
| remove(CompositeShell *shell) | CompositeLump | |
| remove_all_simple_attribute_virt() | CompositeLump | [virtual] |
| remove_bridge(TopologyBridge *bridge) | CompositeLump | [virtual] |
| remove_lump(int index) | CompositeLump | |
| remove_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeLump | [virtual] |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| set_saved_id(int value) | GeometryEntity | [inline] |
| set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| split(VGArray< int > &indices_to_move) | CompositeLump | |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| swap_bridge(TopologyBridge *old_tb, TopologyBridge *new_tb, bool) | CompositeLump | [virtual] |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| update() | CompositeLump | [inline] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| ~CompositeLump() | CompositeLump | [virtual] |
| ~GeometryEntity() | GeometryEntity | [virtual] |
| ~Lump() | Lump | [virtual] |
| ~TBOwner() | TBOwner | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
