, including all inherited members.
| actuate_cubit_attrib(int attrib_type) | CubitAttribUser | |
| actuate_cubit_attrib(DLIList< CubitAttrib * >) | CubitAttribUser | [private] |
| actuate_cubit_attrib(CubitAttrib *) | CubitAttribUser | [private] |
| actuate_cubit_attrib(DLIList< RefEntity * >, int) | CubitAttribUser | [static] |
| add_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
| append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE) | CubitAttribUser | |
| auto_create_for_merge(RefEntity *deletable_entity) | CubitAttribUser | [private] |
| auto_read_cubit_attrib() | CubitAttribUser | |
| auto_reset_cubit_attrib(DLIList< RefEntity * > ref_ents) | CubitAttribUser | [private, static] |
| auto_update_cubit_attrib() | CubitAttribUser | |
| auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE) | CubitAttribUser | [static] |
| clear_all_simple_attrib(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
| clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
| clear_simple_attribs() | CubitAttribUser | |
| clear_simple_attribs_set_to_actuate() | CubitAttribUser | |
| CubitAttribUser(const CubitAttribUser &) | CubitAttribUser | [private] |
| CubitAttribUser(CubitAttrib *=NULL) | CubitAttribUser | |
| find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const | CubitAttribUser | |
| get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE) | CubitAttribUser | |
| get_cubit_attrib_list(DLIList< CubitAttrib * > &) | CubitAttribUser | |
| headAttrib | CubitAttribUser | [protected] |
| merge_owner(RefEntity *deletable_entity) | CubitAttribUser | |
| num_cubit_attrib() | CubitAttribUser | |
| operator=(const CubitAttribUser &) | CubitAttribUser | [private] |
| put_simple_attrib(const CubitSimpleAttrib &cubit_simple_attrib_ptr, CubitBoolean append_it=CUBIT_TRUE) | CubitAttribUser | [private] |
| read_cubit_attrib(int attrib_type) | CubitAttribUser | |
| remove_all_simple_attribute(TopologyBridge *bridge) | CubitAttribUser | |
| remove_attrib_geometry_entity(CubitAttrib *) | CubitAttribUser | |
| remove_cubit_attrib(DLIList< CubitAttrib * >) | CubitAttribUser | [private] |
| remove_cubit_attrib(int attrib_type) | CubitAttribUser | |
| remove_cubit_attrib(CubitAttrib *) | CubitAttribUser | |
| remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| set_updated_flag(CubitBoolean flag) | CubitAttribUser | |
| set_written_flag(CubitBoolean flag) | CubitAttribUser | |
| split_owner(DLIList< CubitSimpleAttrib > &csa_list) | CubitAttribUser | |
| transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor) | CubitAttribUser | |
| update_cubit_attrib(int) | CubitAttribUser | |
| write_cubit_attrib_by_type(int attrib_type) | CubitAttribUser | |
| write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list) | CubitAttribUser | |
| write_cubit_attribs() | CubitAttribUser | |
| write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
| ~CubitAttribUser() | CubitAttribUser | [virtual] |
