, including all inherited members.
| add_facet(CubitFacet *facet_ptr) | CubitFacetEdgeData | [inline, virtual] |
| add_facets() | CubitFacetEdge | |
| add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
| adj_facet(int index) | CubitFacetEdgeData | [virtual] |
| adj_facet_on_surf(int tool_id) | CubitFacetEdge | |
| adjFacetList | CubitFacetEdgeData | [private] |
| angle_between_facets() | CubitFacetEdge | |
| bezier_order() | CubitFacetEdge | [inline, virtual] |
| bezierOrder | CubitFacetEdge | [protected] |
| boundary_edge_points(CubitPoint *&pt0, CubitPoint *&pt1, int tool_id=0) | CubitFacetEdge | |
| bounding_box() | CubitFacetEdge | |
| center() | CubitFacetEdge | [inline] |
| closest_point(const CubitVector &point, CubitVector &closest_point) | CubitFacetEdge | |
| contains(CubitPoint *point_ptr) | CubitFacetEdge | |
| control_points(CubitVector *ctrl_pts) | CubitFacetEdge | [virtual] |
| control_points() | CubitFacetEdge | [inline, virtual] |
| control_points(CubitVector *ctrl_pts, int order) | CubitFacetEdge | [inline, virtual] |
| control_points(CubitFacet *facet, CubitVector *ctrl_pts) | CubitFacetEdge | [virtual] |
| controlPoints | CubitFacetEdge | [protected] |
| CubitFacetEdge() | CubitFacetEdge | |
| CubitFacetEdgeData(CubitPoint *p1, CubitPoint *p2) | CubitFacetEdgeData | |
| CubitFacetEdgeData(CubitPoint *p1, CubitPoint *p2, CubitFacet *facet1, CubitFacet *facet2, int edge_index1, int edge_index2) | CubitFacetEdgeData | |
| debug_draw(int color=-1, int flush=1, int draw_uv=0) | CubitFacetEdge | [virtual] |
| delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| delete_TD(ToolData *td) | ToolDataUser | [virtual] |
| dist_to_edge(const CubitVector &this_point, CubitVector &close_point, CubitBoolean &outside_edge) | CubitFacetEdge | |
| edge_curvature(const CubitVector &point_on_edge, CubitVector &curvature, CubitFacetEdge *closest_edge) | CubitFacetEdge | |
| edge_tangent(const CubitVector &point_on_edge, CubitVector &tangent) | CubitFacetEdge | |
| edges(DLIList< CubitFacetEdge * > &edge_list) | CubitFacetEdgeData | [virtual] |
| end_node() | CubitFacetEdgeData | [inline, virtual] |
| entityId | CubitFacetEdgeData | [private] |
| evaluate(double &t, CubitVector *eval_point, CubitVector *eval_tangent) | CubitFacetEdge | |
| evaluate_2nd_derivative(double &t, CubitVector *outv) | CubitFacetEdge | |
| evaluate_position(const CubitVector &start_position, CubitVector *eval_point, CubitVector *eval_tangent) | CubitFacetEdge | |
| evaluate_single(double &t, CubitVector *outv) | CubitFacetEdge | |
| evaluate_single_tangent(double &t, CubitVector *outv) | CubitFacetEdge | |
| FacetEntity() | FacetEntity | |
| facets(DLIList< CubitFacet * > &facet_list) | CubitFacetEdgeData | [virtual] |
| find_start_point_for_edge_list(DLIList< CubitFacetEdge * > edge_list) | CubitFacetEdge | [static] |
| flip() | CubitFacetEdgeData | [virtual] |
| get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_control_points(CubitPoint *point_ptr, CubitVector ctrl_pts[3]) | CubitFacetEdge | [inline, virtual] |
| get_flag() | CubitFacetEdge | [inline, virtual] |
| get_parents(DLIList< FacetEntity * > &facet_list) | CubitFacetEdge | [virtual] |
| get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
| id() | CubitFacetEdgeData | [inline, virtual] |
| intersect(CubitVector &aa, CubitVector &bb, CubitVector &norm, CubitVector &qq, CubitBoolean &does_intersect) | CubitFacetEdge | |
| intersect_2D_segments(double P0[2], double P1[2], double P2[2], double P3[2], double qq[4]) | CubitFacetEdge | [static] |
| intersect_intervals(double u0, double u1, double v0, double v1, double w[2]) | CubitFacetEdge | [static] |
| is_feature() | CubitFacetEdge | [inline] |
| is_flipped() | CubitFacetEdge | [inline] |
| is_flipped(int flipped) | CubitFacetEdge | [inline] |
| isFeature | CubitFacetEdge | [protected] |
| isFlipped | CubitFacetEdge | [protected] |
| length() | CubitFacetEdge | |
| less_than(CubitFacetEdge *&e1, CubitFacetEdge *&e2) | CubitFacetEdge | [inline] |
| marked(int my_flag) | CubitFacetEdgeData | [inline, virtual] |
| marked() | CubitFacetEdgeData | [inline, virtual] |
| markedFlag | CubitFacetEdge | [protected] |
| merge_edges(CubitFacetEdgeData *other_edge) | CubitFacetEdgeData | |
| num_adj_facets() | CubitFacetEdgeData | [inline, virtual] |
| num_adj_facets_on_surf(int tool_id) | CubitFacetEdge | |
| number_faces() | CubitFacetEdge | [inline, virtual] |
| number_tris() | CubitFacetEdgeData | [inline, virtual] |
| order_edge_list(DLIList< CubitFacetEdge * > &edge_list, CubitPoint *start_point, CubitPoint *&end_point) | CubitFacetEdge | [static] |
| other_facet(CubitFacet *facet_ptr) | CubitFacetEdge | |
| other_facet_on_surf(CubitFacet *facet_ptr) | CubitFacetEdge | |
| other_point(CubitPoint *point_ptr) | CubitFacetEdge | |
| point(int index) | CubitFacetEdgeData | [inline, virtual] |
| pointArray | CubitFacetEdgeData | [private] |
| points(DLIList< CubitPoint * > &point_list) | CubitFacetEdgeData | [virtual] |
| position_from_fraction(double zero_to_one) | CubitFacetEdge | |
| proj_to_line(const CubitVector &this_point, CubitVector &proj_point) | CubitFacetEdge | |
| remove_facet(CubitFacet *facet_ptr) | CubitFacetEdgeData | [virtual] |
| remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| remove_TD(ToolData *td) | ToolDataUser | [virtual] |
| set_as_feature() | CubitFacetEdge | [inline] |
| set_control_points(CubitPoint *point_ptr, CubitVector ctrl_pts[3]) | CubitFacetEdge | [inline, virtual] |
| set_control_points(const double *ctrl_pt_array) | CubitFacetEdge | |
| set_flag(int my_flag) | CubitFacetEdge | [inline, virtual] |
| set_id(int ent_id) | CubitFacetEdgeData | [inline, virtual] |
| set_point(CubitPoint *pt, int index) | CubitFacetEdgeData | [inline] |
| shared_point(CubitFacetEdge *edge_ptr) | CubitFacetEdge | |
| start_node() | CubitFacetEdgeData | [inline, virtual] |
| toggle_is_flipped() | CubitFacetEdge | [inline] |
| ToolDataUser() | ToolDataUser | [inline] |
| tris(DLIList< CubitFacet * > &facet_list) | CubitFacetEdge | [inline] |
| tris(int *, DLIList< CubitFacet * > &facet_list) | CubitFacetEdge | [inline] |
| ~CubitFacetEdge() | CubitFacetEdge | [virtual] |
| ~CubitFacetEdgeData() | CubitFacetEdgeData | |
| ~FacetEntity() | FacetEntity | [virtual] |
| ~ToolDataUser() | ToolDataUser | [virtual] |
