, including all inherited members.
| add_facet(CubitFacet *facet) | CubitPointData | [virtual] |
| add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
| adjacent_points(CubitPoint **adj_points, int &num_adj_points) | CubitPoint | |
| adjacent_points(DLIList< CubitPoint * > &result_list) | CubitPoint | |
| attachedFacets | CubitPointData | [private] |
| bounding_box() | CubitPoint | |
| check_inverted_facets(const CubitVector &new_position) | CubitPoint | |
| coef_vector() | CubitPoint | [inline, virtual] |
| coef_vector(const CubitMatrix &coef) | CubitPoint | [inline, virtual] |
| coefVector | CubitPoint | [protected] |
| collapse_edge(CubitPointData *dead_point) | CubitPointData | |
| compute_avg_normal() | CubitPointData | |
| coordinates() const | CubitPointData | [inline, virtual] |
| coordinates(double point_array[3]) | CubitPointData | [virtual] |
| coords | CubitPointData | [private] |
| CubitPoint() | CubitPoint | |
| CubitPointData(double x_val, double y_val, double z_val) | CubitPointData | |
| CubitPointData(double x_val, double y_val, double z_val, int *) | CubitPointData | |
| CubitPointData(const CubitVector &new_point) | CubitPointData | |
| d_coef(const double d_coefficient) | CubitPoint | [inline, virtual] |
| d_coef() | CubitPoint | [inline, virtual] |
| dCoef | CubitPoint | [protected] |
| debug_draw(int color=-1, int flush=1, int draw_uv=0) | CubitPoint | [virtual] |
| define_tangent_vectors() | CubitPoint | |
| delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| delete_TD(ToolData *td) | ToolDataUser | [virtual] |
| du(CubitVector &duvec) | CubitPoint | [inline, virtual] |
| du() | CubitPoint | [inline, virtual] |
| dv(CubitVector &dvvec) | CubitPoint | [inline, virtual] |
| dv() | CubitPoint | [inline, virtual] |
| edges(DLIList< CubitFacetEdge * > &edge_list) | CubitPointData | [virtual] |
| entityId | CubitPointData | [private] |
| FacetEntity() | FacetEntity | |
| facets(DLIList< CubitFacet * > &facet_list) | CubitPointData | [inline, virtual] |
| facets_on_surf(int surf_id, DLIList< CubitFacet * > &facet_list, CubitBoolean &on_internal_boundary) | CubitPoint | |
| get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_edge(CubitPoint *other_point) | CubitPoint | |
| get_parents(DLIList< FacetEntity * > &facet_list) | CubitPoint | [virtual] |
| get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
| get_uv(CubitFacet *facet, double &u, double &v) | CubitPoint | [virtual] |
| get_uvs(CubitFacet *facet, double &u, double &v, double &s) | CubitPoint | [virtual] |
| id()=0 | CubitPoint | [pure virtual] |
| is_feature() | CubitPoint | [inline] |
| isFeature | CubitPoint | [protected] |
| marked(int marked) | CubitPointData | [inline, virtual] |
| marked() | CubitPointData | [inline, virtual] |
| markedFlag | CubitPoint | [protected] |
| memoryManager | CubitPointData | [private, static] |
| merge_points(CubitPoint *dead_point, CubitBoolean keep_point=CUBIT_FALSE) | CubitPointData | [virtual] |
| next_feature_edges(CubitFacetEdge *this_edge_ptr, DLIList< CubitFacetEdge * > feature_edge_list) | CubitPoint | |
| normal(CubitVector &surf_norm) | CubitPoint | [inline, virtual] |
| normal() | CubitPoint | [inline, virtual] |
| normal(CubitFacet *facet_ptr) | CubitPoint | |
| normal(CubitQuadFacet *qfacet_ptr) | CubitPoint | |
| normal(CubitFacetEdge *edge_ptr) | CubitPoint | |
| normal_ptr() | CubitPoint | [inline, virtual] |
| num_adj_facets() | CubitPointData | [virtual] |
| points(DLIList< CubitPoint * > &point_list) | CubitPointData | [inline, virtual] |
| project_to_tangent_plane(CubitVector &pt) | CubitPoint | |
| remove_facet(CubitFacet *facet) | CubitPointData | [virtual] |
| remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| remove_TD(ToolData *td) | ToolDataUser | [virtual] |
| reset_normal() | CubitPoint | [inline, virtual] |
| rotate_normal(CubitTransformMatrix &rotmat) | CubitPoint | |
| set(const CubitVector &pos) | CubitPointData | [inline, virtual] |
| set_as_feature() | CubitPoint | [inline] |
| set_box_tol(double tol) | CubitPoint | [inline, static] |
| set_id(int new_id) | CubitPointData | [inline, virtual] |
| set_normal(CubitVector &surf_norm) | CubitPoint | [inline, virtual] |
| set_uv(double u, double v) | CubitPoint | [inline, virtual] |
| set_uvs(double u, double v, double s) | CubitPoint | [inline, virtual] |
| SetDynamicMemoryAllocation(memoryManager) int id() | CubitPointData | [inline] |
| shared_edge(CubitPoint *other_point) | CubitPoint | |
| shared_facets(CubitPoint *other_point, CubitFacet *&facet1, CubitFacet *&facet2) | CubitPoint | |
| shared_facets(CubitPoint *other_point, DLIList< CubitFacet * > &result_list) | CubitPoint | |
| size() | CubitPoint | [inline, virtual] |
| sizeVal | CubitPoint | [protected] |
| surfNormal | CubitPoint | [protected] |
| surfU | CubitPoint | [protected] |
| surfV | CubitPoint | [protected] |
| tangent(CubitFacetEdge *edge_ptr, double mindot) | CubitPoint | |
| ToolDataUser() | ToolDataUser | [inline] |
| transform(CubitTransformMatrix &tfmat) | CubitPoint | |
| transform_to_global(CubitVector &loc_vec, CubitVector &glob_vec) | CubitPoint | |
| transform_to_local(CubitVector &glob_vec, CubitVector &loc_vec) | CubitPoint | |
| tris(DLIList< CubitFacet * > &facet_list) | CubitPointData | [inline, virtual] |
| uVal | CubitPoint | [protected] |
| vVal | CubitPoint | [protected] |
| x() | CubitPointData | [inline, virtual] |
| y() | CubitPointData | [inline, virtual] |
| z() | CubitPointData | [inline, virtual] |
| ~CubitPoint() | CubitPoint | [virtual] |
| ~CubitPointData() | CubitPointData | |
| ~FacetEntity() | FacetEntity | [virtual] |
| ~ToolDataUser() | ToolDataUser | [virtual] |
