cgma
| add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
| CubitQuadFacet() | CubitQuadFacet | |
| debug_draw(int color=-1, int flush_it=1, int draw_uv=0) | CubitQuadFacet | [virtual] |
| delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| delete_TD(ToolData *td) | ToolDataUser | [virtual] |
| edge(int index)=0 | CubitQuadFacet | [pure virtual] |
| edges(DLIList< CubitFacetEdge * > &edge_list) | CubitQuadFacet | [virtual] |
| eval_derivatives(double u, double v, CubitVector &point, CubitVector &du, CubitVector &dv) | CubitQuadFacet | [private] |
| evaluate(double u, double v, CubitVector *eval_point, CubitVector *eval_normal=NULL, CubitVector *eval_du=NULL, CubitVector *eval_dv=NULL) | CubitQuadFacet | |
| FacetEntity() | FacetEntity | |
| facets(DLIList< CubitFacet * > &facet_list) | CubitQuadFacet | [virtual] |
| get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_control_points(double *ctrl_pts) | CubitQuadFacet | |
| get_parents(DLIList< FacetEntity * > &) | CubitQuadFacet | [inline, virtual] |
| get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
| get_tri_facet(int index)=0 | CubitQuadFacet | [pure virtual] |
| get_tri_facet_at_point(CubitPoint *point_ptr)=0 | CubitQuadFacet | [pure virtual] |
| init_patch() | CubitQuadFacet | |
| map_to_tri_system(double u, double v, int &tri_index, double &A, double &B, double &C) | CubitQuadFacet | [private] |
| point(int index)=0 | CubitQuadFacet | [pure virtual] |
| points(CubitPoint *points[4])=0 | CubitQuadFacet | [pure virtual] |
| points(DLIList< CubitPoint * > &point_list) | CubitQuadFacet | [virtual] |
| remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| remove_TD(ToolData *td) | ToolDataUser | [virtual] |
| remove_tri_facets()=0 | CubitQuadFacet | [pure virtual] |
| set_control_points(double *ctrl_pts) | CubitQuadFacet | |
| ToolDataUser() | ToolDataUser | [inline] |
| tri_to_quad_index(int tri_index, int pt_index)=0 | CubitQuadFacet | [pure virtual] |
| ~CubitQuadFacet() | CubitQuadFacet | [virtual] |
| ~FacetEntity() | FacetEntity | [virtual] |
| ~ToolDataUser() | ToolDataUser | [virtual] |
