, including all inherited members.
| append_simple_attribute_virt(const CubitSimpleAttrib &)=0 | TopologyBridge | [pure virtual] |
| bodysm() | TopologyBridge | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() const =0 | GeometryEntity | [pure virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| center_point() | Curve | [inline, virtual] |
| ChildType typedef | Curve | |
| closest_point(CubitVector const &location, CubitVector &closest_location, CubitVector *tangent_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL)=0 | Curve | [pure virtual] |
| closest_point_trimmed(CubitVector const &from_pt, CubitVector &result_pt) | Curve | [virtual] |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| Curve() | Curve | |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| end_param()=0 | Curve | [pure virtual] |
| G1_discontinuous(double u, CubitVector *minus_tangent=NULL, CubitVector *plus_tangent=NULL) | Curve | [virtual] |
| geometry_type() | Curve | [inline, virtual] |
| GeometryEntity() | GeometryEntity | [inline] |
| get_arc_length() | Curve | [inline, virtual] |
| get_arc_length(const CubitVector &point1, const CubitVector &point2) | Curve | [inline, virtual] |
| get_arc_length(const CubitVector &point1, const int which_end) | Curve | [inline, virtual] |
| get_center_radius(CubitVector ¢er, double &radius)=0 | Curve | [pure virtual] |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &children)=0 | TopologyBridge | [pure virtual] |
| get_ellipse_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio) const =0 | Curve | [pure virtual] |
| get_geometry_query_engine() const =0 | TopologyBridge | [pure virtual] |
| get_interior_extrema(DLIList< CubitVector * > &interior_points, CubitSense &return_sense)=0 | Curve | [pure virtual] |
| get_param_range(double &lower_bound, double &upper_bound)=0 | Curve | [pure virtual] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &parents)=0 | TopologyBridge | [pure virtual] |
| get_point_direction(CubitVector &origin, CubitVector &direction) | Curve | [virtual] |
| get_saved_id() const | GeometryEntity | [inline] |
| get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &)=0 | TopologyBridge | [pure virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)=0 | TopologyBridge | [pure virtual] |
| get_spline_params(bool &rational, int °ree, DLIList< CubitVector > &cntrl_pts, DLIList< double > &cntrl_pt_weights, DLIList< double > &knots, bool &spline_is_reversed) const =0 | Curve | [pure virtual] |
| is_periodic(double &period)=0 | Curve | [pure virtual] |
| is_position_on(const CubitVector &test_position)=0 | Curve | [pure virtual] |
| is_tolerant() | Curve | [inline, virtual] |
| layer() const | TopologyBridge | [inline, virtual] |
| length_from_u(double parameter1, double parameter2)=0 | Curve | [pure virtual] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| MAX_TB_LAYER enum value | TopologyBridge | |
| measure()=0 | GeometryEntity | [pure virtual] |
| mid_point(const CubitVector &point1, const CubitVector &point2, CubitVector &mid_point) | Curve | [inline, virtual] |
| mid_point(CubitVector &mid_point) | Curve | [inline, virtual] |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| point_containment(const CubitVector &point)=0 | Curve | [pure virtual] |
| point_from_arc_length(double root_param, const double arc_length, CubitVector &new_point) | Curve | [virtual] |
| point_from_arc_length(const CubitVector &root_point, double const arc_length, CubitVector &new_point) | Curve | [virtual] |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| position_from_fraction(const double fraction_along_curve, CubitVector &output_position) | Curve | [inline, virtual] |
| position_from_u(double u_value, CubitVector &output_position)=0 | Curve | [pure virtual] |
| relative_sense(Curve *other_curve) | Curve | [virtual] |
| remove_all_simple_attribute_virt()=0 | TopologyBridge | [pure virtual] |
| remove_simple_attribute_virt(const CubitSimpleAttrib &)=0 | TopologyBridge | [pure virtual] |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| set_saved_id(int value) | GeometryEntity | [inline] |
| set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| start_param()=0 | Curve | [pure virtual] |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| u_from_arc_length(double root_param, double arc_length)=0 | Curve | [pure virtual] |
| u_from_position(const CubitVector &input_position)=0 | Curve | [pure virtual] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| ~Curve() | Curve | [virtual] |
| ~GeometryEntity() | GeometryEntity | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
