, including all inherited members.
| are_nodes_colinear(TRI *tri_ptr) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| bowyer_watson_insert(NODE *point_ptr, DLIList< TRI * > &tri_list, DLIList< TRI * > &facet_list, int &curr_visit_flag, SURF *surf_ptr, TRI *&last_tri) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| circumcenter(TRI *tri_ptr) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| classify_tri_by_angle(TRI *tri_ptr, DLIList< TRI * > *sorted_lists, const int num_lists, const double interval, const double quality_angle) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [static] |
| exhaustive_locate_point(CubitVector &the_point, DLIList< TRI * > &facet_list, TRI *&tri_ptr) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| FacetorUtil() | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [inline] |
| get_size(CubitVector &cc, TRI *tri_ptr) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| insert_at_circumcenter(TRI *tri_ptr, DLIList< TRI * > &facet_list, TRI *&start_tri, int &curr_visit_flag, SURF *surface_ptr, DLIList< TRI * > *sorted_lists, const int num_lists, const double interval, const double quality_angle, SIZEFUNC *sizing_function, ParamTool *p_tool) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [static] |
| insert_node(NODE *node_ptr, DLIList< TRI * > &facet_list, SURF *surface_ptr, int &curr_visit_flag, TRI *&last_tri) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [static] |
| locate_point(CubitVector &the_point, DLIList< TRI * > &facet_list, TRI *starting_tri, SURF *owning_surface, TRI *&tri_ptr) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| natural_neighbor_tris(CubitVector &the_point, DLIList< TRI * > &facet_list, TRI *&start_tri, SURF *surface_ptr, int &curr_visit_flag, DLIList< TRI * > &tri_list) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| point_in_circumcircle(CubitVector &the_point, TRI *tri_ptr, DLIList< TRI * > &tri_list, SURF *surface_ptr, int curr_visit_flag) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| radius(TRI *tri_ptr) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| tri_sort_list(TRI *tri_ptr, int sort_list_index) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| tri_sort_list(TRI *tri_ptr) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| tri_visited(TRI *tri_ptr, int curr_visit_flag) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| tri_visited(TRI *tri_ptr, CubitBoolean visited, int curr_visit_flag) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| valid_void(NODE *, DLIList< TRI * > &tri_list, SURF *surface_ptr, int curr_visit_flag) | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [private, static] |
| ~FacetorUtil() | FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC > | [inline] |
