, including all inherited members.
| add_cancel_opt | ProgOptions | [static] |
| addOpt(const std::string &namestring, const std::string &helpstring, T *value, int flags=0) | ProgOptions | |
| addOpt(const std::string &namestring, const std::string &helpstring, int flags=0) | ProgOptions | [inline] |
| addOptionalArgs(unsigned max_count, const std::string &helpname, const std::string &helpstring, int flags=0) | ProgOptions | |
| addOptionHelpHeading(const std::string &) | ProgOptions | |
| addRequiredArg(const std::string &helpname, const std::string &helpstring, T *value=NULL, int flags=0) | ProgOptions | |
| arg_help_strings | ProgOptions | [protected] |
| brief_help | ProgOptions | [protected] |
| error(const std::string &message) | ProgOptions | |
| evaluate(const ProgOpt &opt, void *target, const std::string &option, unsigned *arg_idx=NULL) | ProgOptions | [protected] |
| expect_optional_args | ProgOptions | [protected] |
| get_namestrings(const std::string &input, std::string *l, std::string *s) | ProgOptions | [protected] |
| get_option_usage_prefix(const ProgOpt &option) | ProgOptions | [protected] |
| getArgs(const std::string &namestring, std::vector< T > &values) | ProgOptions | |
| getOpt(const std::string &namestring, T *value) | ProgOptions | |
| getOptAllArgs(const std::string &namestring, std::vector< T > &values) | ProgOptions | |
| getReqArg(const std::string &namestring) | ProgOptions | |
| help_flag | ProgOptions | [static] |
| help_line typedef | ProgOptions | [protected] |
| int_flag | ProgOptions | [static] |
| long_names | ProgOptions | [protected] |
| lookup(const std::map< std::string, ProgOpt * > &, const std::string &) | ProgOptions | [protected] |
| lookup_option(const std::string &) | ProgOptions | [protected] |
| main_help | ProgOptions | [protected] |
| max_optional_args | ProgOptions | [protected] |
| number_option_name | ProgOptions | [protected] |
| numOptSet(const std::string &namestring) | ProgOptions | |
| option_help_strings | ProgOptions | [protected] |
| optional_args_position | ProgOptions | [protected] |
| parseCommandLine(int argc, char *argv[]) | ProgOptions | |
| printHelp(std::ostream &str=std::cout) | ProgOptions | |
| printUsage(std::ostream &str=std::cout) | ProgOptions | |
| printVersion(std::ostream &str=std::cout) | ProgOptions | |
| process_option(ProgOpt *opt, std::string arg, const char *value=0) | ProgOptions | [protected] |
| progname | ProgOptions | [protected] |
| ProgOptions(const std::string &helptext="", const std::string &briefdesc="") | ProgOptions | |
| progversion | ProgOptions | [protected] |
| rank_subst | ProgOptions | [static] |
| required_args | ProgOptions | [protected] |
| setVersion(const std::string &version_string, bool addFlag=true) | ProgOptions | |
| short_names | ProgOptions | [protected] |
| store_false | ProgOptions | [static] |
| store_true | ProgOptions | [static] |
| version_flag | ProgOptions | [static] |
| write_man_page(std::ostream &to_this_stream) | ProgOptions | |
| ~ProgOptions() | ProgOptions | |
