, including all inherited members.
| add_attribute(PartitionEntity *entity, const CubitSimpleAttrib &csa) | SubEntitySet | |
| add_lower_order(PartitionEntity *partition) | SubEntitySet | |
| add_lower_order(PartitionEntity *entity, const CubitSimpleAttrib &attrib, int dimension, DLIList< CubitVector * > &points_from_attrib, DLIList< int > &facets_from_attrib, DLIList< int > &children_from_attrib, DLIList< int > &facet_point_owners_from_attrib) | SubEntitySet | |
| add_partition(PartitionEntity *partition, PartitionEntity *insert_after=0) | SubEntitySet | |
| body() const | SubEntitySet | [inline] |
| bodyNext | SubEntitySet | [private] |
| bodyPtr | SubEntitySet | [private] |
| bridge_destroyed(TopologyBridge *bridge) | SubEntitySet | [virtual] |
| contains_bridge(TopologyBridge *bridge) const | TBOwner | [inline, virtual] |
| entity_from_id(int id) const | SubEntitySet | |
| get_attributes(PartitionEntity *entity, DLIList< CubitSimpleAttrib > &list) | SubEntitySet | |
| get_attributes(PartitionEntity *entity, const char *name, DLIList< CubitSimpleAttrib > &list) | SubEntitySet | |
| get_entity() const | SubEntitySet | [inline] |
| get_geom_dimension(const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
| get_geom_id(const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
| get_id(PartitionEntity *entity) const | SubEntitySet | |
| get_lower_order(DLIList< PartitionEntity * > &result_set) const | SubEntitySet | |
| get_owner_layer() const | SubEntitySet | [inline, virtual] |
| get_owners(DLIList< TopologyBridge * > &owner_list) const | SubEntitySet | [virtual] |
| get_segment_count(const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
| get_sub_entities(DLIList< PartitionEntity * > &result_set) const | SubEntitySet | |
| get_unique_id() | SubEntitySet | |
| has_lower_order() const | SubEntitySet | [inline] |
| has_multiple_sub_entities() const | SubEntitySet | |
| is_attribute(const CubitSimpleAttrib &csa, int id=0) const | SubEntitySet | [private] |
| lastId | SubEntitySet | [private] |
| layerNumber | SubEntitySet | [private] |
| lowerOrderHead | SubEntitySet | [private] |
| myEntity | SubEntitySet | [private] |
| next_in_body() const | SubEntitySet | [inline] |
| notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_reversed(TopologyBridge *bridge) | SubEntitySet | [virtual] |
| notify_split(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_topology_modified(TopologyBridge *) | TBOwner | [inline, virtual] |
| operator=(const SubEntitySet &) | SubEntitySet | [inline, private] |
| operator==(const SubEntitySet &c) const | SubEntitySet | [inline, private] |
| PartitionBody class | SubEntitySet | [friend] |
| print_debug_info(const char *prefix=0) const | SubEntitySet | |
| read_geometry(int &id, int &dimension, DLIList< CubitVector * > &point_list, DLIList< int > &point_connectivity, DLIList< int > &topo_connectivity, DLIList< int > &point_owners, const CubitSimpleAttrib &attrib) | SubEntitySet | [static] |
| rem_all_attrib(PartitionEntity *entity) | SubEntitySet | |
| rem_attribute(PartitionEntity *entity, const CubitSimpleAttrib &csa) | SubEntitySet | |
| remove(PartitionEntity *partition) | SubEntitySet | |
| remove_bridge(TopologyBridge *bridge) | SubEntitySet | [virtual] |
| remove_non_geom_attribs(DLIList< CubitSimpleAttrib > &list) | SubEntitySet | [static] |
| renumerate(int lowest_value, bool only_higher_ids) | SubEntitySet | |
| reset_unique_id() | SubEntitySet | [inline] |
| save_geometry() | SubEntitySet | |
| save_geometry(int id, int dimension, DLIList< CubitVector * > *point_list, DLIList< int > *point_connectivity, DLIList< int > *topo_connectivity, DLIList< int > *point_owners, CubitSimpleAttrib &attrib) | SubEntitySet | |
| set_id(PartitionEntity *entity, int id) | SubEntitySet | |
| strip_attributes(TopologyBridge *bridge) | SubEntitySet | [static] |
| strip_attributes() | SubEntitySet | |
| subEntityHead | SubEntitySet | [private] |
| SubEntitySet(TopologyBridge *real_entity, PartitionEntity *first_partition) | SubEntitySet | |
| swap_bridge(TopologyBridge *remove, TopologyBridge *add, bool reversed) | SubEntitySet | [virtual] |
| uniqueId | SubEntitySet | [private] |
| unwrap_attribute(CubitSimpleAttrib &csa) const | SubEntitySet | [private] |
| unwrap_attributes() | SubEntitySet | |
| wrap_attribute(CubitSimpleAttrib &csa, int id) const | SubEntitySet | [private] |
| ~SubEntitySet() | SubEntitySet | [virtual] |
| ~TBOwner() | TBOwner | [virtual] |
| ~TBOwnerSet() | TBOwnerSet | |
