, including all inherited members.
| append_simple_attribute_virt(const CubitSimpleAttrib &)=0 | TopologyBridge | [pure virtual] |
| are_positions_on(DLIList< CubitVector * > &test_position_list, DLIList< CubitBoolean * > &is_on_list) | Surface | [virtual] |
| bodysm() | TopologyBridge | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() const =0 | GeometryEntity | [pure virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| ChildType typedef | Surface | |
| closest_point(CubitVector const &location, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL, CubitVector *curvature1=NULL, CubitVector *curvature2=NULL)=0 | Surface | [pure virtual] |
| closest_point_along_vector(CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface)=0 | Surface | [pure virtual] |
| closest_point_trimmed(CubitVector from_point, CubitVector &point_on_surface)=0 | Surface | [pure virtual] |
| closest_point_uv_guess(CubitVector const &location, double &u_guess, double &v_guess, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL)=0 | Surface | [pure virtual] |
| closest_points(DLIList< CubitVector * > &location_list, DLIList< CubitVector * > *closest_location_list=NULL, DLIList< CubitVector * > *unit_normal_list=NULL, DLIList< CubitVector * > *curvature1_list=NULL, DLIList< CubitVector * > *curvature2_list=NULL) | Surface | [virtual] |
| closest_points_trimmed(std::vector< CubitVector > &from_points_list, std::vector< CubitVector > &points_on_surface_list) | Surface | [virtual] |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| evaluate(double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2)=0 | Surface | [pure virtual] |
| evaluate(double u, double v, CubitVector &pos, CubitVector deriv1[2], CubitVector deriv2[3]) | Surface | [virtual] |
| geometry_type() | Surface | [inline, virtual] |
| GeometryEntity() | GeometryEntity | [inline] |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &children)=0 | TopologyBridge | [pure virtual] |
| get_cone_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const =0 | Surface | [pure virtual] |
| get_geometry_query_engine() const =0 | TopologyBridge | [pure virtual] |
| get_geometry_sense()=0 | Surface | [pure virtual] |
| get_nurb_params(bool &rational, int °ree_u, int °ree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const =0 | Surface | [pure virtual] |
| get_param_range_U(double &lower_bound, double &upper_bound)=0 | Surface | [pure virtual] |
| get_param_range_V(double &lower_bound, double &upper_bound)=0 | Surface | [pure virtual] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &parents)=0 | TopologyBridge | [pure virtual] |
| get_point_normal(CubitVector &point, CubitVector &normal)=0 | Surface | [pure virtual] |
| get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance)=0 | Surface | [pure virtual] |
| get_saved_id() const | GeometryEntity | [inline] |
| get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
| get_shell_sense(ShellSM *shell_ptr) const =0 | Surface | [pure virtual] |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &)=0 | TopologyBridge | [pure virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)=0 | TopologyBridge | [pure virtual] |
| get_sphere_params(CubitVector ¢er, double &radius) const =0 | Surface | [pure virtual] |
| get_torus_params(CubitVector ¢er, CubitVector &normal, double &major_radius, double &minor_radius) const =0 | Surface | [pure virtual] |
| get_uv_sense() | Surface | [inline, virtual] |
| is_closed_in_U() | Surface | [inline, virtual] |
| is_closed_in_V() | Surface | [inline, virtual] |
| is_cylindrical() | Surface | [inline, virtual] |
| is_parametric()=0 | Surface | [pure virtual] |
| is_periodic()=0 | Surface | [pure virtual] |
| is_periodic_in_U(double &period)=0 | Surface | [pure virtual] |
| is_periodic_in_V(double &period)=0 | Surface | [pure virtual] |
| is_position_on(CubitVector &test_position)=0 | Surface | [pure virtual] |
| is_singular_in_U(double u_param)=0 | Surface | [pure virtual] |
| is_singular_in_V(double v_param)=0 | Surface | [pure virtual] |
| layer() const | TopologyBridge | [inline, virtual] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| MAX_TB_LAYER enum value | TopologyBridge | |
| measure()=0 | GeometryEntity | [pure virtual] |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| param_dir(CubitVector &, CubitVector &, double &, double &) | Surface | [inline, virtual] |
| point_containment(const CubitVector &point)=0 | Surface | [pure virtual] |
| point_containment(double u, double v)=0 | Surface | [pure virtual] |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| position_from_u_v(double u, double v)=0 | Surface | [pure virtual] |
| principal_curvatures(CubitVector const &location, double &curvature_1, double &curvature_2, CubitVector *closest_location=NULL)=0 | Surface | [pure virtual] |
| remove_all_simple_attribute_virt()=0 | TopologyBridge | [pure virtual] |
| remove_simple_attribute_virt(const CubitSimpleAttrib &)=0 | TopologyBridge | [pure virtual] |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| set_saved_id(int value) | GeometryEntity | [inline] |
| set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| Surface() | Surface | |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| SurfaceSM() | SurfaceSM | |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| u_v_from_position(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL)=0 | Surface | [pure virtual] |
| uv_derivitives(double u_param, double v_param, CubitVector &du, CubitVector &dv)=0 | Surface | [pure virtual] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| ~GeometryEntity() | GeometryEntity | [virtual] |
| ~Surface() | Surface | [virtual] |
| ~SurfaceSM() | SurfaceSM | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
