cgma
00001 #include <iostream> 00002 #include <map> 00003 #include <cfloat> 00004 00005 #include <cassert> 00006 00007 #include "MCNPInput.hpp" 00008 #include "volumes.hpp" 00009 #include "geometry.hpp" 00010 #include "options.hpp" 00011 00012 00013 static Vector3d origin(0,0,0); 00014 00015 00016 iBase_EntityHandle makeWorldSphere( iGeom_Instance& igm, double world_size ){ 00017 iBase_EntityHandle world_sphere; 00018 int igm_result; 00019 // Note: I tried using createBrick instead of createSphere to bound the universe with a box 00020 // instead of a sphere. This worked but led to a substantial increase in run times and 00021 // memory usage, so should be avoided. 00022 iGeom_createSphere( igm, world_size, &world_sphere, &igm_result); 00023 CHECK_IGEOM( igm_result, "making world sphere" ); 00024 return world_sphere; 00025 } 00026 00033 static iBase_EntityHandle embedWithinWorld( bool positive, iGeom_Instance& igm, double world_size, 00034 iBase_EntityHandle body, bool bound_with_world ) 00035 { 00036 iBase_EntityHandle final_body; 00037 int igm_result; 00038 00039 if( !positive && !bound_with_world ){ 00040 final_body = body; 00041 } 00042 else{ 00043 iBase_EntityHandle world_sphere = makeWorldSphere( igm, world_size ); 00044 00045 if( positive ){ 00046 iGeom_subtractEnts( igm, world_sphere, body, &final_body, &igm_result); 00047 CHECK_IGEOM( igm_result, "making positive body" ); 00048 } 00049 else{ // !positive && bound_with_world 00050 iGeom_intersectEnts( igm, world_sphere, body, &final_body, &igm_result); 00051 CHECK_IGEOM( igm_result, "making negative body" ); 00052 } 00053 } 00054 return final_body; 00055 } 00056 00057 00058 00059 iBase_EntityHandle applyTransform( const Transform& t, iGeom_Instance& igm, iBase_EntityHandle& e ) { 00060 00061 int igm_result; 00062 if( t.hasRot() ){ 00063 const Vector3d& axis = t.getAxis(); 00064 iGeom_rotateEnt( igm, e, t.getTheta(), axis.v[0], axis.v[1], axis.v[2], &igm_result ); 00065 CHECK_IGEOM( igm_result, "applying rotation" ); 00066 } 00067 00068 if( t.hasInversion() ){ 00069 //TODO: ask about the right way to do this. Rotate seems to work, but I don't really know why... 00070 //iGeom_rotateEnt( igm, e, 180, 0, 0, 0, &igm_result ); 00071 00072 //if( !t.hasRot() ){ 00073 iGeom_reflectEnt( igm, e, 0, 0, 0, 0, 0, 1, &igm_result ); 00074 iGeom_reflectEnt( igm, e, 0, 0, 0, 0, 1, 0, &igm_result ); 00075 iGeom_reflectEnt( igm, e, 0, 0, 0, 1, 0, 0, &igm_result ); 00076 //} 00077 //else{ 00078 // const Vector3d& axis = t.getAxis(); 00079 // iGeom_reflectEnt( igm, e, axis.v[0], axis.v[1], axis.v[2], &igm_result ); 00080 // } 00081 00082 CHECK_IGEOM( igm_result, "inverting for transformation" ); 00083 } 00084 00085 00086 const Vector3d& translation = t.getTranslation(); 00087 iGeom_moveEnt( igm, e, translation.v[0], translation.v[1], translation.v[2], &igm_result); 00088 CHECK_IGEOM( igm_result, "applying translation" ); 00089 00090 return e; 00091 } 00092 00093 iBase_EntityHandle applyReverseTransform( const Transform& tx, iGeom_Instance& igm, iBase_EntityHandle& e ) { 00094 00095 int igm_result; 00096 Transform rev_t = tx.reverse(); 00097 00098 const Vector3d& translation = rev_t.getTranslation(); 00099 iGeom_moveEnt( igm, e, translation.v[0], translation.v[1], translation.v[2], &igm_result); 00100 CHECK_IGEOM( igm_result, "applying reverse translation" ); 00101 00102 if( rev_t.hasInversion() ){ 00103 iGeom_rotateEnt( igm, e, 180, 0, 0, 0, &igm_result ); 00104 CHECK_IGEOM( igm_result, "inverting for reverse transformation" ); 00105 } 00106 00107 if( rev_t.hasRot() ){ 00108 const Vector3d& axis = rev_t.getAxis(); 00109 iGeom_rotateEnt( igm, e, rev_t.getTheta(), axis.v[0], axis.v[1], axis.v[2], &igm_result ); 00110 CHECK_IGEOM( igm_result, "applying rotation" ); 00111 } 00112 00113 00114 return e; 00115 } 00116 00117 00118 iBase_EntityHandle SurfaceVolume::define( bool positive, iGeom_Instance& igm, double world_size ){ 00119 iBase_EntityHandle handle = this->getHandle( positive, igm, world_size ); 00120 if( transform ){ 00121 handle = applyTransform( *transform, igm, handle ); 00122 } 00123 return handle; 00124 } 00125 00126 00127 00128 class PlaneSurface : public SurfaceVolume { 00129 00130 protected: 00131 Vector3d normal; 00132 double offset; 00133 00134 public: 00135 PlaneSurface( const Vector3d& normal_p, double offset_p ) : 00136 SurfaceVolume(), normal(normal_p), offset(offset_p) 00137 {} 00138 00139 virtual double getFarthestExtentFromOrigin() const{ 00140 // this is a funny situation, since planes are technically infinte... 00141 // in order to have a sane answer, we just return the offset from the origin. 00142 // (multiplied by root 3, which was done in the old converter, why?) 00143 return sqrt(3.0) * std::fabs(offset); 00144 } 00145 00146 protected: 00147 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size){ 00148 00149 int igm_result; 00150 iBase_EntityHandle world_sphere = makeWorldSphere(igm, world_size); 00151 iBase_EntityHandle hemisphere; 00152 // note the reversal of sense in this call; mcnp and igeom define it differently. 00153 iGeom_sectionEnt( igm, world_sphere, 00154 normal.v[0], normal.v[1], normal.v[2], offset, !positive, &hemisphere, &igm_result); 00155 CHECK_IGEOM( igm_result, "Sectioning world for a plane" ); 00156 return hemisphere; 00157 00158 00159 } 00160 00161 }; 00162 00163 00164 typedef enum { X=0, Y=1, Z=2 } axis_t; 00165 00166 00167 class CylinderSurface : public SurfaceVolume { 00168 00169 protected: 00170 axis_t axis; 00171 double radius; 00172 Vector3d center; 00173 bool onaxis; 00174 00175 public: 00176 CylinderSurface( axis_t axis_p, double radius_p ): 00177 SurfaceVolume(), axis(axis_p), radius(radius_p), center(origin), onaxis(true) 00178 {} 00179 00180 CylinderSurface( axis_t axis_p, double radius_p, double trans1, double trans2 ): 00181 SurfaceVolume(), axis(axis_p), radius(radius_p), center(origin), onaxis(false) 00182 { 00183 switch(axis){ 00184 case X: center.v[Y] += trans1; center.v[Z] += trans2; break; 00185 case Y: center.v[X] += trans1; center.v[Z] += trans2; break; 00186 case Z: center.v[X] += trans1; center.v[Y] += trans2; break; 00187 } 00188 } 00189 00190 virtual double getFarthestExtentFromOrigin( ) const{ 00191 return radius + center.length(); 00192 } 00193 00194 protected: 00195 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00196 int igm_result; 00197 00198 iBase_EntityHandle cylinder; 00199 iGeom_createCylinder( igm, 2.0 * world_size, radius, 0, &cylinder, &igm_result); 00200 CHECK_IGEOM( igm_result, "making cylinder" ); 00201 00202 00203 if( axis == X ){ 00204 iGeom_rotateEnt( igm, cylinder, 90, 0, 1, 0, &igm_result ); 00205 CHECK_IGEOM( igm_result, "rotating cylinder (X)" ); 00206 } 00207 else if( axis == Y ){ 00208 iGeom_rotateEnt( igm, cylinder, 90, 1, 0, 0, &igm_result ); 00209 CHECK_IGEOM( igm_result, "rotating cylinder (Y)" ); 00210 } 00211 00212 if( onaxis == false ){ 00213 iGeom_moveEnt( igm, cylinder, center.v[0], center.v[1], center.v[2], &igm_result); 00214 CHECK_IGEOM( igm_result, "moving cylinder" ); 00215 } 00216 00217 iBase_EntityHandle final_cylinder = embedWithinWorld( positive, igm, world_size, cylinder, true ); 00218 00219 return final_cylinder; 00220 }; 00221 00222 }; 00223 00224 //#ifdef HAVE_IGEOM_CONE 00225 00226 class ConeSurface : public SurfaceVolume { 00227 00228 protected: 00229 00230 enum nappe {LEFT=-1, BOTH=0, RIGHT=1}; 00231 00232 static enum nappe make_nappe( double param ){ 00233 00234 enum nappe n = static_cast<enum nappe>(param); 00235 if( -1 <= n && n <= 1 ){ 00236 return n; 00237 } 00238 else{ 00239 std::cerr << "WARNING: Bad cylinder +/-1 argument: " << param << std::endl; 00240 std::cerr << " will pretend it was really 0" << std::endl; 00241 return BOTH; 00242 } 00243 } 00244 00245 axis_t axis; 00246 double theta; 00247 Vector3d center; 00248 bool onaxis; 00249 enum nappe nappe; 00250 00251 public: 00252 ConeSurface( axis_t axis_p, double tsquared_p, double point_p, double nappe_p ): 00253 SurfaceVolume(), axis(axis_p), theta( atan(sqrt(tsquared_p)) ), center(origin), onaxis(true), nappe(make_nappe(nappe_p)) 00254 { 00255 center.v[axis] = point_p; 00256 } 00257 00258 ConeSurface( axis_t axis_p, double tsquared_p, Vector3d center_p, double nappe_p ): 00259 SurfaceVolume(), axis(axis_p), theta( atan(sqrt(tsquared_p)) ), center(center_p), onaxis(false), nappe(make_nappe(nappe_p)) 00260 {} 00261 00262 virtual double getFarthestExtentFromOrigin( ) const{ 00263 return sqrt(3) + ( center.length() ); 00264 } 00265 00266 protected: 00267 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00268 00269 double height = (center.length() + world_size); 00270 00271 // based on the textual descriptions in the manual, I think the following expression should be 00272 // height * tan ( theta / 2 ) -- unless "opening angle" refers to only half the apex angle 00273 // of the cylinder. But this implementation seems to be more correct in examples I can check against. 00274 double base_radius = height * tan( theta ); 00275 00276 int igm_result; 00277 00278 iBase_EntityHandle right_nappe = 0; 00279 iBase_EntityHandle left_nappe = 0; 00280 iBase_EntityHandle cone; 00281 00282 if( nappe != LEFT){ 00283 iGeom_createCone( igm, height, base_radius, 0, 0, &right_nappe, &igm_result); 00284 CHECK_IGEOM( igm_result, "making cone (right nappe)" ); 00285 iGeom_rotateEnt( igm, right_nappe, 180, 1, 0, 0, &igm_result); 00286 CHECK_IGEOM( igm_result, "Rotating cone (right nappe)"); 00287 iGeom_moveEnt( igm, right_nappe, 0, 0, height/2.0, &igm_result ); 00288 CHECK_IGEOM( igm_result, "Moving cone (right nappe)"); 00289 cone = right_nappe; 00290 } 00291 if( nappe != RIGHT ){ 00292 iGeom_createCone( igm, height, base_radius, 0, 0, &left_nappe, &igm_result ); 00293 CHECK_IGEOM( igm_result, "making cone (left nappe)" ); 00294 iGeom_moveEnt( igm, left_nappe, 0, 0, -height/2.0, &igm_result ); 00295 CHECK_IGEOM( igm_result, "Moving cone (left nappe)" ); 00296 cone = left_nappe; 00297 } 00298 00299 00300 if( right_nappe && left_nappe ){ 00301 iBase_EntityHandle nappes[2] = {right_nappe, left_nappe}; 00302 iGeom_uniteEnts( igm, nappes, 2, &cone, &igm_result ); 00303 CHECK_IGEOM( igm_result, "Unioning cone nappes" ); 00304 } 00305 00306 if( axis == X ){ 00307 iGeom_rotateEnt( igm, cone, 90, 0, 1, 0, &igm_result ); 00308 CHECK_IGEOM( igm_result, "rotating cone (X)" ); 00309 } 00310 else if( axis == Y ){ 00311 iGeom_rotateEnt( igm, cone, -90, 1, 0, 0, &igm_result ); 00312 CHECK_IGEOM( igm_result, "rotating cone (Y)" ); 00313 } 00314 00315 iGeom_moveEnt( igm, cone, center.v[0], center.v[1], center.v[2], &igm_result); 00316 CHECK_IGEOM( igm_result, "moving cone to its apex" ); 00317 00318 iBase_EntityHandle final_cone = embedWithinWorld( positive, igm, world_size, cone, true ); 00319 00320 return final_cone; 00321 00322 } 00323 00324 }; 00325 00326 //#endif /* HAVE_IGEOM_CONE */ 00327 00328 class TorusSurface : public SurfaceVolume { 00329 00330 protected: 00331 Vector3d center; 00332 axis_t axis; 00333 double radius; 00334 double ellipse_axis_rad; 00335 double ellipse_perp_rad; 00336 00337 public: 00338 TorusSurface( axis_t axis_p, const Vector3d& center_p, double A, double B, double C ) : 00339 center(center_p), axis( axis_p ), radius(A), ellipse_axis_rad( B ), ellipse_perp_rad( C ) 00340 {} 00341 00342 virtual double getFarthestExtentFromOrigin ( ) const { 00343 return center.length() + radius + std::max( ellipse_axis_rad, ellipse_perp_rad ); 00344 } 00345 00346 protected: 00347 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00348 00349 int igm_result; 00350 00351 iBase_EntityHandle torus; 00352 00353 iGeom_createTorus( igm, radius, ellipse_perp_rad, &torus, &igm_result ); 00354 CHECK_IGEOM( igm_result, "Creating initial torus"); 00355 00356 if( ellipse_axis_rad != ellipse_perp_rad ){ 00357 double scalef = ellipse_axis_rad / ellipse_perp_rad; 00358 iGeom_scaleEnt( igm, torus, 0, 0, 0, 1.0, 1.0, scalef, &igm_result ); 00359 CHECK_IGEOM( igm_result, "Scaling torus" ); 00360 } 00361 00362 if( axis == X ){ 00363 iGeom_rotateEnt( igm, torus, 90, 0, 1, 0, &igm_result ); 00364 CHECK_IGEOM( igm_result, "rotating torus (X)" ); 00365 } 00366 else if( axis == Y ){ 00367 iGeom_rotateEnt( igm, torus, -90, 1, 0, 0, &igm_result ); 00368 CHECK_IGEOM( igm_result, "rotating torus (Y)" ); 00369 } 00370 00371 iGeom_moveEnt( igm, torus, center.v[0], center.v[1], center.v[2], &igm_result); 00372 CHECK_IGEOM( igm_result, "moving torus to its center point" ); 00373 00374 00375 iBase_EntityHandle final_torus = embedWithinWorld( positive, igm, world_size, torus, false ); 00376 00377 return final_torus; 00378 00379 } 00380 00381 }; 00382 00383 class SphereSurface : public SurfaceVolume { 00384 00385 protected: 00386 Vector3d center; 00387 double radius; 00388 00389 public: 00390 SphereSurface( const Vector3d& center_p, double radius_p ) : 00391 SurfaceVolume(), center(center_p), radius(radius_p) 00392 {} 00393 00394 virtual ~SphereSurface(){} 00395 00396 virtual double getFarthestExtentFromOrigin ( ) const { 00397 return (center.length() + radius); 00398 } 00399 00400 protected: 00401 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00402 00403 int igm_result; 00404 iBase_EntityHandle sphere; 00405 00406 iGeom_createSphere( igm, radius, &sphere, &igm_result); 00407 CHECK_IGEOM( igm_result, "making sphere" ); 00408 00409 iGeom_moveEnt( igm, sphere, center.v[0], center.v[1], center.v[2], &igm_result ); 00410 CHECK_IGEOM( igm_result, "moving sphere" ); 00411 00412 00413 iBase_EntityHandle final_sphere = embedWithinWorld( positive, igm, world_size, sphere, false ); 00414 00415 return final_sphere; 00416 } 00417 00418 }; 00419 00420 class EllipsoidSurface : public SurfaceVolume { 00421 00422 protected: 00423 Vector3d center; 00424 Vector3d axes; 00425 00426 public: 00427 EllipsoidSurface( const Vector3d& center_p, const Vector3d& axes_p ) : 00428 SurfaceVolume(), center(center_p), axes(axes_p) 00429 {} 00430 00431 virtual ~EllipsoidSurface(){} 00432 00433 virtual double getFarthestExtentFromOrigin ( ) const { 00434 return (center.length() + axes.length()); 00435 } 00436 00437 protected: 00438 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00439 00440 int igm_result; 00441 iBase_EntityHandle sphere; 00442 double radius = 1; 00443 00444 iGeom_createSphere( igm, radius, &sphere, &igm_result); 00445 CHECK_IGEOM( igm_result, "making sphere" ); 00446 00447 iGeom_scaleEnt( igm, sphere, 0, 0, 0, sqrt(1/axes.v[0]), sqrt(1/axes.v[1]), sqrt(1/axes.v[2]), &igm_result); 00448 CHECK_IGEOM( igm_result, "scaling sphere to ellipsoid" ); 00449 00450 iGeom_moveEnt( igm, sphere, center.v[0], center.v[1], center.v[2], &igm_result ); 00451 CHECK_IGEOM( igm_result, "moving sphere" ); 00452 00453 00454 iBase_EntityHandle final_sphere = embedWithinWorld( positive, igm, world_size, sphere, false ); 00455 00456 return final_sphere; 00457 } 00458 00459 }; 00460 00461 00462 00463 static Transform axesImage( const Vector3d& v1, const Vector3d& v2, const Vector3d &v3, const Vector3d& translation = Vector3d() ) 00464 { 00465 Vector3d x(1, 0, 0), y(0, 1, 0), z(0, 0, 1); 00466 Vector3d a1 = v1.normalize(), a2 = v2.normalize(), a3 = v3.normalize(); 00467 00468 if( OPT_DEBUG ) std::cout << "Axes image: " << a1 << " : " << a2 << " : " << a3 << std::endl; 00469 00470 double rot_matrix[9] = 00471 { a1.dot(x), a2.dot(x), a3.dot(x), 00472 a1.dot(y), a2.dot(y), a3.dot(y), 00473 a1.dot(z), a2.dot(z), a3.dot(z) }; 00474 00475 00476 return Transform( rot_matrix, translation ); 00477 } 00478 00479 static Transform imageZAxisTo( const Vector3d& v, const Vector3d& translation = Vector3d() ){ 00480 // approach: find two vectors perpendicular to v, then use axesImage. 00481 Vector3d a = v.normalize(); 00482 00483 Vector3d x(1, 0, 0); 00484 Vector3d b = x.cross( v.normalize() ); 00485 00486 if( b.length() < DBL_EPSILON ){ 00487 // v is indistinguishable from the x axis 00488 b = Vector3d(0, -1, 0); 00489 if( OPT_DEBUG ) std::cout << "imageZAxisTo: Changing v " << std::endl; 00490 } 00491 00492 Vector3d c = b.cross( v.normalize() ); 00493 return axesImage( c, b, a, translation ); 00494 00495 00496 } 00497 00498 00499 00500 class BoxVolume : public SurfaceVolume { 00501 00502 protected: 00503 Vector3d dimensions; 00504 Transform transform; 00505 00506 public: 00507 BoxVolume( const Vector3d& corner, const Vector3d& v1, const Vector3d& v2, const Vector3d& v3 ) : 00508 dimensions( v1.length(), v2.length(), v3.length() ), transform( axesImage(v1,v2,v3,corner) ) 00509 {} 00510 00511 virtual double getFarthestExtentFromOrigin ( ) const { 00512 return transform.getTranslation().length() + dimensions.length(); 00513 } 00514 00515 protected: 00516 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00517 00518 00519 int igm_result; 00520 iBase_EntityHandle box; 00521 00522 iGeom_createBrick( igm, dimensions.v[0], dimensions.v[1], dimensions.v[2], &box, &igm_result ); 00523 CHECK_IGEOM( igm_result, "making box" ); 00524 00525 Vector3d halfdim = dimensions.scale( 1.0 / 2.0 ); 00526 iGeom_moveEnt( igm, box, halfdim.v[0], halfdim.v[1], halfdim.v[2], &igm_result ); 00527 CHECK_IGEOM( igm_result, "moving box (halfdim)" ); 00528 00529 box = applyTransform( transform, igm, box ); 00530 iBase_EntityHandle final_box = embedWithinWorld( positive, igm, world_size, box, false ); 00531 00532 return final_box; 00533 } 00534 00535 }; 00536 00537 00538 class RppVolume : public SurfaceVolume { 00539 00540 protected: 00541 Vector3d dimensions; 00542 Vector3d center_offset; 00543 00544 public: 00545 RppVolume( const Vector3d& lower, const Vector3d& upper ) 00546 { 00547 for( int i = 0; i < 3; ++i ){ 00548 dimensions.v[i] = upper.v[i] - lower.v[i]; 00549 center_offset.v[i] = (upper.v[i]+lower.v[i]) / 2.0; 00550 } 00551 } 00552 00553 virtual double getFarthestExtentFromOrigin ( ) const { 00554 return dimensions.length() + center_offset.length(); 00555 } 00556 00557 protected: 00558 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00559 00560 int igm_result; 00561 iBase_EntityHandle rpp; 00562 00563 iGeom_createBrick( igm, dimensions.v[0], dimensions.v[1], dimensions.v[2], &rpp, &igm_result ); 00564 CHECK_IGEOM( igm_result, "making rpp" ); 00565 00566 iGeom_moveEnt( igm, rpp, center_offset.v[0], center_offset.v[1], center_offset.v[2], &igm_result ); 00567 CHECK_IGEOM( igm_result, "moving rpp" ); 00568 00569 iBase_EntityHandle final_rpp = embedWithinWorld( positive, igm, world_size, rpp, false ); 00570 return final_rpp; 00571 } 00572 00573 }; 00574 00575 00576 class RecVolume : public SurfaceVolume { 00577 00578 protected: 00579 Vector3d base_center; 00580 Transform transform; 00581 double length, radius1, radius2; 00582 00583 public: 00584 RecVolume( const Vector3d& center_p, const Vector3d& axis, const Vector3d& v1, const Vector3d& v2 ) : 00585 base_center( center_p ), transform( axesImage( v1, v2, axis, center_p ) ), 00586 length( axis.length() ), radius1( v1.length() ), radius2( v2.length() ) 00587 {} 00588 00589 RecVolume( const Vector3d& center_p, const Vector3d& axis, const Vector3d& v1, double length2 ) : 00590 base_center( center_p ), transform( axesImage( v1, v1.cross(axis), axis, center_p ) ), 00591 length( axis.length() ), radius1( v1.length() ), radius2( length2 ) 00592 {} 00593 00594 virtual double getFarthestExtentFromOrigin ( ) const { 00595 return base_center.length() + length + std::max( radius1, radius2 ); 00596 } 00597 00598 protected: 00599 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00600 int igm_result; 00601 iBase_EntityHandle rec; 00602 00603 iGeom_createCylinder( igm, length, radius1, radius2, &rec, &igm_result ); 00604 CHECK_IGEOM( igm_result, "creating rec" ); 00605 00606 00607 double movement_factor = length / 2.0; 00608 iGeom_moveEnt( igm, rec, 0, 0, movement_factor, &igm_result ); 00609 CHECK_IGEOM( igm_result, "moving rec" ); 00610 00611 rec = applyTransform( transform, igm, rec ); 00612 iBase_EntityHandle final_rec = embedWithinWorld( positive, igm, world_size, rec, false ); 00613 return final_rec; 00614 } 00615 }; 00616 00617 00618 class RccVolume : public SurfaceVolume { 00619 00620 protected: 00621 Vector3d base_center; 00622 Transform transform; 00623 double length, radius; 00624 00625 public: 00626 RccVolume( const Vector3d& center_p, const Vector3d& axis, double radius_p ) : 00627 base_center( center_p ), transform( imageZAxisTo( axis, center_p ) ), length( axis.length() ), radius(radius_p) 00628 {} 00629 00630 virtual double getFarthestExtentFromOrigin ( ) const { 00631 return base_center.length() + length + radius; 00632 } 00633 00634 protected: 00635 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00636 int igm_result; 00637 iBase_EntityHandle rcc; 00638 00639 iGeom_createCylinder( igm, length, radius, 0, &rcc, &igm_result ); 00640 CHECK_IGEOM( igm_result, "creating rcc" ); 00641 00642 double movement_factor = length / 2.0; 00643 iGeom_moveEnt( igm, rcc, 0, 0, movement_factor, &igm_result ); 00644 CHECK_IGEOM( igm_result, "moving rcc" ); 00645 00646 rcc = applyTransform( transform, igm, rcc ); 00647 iBase_EntityHandle final_rcc = embedWithinWorld( positive, igm, world_size, rcc, false ); 00648 return final_rcc; 00649 } 00650 00651 }; 00652 00653 00654 #ifdef HAVE_IGEOM_CONE 00655 class TrcVolume : public SurfaceVolume { 00656 00657 protected: 00658 Vector3d base_center; 00659 Transform transform; 00660 double length, radius1, radius2; 00661 00662 public: 00663 TrcVolume( const Vector3d& center_p, const Vector3d& axis, double radius1_p, double radius2_p ) : 00664 base_center( center_p ), transform( imageZAxisTo( axis, center_p ) ), length( axis.length() ), 00665 radius1(radius1_p), radius2(radius2_p) 00666 {} 00667 00668 virtual double getFarthestExtentFromOrigin ( ) const { 00669 return base_center.length() + length + std::max(radius1,radius2); 00670 } 00671 00672 protected: 00673 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00674 int igm_result; 00675 iBase_EntityHandle trc; 00676 00677 iGeom_createCone( igm, length, radius1, 0, radius2, &trc, &igm_result ); 00678 CHECK_IGEOM( igm_result, "creating trc" ); 00679 00680 iGeom_moveEnt( igm, trc, 0, 0, length / 2.0, &igm_result ); 00681 CHECK_IGEOM( igm_result, "moving trc" ); 00682 00683 trc = applyTransform( transform, igm, trc ); 00684 iBase_EntityHandle final_trc = embedWithinWorld( positive, igm, world_size, trc, false ); 00685 return final_trc; 00686 } 00687 00688 }; 00689 #endif 00690 00691 00692 class HexVolume : public SurfaceVolume { 00693 00694 protected: 00695 Vector3d base_center; 00696 Vector3d heightV, RV, SV, TV; 00697 //Transform transform; 00698 00699 public: 00700 HexVolume( const Vector3d& center_p, const Vector3d& h_p, const Vector3d& r_p, 00701 const Vector3d& s_p, const Vector3d& t_p ) : 00702 base_center(center_p), heightV(h_p), RV(r_p), SV(s_p), TV(t_p) 00703 {} 00704 00705 HexVolume( const Vector3d& center_p, const Vector3d& h_p, const Vector3d& r_p ) : 00706 base_center(center_p), heightV(h_p), RV(r_p), SV( r_p.rotate_about(h_p,60.0) ), TV( r_p.rotate_about(h_p,120.0) ) 00707 { 00708 if( OPT_DEBUG ){ 00709 std::cout << "Inferred vectors for 9-args HEX/RHP:" << RV << SV << TV << std::endl; 00710 } 00711 } 00712 00713 virtual double getFarthestExtentFromOrigin ( ) const { 00714 double hex_max = std::max( RV.length(), std::max( SV.length(), TV.length() ) ); 00715 return base_center.length() + heightV.length() + hex_max; 00716 } 00717 00718 protected: 00719 virtual iBase_EntityHandle getHandle( bool positive, iGeom_Instance& igm, double world_size ){ 00720 int igm_result; 00721 iBase_EntityHandle hex; 00722 00723 hex = makeWorldSphere( igm, world_size ); 00724 00725 Vector3d b = - heightV.normalize(); 00726 iGeom_sectionEnt( igm, hex, b.v[0], b.v[1], b.v[2], 0, true, &hex, &igm_result ); 00727 CHECK_IGEOM( igm_result, "Sectioning world for a hex (1)" ); 00728 00729 b = -b; 00730 iGeom_sectionEnt( igm, hex, b.v[0], b.v[1], b.v[2], heightV.length(), true, &hex, &igm_result ); 00731 CHECK_IGEOM( igm_result, "Sectioning world for a hex (2)" ); 00732 00733 00734 00735 const Vector3d* vec[3] = {&RV, &SV, &TV}; 00736 for( int i = 0; i < 3; ++i ){ 00737 Vector3d v = *(vec[i]); 00738 double length = v.length(); 00739 v = v.normalize(); 00740 00741 iGeom_sectionEnt( igm, hex, v.v[0], v.v[1], v.v[2], length, true, &hex, &igm_result ); 00742 CHECK_IGEOM( igm_result, "Sectioning world for a hex (3)" ); 00743 00744 v = -v; 00745 iGeom_sectionEnt( igm, hex, v.v[0], v.v[1], v.v[2], length, true, &hex, &igm_result ); 00746 CHECK_IGEOM( igm_result, "Sectioning world for a hex (4)" ); 00747 00748 00749 } 00750 00751 iGeom_moveEnt( igm, hex, base_center.v[0], base_center.v[1], base_center.v[2], &igm_result ); 00752 CHECK_IGEOM( igm_result, "Moving hex" ); 00753 00754 iBase_EntityHandle final_hex = embedWithinWorld( positive, igm, world_size, hex, false ); 00755 return final_hex; 00756 00757 } 00758 00759 }; 00760 00761 00762 class VolumeCache{ 00763 00764 protected: 00765 std::map<const SurfaceCard*,SurfaceVolume*> mapping; 00766 00767 public: 00768 VolumeCache(){} 00769 00770 bool contains( const SurfaceCard* c ) const { 00771 return ( mapping.find(c) != mapping.end() ); 00772 } 00773 00774 SurfaceVolume* get( const SurfaceCard* c ) { 00775 assert( contains( c ) ); 00776 return (*(mapping.find(c))).second; 00777 } 00778 00779 void insert( const SurfaceCard* c, SurfaceVolume* s ){ 00780 mapping[c] = s; 00781 } 00782 00783 }; 00784 00785 bool sqIsEllipsoid(const std::vector< double >& args) { 00786 00787 bool isEllipsoid = true; 00788 00789 if ( args.at(3)*args.at(3) + args.at(4)*args.at(4) + args.at(5)*args.at(5) != 0) 00790 isEllipsoid = false; 00791 00792 if ( args.at(0)*args.at(1)*args.at(2)*args.at(6) >= 0 ) 00793 isEllipsoid = false; 00794 00795 return isEllipsoid; 00796 00797 } 00798 00799 // the VolumeCache to use if none is provided to makeSurface() calls. 00800 static VolumeCache default_volume_cache; 00801 00802 SurfaceVolume& makeSurface( const SurfaceCard* card, VolumeCache* v){ 00803 00804 VolumeCache& cache = default_volume_cache; 00805 if( v != NULL ){ 00806 cache = *v; 00807 } 00808 00809 00810 if( cache.contains( card ) ){ 00811 return *cache.get( card ); 00812 } 00813 else{ 00814 // SurfaceCard variables: mnemonic, args, coord_xform 00815 SurfaceVolume* surface; 00816 const std::string& mnemonic = card->getMnemonic(); 00817 const std::vector< double >& args = card->getArgs(); 00818 00819 if( mnemonic == "so"){ 00820 surface = new SphereSurface( origin, args.at(0) ); 00821 } 00822 else if( mnemonic == "sx"){ 00823 surface = new SphereSurface( Vector3d( args.at(0), 0, 0 ), args.at(1) ); 00824 } 00825 else if( mnemonic == "sy"){ 00826 surface = new SphereSurface( Vector3d( 0, args.at(0), 0 ), args.at(1) ); 00827 } 00828 else if( mnemonic == "sz"){ 00829 surface = new SphereSurface( Vector3d( 0, 0, args.at(0) ), args.at(1) ); 00830 } 00831 else if( mnemonic == "s" || mnemonic == "sph" ){ 00832 surface = new SphereSurface( Vector3d( args ), args.at(3) ); 00833 } 00834 else if( mnemonic == "sq" && sqIsEllipsoid(args) ){ 00835 surface = new EllipsoidSurface( Vector3d( args.at(7), args.at(8), args.at(9) ), Vector3d( args )* (-1/args.at(6)) ); 00836 } 00837 else if( mnemonic == "p"){ 00838 if( args.size() == 4 ){ 00839 // plane given as ABCD coefficients (Ax+By+Cz-D=0) 00840 Vector3d v(args); 00841 surface = new PlaneSurface( v, args.at(3)/v.length() ); 00842 } 00843 else if( args.size() == 9 ){ 00844 // plane is given at three points in space 00845 Vector3d v1(args), v2(args,3), v3(args,6); 00846 00847 // ordering of the points is arbitrary, but make sure v1 is furthest from origin. 00848 if( v1.length() < v2.length() ){ 00849 std::swap( v1, v2 ); 00850 } 00851 if( v1.length() < v3.length() ){ 00852 std::swap( v1, v3 ); 00853 } 00854 00855 // the normal (up to reversal) of the plane 00856 // The normal may need to be reversed to ensure that the origin 00857 // has negative sense, as required by MCNP 00858 Vector3d normal = v1.add(-v2).cross( v1.add(-v3) ).normalize(); 00859 00860 // If a ray started from the origin and followed the normal vector, 00861 // p is the point where it intersects the plane 00862 Vector3d p = normal.scale( v1.dot(normal) ); 00863 00864 // cos of the angle between v1 and normal 00865 double angle = normal.dot( v1.normalize() ); 00866 00867 // invert the normal if the angle is > 90 degrees, which indicates 00868 // that reversal is required. 00869 if( angle < 0 ){ 00870 normal = -normal; 00871 } 00872 00873 //std::cout << normal << " " << p.length() << " : " << angle << std::endl; 00874 surface = new PlaneSurface( normal, p.length() ); 00875 00876 00877 } 00878 else{ 00879 throw std::runtime_error( "P surface with unsupported number of params" ); 00880 } 00881 00882 } 00883 else if( mnemonic == "px"){ 00884 surface = new PlaneSurface( Vector3d( 1, 0, 0), args.at(0) ); 00885 } 00886 else if( mnemonic == "py"){ 00887 surface = new PlaneSurface( Vector3d( 0, 1, 0), args.at(0) ); 00888 } 00889 else if( mnemonic == "pz"){ 00890 surface = new PlaneSurface( Vector3d( 0, 0, 1), args.at(0) ); 00891 } 00892 else if( mnemonic == "cx" ){ 00893 surface = new CylinderSurface( X, args.at(0) ); 00894 } 00895 else if( mnemonic == "cy" ){ 00896 surface = new CylinderSurface( Y, args.at(0) ); 00897 } 00898 else if( mnemonic == "cz" ){ 00899 surface = new CylinderSurface( Z, args.at(0) ); 00900 } 00901 else if( mnemonic == "c/x"){ 00902 surface = new CylinderSurface( X, args.at(2), args.at(0), args.at(1) ); 00903 } 00904 else if( mnemonic == "c/y"){ 00905 surface = new CylinderSurface( Y, args.at(2), args.at(0), args.at(1) ); 00906 } 00907 else if( mnemonic == "c/z"){ 00908 surface = new CylinderSurface( Z, args.at(2), args.at(0), args.at(1) ); 00909 } 00910 #ifdef HAVE_IGEOM_CONE 00911 else if( mnemonic == "kx"){ 00912 double arg3 = ( args.size() == 3 ? args.at(2) : 0.0 ); 00913 surface = new ConeSurface( X, args.at(1), args.at(0), arg3 ); 00914 } 00915 else if( mnemonic == "ky"){ 00916 double arg3 = ( args.size() == 3 ? args.at(2) : 0.0 ); 00917 surface = new ConeSurface( Y, args.at(1), args.at(0), arg3 ); 00918 } 00919 else if( mnemonic == "kz"){ 00920 double arg3 = ( args.size() == 3 ? args.at(2) : 0.0 ); 00921 surface = new ConeSurface( Z, args.at(1), args.at(0), arg3 ); 00922 } 00923 else if( mnemonic == "k/x" ){ 00924 double arg5 = ( args.size() == 5 ? args.at(4) : 0.0 ); 00925 surface = new ConeSurface( X, args.at(3), Vector3d(args), arg5 ); 00926 } 00927 else if( mnemonic == "k/y" ){ 00928 double arg5 = ( args.size() == 5 ? args.at(4) : 0.0 ); 00929 surface = new ConeSurface( Y, args.at(3), Vector3d(args), arg5 ); 00930 } 00931 else if( mnemonic == "k/z" ){ 00932 double arg5 = ( args.size() == 5 ? args.at(4) : 0.0 ); 00933 surface = new ConeSurface( Z, args.at(3), Vector3d(args), arg5 ); 00934 } 00935 else if( mnemonic == "trc" ){ 00936 surface = new TrcVolume( Vector3d(args), Vector3d(args,3), args.at(6), args.at(7) ); 00937 } 00938 #endif /*HAVE_IGEOM_CONE */ 00939 else if( mnemonic == "tx" ){ 00940 surface = new TorusSurface( X, Vector3d(args), args.at(3), args.at(4), args.at(5) ); 00941 } 00942 else if( mnemonic == "ty" ){ 00943 surface = new TorusSurface( Y, Vector3d(args), args.at(3), args.at(4), args.at(5) ); 00944 } 00945 else if( mnemonic == "tz" ){ 00946 surface = new TorusSurface( Z, Vector3d(args), args.at(3), args.at(4), args.at(5) ); 00947 } 00948 else if( mnemonic == "box" ){ 00949 surface = new BoxVolume( Vector3d(args), Vector3d(args,3), Vector3d(args,6), Vector3d(args,9) ); 00950 } 00951 else if( mnemonic == "rpp" ){ 00952 surface = new RppVolume( Vector3d(args.at(0), args.at(2), args.at(4)), Vector3d(args.at(1), args.at(3), args.at(5)) ); 00953 } 00954 else if( mnemonic == "rcc" ){ 00955 surface = new RccVolume( Vector3d(args), Vector3d(args,3), args.at(6) ); 00956 } 00957 else if( mnemonic == "rec" ){ 00958 if( args.size() == 10 ){ 00959 surface = new RecVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6), args.at(9) ); 00960 } 00961 else{ 00962 surface = new RecVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6), Vector3d(args,9) ); 00963 } 00964 } 00965 else if( mnemonic == "hex" || mnemonic == "rhp" ){ 00966 if( args.size() == 9 ){ 00967 surface = new HexVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6) ); 00968 } 00969 else{ 00970 surface = new HexVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6), Vector3d(args,9), Vector3d(args,12) ); 00971 } 00972 } 00973 else if( mnemonic == "x" ) { 00974 switch (args.size()) { 00975 case 2: // plane 00976 surface = new PlaneSurface( Vector3d( 1, 0, 0), args.at(0) ); 00977 break; 00978 case 4: // either plane, cylinder or cone 00979 if ( args.at(0) == args.at(2) ) // plane 00980 surface = new PlaneSurface( Vector3d( 1, 0, 0), args.at(0) ); 00981 else if (args.at(1) == args.at(3)) // cylinder 00982 surface = new CylinderSurface( X, args.at(1) ); 00983 else // cone 00984 { 00985 double m = (args.at(3) - args.at(1))/(args.at(2)-args.at(0)); 00986 double apex_p = args.at(0) - args.at(1)/m; 00987 surface = new ConeSurface( X, m*m, apex_p, (m > 0 ? 1 : -1 ) ); 00988 } 00989 break; 00990 default: 00991 throw std::runtime_error( mnemonic + " is only a supported surface with 2 or 4 arguments" ); 00992 break; 00993 } 00994 } 00995 else if( mnemonic == "y" ) { 00996 switch (args.size()) { 00997 case 2: // plane 00998 surface = new PlaneSurface( Vector3d( 0, 1, 0), args.at(0) ); 00999 break; 01000 case 4: // either plane, cylinder or cone 01001 if ( args.at(0) == args.at(2) ) // plane 01002 surface = new PlaneSurface( Vector3d( 0, 1, 0), args.at(0) ); 01003 else if (args.at(1) == args.at(3)) // cylinder 01004 surface = new CylinderSurface( Y, args.at(1) ); 01005 else // cone 01006 { 01007 double m = (args.at(3) - args.at(1))/(args.at(2)-args.at(0)); 01008 double apex_p = args.at(0) - args.at(1)/m; 01009 surface = new ConeSurface( Y, m*m, apex_p, (m > 0 ? 1 : -1 ) ); 01010 } 01011 break; 01012 default: 01013 throw std::runtime_error( mnemonic + " is only a supported surface with 2 or 4 arguments" ); 01014 break; 01015 } 01016 } 01017 else if( mnemonic == "z" ) { 01018 switch (args.size()) { 01019 case 2: // plane 01020 surface = new PlaneSurface( Vector3d( 0, 0, 1), args.at(0) ); 01021 break; 01022 case 4: // either plane, cylinder or cone 01023 if ( args.at(0) == args.at(2) ) // plane 01024 surface = new PlaneSurface( Vector3d( 0, 0, 1), args.at(0) ); 01025 else if (args.at(1) == args.at(3)) // cylinder 01026 surface = new CylinderSurface( Z, args.at(1) ); 01027 else // cone 01028 { 01029 double m = (args.at(3) - args.at(1))/(args.at(2)-args.at(0)); 01030 double apex_p = args.at(0) - args.at(1)/m; 01031 surface = new ConeSurface( Z, m*m, apex_p, (m > 0 ? 1 : -1 ) ); 01032 } 01033 break; 01034 default: 01035 throw std::runtime_error( mnemonic + " is only a supported surface with 2 or 4 arguments" ); 01036 break; 01037 } 01038 } 01039 else{ 01040 throw std::runtime_error( mnemonic + " is not a supported surface" ); 01041 } 01042 01043 if( card->getTransform().hasData() ){ 01044 const Transform& transform = card->getTransform().getData(); 01045 surface->setTransform( &transform ); 01046 } 01047 01048 cache.insert( card, surface ); 01049 return *surface; 01050 01051 } 01052 01053 01054 } 01055 01056
