MeshKit
1.0
00001 #include "meshkit/AF2FreeZone.hpp" 00002 00003 #include <algorithm> 00004 #include <math.h> 00005 AF2FreeZone::AF2FreeZone( 00006 std::list<AF2Point2D> const & bndryPoints) : 00007 vertices(bndryPoints.begin(), bndryPoints.end()) 00008 { 00009 typedef std::list<AF2Point2D>::const_iterator ItrType; 00010 00011 // determine the bounding box 00012 minX = 0; 00013 maxX = 0; 00014 minY = 0; 00015 maxY = 0; 00016 bool isFirst = true; 00017 for (ItrType itr = vertices.begin(); itr != vertices.end(); ++itr) 00018 { 00019 if (isFirst) 00020 { 00021 minX = itr->getX(); 00022 maxX = itr->getX(); 00023 minY = itr->getY(); 00024 maxY = itr->getY(); 00025 isFirst = false; 00026 } 00027 else 00028 { 00029 minX = std::min(minX, itr->getX()); 00030 maxX = std::max(maxX, itr->getX()); 00031 minY = std::min(minY, itr->getY()); 00032 maxY = std::max(maxY, itr->getY()); 00033 } 00034 } 00035 00036 // determine the scale 00037 scale = std::max(maxX - minX, maxY - minY); 00038 scale = std::max(scale, fabs(maxX)); 00039 scale = std::max(scale, fabs(minX)); 00040 scale = std::max(scale, fabs(maxY)); 00041 scale = std::max(scale, fabs(minY)); 00042 } 00043 00044 bool AF2FreeZone::nearContains(AF2Point2D const & testPnt, 00045 bool const & containsBndry) const 00046 { 00047 // Remark: This method could execute faster if the class precomputed 00048 // and stored the coefficients needed for the comparisons. That is 00049 // how netgen version 5.2 did it. 00050 // The test point x-coefficient would be -rayYDiff. 00051 // The test point y-coefficient would be rayXDiff. 00052 // The constant would be ( -rayXDiff * itr->getY() ) + . . . 00053 // ( rayYDiff * itr->getX() ) 00054 00055 typedef std::list<AF2Point2D>::const_iterator ItrType; 00056 00057 // check whether the test point lies outside of the free zone bounding box 00058 if (testPnt.getX() < minX || testPnt.getX() > maxX || 00059 testPnt.getY() < minY || testPnt.getY() > maxY) 00060 { 00061 return false; 00062 } 00063 00064 // check whether the test point is clockwise (i.e., outside) relative 00065 // to one of the bounding line segments of the free zone 00066 for (ItrType itr = vertices.begin(); itr != vertices.end(); ++itr) 00067 { 00068 // if the parameter is defined such that the free zone should not 00069 // be considered to contain points approximately equal to its boundary 00070 // points, explicitly test whether the test point is approximately 00071 // equal to the boundary point, and, if so, count it as clockwise 00072 if (!containsBndry && nearEqual(testPnt, *itr)) 00073 { 00074 return false; 00075 } 00076 00077 // get an iterator pointing to the point after the current point, 00078 // wrapping around if necessary 00079 ItrType next = itr; 00080 ++next; 00081 if (next == vertices.end()) 00082 { 00083 next = vertices.begin(); 00084 } 00085 00086 // calculate the ray direction 00087 double rayXDiff = next->getX() - itr->getX(); 00088 double rayYDiff = next->getY() - itr->getY(); 00089 00090 // test whether the test point is clockwise from the ray from the 00091 // current point to the next point 00092 double testXDiff = (testPnt.getX() - itr->getX()); 00093 double testYDiff = (testPnt.getY() - itr->getY()); 00094 if (testYDiff*rayXDiff - rayYDiff*testXDiff < -1.0e-14*scale*scale) 00095 { 00096 // if this condition is true (test would be < 0 in perfect arithmetic, 00097 // but want to guarantee the point is outside here), then the 00098 // test point is clockwise from the ray 00099 // (== 0 would mean collinear in perfect arithmetic) 00100 return false; 00101 } 00102 } 00103 00104 return true; 00105 } 00106 00107 bool AF2FreeZone::nearEqual(AF2Point2D const & pointAlpha, 00108 AF2Point2D const & pointBravo) const 00109 { 00110 double xDiff = pointAlpha.getX() - pointBravo.getX(); 00111 double yDiff = pointAlpha.getY() - pointBravo.getY(); 00112 return xDiff*xDiff + yDiff*yDiff < 2.0e-28*scale*scale; 00113 } 00114 00115 bool AF2FreeZone::nearIntersects(AF2Point2D const & startPoint, 00116 AF2Point2D const & endPoint, bool const & containsBndry) const 00117 { 00118 // Remark: This method could execute faster if the class precomputed 00119 // and stored the coefficients needed for the comparisons. That is 00120 // how netgen version 5.2 did it. 00121 // The edge endpoints x-coefficient would be -rayYDiff. 00122 // The edge endpoints y-coefficient would be rayXDiff. 00123 // The constant would be ( -rayXDiff * itr->getY() ) + . . . 00124 // ( rayYDiff * itr->getX() ) 00125 00126 typedef std::list<AF2Point2D>::const_iterator ItrType; 00127 00128 // check whether both endpoints lie outside of the free zone bounding box 00129 if ((startPoint.getX() < minX && endPoint.getX() < minX) || 00130 (startPoint.getX() > maxX && endPoint.getX() > maxX) || 00131 (startPoint.getY() < minY && endPoint.getY() < minY) || 00132 (startPoint.getY() > maxY && endPoint.getY() > maxY)) 00133 { 00134 return false; 00135 } 00136 00137 // check whether both endpoints of the edge are clockwise (i.e., outside) 00138 // relative to one of the bounding line segments of the free zone 00139 for (ItrType itr = vertices.begin(); itr != vertices.end(); ++itr) 00140 { 00141 // get an iterator pointing to the point after the current point, 00142 // wrapping around if necessary 00143 ItrType next = itr; 00144 ++next; 00145 if (next == vertices.end()) 00146 { 00147 next = vertices.begin(); 00148 } 00149 00150 // establish offsets that can be used to avoid detecting intersections 00151 // with the boundary as intersections 00152 double startXOffset = 0.0; 00153 double startYOffset = 0.0; 00154 double endXOffset = 0.0; 00155 double endYOffset = 0.0; 00156 bool offsetStart = false; 00157 bool offsetEnd = false; 00158 00159 if (!containsBndry) 00160 { 00161 if (nearEqual(startPoint, *itr)) 00162 { 00163 if (nearEqual(endPoint, *next)) 00164 { 00165 // the query line segment matches a boundary line segment 00166 return false; 00167 } 00168 // the start point is approximately equal to a boundary point 00169 // so it should be offset in the direction of the end point 00170 offsetStart = true; 00171 } 00172 else if (nearEqual(startPoint, *next)) 00173 { 00174 if (nearEqual(endPoint, *itr)) 00175 { 00176 // the query line segment matches a boundary line segment 00177 return false; 00178 } 00179 // the start point is approximately equal to a boundary point 00180 // so it should be offset in the direction of the end point 00181 offsetStart = true; 00182 } 00183 else if (nearEqual(endPoint, *itr) || nearEqual(endPoint, *next)) 00184 { 00185 offsetEnd = true; 00186 } 00187 00188 if (offsetStart || offsetEnd) 00189 { 00190 double testSegXDiff = endPoint.getX() - startPoint.getX(); 00191 double testSegYDiff = endPoint.getY() - startPoint.getY(); 00192 double testSegLength = sqrt(testSegXDiff * testSegXDiff + 00193 testSegYDiff * testSegYDiff); 00194 if (testSegLength == 0) 00195 { 00196 testSegLength = 1.0; 00197 } 00198 // The offset amount affects which segment directions are acceptable 00199 // near the borderline. A factor of 2.0e-10 usually allows the 00200 // clockwise test to pass if the test segment makes an angle of more 00201 // than 1.0e-3 radians (in the appropriate direction) with the ray. 00202 if (offsetStart) 00203 { 00204 startXOffset = 2.0e-10 * scale * testSegXDiff / testSegLength; 00205 startYOffset = 2.0e-10 * scale * testSegYDiff / testSegLength; 00206 } 00207 if (offsetEnd) 00208 { 00209 endXOffset = -2.0e-10 * scale * testSegXDiff / testSegLength; 00210 endYOffset = -2.0e-10 * scale * testSegYDiff / testSegLength; 00211 } 00212 } 00213 } 00214 00215 // calculate the ray direction 00216 double rayXDiff = next->getX() - itr->getX(); 00217 double rayYDiff = next->getY() - itr->getY(); 00218 00219 // test whether the start point and end point are both clockwise from 00220 // the ray from the current point to the next point 00221 double startXDiff = (startPoint.getX() + startXOffset - itr->getX()); 00222 double startYDiff = (startPoint.getY() + startYOffset - itr->getY()); 00223 double endXDiff = (endPoint.getX() + endXOffset - itr->getX()); 00224 double endYDiff = (endPoint.getY() + endYOffset - itr->getY()); 00225 if ((startYDiff*rayXDiff - rayYDiff*startXDiff < -1.0e-14*scale*scale) && 00226 (endYDiff*rayXDiff - rayYDiff*endXDiff < -1.0e-14*scale*scale)) 00227 { 00228 // if these condition are true (test would be < 0 in perfect arithmetic, 00229 // but want to guarantee the point is outside here), then the 00230 // whole edge is clockwise from the ray 00231 // (== 0 would mean collinear in perfect arithmetic) 00232 return false; 00233 } 00234 } 00235 00236 // Check whether the whole free zone is either clockwise (right) or 00237 // counterclockwise (left) of the test line segment 00238 bool allCW = true; 00239 bool allCCW = true; 00240 // First calculate the x and y difference of the test line segment 00241 double testSegXDiff = (endPoint.getX() - startPoint.getX()); 00242 double testSegYDiff = (endPoint.getY() - startPoint.getY()); 00243 for (ItrType itr = vertices.begin(); 00244 itr != vertices.end() && (allCW || allCCW); ++itr) 00245 { 00246 00247 // calculate the difference from the start point to the 00248 // free zone vertex 00249 double fzvXDiff = itr->getX() - startPoint.getX(); 00250 double fzvYDiff = itr->getY() - startPoint.getY(); 00251 00252 // test whether the free zone vertex is clockwise from (right of) 00253 // the test line segment 00254 if (fzvYDiff*testSegXDiff - testSegYDiff*fzvXDiff > -1.0e-14*scale*scale) 00255 { 00256 // if this condition is true (test would be >= 0 in perfect arithmetic, 00257 // but want to guarantee the point is clockwise if the condition 00258 // is false), then the free zone vertex is (probably) not clockwise 00259 // from the test line segment. 00260 allCW = false; 00261 } 00262 00263 // test whether the free zone vertex is counterclockwise from (left of) 00264 // the test line segment 00265 if (fzvYDiff*testSegXDiff - testSegYDiff*fzvXDiff < 1.0e-14*scale*scale) 00266 { 00267 // if this condition is true (test would be <= 0 in perfect arithmetic, 00268 // but want to guarantee the point is counterclockwise if the condition 00269 // is false), then the free zone vertex is (probably) not 00270 // counterclockwise from the test line segment. 00271 allCCW = false; 00272 } 00273 } 00274 00275 return ( !allCW && !allCCW ); 00276 } 00277 00278 bool AF2FreeZone::isConvex() const 00279 { 00280 typedef std::list<AF2Point2D>::const_iterator ItrType; 00281 00282 for (ItrType itr = vertices.begin(); itr != vertices.end(); ++itr) 00283 { 00284 // get an iterator pointing to the point after the current point, 00285 // wrapping around if necessary 00286 ItrType next = itr; 00287 ++next; 00288 if (next == vertices.end()) 00289 { 00290 next = vertices.begin(); 00291 } 00292 00293 // calculate the ray direction 00294 double rayXDiff = next->getX() - itr->getX(); 00295 double rayYDiff = next->getY() - itr->getY(); 00296 00297 // test whether all other points are counterclockwise 00298 for (ItrType testPnt = vertices.begin(); 00299 testPnt != vertices.end(); ++testPnt) 00300 { 00301 // skip the test if the test point is the current point or the next point 00302 if ((*testPnt) == (*itr) || (*testPnt) == (*next)) 00303 { 00304 continue; 00305 } 00306 00307 // test that the test point is counterclockwise from the ray from the 00308 // current point to the next point 00309 double testXDiff = (testPnt->getX() - itr->getX()); 00310 double testYDiff = (testPnt->getY() - itr->getY()); 00311 if (testYDiff*rayXDiff - rayYDiff*testXDiff < -1.0e-14*scale*scale) 00312 { 00313 // if this condition is true (test would be < 0 in perfect arithmetic), 00314 // then the test point is clockwise from the ray 00315 // (== 0 would mean collinear in perfect arithmetic) 00316 return false; 00317 } 00318 } 00319 } 00320 00321 return true; 00322 }
