MeshKit
1.0
00001 #include "meshkit/AF2Neighborhood.hpp" 00002 00003 // MeshKit 00004 #include "meshkit/Error.hpp" 00005 00006 // C++ 00007 #include <set> 00008 00009 AF2Neighborhood::AF2Neighborhood(const std::list<AF2Point3D*> & points, 00010 AF2Edge3D* baselineEdge, 00011 const std::list<const AF2Edge3D*> & otherEdges, 00012 const AF2LocalTransform* localTransformArg) 00013 { 00014 typedef std::list<AF2Point3D*>::const_iterator ConstPoint3DItr; 00015 typedef std::list<const AF2Edge3D*>::const_iterator ConstEdge3DItr; 00016 typedef std::map<AF2Point3D*, const AF2Point2D*>::const_iterator MapItr; 00017 00018 std::set<AF2Point3D*> illegalPoints; 00019 00020 baseEdge3D = baselineEdge; 00021 localTransform = localTransformArg; 00022 00023 for (ConstPoint3DItr itr = points.begin(); itr != points.end(); ++itr) 00024 { 00025 bool legal = true; 00026 AF2Point2D* point2D = localTransform->transformFromSurface(**itr, legal); 00027 if (legal) 00028 { 00029 points2D.push_back(point2D); 00030 map2DTo3D[point2D] = *itr; 00031 } 00032 else 00033 { 00034 illegalPoints.insert(*itr); 00035 } 00036 map3DTo2D[*itr] = point2D; 00037 } 00038 00039 MapItr baseStartItr = map3DTo2D.find(baselineEdge->getStart()); 00040 MapItr baseEndItr = map3DTo2D.find(baselineEdge->getEnd()); 00041 if (baseStartItr == map3DTo2D.end() || baseEndItr == map3DTo2D.end()) 00042 { 00043 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00044 badArg.set_string( 00045 "A baseline edge endpoint is not listed in the neighborhood points."); 00046 throw badArg; 00047 } 00048 baseEdge2D = new AF2Edge2D(baseStartItr->second, baseEndItr->second); 00049 edges2D.push_back(baseEdge2D); 00050 00051 for (ConstEdge3DItr itr = otherEdges.begin(); 00052 itr != otherEdges.end(); ++itr) 00053 { 00054 if (*itr == baselineEdge) 00055 { 00056 // the baseline edge should be listed only once (and listed first) 00057 // in the list of edges 00058 continue; 00059 } 00060 MapItr startItr = map3DTo2D.find((*itr)->getStart()); 00061 MapItr endItr = map3DTo2D.find((*itr)->getEnd()); 00062 if (startItr == map3DTo2D.end() || endItr == map3DTo2D.end()) 00063 { 00064 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00065 badArg.set_string( 00066 "An edge endpoint is not listed in the neighborhood points."); 00067 throw badArg; 00068 } 00069 if ((illegalPoints.find((*itr)->getStart()) != illegalPoints.end()) || 00070 (illegalPoints.find((*itr)->getEnd()) != illegalPoints.end())) 00071 { 00072 // Don't create an edge if its endpoints are illegal 00073 // TODO: Decide whether there is something better to do if one endpoint 00074 // is legal and the other is not legal 00075 continue; 00076 } 00077 const AF2Edge2D* edge2D = 00078 new AF2Edge2D(startItr->second, endItr->second); 00079 edges2D.push_back(edge2D); 00080 } 00081 } 00082 00083 AF2Neighborhood::~AF2Neighborhood() 00084 { 00085 typedef std::list<const AF2Point2D*>::const_iterator ConstPoint2DItr; 00086 typedef std::list<const AF2Edge2D*>::const_iterator ConstEdge2DItr; 00087 00088 for (ConstEdge2DItr itr = edges2D.begin(); itr != edges2D.end(); ++itr) 00089 { 00090 delete *itr; 00091 } 00092 for (ConstPoint2DItr itr = points2D.begin(); itr != points2D.end(); ++itr) 00093 { 00094 delete *itr; 00095 } 00096 delete localTransform; 00097 } 00098 00099 AF2Neighborhood::AF2Neighborhood(const AF2Neighborhood & toCopy) 00100 { 00101 MeshKit::Error notImpl(MeshKit::MK_NOT_IMPLEMENTED); 00102 notImpl.set_string("AF2Neighborhood copy construction is not supported."); 00103 throw notImpl; 00104 } 00105 00106 AF2Neighborhood& AF2Neighborhood::operator=(const AF2Neighborhood & rhs) 00107 { 00108 MeshKit::Error notImpl(MeshKit::MK_NOT_IMPLEMENTED); 00109 notImpl.set_string("AF2Neighborhood assignment operator is not supported."); 00110 throw notImpl; 00111 } 00112 00113 const AF2Edge2D* AF2Neighborhood::getBaselineEdge2D() const 00114 { 00115 return baseEdge2D; 00116 } 00117 00118 AF2Edge3D* AF2Neighborhood::getBaselineEdge3D() const 00119 { 00120 return baseEdge3D; 00121 } 00122 00123 AF2Point3D* AF2Neighborhood::getCorrespondingPoint( 00124 const AF2Point2D* const & ngbhdPoint2D) const 00125 { 00126 typedef std::map<const AF2Point2D*, AF2Point3D*>::const_iterator MapItr; 00127 MapItr ngbhdPntItr = map2DTo3D.find(ngbhdPoint2D); 00128 if (ngbhdPntItr == map2DTo3D.end()) 00129 { 00130 return NULL; 00131 } 00132 return ngbhdPntItr->second; 00133 } 00134 00135 const std::list<const AF2Edge2D*>* AF2Neighborhood::getEdges2D() const 00136 { 00137 return &edges2D; 00138 } 00139 00140 const std::list<const AF2Point2D*>* AF2Neighborhood::getPoints2D() const 00141 { 00142 return &points2D; 00143 } 00144 00145 AF2Point3D* AF2Neighborhood::transformPoint( 00146 const AF2Point2D* const & point2D, unsigned long const & pntId) const 00147 { 00148 return localTransform->transformToSurface(*point2D, pntId); 00149 }
