MeshKit
1.0
00001 #include "meshkit/AF2Polygon2D.hpp" 00002 #include "meshkit/Error.hpp" 00003 00004 AF2Polygon2D::AF2Polygon2D( 00005 std::list<const AF2Point2D*> const & polygonVertices) : 00006 numVertices(polygonVertices.size()) 00007 { 00008 typedef std::list<const AF2Point2D*>::const_iterator ItrType; 00009 00010 // check for the exceptional case of a null pointer in the list of vertices 00011 for (ItrType itr = polygonVertices.begin(); 00012 itr != polygonVertices.end(); ++itr) 00013 { 00014 if (*itr == NULL) 00015 { 00016 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00017 badArg.set_string( 00018 "polygonVertices may not contain a null pointer in AF2Polygon2D."); 00019 throw badArg; 00020 } 00021 } 00022 00023 // allocate memory and copy the vertex pointers 00024 vertices = new const AF2Point2D*[numVertices]; 00025 int indx = 0; 00026 for (ItrType itr = polygonVertices.begin(); 00027 itr != polygonVertices.end(); ++itr) 00028 { 00029 vertices[indx] = *itr; 00030 ++indx; 00031 } 00032 } 00033 00034 AF2Polygon2D::~AF2Polygon2D() 00035 { 00036 delete[] vertices; 00037 } 00038 00039 AF2Polygon2D::AF2Polygon2D(const AF2Polygon2D & toCopy) : 00040 numVertices(toCopy.numVertices) 00041 { 00042 vertices = new const AF2Point2D*[numVertices]; 00043 for (unsigned int indx = 0; indx < numVertices; ++indx) 00044 { 00045 vertices[indx] = toCopy.vertices[indx]; 00046 } 00047 } 00048 00049 AF2Polygon2D& AF2Polygon2D::operator=(const AF2Polygon2D & rhs) 00050 { 00051 // directly copy the number of vertices 00052 numVertices = rhs.numVertices; 00053 00054 // allocate new array in temporary location 00055 // and copy the pointers into the temporary array 00056 const AF2Point2D** tempVertices = new const AF2Point2D*[numVertices]; 00057 for (unsigned int indx = 0; indx < numVertices; ++indx) 00058 { 00059 tempVertices[indx] = rhs.vertices[indx]; 00060 } 00061 00062 // delete what used to be held by the array of vertices 00063 // (may be null if default constructor was used) 00064 delete[] vertices; 00065 00066 // transfer ownership from the temporary array to a member of this object 00067 vertices = tempVertices; 00068 tempVertices = NULL; // not necessary, but to be explicit 00069 00070 return *this; 00071 } 00072 00073 unsigned int AF2Polygon2D::getNumVertices() const 00074 { 00075 return numVertices; 00076 } 00077 00078 const AF2Point2D* AF2Polygon2D::getVertex(unsigned int vtxNum) const 00079 { 00080 if (vtxNum >= numVertices) 00081 { 00082 MeshKit::Error badArg(MeshKit::MK_BAD_INPUT); 00083 badArg.set_string("The vertex index is too large."); 00084 throw badArg; 00085 } 00086 return vertices[vtxNum]; 00087 }
