MeshKit
1.0
00001 // IAMilp.hpp 00002 // Interval Assignment for Meshkit 00003 // 00004 // This is the solver-translation from Meshkit to the GLPK library 00005 // for solving the MILP (integer solution, no fractional intervals) 00006 // 00007 00008 #ifndef MESHKIT_IA_IAMILP_HP 00009 #define MESHKIT_IA_IAMILP_HP 00010 00024 #include <vector> 00025 00026 #incude "IAWeights.hpp" 00027 00028 // forward declarations 00029 class IAData; 00030 class IASolution; 00031 class GlpRepresentation; 00032 00033 class IAMilp 00034 { 00035 public: 00037 // on input, solution_ptr contains a non-integer solution to the interval assignment problem 00038 IAMilp(const IAData *data_ptr, IASolution *solution_ptr); 00039 00041 virtual ~IAMilp(); 00042 00043 // Find an integer solution. 00044 // on completion, the integer solution is placed into the solution_ptr that was passed to the constructor 00045 bool solve(); 00046 00047 private: 00048 // hide untrusted default methods 00050 // IA_NLP(); 00051 IAMilp(); 00052 IAMilp(const IAMilp&); 00053 IAMilp& operator=(const IAMilp&); 00055 00056 // input data 00057 const IAData *data; 00058 // solution data 00059 IASolution *solution; 00060 00061 // scratch space 00062 // objective weights of deltas 00063 IAWeights weights_plus; 00064 IAWeights weights_minus; 00065 00066 const bool debugging; 00067 00068 // much roundoff is tolerated before treating it as integer or satisfied 00069 const double constraint_tolerance; 00070 const double integrality_tolerance; 00071 00072 // glpk-implementation specific 00073 GlpRepresentation *lp; 00074 bool naturalConstraintsSet; 00075 bool deltasSet; 00076 bool weightsSet; 00077 bool maxesSet; 00078 bool solved; 00079 00080 // translate our indices to glpk indexing 00081 int xStart; // column index 00082 int x_i(int i); // glpk index for curve_i 00083 int deltaStart; // column index 00084 int delta_plus_i(int i); // glpk col index for curve_i's value above its goal 00085 int delta_minus_i(int i);// glpk col index for curve_i's value below its goal 00086 int deltaConstraintStart; // first row index of constraint that forces x_i - I_i = p_i - n_i 00087 int delta_j(int j); // continuation of above 00088 int mwp_i; // column index of maximum of weighted delta_plus variable 00089 int mwp_j; // first row index of constraint that calculates mwp variable 00090 int mwm_i; // column index of maximum of weighted deltas_minus variable 00091 int mwm_j; // first row index of constraint that calculates mwm variable 00092 int mw_i; // column index of maximum of weighted deltas_minus variable 00093 int mw_j; // row index of constaint that calculates mw > mwp variable, mw_j+1 calcs mw > mwm 00094 00095 // substeps in setting up and solving the solution 00096 bool create_problem(); 00097 bool destroy_problem(); 00098 bool set_natural_constraints(); 00099 bool set_deltas(); 00100 bool weight_deltas_1(); 00101 bool set_maxes(); 00102 bool set_objectives_1(); 00103 bool set_sum_even_constratins(); 00104 bool set_bounds_1(); 00105 bool set_bounds_2(); 00106 bool set_bounds_3(); 00107 bool set_bounds_4(); 00108 bool set_bounds_A(); 00109 bool set_bounds_B(); 00110 bool glpk_solve(bool &optimal); 00111 bool get_solution(); 00112 bool solution_is_integer(); 00113 bool solution_satisfies_constraints(); 00114 void print_constraint(int j); 00115 void print_solution(int i); 00116 00117 00118 00119 // utilities 00120 // fill with [I,x_solution] or [x_solution,I], depending on which is smaller and defines a proper interval 00121 void get_x_bounds(const int i, double &lobound, double &hibound); 00122 }; 00123 00124 #endif
