MeshKit
1.0
00001 // IANnl.hpp 00002 // Interval Assignment for Meshkit 00003 // 00004 // This is the solver-translation from Meshkit to the ipopt library 00005 // Here we provide the functions that ipopt needs to solve the optimization problem 00006 // 00007 // Adapted from: 00008 // Copyright (C) 2005, 2007 International Business Machines and others. 00009 // All Rights Reserved. 00010 // This code is published under the Eclipse Public License. 00011 // 00012 // $Id: hs071_nlp.hpp 1864 2010-12-22 19:21:02Z andreasw $ 00013 // 00014 // Authors: Carl Laird, Andreas Waechter IBM 2005-08-09 00015 00016 #ifndef MESHKIT_IA_IANLP_HP 00017 #define MESHKIT_IA_IANLP_HP 00018 00046 #include "MKVersion.h" 00047 00048 #include "IpTNLP.hpp" 00049 //using namespace Ipopt; 00050 using Ipopt::Index; 00051 using Ipopt::Number; 00052 using Ipopt::SolverReturn; 00053 using Ipopt::IpoptData; 00054 using Ipopt::IpoptCalculatedQuantities; 00055 using Ipopt::TNLP; 00056 // IndexStyleEnum defined by Ipopt in global space 00057 00058 namespace MeshKit 00059 { 00060 00061 class IAData; 00062 class IASolution; 00063 00064 class IANlp : public TNLP 00065 { 00066 public: 00068 IANlp(const IAData *data_ptr, IASolution *solution_ptr, const bool set_silent = true); 00069 00071 virtual ~IANlp(); 00072 00076 virtual bool get_nlp_info(Index& n, Index& m, Index& nnz_jac_g, 00077 Index& nnz_h_lag, IndexStyleEnum& index_style); 00078 00080 virtual bool get_bounds_info(Index n, Number* x_l, Number* x_u, 00081 Index m, Number* g_l, Number* g_u); 00082 00084 virtual bool get_starting_point(Index n, bool init_x, Number* x_init, 00085 bool init_z, Number* z_L, Number* z_U, 00086 Index m, bool init_lambda, 00087 Number* lambda); 00088 00090 virtual bool eval_f(Index n, const Number* x, bool new_x, Number& obj_value); 00091 00093 virtual bool eval_grad_f(Index n, const Number* x, bool new_x, Number* grad_f); 00094 00096 virtual bool eval_g(Index n, const Number* x, bool new_x, Index m, Number* g); 00097 00102 virtual bool eval_jac_g(Index n, const Number* x, bool new_x, 00103 Index m, Index nele_jac, Index* iRow, Index *jCol, 00104 Number* values); 00105 00110 virtual bool eval_h(Index n, const Number* x, bool new_x, 00111 Number obj_factor, Index m, const Number* lambda, 00112 bool new_lambda, Index nele_hess, Index* iRow, 00113 Index* jCol, Number* values); 00114 00116 00120 virtual void finalize_solution(SolverReturn status, 00121 Index n, const Number* x, const Number* z_L, const Number* z_U, 00122 Index m, const Number* g, const Number* lambda, 00123 Number obj_value, 00124 const IpoptData *ip_data, 00125 IpoptCalculatedQuantities* ip_cq); 00127 00128 // Common routines, could be used by other Nlp's 00129 int get_neleJac() const { return neleJac; } 00130 00131 // return the value of the ith sum-even constraint, given current values of x 00132 double eval_even_sum(const int i, const Number* x) const; 00133 00134 // return the value of the ith sum-equal constraint, given current values of x 00135 double eval_equal_sum(const int i, const Number* x) const; 00136 00137 private: 00138 // hide untrusted default methods 00140 // IA_NLP(); 00141 IANlp(); 00142 IANlp(const IANlp&); 00143 IANlp& operator=(const IANlp&); 00145 00146 // input data 00147 const IAData *data; 00148 static const int p_norm; 00149 // solution data 00150 IASolution *solution; 00151 int neleJac; 00152 00153 const bool silent; 00154 const bool debugging; 00155 const bool verbose; // verbose debugging 00156 00157 // internally used methods 00158 // contributions of one variable to the objective function and gradient 00159 // underlying function 00160 00161 00162 // r functions: if x>I then x-I / I else I-x / x 00163 static Number eval_r_i(const Number& I_i, const Number& x_i); 00164 static Number eval_grad_r_i(const Number& I_i, const Number& x_i); 00165 static Number eval_hess_r_i(const Number& I_i, const Number& x_i); 00166 00167 // s functions: r weighted by x: r*x 00168 static Number eval_s_i(const Number& I_i, const Number& x_i); 00169 static Number eval_grad_s_i(const Number& I_i, const Number& x_i); 00170 static Number eval_hess_s_i(const Number& I_i, const Number& x_i); 00171 00172 // Capital functions, l-p norms of the lowercase functions 00173 public: 00174 static Number eval_R_i(const Number& I_i, const Number& x_i); 00175 private: 00176 static Number eval_grad_R_i(const Number& I_i, const Number& x_i); 00177 static Number eval_hess_R_i(const Number& I_i, const Number& x_i); 00178 00179 static Number eval_S_i(const Number& I_i, const Number& x_i); 00180 static Number eval_grad_S_i(const Number& I_i, const Number& x_i); 00181 static Number eval_hess_S_i(const Number& I_i, const Number& x_i); 00182 00183 00184 }; 00185 00186 } // namespace MeshKit 00187 00188 #endif
