MeshKit
1.0
00001 // IARoundingFarNlp.cpp 00002 // Interval Assignment for Meshkit 00003 // 00004 // Adapted from 00005 // Copyright (C) 2005, 2006 International Business Machines and others. 00006 // All Rights Reserved. 00007 // This code is published under the Eclipse Public License. 00008 // 00009 // $Id: hs071_nlp.cpp 1864 2010-12-22 19:21:02Z andreasw $ 00010 // 00011 // Authors: Carl Laird, Andreas Waechter IBM 2005-08-16 00012 00013 #include "meshkit/IARoundingFarNlp.hpp" 00014 #include "meshkit/IARoundingNlp.hpp" 00015 #include "meshkit/IAData.hpp" 00016 #include "meshkit/IPData.hpp" 00017 #include "meshkit/IASolution.hpp" 00018 #include "meshkit/IANlp.hpp" 00019 00020 #include <math.h> 00021 #include <algorithm> 00022 00023 // for printf 00024 #ifdef HAVE_CSTDIO 00025 # include <cstdio> 00026 #else 00027 # ifdef HAVE_STDIO_H 00028 # include <stdio.h> 00029 # else 00030 # error "don't have header file for stdio" 00031 # endif 00032 #endif 00033 00034 /* Idea: a form of IARoundingNlp with larger variable bounds, but still with a natural integer solution. 00035 x in [1..inf] 00036 xr = x optimal relaxed solution with objective function fnlp, see IANlp.xpp 00037 f is piecewise linear, with corners at integer values. f slopes are unique (we hope) 00038 Slope definitions 00039 for x between xl = floor xr and xh = ceil xr, we use the difference in fnlp between xl and xh 00040 00041 case A. xr > ceil g, g is goal I[i] 00042 for x above xh, 00043 let h+ be fnlp ( xh+1 ) - fnlp ( xh ) 00044 let kp be the number of intervals x is above xh 00045 then slope = floor kp * h+ 00046 for x below xl, h- = sqrt(11) / 5 h+, and slope = floor km * h- 00047 all this is weighted by some unique weight 00048 00049 case B. xr in [ floor g, ceil g] 00050 h+ = fnlp ( xh+1 ) - fnlp ( xh ) 00051 h- = fnlp ( xl-1 ) - fnlp ( xl ), not used if xl == 1 00052 00053 case C. xr < floor g 00054 h- = fnlp ( xl-1 ) - fnlp ( xl ) 00055 h+ = sqrt(10)/5 h- 00056 If g < 2, then h- is unused, and h+ = as in case B 00057 00058 // representation: 00059 h0 is weights 0..n-1 00060 h+ is weights n..2n-1 00061 h- is weights 2n.. 00062 00063 */ 00064 00065 00066 // to do 00067 // set h 00068 // uniquify h initially 00069 // randomize h if solution is non-integer 00070 // compute f 00071 // compute f' 00072 // compute f'' == 0 00073 00074 // clean up 00075 // move the re-used part of IANlp, dealing with constraints but not obj, to some underlying class, without it being a TNLP 00076 00077 00078 // the objective function we should use for deriving the weights 00079 double IARoundingFarNlp::f_x_value( double I_i, double x_i ) const 00080 { 00081 // to do revise 00082 return x_i > I_i ? 00083 (x_i - I_i) / I_i : 00084 1.103402234045 * (I_i - x_i) / x_i; 00085 } 00086 00087 // destructor 00088 IARoundingFarNlp::~IARoundingFarNlp() 00089 { 00090 data = NULL; 00091 ipData = NULL; 00092 solution = NULL; 00093 } 00094 00095 // constructor 00096 IARoundingFarNlp::IARoundingFarNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr): 00097 data(data_ptr), ipData(ip_data_ptr), solution(solution_ptr), baseNlp(data_ptr, solution_ptr), 00098 debugging(true), verbose(true) // true 00099 { 00100 printf("\nIARoundingFarNlp Problem:\n"); 00101 00102 // weights for function value 00103 h0.resize(data->num_variables()); 00104 hp.resize(data->num_variables()); 00105 hm.resize(data->num_variables()); 00106 for (int i = 0; i < data->num_variables(); ++i) 00107 { 00108 const double x = ipData->relaxedSolution[i]; 00109 const double xl = floor(x); 00110 const double xh = xl + 1; 00111 const double g = data->I[i]; // goal 00112 00113 const double fl = f_x_value(g, xl); 00114 const double fh = f_x_value(g, xh); 00115 const double w = fh - fl; 00116 h0[i] = w; 00117 00118 // use sqrt(3) to ensure hp and hm is larger than h0 00119 const double fp = sqrt(3) * (f_x_value(g,xh+1) - f_x_value(g,xh)); 00120 double fm = 0.; 00121 00122 if (xl > 1) 00123 { 00124 fm = sqrt(5) * (f_x_value(g,xl) - f_x_value(g,xl-1)); 00125 } 00126 else // if (xl == 1) 00127 { 00128 // unused anyway, assign it something that won't screw up the distribution 00129 fm = - sqrt(5) * fabs(f_x_value(g,2) - f_x_value(g,1)); 00130 } 00131 00132 // case A 00133 if ( x > ceil(g) ) 00134 { 00135 hp[i] = fp; 00136 hm[i] = -fp * sqrt(11) / 5.; 00137 assert( fabs(hm[i]) < fabs(hp[i]) ); 00138 } 00139 // case B 00140 else if ( x >= floor(g) ) 00141 { 00142 hp[i] = fp; 00143 hm[i] = fm; 00144 } 00145 // case C 00146 else // x < floor(g) 00147 { 00148 hm[i] = fm; 00149 hp[i] = -fm * sqrt(7) / 3.; 00150 assert( fabs(hm[i]) > fabs(hp[i]) ); 00151 } 00152 00153 // invariants for all cases, to produce a super-linear preference for xl or xh 00154 assert( hp[i] > 0 ); 00155 assert( hp[i] > h0[i] ); 00156 assert( hm[i] < 0 ); 00157 assert( hm[i] < h0[i] ); 00158 00159 /* 00160 //zzyk experiment with limited f' discontinuity 00161 // this makes hp < 0 and hm > 0 sometimes, so watch the other asserts 00162 if ( h0[i] > 0 ) 00163 { 00164 hp[i] = h0[i]*2.; 00165 hm[i] = h0[i]*0.5; 00166 } 00167 else 00168 { 00169 hp[i] = h0[i]*0.5; 00170 hm[i] = h0[i]*2.; 00171 } 00172 */ 00173 00174 if (0 && debugging) 00175 printf(": %f %f %f", h0[i], hp[i], hm[i]); // 0th+/i, first should be positive, second negative 00176 } 00177 00178 // uniquify and scale the weights = slopes 00179 const double h0_lo = 1; 00180 const double h0_hi = h0_lo * (10 + 2 * data->num_variables()); 00181 // uniquify preserving h0 < hm, hp 00182 if (0) 00183 { 00184 // todo experiment with ranges 00185 // want the largest h0 to be less then the smallest hp or hm, in absolute value 00186 // so that a simple rounding from the relaxed solution is optimal, if feasible 00187 // 1.e4? 1.e3 makes the jumps in values wash out for the big chain problem, need some jumps? 00188 // idea, dynamically scale this based on the problem size, h0_hi = 2*num_variables; 00189 const double hpm_lo = h0_hi + 1.; 00190 const double hpm_hi = 1.e5; 00191 h0.uniquify(h0_lo, h0_hi); 00192 00193 // uniquify and scale hp hm to come after h0 00194 IAWeights hpm(); 00195 hpm = hp; // hpm = hp 00196 hpm.insert( hpm.end(), hm.begin(), hm.end() ); // hmp += hm 00197 hpm.uniquify(hpm_lo, hpm_hi); 00198 hp.assign(hpm.begin(), hpm.begin()+hp.size()); // extract hp 00199 hm.assign(hpm.begin()+hp.size(), hpm.end()); // extract hm 00200 } 00201 // uniquify lumping h0 with hm and hp 00202 else { 00203 h0.uniquify(h0, h0_lo, h0_hi); 00204 00205 // uniquify and scale hp hm to come after h0 00206 IAWeights h0pm; 00207 hpm = h0; // h0pm = h0 00208 h0pm.insert( h0pm.end(), hp.begin(), hp.end() ); // h0pm += hp 00209 h0pm.insert( h0pm.end(), hm.begin(), hm.end() ); // h0pm += hm 00210 h0pm.uniquify(h0_lo, h0_hi); 00211 const size_t sz = data->num_variables(); 00212 h0.assign(h0pm.begin(), h0pm.begin()+sz); // extract h0 00213 hp.assign(h0pm.begin()+sz, h0pm.begin()+2*sz); // extract hp 00214 hm.assign(h0pm.begin()+2*sz, h0pm.end()); // extract hm 00215 00216 } 00217 00218 if (debugging) 00219 { 00220 printf("\n"); 00221 for (int i = 0; i < data->num_variables(); ++i) 00222 { 00223 const double x = ipData->relaxedSolution[i]; 00224 printf("x %d (relaxed %f, goal %e), h0 %10.4f hp %10.4f hm %10.4f\n", i, x, data->I[i], h0[i], hp[i], hm[i]); 00225 } 00226 } 00227 } 00228 00229 00230 // returns the size of the problem 00231 bool IARoundingFarNlp::get_nlp_info(Index& n, Index& m, Index& nnz_jac_g, 00232 Index& nnz_h_lag, IndexStyleEnum& index_style) 00233 { 00234 bool base_ok = baseNlp.get_nlp_info(n, m, nnz_jac_g, nnz_h_lag, index_style); 00235 nnz_h_lag = 0; // obj is piecewise linear. We could define h near the corners, but lets try zero first. nele_hess 00236 return true && base_ok; 00237 // need to change this if there are more variables, such as delta-minuses 00238 } 00239 00240 // returns the variable bounds 00241 bool IARoundingFarNlp::get_bounds_info(Index n, Number* x_l, Number* x_u, 00242 Index m, Number* g_l, Number* g_u) 00243 { 00244 const bool base_ok = baseNlp.get_bounds_info(n, x_l, x_u, m, g_l, g_u); 00245 00246 // test various ranges 00247 /* 00248 for (Index i=0; i<n; ++i) 00249 { 00250 */ 00251 00252 /* 00253 // debug: x in [xl-1, xh+1] 00254 const double x = ipData->relaxedSolution[i]; 00255 const double xl = floor(x); 00256 assert(xl >= 1.); 00257 if (xl > 1) 00258 x_l[i] = xl-1; 00259 else 00260 x_l[i] = 1; 00261 x_u[i] = xl + 2; 00262 */ 00263 00264 /* 00265 // debug: x in [xl,xh] 00266 x_l[i] = xl; 00267 x_u[i] = xl + 1.; 00268 */ 00269 00270 //if (debugging) 00271 // printf("x %d (%f) in [%d,%d]\n", i, x, (int) x_l[i], (int) x_u[i]); 00272 00273 /* 00274 } 00275 */ 00276 00277 return base_ok && true; 00278 } 00279 00280 // returns the initial point for the problem 00281 bool IARoundingFarNlp::get_starting_point(Index n, bool init_x, Number* x_init, 00282 bool init_z, Number* z_L, Number* z_U, 00283 Index m, bool init_lambda, 00284 Number* lambda) 00285 { 00286 // Minimal info is starting values for x, x_init 00287 // Improvement: we can provide starting values for the dual variables if we wish 00288 assert(init_x == true); 00289 assert(init_z == false); 00290 assert(init_lambda == false); 00291 00292 // initialize x to the relaxed solution 00293 for (Index i=0; i<n; ++i) 00294 { 00295 x_init[i] = ipData->relaxedSolution[i]; 00296 } 00297 00298 return true; 00299 } 00300 00301 inline 00302 double IARoundingFarNlp::get_f_xl(int i) const 00303 { 00304 return (h0[i] > 0.) ? 0. : -h0[i]; 00305 } 00306 00307 inline 00308 double IARoundingFarNlp::get_f_xh(int i) const 00309 { 00310 return (h0[i] > 0.) ? h0[i] : 0.; 00311 } 00312 00313 00314 // returns the value of the objective function 00315 bool IARoundingFarNlp::eval_f(Index n, const Number* x, bool new_x, Number& obj_value) 00316 { 00317 assert(n == data->num_variables()); 00318 00319 double obj = 0.; 00320 for (Index i = 0; i<n; ++i) 00321 { 00322 // find which interval we're in 00323 const double xl = ipData->get_xl(i); 00324 const double xh = xl + 1; 00325 const double x_i = x[i]; 00326 00327 double obj_i(-1.); // bad value 00328 if (x_i >xh) // above xh 00329 { 00330 // the slope of the kth interval is k hp[i] 00331 // f = f(xh) + sum_{k=1:kp} k hp + kp_frac (kp+1) hp 00332 // = f(xh) + kp (kp+1) / 2 hp + kp_frac (kp+1) hp 00333 // = f(xh) + hp (kp+1) (kp_frac + kp / 2 ) 00334 int kp_int; 00335 double kp_frac; 00336 ipData->get_kp(i, x_i, kp_int, kp_frac); 00337 obj_i = get_f_xh(i) + hp[i] * (kp_int + 1) * (kp_frac + ((double) kp_int) / 2.); 00338 assert(obj_i >= 0.); 00339 } 00340 else if (x_i < xl) // below xl 00341 { 00342 // the slope of the kth interval is k hm[i] 00343 // f = f(xl) + sum_{k=1:km} k hm + km_frac (km+1) hm 00344 // = f(xl) + km (km+1) / 2 hm + km_frac (km+1) hm 00345 // = f(xl) + hm (km+1) (k_frac + km / 2 ) 00346 int km_int; 00347 double km_frac; 00348 ipData->get_km(i, x_i, km_int, km_frac); 00349 obj_i = get_f_xl(i) + fabs(hm[i]) * (km_int + 1) * (km_frac + ((double) km_int) / 2.); 00350 assert(obj_i >= 0.); 00351 } 00352 else // middle 00353 { 00354 // zzyk - testing truncating x within an interval around xl, continuity 00355 /* 00356 static double max_over = 0.; 00357 static double max_under = 0.; 00358 00359 if (x_i < xl) 00360 { 00361 if ( xl - x_i > max_under ) 00362 { 00363 max_under = xl - x_i; 00364 printf("max under %g\n", max_under); 00365 } 00366 x_i = xl; 00367 } 00368 else if (x_i > xh) 00369 { 00370 if ( x_i - xh > max_over ) 00371 { 00372 max_over = x_i - xh; 00373 printf("max OVER %g\n", max_over); 00374 } 00375 x_i = xh; 00376 } */ 00377 00378 obj_i = (h0[i] > 0) ? h0[i] * ( x_i - xl ) : -h0[i] * ( xh - x_i ); 00379 assert(obj_i >= 0.); 00380 00381 } 00382 assert(obj_i >= 0.); 00383 00384 obj += obj_i; 00385 } 00386 assert(obj >= 0.); 00387 obj_value = obj; 00388 printf(" %f", obj_value); // debug progress, is this going anywhere? 00389 00390 return true; 00391 } 00392 00393 // return the gradient of the objective function grad_{x} f(x) 00394 bool IARoundingFarNlp::eval_grad_f(Index n, const Number* x, bool new_x, Number* grad_f) 00395 { 00396 assert(n == data->num_variables()); 00397 for (Index i = 0; i<n; ++i) 00398 { 00399 // find which interval we're in 00400 if (x[i] > ipData->get_xh(i)) // above xh 00401 { 00402 // the slope of the kth interval is k hp[i] 00403 int kp_int; 00404 double kp_frac; 00405 ipData->get_kp(i, x[i], kp_int, kp_frac); 00406 grad_f[i] = (1+kp_int) * hp[i]; 00407 } 00408 else if (x[i] < ipData->get_xl(i)) // below xl 00409 { 00410 // the slope of the kth interval is k hm[i] 00411 int km_int; 00412 double km_frac; 00413 ipData->get_km(i, x[i], km_int, km_frac); 00414 grad_f[i] = (1+km_int) * hm[i]; 00415 } 00416 else // between xl and xh 00417 { 00418 // slope is h0 00419 grad_f[i] = h0[i]; 00420 } 00421 } 00422 return true; 00423 } 00424 00425 // return the value of the constraints: g(x) 00426 bool IARoundingFarNlp::eval_g(Index n, const Number* x, bool new_x, Index m, Number* g) 00427 { 00428 return baseNlp.eval_g(n, x, new_x, m, g); 00429 } 00430 00431 // return the structure or values of the jacobian 00432 bool IARoundingFarNlp::eval_jac_g(Index n, const Number* x, bool new_x, 00433 Index m, Index nele_jac, Index* iRow, Index *jCol, 00434 Number* values) 00435 { 00436 return baseNlp.eval_jac_g(n, x, new_x, m, nele_jac, iRow, jCol, values); 00437 } 00438 00439 //return the structure or values of the hessian 00440 bool IARoundingFarNlp::eval_h(Index n, const Number* x, bool new_x, 00441 Number obj_factor, Index m, const Number* lambda, 00442 bool new_lambda, Index nele_hess, Index* iRow, 00443 Index* jCol, Number* values) 00444 { 00445 // because the constraints are linear 00446 // and the objective function is piecewise linear 00447 // the hessian for this problem is actually empty 00448 00449 // to do: may need to fill with zeros so ipopt doesn't think it is globally linear 00450 assert(nele_hess == 0); 00451 00452 // This is a symmetric matrix, fill the lower left triangle only. 00453 if (values == NULL) { 00454 // return the structure. 00455 ; 00456 } 00457 else { 00458 // return the values. 00459 ; 00460 } 00461 00462 return true; 00463 } 00464 00465 void IARoundingFarNlp::finalize_solution(SolverReturn status, 00466 Index n, const Number* x, const Number* z_L, const Number* z_U, 00467 Index m, const Number* g, const Number* lambda, 00468 Number obj_value, 00469 const IpoptData* ip_data, 00470 IpoptCalculatedQuantities* ip_cq) 00471 { 00472 baseNlp.finalize_solution(status, n, x, z_L, z_U, m, g, lambda, obj_value, ip_data, ip_cq); 00473 }
