MeshKit
1.0
00001 // IASolverTool.cpp 00002 // Interval Assignment for Meshkit 00003 // 00004 00005 #include "meshkit/IASolverTool.hpp" 00006 #include "meshkit/IAData.hpp" 00007 #include "meshkit/IASolution.hpp" 00008 #include "meshkit/IPData.hpp" 00009 00010 #include <cstdlib> 00011 #include <stdio.h> 00012 #include <math.h> 00013 #include <limits.h> 00014 00015 namespace MeshKit 00016 { 00017 00018 IASolverTool::~IASolverTool() 00019 { 00020 iaData = NULL; 00021 iaSolution=NULL; 00022 } 00023 00024 bool IASolverTool::is_integer(const double x, double &x_int_double) const 00025 { 00026 x_int_double = ( floor( x + 0.5 ) ); 00027 // beware cases where this epsilon is too large, e.g. sides with more than 100 curves = 1 / 1.e-2 00028 return fabs( x - x_int_double ) < 1.e-2; 00029 } 00030 00031 bool IASolverTool::is_integer(const double x, int &x_int) const 00032 { 00033 double x_int_double; 00034 bool is_int = is_integer( x, x_int_double ); 00035 x_int = (int) ( x_int_double ); 00036 return is_int; 00037 } 00038 00039 00040 bool IASolverTool::is_integer(const double x) const 00041 { 00042 double x_int_double; 00043 return is_integer( x, x_int_double ); 00044 } 00045 00046 00047 bool IASolverTool::valid_solution() const 00048 { 00049 return (iaSolution && iaData && (iaSolution->x_solution.size() >= iaData->I.size())); // could be bigger if deltas are retained 00050 } 00051 00052 00053 void IASolverTool::print(const bool do_print_solution, const bool do_print_nonint, 00054 const bool do_print_equal_constraints, const bool do_print_nonequal, 00055 const bool do_print_even_constraints, const bool do_print_noneven ) const 00056 { 00057 00058 int info_case; 00059 /* 00060 four cases 00061 0 nothing 00062 1 data_and_solution 00063 2 data_only 00064 3 solution_only 00065 */ 00066 if (iaData) 00067 { 00068 if (valid_solution()) 00069 info_case = 1; //data_and_solution = true; 00070 else 00071 info_case = 2; // data_only = true; 00072 } 00073 else 00074 { 00075 if (iaSolution && iaSolution->x_solution.size()) 00076 info_case = 3; // solution_only = true; 00077 else 00078 info_case = 0; // nothing = true; 00079 } 00080 00081 // header 00082 switch (info_case) { 00083 case 0: 00084 printf("no data, no solution\n"); 00085 return; 00086 break; 00087 00088 case 1: 00089 printf("\nIA data and solution:\n"); 00090 break; 00091 00092 case 2: 00093 printf("\nIA data:\n"); 00094 break; 00095 00096 case 3: 00097 printf("\nIA solution:\n"); 00098 break; 00099 00100 default: 00101 break; 00102 } 00103 00104 // variables 00105 if ( info_case == 1 || info_case == 2 ) // data exists 00106 { 00107 printf("%d vars\n", iaData->num_variables()); 00108 for (int i=0; i<iaData->num_variables(); ++i) 00109 { 00110 printf("%d x (goal %e) ",i, iaData->I[i]); 00111 if (do_print_solution && info_case == 1) 00112 { 00113 //printf(" relaxed %e solution ", ip_data.relaxedSolution[i]); 00114 const double x = iaSolution->x_solution[i]; 00115 int x_int; 00116 if (is_integer(x,x_int)) 00117 printf("%d\n",x_int); 00118 else 00119 printf("%e NON-INTEGER\n",x); 00120 } 00121 else 00122 { 00123 printf("\n"); 00124 } 00125 } 00126 } 00127 else if ( info_case == 3 && do_print_solution) 00128 { 00129 printf("%d x solution values\n", iaData->num_variables()); 00130 for (unsigned int i=0; i<iaSolution->x_solution.size(); ++i) 00131 { 00132 printf("x_%d ",i); 00133 //printf(" relaxed %e solution ", ip_data.relaxedSolution[i]); 00134 const double x = iaSolution->x_solution[i]; 00135 int x_int; 00136 if (is_integer(x,x_int)) 00137 printf("%d\n",x_int); 00138 else 00139 printf("%e NON-INTEGER\n",x); 00140 } 00141 } 00142 00143 if ( info_case == 1 || info_case == 2 ) // data exists 00144 { 00145 if (do_print_equal_constraints || do_print_nonequal) 00146 { 00147 printf("%lu equality constraints:\n", iaData->constraints.size()); 00148 equal_constraints(do_print_equal_constraints, do_print_nonequal ); 00149 } 00150 if (do_print_even_constraints || do_print_noneven) 00151 { 00152 printf("%lu even constraints:\n", iaData->sumEvenConstraints.size()); 00153 even_constraints(do_print_even_constraints, do_print_noneven); 00154 } 00155 } 00156 00157 if (do_print_solution && valid_solution()) 00158 printf("objective function value %e\n", iaSolution->obj_value); 00159 printf("\n"); 00160 } 00161 00162 void IASolverTool::print_solution() const 00163 { 00164 print( true, false, false, false, false, false ); 00165 } 00166 00167 void IASolverTool::print_problem() const 00168 { 00169 print( false, true, false, false, false, false ); 00170 } 00171 00172 bool IASolverTool::is_even(double y, int &y_even) const 00173 { 00174 // nearest even value, including 0 and 2 00175 y_even = (int) floor( 2. * floor( y / 2. + 0.5 ) + 1.e-2 ); 00176 if ( fabs( y - y_even ) < 1.0e-2 ) 00177 return true; 00178 return false; 00179 } 00180 00181 bool IASolverTool::is_even(double y) const 00182 { 00183 int y_even; 00184 return is_even(y, y_even); 00185 } 00186 00187 double IASolverTool::equal_value(const int i) const 00188 { 00189 double g_i = 0.; // no rhs, it is placed into the bounds instead 00190 if (valid_solution()) 00191 { 00192 for (unsigned int j = 0; j < iaData->constraints[i].M.size(); ++j) 00193 { 00194 g_i += iaSolution->x_solution[ iaData->constraints[i].M[j].col ] * iaData->constraints[i].M[j].val; 00195 } 00196 } 00197 return g_i; 00198 } 00199 00200 00201 double IASolverTool::even_value(const int i) const 00202 { 00203 double g_i = - iaData->sumEvenConstraints[i].rhs; 00204 if (valid_solution()) 00205 { 00206 for (unsigned int j = 0; j < iaData->sumEvenConstraints[i].M.size(); ++j) 00207 { 00208 double x = iaSolution->x_solution[ iaData->sumEvenConstraints[i].M[j].col ]; 00209 double x_int_double; 00210 if (is_integer(x, x_int_double)) 00211 x = x_int_double; 00212 g_i += x * iaData->sumEvenConstraints[i].M[j].val; 00213 } 00214 } 00215 return g_i; 00216 } 00217 00218 void IASolverTool::even_floor_ceil(double s, double &s_floor, double &s_ceil) const 00219 { 00220 s_floor = 2. * floor(s / 2); 00221 s_ceil = s_floor + 2.; 00222 } 00223 00224 void IASolverTool::int_floor_ceil(double x, double &x_floor, double &x_ceil) const 00225 { 00226 x_floor = floor(x); 00227 x_ceil = x_floor + 1.; 00228 } 00229 00230 // compare to 00231 // bool IANlp::eval_g(Index n, const Number* x, bool new_x, Index m, Number* g) 00232 // does the same thing with the data in ipopt format 00233 00234 std::pair< bool, double> IASolverTool::equal_constraint(const int i, const bool print_me, const bool print_unsatisfied ) const 00235 { 00236 const double g_i = equal_value(i); 00237 // epsilons values 00238 const double epsilon_lower = 1.e-2; 00239 const double epsilon_upper = 1.e-2; 00240 bool satisfied = 00241 (g_i + epsilon_lower > iaData->constraints[i].lowerBound) || 00242 (g_i < iaData->constraints[i].upperBound + epsilon_upper); 00243 if (print_me || (print_unsatisfied && !satisfied)) 00244 { 00245 printf("equal constraint %d:", i); 00246 for (unsigned int j = 0; j < iaData->constraints[i].M.size(); ++j) 00247 { 00248 printf( " %f x_%d", iaData->constraints[i].M[j].val, iaData->constraints[i].M[j].col ); 00249 if (valid_solution()) 00250 printf(" (%f)", 00251 iaSolution->x_solution[ iaData->constraints[i].M[j].col ] * iaData->constraints[i].M[j].val ); 00252 } 00253 if (valid_solution()) 00254 printf(" = %f", g_i); 00255 printf(" in [%f, %f]", iaData->constraints[i].lowerBound, iaData->constraints[i].upperBound); 00256 if (!satisfied) 00257 printf(" VIOLATED"); 00258 printf("\n"); 00259 } 00260 return std::make_pair(satisfied, g_i); 00261 } 00262 00263 std::pair< bool, double> IASolverTool::even_constraint(const int i, const bool print_me, const bool print_unsatisfied ) const 00264 { 00265 const double g_i = even_value(i); 00266 // epsilon values 00267 int g_even; 00268 bool satisfied = is_even(g_i, g_even); 00269 if (print_me || (print_unsatisfied && !satisfied)) 00270 { 00271 printf("even constraint %d:", i); 00272 for (unsigned int j = 0; j < iaData->sumEvenConstraints[i].M.size(); ++j) 00273 { 00274 printf( " %f x_%d", iaData->sumEvenConstraints[i].M[j].val, iaData->sumEvenConstraints[i].M[j].col ); 00275 if (valid_solution()) 00276 printf(" (%f) ", 00277 iaSolution->x_solution[ iaData->sumEvenConstraints[i].M[j].col ] 00278 * iaData->sumEvenConstraints[i].M[j].val ); 00279 } 00280 if (valid_solution()) 00281 { 00282 if (satisfied) 00283 printf(" = %f = %d", g_i, g_even); 00284 else 00285 printf(" = %f != %d NOT-EVEN", g_i, g_even); 00286 } 00287 printf("\n"); 00288 } 00289 return std::make_pair(satisfied, g_i); 00290 } 00291 00292 00293 bool IASolverTool::equal_constraints( bool print_me, bool print_unsatisfied ) const 00294 { 00295 bool equal_satisfied = true; 00296 for (unsigned int i = 0; i<iaData->constraints.size(); ++i) 00297 { 00298 if (! equal_constraint(i, print_me, print_unsatisfied).first ) 00299 equal_satisfied = false; 00300 } 00301 return equal_satisfied; 00302 } 00303 00304 bool IASolverTool::even_constraints( bool print_me, bool print_unsatisfied ) const 00305 { 00306 bool even_satisfied = true; 00307 for (unsigned int i = 0; i<iaData->sumEvenConstraints.size(); ++i) 00308 { 00309 if (! even_constraint(i, print_me, print_unsatisfied).first ) 00310 even_satisfied = false; 00311 } 00312 return even_satisfied; 00313 } 00314 00315 bool IASolverTool::all_constraints( bool print_me, bool print_unsatisfied ) const 00316 { 00317 bool equal_satisfied = equal_constraints( print_me, print_unsatisfied ); 00318 bool even_satisfied = even_constraints( print_me, print_unsatisfied ); 00319 return equal_satisfied && even_satisfied; 00320 } 00321 00322 00323 } // namespace MeshKit
