, including all inherited members.
| advance_front_edges_swap_once(int layerid) | QuadCleanUp | [private] |
| advancing_front_cleanup() | QuadCleanUp | |
| advancing_front_edges_swap() | QuadCleanUp | |
| apply_advance_front_bridge_rule(Vertex *v0, Vertex *v1) | QuadCleanUp | [private] |
| apply_advance_front_excess_rule(Vertex *v) | QuadCleanUp | [private] |
| apply_advance_front_singlet_rule(Vertex *v) | QuadCleanUp | [private] |
| apply_advance_front_triplet_rule(Vertex *v) | QuadCleanUp | [private] |
| apply_shift_node3_rule(Vertex *vertex) | QuadCleanUp | [private] |
| atomic_op_face_close(Face *f) | QuadCleanUp | |
| atomic_op_swap_edge(Vertex *v0, Vertex *v1) | QuadCleanUp | |
| automatic() | QuadCleanUp | |
| boundary_vertex_degree_reduction_once() | QuadCleanUp | [private] |
| build_one_defect_patch(Vertex *vertex=NULL) | QuadCleanUp | |
| clean_layer(int id) | QuadCleanUp | |
| clean_layer_once(int id) | QuadCleanUp | [private] |
| cleanup_boundary(double cutOffAngle=100.0) | QuadCleanUp | |
| cleanup_internal_boundary_face() | QuadCleanUp | [private] |
| defective_patch | QuadCleanUp | [private] |
| degree_5_dominated() | QuadCleanUp | |
| diamond_collapse(FaceClose &d) | QuadCleanUp | [private] |
| djkpath | QuadCleanUp | [private] |
| face_close(Face *face, Vertex *v0, Vertex *v2) | QuadCleanUp | [private] |
| get_strips(Face *face, FaceSequence &strip1, FaceSequence strip2) | QuadCleanUp | |
| has_interior_nodes_degree_345() | QuadCleanUp | [private] |
| hasSinglet(const Face *f) | QuadCleanUp | [inline, static] |
| insert_boundary_doublet(Face *face) | QuadCleanUp | |
| insert_doublet(Face *face) | QuadCleanUp | |
| insert_doublet(Face *face, Vertex *v0, Vertex *v2) | QuadCleanUp | |
| internal_vertex_degree_reduction_once() | QuadCleanUp | [private] |
| irregular_nodes | QuadCleanUp | [private] |
| isDiamond(Face *f, int &pos, int type=33) | QuadCleanUp | [static] |
| isDoublet(const Vertex *v) | QuadCleanUp | [inline, static] |
| isEdge33(const Edge *e) | QuadCleanUp | [static] |
| isEdge35(const Edge *e) | QuadCleanUp | [static] |
| isRegular(const Vertex *v) | QuadCleanUp | [inline, static] |
| isSinglet(const Vertex *v) | QuadCleanUp | [inline, static] |
| isTunnel(const Edge *e) | QuadCleanUp | [static] |
| mesh | QuadCleanUp | [private] |
| mopt | QuadCleanUp | [private] |
| QuadCleanUp() | QuadCleanUp | [inline] |
| QuadCleanUp(Mesh *m) | QuadCleanUp | [inline] |
| reduce_boundary_vertex_degree(Vertex *v) | QuadCleanUp | |
| reduce_degree(Vertex *v) | QuadCleanUp | |
| reduce_internal_vertex_degree(Vertex *v) | QuadCleanUp | |
| refine_3434_pattern(Face *face, int pos) | QuadCleanUp | [private] |
| refine_3444_pattern(Face *face, int pos) | QuadCleanUp | [private] |
| refine_3454_pattern(Face *face, int pos) | QuadCleanUp | [private] |
| refine_bridges_face() | QuadCleanUp | |
| refine_degree3_faces() | QuadCleanUp | |
| refine_restricted_node(Vertex *resnode, Vertex *bndnode) | QuadCleanUp | |
| remesh_defective_patches() | QuadCleanUp | |
| remove_boundary_singlet_type1(const Singlet &s) | QuadCleanUp | [private] |
| remove_boundary_singlet_type2(const Singlet &s) | QuadCleanUp | [private] |
| remove_boundary_singlets() | QuadCleanUp | |
| remove_boundary_singlets_once() | QuadCleanUp | [private] |
| remove_bridges() | QuadCleanUp | |
| remove_bridges_in_layer(int l) | QuadCleanUp | [private] |
| remove_bridges_once() | QuadCleanUp | [private] |
| remove_diamonds() | QuadCleanUp | |
| remove_diamonds_in_layer(int l) | QuadCleanUp | [private] |
| remove_diamonds_once() | QuadCleanUp | [private] |
| remove_doublets_once() | QuadCleanUp | [private] |
| remove_interior_doublet(Doublet &d) | QuadCleanUp | [private] |
| remove_interior_doublets() | QuadCleanUp | |
| remove_interior_doublets_once() | QuadCleanUp | [private] |
| remove_tunnels() | QuadCleanUp | |
| report() | QuadCleanUp | |
| search_boundary_singlets() | QuadCleanUp | |
| search_diamonds(int type=33) | QuadCleanUp | |
| search_diamonds_in_layer(int l) | QuadCleanUp | [private] |
| search_flat_quads() | QuadCleanUp | |
| search_interior_doublets() | QuadCleanUp | |
| search_one_defect_patches() | QuadCleanUp | |
| search_restricted_faces() | QuadCleanUp | |
| search_restricted_nodes() | QuadCleanUp | |
| search_tunnels() | QuadCleanUp | |
| setMesh(Mesh *m) | QuadCleanUp | [inline] |
| shift_irregular_nodes() | QuadCleanUp | |
| swap_concave_faces() | QuadCleanUp | |
| vDefectPatches | QuadCleanUp | [private] |
| vDiamonds | QuadCleanUp | [private] |
| vDoublets | QuadCleanUp | [private] |
| vertex_degree_reduction() | QuadCleanUp | |
| vSinglets | QuadCleanUp | [private] |
| ~QuadCleanUp() | QuadCleanUp | [inline] |
