, including all inherited members.
| add_hessian_entry(int i, int j, int &k) | IAIntWaveNlp | [protected] |
| base_m | IAIntWaveNlp | [protected] |
| base_n | IAIntWaveNlp | [protected] |
| baseNlp | IAIntWaveNlp | [protected] |
| build_hessian() | IAIntWaveNlp | [protected] |
| data | IAIntWaveNlp | [protected] |
| debugging | IAIntWaveNlp | [protected] |
| eval_f(Index n, const Number *x, bool new_x, Number &obj_value) | IAIntWaveNlp | [virtual] |
| eval_g(Index n, const Number *x, bool new_x, Index m, Number *g) | IAIntWaveNlp | [virtual] |
| eval_g_int_s(const double s)=0 | IAIntWaveNlp | [protected, pure virtual] |
| eval_g_int_x(const double x)=0 | IAIntWaveNlp | [protected, pure virtual] |
| eval_grad_f(Index n, const Number *x, bool new_x, Number *grad_f) | IAIntWaveNlp | [virtual] |
| eval_h(Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values) | IAIntWaveNlp | [virtual] |
| eval_hess_int_s(const double s)=0 | IAIntWaveNlp | [protected, pure virtual] |
| eval_hess_int_x(const double x)=0 | IAIntWaveNlp | [protected, pure virtual] |
| eval_jac_g(Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values) | IAIntWaveNlp | [virtual] |
| eval_jac_int_s(const double s)=0 | IAIntWaveNlp | [protected, pure virtual] |
| eval_jac_int_x(const double x)=0 | IAIntWaveNlp | [protected, pure virtual] |
| f_x_value(double I_i, double x_i) | IAIntWaveNlp | [protected] |
| finalize_solution(SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq) | IAIntWaveNlp | [virtual] |
| get_bounds_info(Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u) | IAIntWaveNlp | [virtual] |
| get_hessian_k(int i, int j) | IAIntWaveNlp | [protected] |
| get_nlp_info(Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style) | IAIntWaveNlp | [virtual] |
| get_starting_point(Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda) | IAIntWaveNlp | [virtual] |
| hessian_map | IAIntWaveNlp | [protected] |
| hessian_vector | IAIntWaveNlp | [protected] |
| IAIntWaveNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr, const bool set_silent=true) | IAIntWaveNlp | |
| IAIntWaveNlp() | IAIntWaveNlp | [private] |
| IAIntWaveNlp(const IAIntWaveNlp &) | IAIntWaveNlp | [private] |
| ipData | IAIntWaveNlp | [protected] |
| operator=(const IAIntWaveNlp &) | IAIntWaveNlp | [private] |
| print_hessian() | IAIntWaveNlp | [protected] |
| problem_m | IAIntWaveNlp | [protected] |
| problem_n | IAIntWaveNlp | [protected] |
| silent | IAIntWaveNlp | [protected] |
| solution | IAIntWaveNlp | [protected] |
| SparseMatrixMap typedef | IAIntWaveNlp | [protected] |
| verbose | IAIntWaveNlp | [protected] |
| wave_even_constraint_start | IAIntWaveNlp | [protected] |
| wave_int_constraint_start | IAIntWaveNlp | [protected] |
| ~IAIntWaveNlp() | IAIntWaveNlp | [virtual] |
