MeshKit
1.0
00001 00002 #include "meshkit/AssyGen.hpp" 00003 00004 namespace MeshKit 00005 { 00006 00007 void AssyGen::CreatePinCell(int i, double dX, double dY, double dZ) 00008 //--------------------------------------------------------------------------- 00009 //Function: Create pincell i in location dX dY and dZ 00010 //Input: none 00011 //Output: none 00012 //--------------------------------------------------------------------------- 00013 { 00014 int nRadii=0, nCyl=0, nCells = 0; 00015 double dCylMoveX = 0.0, dCylMoveY = 0.0, dHeightTotal = 0.0; 00016 double dHeight =0.0,dZMove = 0.0, PX = 0.0,PY = 0.0,PZ = 0.0, dP=0.0; 00017 CVector<double> dVCylZPos(2), dVCylXYPos(2), dVStartZ, dVEndZ;; 00018 CVector<std::string> szVCellMat; 00019 iBase_EntityHandle cell = NULL, cyl= NULL, tmp_vol= NULL,tmp_vol1= NULL, tmp_new= NULL; 00020 (void) tmp_vol; 00021 std::vector<iBase_EntityHandle> cp_in; 00022 // name tag handle 00023 iBase_TagHandle this_tag= NULL; 00024 00025 std::string sMatName = ""; 00026 std::string sMatName1 = ""; 00027 int nDuctIndex = -1; 00028 00029 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00030 std::ostringstream os; 00031 pin_name = "_xp"; 00032 os << (m_nTotalPincells + m_nStartpinid - 1); 00033 os << "_"; 00034 std::string pid = os.str(); //retrieve as a string 00035 pin_name+=pid; 00036 } 00037 00038 // get tag handle for 'NAME' tag, already created as iGeom instance is created 00039 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00040 char* tag_name = (char*)"NAME"; 00041 iGeom_getTagHandle(igeomImpl->instance(), tag_name, &this_tag, &err, 4); 00042 #endif 00043 00044 // get cell material 00045 m_Pincell(i).GetCellMatSize(nCells); 00046 SimpleArray<iBase_EntityHandle> cells(nCells); 00047 00048 // branch when cells are present 00049 if(nCells > 0){ 00050 dVStartZ.SetSize(nCells); 00051 dVEndZ.SetSize(nCells); 00052 szVCellMat.SetSize(nCells); 00053 m_Pincell(i).GetCellMat(dVStartZ, dVEndZ, szVCellMat); 00054 00055 // get cylinder data 00056 m_Pincell(i).GetNumCyl(nCyl); 00057 00058 for(int n=1;n<=nCells; n++){ 00059 // get cylinder locations 00060 if(nCyl > 0){ 00061 m_Pincell(i).GetCylZPos(n, dVCylZPos); 00062 nDuctIndex = -1; 00063 00064 // get the index for cp_inpins based on Z-heights 00065 for (int dd = 1; dd <= m_nDuct; dd++){ 00066 if((m_dMZAssm(dd, 2)) >= (dVCylZPos(2)) && (m_dMZAssm(dd, 1)) >= (dVCylZPos(1))) 00067 nDuctIndex = dd; 00068 if (nDuctIndex != -1) 00069 break; 00070 } 00071 } 00072 dHeight = fabs(dVEndZ(n) - dVStartZ(n)); 00073 m_PyCubGeomFile << "cells = []\ncyls = []\ncp_in = []" << std::endl; 00074 m_PyCubGeomFile << "sub1 = [] \nsub2 = []" << std::endl; 00075 00076 if(m_szGeomType =="hexagonal"){ 00077 00078 m_Pincell(i).GetPitch(dP, dHeightTotal); // this dHeight is not used in creation 00079 double dSide = dP/(sqrt(3)); 00080 00081 if(nCells >0){ 00082 // create prism 00083 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00084 iGeom_createPrism(igeomImpl->instance(), dHeight, 6, 00085 dSide, dSide, 00086 &cell, &err); 00087 #endif 00088 m_PyCubGeomFile << "cell = cubit.prism( " << dHeight << ", 6, " << dSide << ", " << dSide << ")" << std::endl; 00089 } 00090 } 00091 // if rectangular geometry 00092 if(m_szGeomType =="rectangular"){ 00093 00094 m_Pincell(i).GetPitch(PX, PY, PZ); 00095 00096 if(nCells >0){ 00097 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00098 // create brick 00099 iGeom_createBrick( igeomImpl->instance(),PX,PY,dHeight,&cell,&err ); 00100 #endif 00101 m_PyCubGeomFile << "cell = cubit.brick( " << PX << ", " << PY << ", " << dHeight << ")" << std::endl; 00102 } 00103 } 00104 00105 dZMove = (dVStartZ(n)+dVEndZ(n))/2.0; 00106 if(nCells > 0){ 00107 // position the brick in assembly 00108 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00109 iGeom_moveEnt(igeomImpl->instance(), cell, dX, dY, dZMove, &err); 00110 #endif 00111 m_PyCubGeomFile << "vector = [" << dX << ", " << dY << ", " << dZMove << "]" << std::endl; 00112 m_PyCubGeomFile << "cubit.move( cell, vector)" << std::endl; 00113 00114 m_PyCubGeomFile << "cells.append(cell)" << std::endl; 00115 cells[n-1]=cell; 00116 00117 //search for the full name of the abbreviated Cell Mat and set name 00118 for(int p=1;p<= m_szAssmMatAlias.GetSize();p++){ 00119 if(strcmp (szVCellMat(n).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00120 sMatName = m_szAssmMat(p); 00121 } 00122 } 00123 std::cout << "created: " << sMatName << std::endl; 00124 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00125 iGeom_setData(igeomImpl->instance(), cell, this_tag, 00126 sMatName.c_str(), sMatName.size(), &err); 00127 #endif 00128 m_PyCubGeomFile << "lid = cells[0].id()" << std::endl; 00129 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00130 00131 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00132 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00133 iGeom_setData(igeomImpl->instance(), cell, this_tag, 00134 pin_name.c_str(), pin_name.size(), &err); 00135 #endif 00136 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << pin_name << "\" )" << std::endl; 00137 std::cout << "Naming pin body :" << pin_name << std::endl; 00138 } 00139 00140 00141 Name_Faces(sMatName, cell, this_tag); 00142 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", cell) " << std::endl; 00143 } 00144 // loop and create cylinders 00145 if(nCyl > 0){ 00146 m_Pincell(i).GetCylSizes(n, nRadii); 00147 SimpleArray<iBase_EntityHandle> cyls(nRadii); 00148 00149 //declare variables 00150 CVector<double> dVCylRadii(2*nRadii); 00151 CVector<std::string> szVMat(nRadii); 00152 CVector<std::string> szVCylMat(nRadii); 00153 int nType = 0; 00154 //get values 00155 m_Pincell(i).GetCylRadii(n, dVCylRadii); 00156 m_Pincell(i).GetCylPos(n, dVCylXYPos); 00157 m_Pincell(i).GetCylMat(n, szVCylMat); 00158 m_Pincell(i).GetCylZPos(n, dVCylZPos); 00159 m_Pincell(i).GetCellType(n, nType); 00160 00161 dHeight = dVCylZPos(2)-dVCylZPos(1); 00162 00163 for (int m=1; m<=nRadii; m++){ 00164 00165 if (nType == 0){ 00166 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00167 iGeom_createCylinder(igeomImpl->instance(), dHeight, dVCylRadii(m), dVCylRadii(m), 00168 &cyl, &err); 00169 #endif 00170 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ")" << std::endl; 00171 std::cout << m << ": Creating cylinder with radii " << dVCylRadii(m) << std::endl; 00172 } 00173 else{ 00174 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00175 iGeom_createCone(igeomImpl->instance(), dHeight, dVCylRadii(2*m-1), dVCylRadii(2*m-1), dVCylRadii(2*m), 00176 &cyl, &err); 00177 #endif 00178 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m) << ")" << std::endl; 00179 } 00180 // move their centers and also move to the assembly location ! Modify if cyl is outside brick 00181 dCylMoveX = dVCylXYPos(1)+dX; 00182 dCylMoveY = dVCylXYPos(2)+dY; 00183 dZMove = (dVCylZPos(1)+dVCylZPos(2))/2.0; 00184 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00185 iGeom_moveEnt(igeomImpl->instance(), cyl, dCylMoveX,dCylMoveY,dZMove, &err); 00186 #endif 00187 m_PyCubGeomFile << "cyls.append(cyl)" << std::endl; 00188 00189 m_PyCubGeomFile << "vector = [" << dCylMoveX << ", " << dCylMoveY << ", " << dZMove << "]" << std::endl; 00190 m_PyCubGeomFile << "cubit.move(cyl, vector)" << std::endl; 00191 cyls[m-1] = cyl; 00192 } 00193 00194 m_PyCubGeomFile << "sub1[:] = []\nsub2[:] = []" << std::endl; 00195 00196 if(nCells > 0){ 00197 // copy cyl before subtract 00198 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00199 iGeom_copyEnt(igeomImpl->instance(), cyls[nRadii-1], &tmp_vol, &err); 00200 #endif 00201 m_PyCubGeomFile << "tmp_vol = cubit.copy_body(cyls[" << nRadii-1 << "])" << std::endl; 00202 00203 // subtract outer most cyl from brick 00204 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00205 iGeom_subtractEnts(igeomImpl->instance(), cells[n-1], tmp_vol, &tmp_new, &err); 00206 #endif 00207 m_PyCubGeomFile << "sub1.append(cells[" << n-1 << "])\nsub2.append(tmp_vol)" << std::endl; 00208 m_PyCubGeomFile << "tmp_new = cubit.subtract(sub2, sub1)" << std::endl; 00209 m_PyCubGeomFile << "sub1[:] = []\nsub2[:] = []" << std::endl; 00210 00211 m_PyCubGeomFile << "cells.append(tmp_new[0]) \ncell = tmp_new[0]" << std::endl; 00212 00213 // copy the new into the cyl array 00214 cells[n-1] = tmp_new; cell = tmp_new; 00215 00216 } 00217 cp_in.push_back(tmp_new); 00218 m_PyCubGeomFile << "cp_in.append(tmp_new[0])" << std::endl; 00219 00220 //set tag on inner most cylinder, search for the full name of the abbreviated Cell Mat 00221 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00222 if(strcmp (szVCylMat(1).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00223 sMatName = m_szAssmMat(p); 00224 } 00225 } 00226 tmp_vol1=cyls[0]; //inner most cyl 00227 cp_in.push_back(tmp_vol1); 00228 m_PyCubGeomFile << "tmp_vol1 = cyls[0]\ncp_in.append(tmp_vol1)" << std::endl; 00229 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00230 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00231 sMatName.c_str(), 10, &err); 00232 #endif 00233 m_PyCubGeomFile << "lid = tmp_vol1.id()" << std::endl; 00234 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00235 00236 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00237 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00238 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00239 pin_name.c_str(), pin_name.size(), &err); 00240 #endif 00241 std::cout << "Naming pin body :" << pin_name << std::endl; 00242 } 00243 00244 Name_Faces(sMatName, tmp_vol1, this_tag); 00245 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_vol1) " << std::endl; 00246 00247 // other cyl annulus after substraction 00248 for (int b=nRadii; b>1; b--){ 00249 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00250 iGeom_copyEnt(igeomImpl->instance(), cyls[b-2], &tmp_vol, &err); 00251 #endif 00252 m_PyCubGeomFile << "tmp_vol = cubit.copy_body(cyls[" << b-2 << "])" << std::endl; 00253 00254 //subtract tmp vol from the outer most 00255 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00256 iGeom_subtractEnts(igeomImpl->instance(), cyls[b-1], tmp_vol, &tmp_new, &err); 00257 #endif 00258 m_PyCubGeomFile << "sub1.append(cyls[" << b-1 << "])\nsub2.append(tmp_vol)" << std::endl; 00259 m_PyCubGeomFile << "tmp_new = cubit.subtract(sub2, sub1)" << std::endl; 00260 m_PyCubGeomFile << "sub1[:] = []\nsub2[:] = []" << std::endl; 00261 00262 // now search for the full name of the abbreviated Cell Mat 00263 // int tag_no; 00264 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00265 if(strcmp (szVCylMat(b).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00266 // tag_no = p; 00267 sMatName = m_szAssmMat(p); 00268 } 00269 } 00270 std::cout << "created: " << sMatName << std::endl; 00271 cp_in.push_back(tmp_new); 00272 m_PyCubGeomFile << "cp_in.append(tmp_new[0])" << std::endl; 00273 00274 // set the name of the annulus 00275 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00276 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00277 sMatName.c_str(),sMatName.size(), &err); 00278 #endif 00279 m_PyCubGeomFile << "lid = tmp_new[0].id()" << std::endl; 00280 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00281 00282 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00283 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00284 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00285 pin_name.c_str(), pin_name.size(), &err); 00286 #endif 00287 std::cout << "Naming pin body :" << pin_name<< std::endl; 00288 00289 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << pin_name << "\" )" << std::endl; 00290 } 00291 Name_Faces(sMatName, tmp_new, this_tag); 00292 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_new[0]) " << std::endl; 00293 m_PyCubGeomFile << "cyls[" << b-1 << "] = tmp_new" << std::endl; 00294 00295 // copy the new into the cyl array 00296 cyls[b-1] = tmp_new; 00297 tmp_vol=NULL; 00298 } 00299 } 00300 if(nDuctIndex > 0){ 00301 m_PyCubGeomFile << "cp_inpins.append([])" << std::endl; 00302 for (int count = 0; count < (int) cp_in.size(); count++){ 00303 cp_inpins[nDuctIndex-1].push_back(cp_in[count]); 00304 m_PyCubGeomFile << "cp_inpins[" << nDuctIndex-1 << "].append(cp_in[" << count << "])" << std::endl; 00305 } 00306 } 00307 cp_in.clear(); 00308 m_PyCubGeomFile << "cp_in[:] =[]" << std::endl; 00309 } 00310 } 00311 // this branch of the routine is responsible for creating cylinders with '0' cells 00312 if(nCells == 0){ 00313 00314 // get cylinder data 00315 m_Pincell(i).GetNumCyl(nCyl); 00316 nCells = nCyl; 00317 00318 for(int n=1;n<=nCells; n++){ 00319 nDuctIndex = -1; 00320 if(m_szGeomType =="hexagonal"){ 00321 00322 m_Pincell(i).GetPitch(dP, dHeightTotal); // this dHeight is not used in creation 00323 } 00324 // if rectangular geometry 00325 if(m_szGeomType =="rectangular"){ 00326 00327 m_Pincell(i).GetPitch(PX, PY, PZ); 00328 } 00329 00330 // loop and create cylinders 00331 if(nCyl > 0){ 00332 m_Pincell(i).GetCylSizes(n, nRadii); 00333 SimpleArray<iBase_EntityHandle> cyls(nRadii); 00334 00335 //declare variables 00336 CVector<double> dVCylRadii(2*nRadii); 00337 CVector<std::string> szVMat(nRadii); 00338 CVector<std::string> szVCylMat(nRadii); 00339 int nType = 0; 00340 //get values 00341 m_Pincell(i).GetCylRadii(n, dVCylRadii); 00342 m_Pincell(i).GetCylPos(n, dVCylXYPos); 00343 m_Pincell(i).GetCylMat(n, szVCylMat); 00344 m_Pincell(i).GetCylZPos(n, dVCylZPos); 00345 m_Pincell(i).GetCellType(n, nType); 00346 00347 dHeight = dVCylZPos(2)-dVCylZPos(1); 00348 00349 // get the index for cp_inpins based on Z-heights 00350 for (int dd = 1; dd <= m_nDuct; dd++){ 00351 if((m_dMZAssm(dd, 2)) >= (dVCylZPos(2)) && (m_dMZAssm(dd, 1)) >= (dVCylZPos(1))) 00352 nDuctIndex = dd; 00353 if (nDuctIndex != -1) 00354 break; 00355 } 00356 00357 m_PyCubGeomFile << "cyls = [] \ncp_in = []" << std::endl; 00358 m_PyCubGeomFile << "sub1 = [] \nsub2 = []" << std::endl; 00359 00360 for (int m=1; m<=nRadii; m++){ 00361 if (nType == 0){ 00362 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00363 iGeom_createCylinder(igeomImpl->instance(), dHeight, dVCylRadii(m), dVCylRadii(m), 00364 &cyl, &err); 00365 #endif 00366 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ")" << std::endl; 00367 } 00368 else{ 00369 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00370 iGeom_createCone(igeomImpl->instance(), dHeight, dVCylRadii(2*m - 1), dVCylRadii(2*m - 1), dVCylRadii(2*m), 00371 &cyl, &err); 00372 #endif 00373 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m) << ")" << std::endl; 00374 } 00375 00376 // move their centers and also move to the assembly location ! Modify if cyl is outside brick 00377 dCylMoveX = dVCylXYPos(1)+dX; 00378 dCylMoveY = dVCylXYPos(2)+dY; 00379 dZMove = (dVCylZPos(1)+dVCylZPos(2))/2.0; 00380 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00381 iGeom_moveEnt(igeomImpl->instance(), cyl, dCylMoveX, dCylMoveY, dZMove, &err); 00382 #endif 00383 m_PyCubGeomFile << "vector = [" << dCylMoveX << ", " << dCylMoveY << ", " << dZMove << "]" << std::endl; 00384 m_PyCubGeomFile << "cubit.move( cyl, vector)" << std::endl; 00385 m_PyCubGeomFile << "cyls.append(cyl)" << std::endl; 00386 cyls[m-1] = cyl; 00387 } 00388 00389 //set tag on inner most cylinder, search for the full name of the abbreviated Cell Mat 00390 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00391 if(strcmp (szVCylMat(1).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00392 sMatName = m_szAssmMat(p); 00393 } 00394 } 00395 std::cout << "created: " << sMatName << std::endl; 00396 tmp_vol1=cyls[0]; //inner most cyl 00397 00398 cp_in.push_back(tmp_vol1); 00399 m_PyCubGeomFile << "tmp_vol1 = cyls[0] \ncp_in.append(tmp_vol1)" << std::endl; 00400 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00401 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00402 sMatName.c_str(), 10, &err); 00403 #endif 00404 m_PyCubGeomFile << "lid =cyls[0].id()" << std::endl; 00405 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00406 00407 00408 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00409 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00410 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00411 pin_name.c_str(), pin_name.size(), &err); 00412 #endif 00413 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << pin_name << "\" )" << std::endl; 00414 00415 std::cout << "Naming pin body :" << pin_name<< std::endl; 00416 } 00417 00418 Name_Faces(sMatName, tmp_vol1, this_tag); 00419 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_vol1) " << std::endl; 00420 00421 // other cyl annulus after substraction 00422 for (int b=nRadii; b>1; b--){ 00423 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00424 iGeom_copyEnt(igeomImpl->instance(), cyls[b-2], &tmp_vol, &err); 00425 #endif 00426 m_PyCubGeomFile << "# SUBTRACTING ANNULUS ##\ntmp_vol = cubit.copy_body(cyls[" << b-2 << "])" << std::endl; 00427 00428 //subtract tmp vol from the outer most 00429 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00430 iGeom_subtractEnts(igeomImpl->instance(), cyls[b-1], tmp_vol, &tmp_new, &err); 00431 #endif 00432 m_PyCubGeomFile << "sub1.append(cyls[" << b-1 << "])\nsub2.append(tmp_vol)" << std::endl; 00433 m_PyCubGeomFile << "tmp_new = cubit.subtract(sub2, sub1)" << std::endl; 00434 m_PyCubGeomFile << "sub1[:] = []\nsub2[:] = []" << std::endl; 00435 00436 // now search for the full name of the abbreviated Cell Mat 00437 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00438 if(strcmp (szVCylMat(b).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00439 sMatName = m_szAssmMat(p); 00440 } 00441 } 00442 std::cout <<"created: " << sMatName << std::endl; 00443 00444 cp_in.push_back(tmp_new); 00445 m_PyCubGeomFile << "cp_in.append(tmp_new[0])" << std::endl; 00446 00447 // set the name of the annulus 00448 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00449 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00450 sMatName.c_str(),sMatName.size(), &err); 00451 #endif 00452 m_PyCubGeomFile << "lid = tmp_new[0].id()" << std::endl; 00453 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00454 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00455 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00456 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00457 pin_name.c_str(), pin_name.size(), &err); 00458 #endif 00459 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << pin_name << "\" )" << std::endl; 00460 00461 std::cout << "Naming pin body :" << pin_name<< std::endl; 00462 } 00463 00464 Name_Faces(sMatName, tmp_new, this_tag); 00465 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_new[0]) " << std::endl; 00466 m_PyCubGeomFile << "cyls[" << b-1 << "] = tmp_new" << std::endl; 00467 00468 // copy the new into the cyl array 00469 cyls[b-1] = tmp_new; 00470 } 00471 } 00472 if(nDuctIndex > 0){ 00473 m_PyCubGeomFile << "cp_inpins.append([])" << std::endl; 00474 for (int count = 0; count < (int) cp_in.size(); count++){ 00475 cp_inpins[nDuctIndex-1].push_back(cp_in[count]); 00476 m_PyCubGeomFile << "cp_inpins["<< nDuctIndex -1 << "].append(cp_in[" << count << "])" << std::endl; 00477 00478 } 00479 } 00480 cp_in.clear(); 00481 m_PyCubGeomFile << "cp_in[:] =[]" << std::endl; 00482 00483 } 00484 } 00485 00486 } 00487 00488 00489 void AssyGen::CreatePinCell_Intersect(int i, double dX, double dY, double dZ) 00490 //--------------------------------------------------------------------------- 00491 //Function: Create pincell i in location dX dY and dZ 00492 //Input: none 00493 //Output: none 00494 //--------------------------------------------------------------------------- 00495 { 00496 int nRadii=0, nCyl=0, nCells = 0; 00497 double dCylMoveX = 0.0, dCylMoveY = 0.0, dHeightTotal = 0.0; 00498 double dHeight =0.0,dZMove = 0.0, PX = 0.0,PY = 0.0,PZ = 0.0, dP=0.0; 00499 CVector<double> dVCylZPos(2), dVCylXYPos(2), dVEndZ, dVStartZ; 00500 CVector<std::string> szVCellMat; 00501 iBase_EntityHandle cell = NULL, cyl= NULL, tmp_vol1= NULL, tmp_new= NULL, cell_copy = NULL, intersec = NULL; 00502 std::vector<iBase_EntityHandle> cp_in; 00503 00504 // name tag handle 00505 iBase_TagHandle this_tag= NULL; 00506 std::string sMatName = ""; 00507 std::string sMatName0 = ""; 00508 std::string sMatName1 = ""; 00509 int nDuctIndex = -1; 00510 00511 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00512 std::ostringstream os; 00513 pin_name = "_xp"; 00514 os << (m_nTotalPincells + m_nStartpinid - 1); 00515 os << "_"; 00516 std::string pid = os.str(); //retrieve as a string 00517 pin_name+=pid; 00518 } 00519 00520 // get tag handle for 'NAME' tag, already created as iGeom instance is created 00521 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00522 char* tag_name = (char*)"NAME"; 00523 iGeom_getTagHandle(igeomImpl->instance(), tag_name, &this_tag, &err, 4); 00524 #endif 00525 00526 // get cell material 00527 m_Pincell(i).GetCellMatSize(nCells); 00528 m_Pincell(i).GetNumCyl(nCyl); 00529 SimpleArray<iBase_EntityHandle> cells(nCells); 00530 00531 // branch when cells are present 00532 if(nCells > 0){ 00533 dVStartZ.SetSize(nCells); 00534 dVEndZ.SetSize(nCells); 00535 szVCellMat.SetSize(nCells); 00536 m_Pincell(i).GetCellMat(dVStartZ, dVEndZ, szVCellMat); 00537 00538 // get cylinder data 00539 m_Pincell(i).GetNumCyl(nCyl); 00540 m_PyCubGeomFile << "cells = []\ncyls = []\ncp_in = []" << std::endl; 00541 00542 for(int n=1;n<=nCells; n++){ 00543 00544 dHeight = fabs(dVEndZ(n) - dVStartZ(n)); 00545 // get the index for cp_inpins based on Z-heights 00546 for (int dd = 1; dd <= m_nDuct; dd++){ 00547 if((m_dMZAssm(dd, 2)) >= (dVCylZPos(2)) && (m_dMZAssm(dd, 1)) >= (dVCylZPos(1))) 00548 nDuctIndex = dd; 00549 if (nDuctIndex != -1) 00550 break; 00551 } 00552 if(m_szGeomType =="hexagonal"){ 00553 00554 m_Pincell(i).GetPitch(dP, dHeightTotal); // this dHeight is not used in creation 00555 00556 double dSide = dP/(sqrt(3)); 00557 00558 if(nCells >0){ 00559 // create prism 00560 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00561 iGeom_createPrism(igeomImpl->instance(), dHeight, 6, 00562 dSide, dSide, 00563 &cell, &err); 00564 #endif 00565 m_PyCubGeomFile << "cell = cubit.prism(' " << dHeight << ", 6, " << dSide << ", " << dSide << ")" << std::endl; } 00566 } 00567 // if rectangular geometry 00568 if(m_szGeomType =="rectangular"){ 00569 00570 m_Pincell(i).GetPitch(PX, PY, PZ); 00571 00572 if(nCells >0){ 00573 // create brick 00574 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00575 iGeom_createBrick( igeomImpl->instance(),PX,PY,dHeight,&cell,&err ); 00576 #endif 00577 m_PyCubGeomFile << "cell = cubit.brick(' " << PX << ", " << PY << ", " << dHeight << ")" << std::endl; } 00578 } 00579 00580 dZMove = (dVStartZ(n)+dVEndZ(n))/2.0; 00581 00582 if(nCells > 0){ 00583 // position the brick in assembly 00584 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00585 iGeom_moveEnt(igeomImpl->instance(), cell, dX, dY, dZMove, &err); 00586 #endif 00587 m_PyCubGeomFile << "vector = [" << dX << ", " << dY << ", " << dZMove << "]" << std::endl; 00588 m_PyCubGeomFile << "cubit.move( cell, vector)" << std::endl; 00589 m_PyCubGeomFile << "cells.append(cell)" << std::endl; 00590 00591 cells[n-1]=cell; 00592 } 00593 // loop and create cylinders 00594 if(nCyl > 0){ 00595 m_Pincell(i).GetCylSizes(n, nRadii); 00596 SimpleArray<iBase_EntityHandle> cyls(nRadii); 00597 SimpleArray<iBase_EntityHandle> cell_copys(nRadii); 00598 SimpleArray<iBase_EntityHandle> intersec_main(nRadii); 00599 iBase_EntityHandle tmp_intersec = NULL; 00600 (void) tmp_intersec; 00601 //declare variables 00602 CVector<double> dVCylRadii(2*nRadii); 00603 CVector<std::string> szVMat(nRadii); 00604 CVector<std::string> szVCylMat(nRadii); 00605 int nType = 0; 00606 //get values 00607 m_Pincell(i).GetCylRadii(n, dVCylRadii); 00608 m_Pincell(i).GetCylPos(n, dVCylXYPos); 00609 m_Pincell(i).GetCylMat(n, szVCylMat); 00610 m_Pincell(i).GetCylZPos(n, dVCylZPos); 00611 m_Pincell(i).GetCellType(n, nType); 00612 00613 dHeight = dVCylZPos(2)-dVCylZPos(1); 00614 00615 m_PyCubGeomFile << "cells_copy=[]\nintersec_main=[]" << std::endl; 00616 m_PyCubGeomFile << "cyls = [] \ncp_in = []" << std::endl; 00617 m_PyCubGeomFile << "sub1 = [] \nsub2 = []" << std::endl; 00618 for (int m=1; m<=nRadii; m++){ 00619 if (nType == 0){ 00620 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00621 iGeom_createCylinder(igeomImpl->instance(), dHeight, dVCylRadii(m), dVCylRadii(m), 00622 &cyl, &err); 00623 #endif 00624 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ")" << std::endl; 00625 } 00626 else{ 00627 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00628 iGeom_createCone(igeomImpl->instance(), dHeight, dVCylRadii(2*m-1), dVCylRadii(2*m-1), dVCylRadii(2*m), 00629 &cyl, &err); 00630 #endif 00631 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m) << ")" << std::endl; 00632 } 00633 00634 // move their centers and also move to the assembly location ! Modify if cyl is outside brick 00635 dCylMoveX = dVCylXYPos(1)+dX; 00636 dCylMoveY = dVCylXYPos(2)+dY; 00637 dZMove = (dVCylZPos(1)+dVCylZPos(2))/2.0; 00638 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00639 iGeom_moveEnt(igeomImpl->instance(), cyl, dCylMoveX,dCylMoveY,dZMove, &err); 00640 #endif 00641 m_PyCubGeomFile << "vector = [" << dCylMoveX << ", " << dCylMoveY << ", " << dZMove << "]" << std::endl; 00642 m_PyCubGeomFile << "cubit.move( cell, vector)" << std::endl; 00643 m_PyCubGeomFile << "cyls.append(cyl)" << std::endl; 00644 cyls[m-1] = cyl; 00645 00646 00647 //copy cell nRadii times for intersection with cylinders 00648 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00649 iGeom_copyEnt(igeomImpl->instance(), cells[n-1], &cell_copy, &err); 00650 #endif 00651 m_PyCubGeomFile << "cell_copy = cubit.copy_body(cells[" << n-1 << "])" << std::endl; 00652 m_PyCubGeomFile << "cells_copy.append(cell_copy)" << std::endl; 00653 cell_copys[m-1] = cell_copy; 00654 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00655 iGeom_intersectEnts(igeomImpl->instance(), cell_copys[m-1], cyls[m-1],&intersec,&err); 00656 #endif 00657 m_PyCubGeomFile << "tmpunite = cubit.unite(cells_copy[" << m-1 << "]\ncyls [" << m-1 << "])" << std::endl; 00658 m_PyCubGeomFile << "intersec = cubit.subtract(tmpunite, cells_copy[" << m-1 << "])" << std::endl; 00659 m_PyCubGeomFile << "intersec_main.append(intersec)" << std::endl; 00660 intersec_main[m-1] = intersec; 00661 intersec = NULL; 00662 } 00663 00664 //set tag on inner most cylinder, search for the full name of the abbreviated Cell Mat 00665 tmp_vol1=intersec_main[0]; 00666 m_PyCubGeomFile << "tmp_vol1 = intersec_main[0]" << std::endl; 00667 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00668 if(strcmp (szVCylMat(1).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00669 sMatName = m_szAssmMat(p); 00670 } 00671 } 00672 m_PyCubGeomFile << "tmp_vol1 = cyls[0] \ncp_in.append(tmp_vol1)" << std::endl; 00673 cp_in.push_back(tmp_vol1); 00674 00675 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00676 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00677 sMatName.c_str(), 10, &err); 00678 #endif 00679 m_PyCubGeomFile << "lid =tmp_vol1.id()" << std::endl; 00680 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00681 00682 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00683 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00684 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00685 pin_name.c_str(), pin_name.size(), &err); 00686 #endif 00687 std::cout << "Naming pin body :" << pin_name<< std::endl; 00688 } 00689 Name_Faces(sMatName, tmp_vol1, this_tag); 00690 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_vol1) " << std::endl; 00691 00692 // copy the outermost cyl 00693 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00694 iGeom_copyEnt(igeomImpl->instance(), intersec_main[nRadii-1], &tmp_intersec, &err); 00695 #endif 00696 m_PyCubGeomFile << "tmp_intersec = cubit.copy_body(intersec_main[" << nRadii-1 << "])" << std::endl; 00697 00698 // subtract the outermost cyl from the cell 00699 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00700 iGeom_subtractEnts(igeomImpl->instance(), cells[n-1], tmp_intersec, &tmp_new, &err); 00701 #endif 00702 m_PyCubGeomFile << "sub1.append(tmp_intersec\nsub2.append(cells["<< n-1 << "])" << std::endl; 00703 m_PyCubGeomFile << "tmp_new = cubit.subtract(sub2, sub1)" << std::endl; 00704 m_PyCubGeomFile << "sub1[:] = []\nsub2[:] = []" << std::endl; 00705 // now search for the full name of the abbreviated Cell Mat 00706 // int tag_no; 00707 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00708 if(strcmp (szVCellMat(n).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00709 // tag_no = p; 00710 sMatName = m_szAssmMat(p); 00711 } 00712 } 00713 std::cout << "created: " << sMatName << std::endl; 00714 00715 cp_in.push_back(tmp_new); 00716 m_PyCubGeomFile << "cp_in.append(tmp_new)" << std::endl; 00717 00718 // set the name of the annulus 00719 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00720 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00721 sMatName.c_str(),sMatName.size(), &err); 00722 #endif 00723 m_PyCubGeomFile << "lid =tmp_new.id()" << std::endl; 00724 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00725 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00726 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00727 pin_name.c_str(), pin_name.size(), &err); 00728 #endif 00729 std::cout << "Naming pin body :" << pin_name<< std::endl; 00730 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << pin_name << "\" )" << std::endl; 00731 00732 Name_Faces(sMatName, tmp_new, this_tag); 00733 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_new) " << std::endl; 00734 00735 for (int b=nRadii; b>1; b--){ 00736 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00737 iGeom_copyEnt(igeomImpl->instance(), intersec_main[b-2], &tmp_intersec, &err); 00738 #endif 00739 m_PyCubGeomFile << "tmp_intersec = cubit.copy_body(intersec_main[" << b-1 << "])" << std::endl; 00740 00741 //subtract tmp vol from the outer most 00742 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00743 iGeom_subtractEnts(igeomImpl->instance(), intersec_main[b-1], tmp_intersec, &tmp_new, &err); 00744 #endif 00745 m_PyCubGeomFile << "sub1.append(tmp_intersec\nsub2.append(intersec_main["<< b-1 << "])" << std::endl; 00746 m_PyCubGeomFile << "tmp_new = cubit.subtract(sub2, sub1)" << std::endl; 00747 m_PyCubGeomFile << "sub1[:] = []\nsub2[:] = []" << std::endl; 00748 // now search for the full name of the abbreviated Cell Mat 00749 // int tag_no; 00750 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00751 if(strcmp (szVCylMat(b).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00752 // tag_no = p; 00753 sMatName = m_szAssmMat(p); 00754 } 00755 } 00756 std::cout << "created: " << sMatName << std::endl; 00757 00758 cp_in.push_back(tmp_new); 00759 m_PyCubGeomFile << "cp_in.append(tmp_new)" << std::endl; 00760 00761 // set the name of the annulus 00762 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00763 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00764 sMatName.c_str(),sMatName.size(), &err); 00765 #endif 00766 m_PyCubGeomFile << "lid =tmp_new.id()" << std::endl; 00767 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00768 00769 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00770 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00771 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00772 pin_name.c_str(), pin_name.size(), &err); 00773 #endif 00774 std::cout << "Naming pin body :" << pin_name<< std::endl; 00775 } 00776 Name_Faces(sMatName, tmp_new, this_tag); 00777 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_new) " << std::endl; 00778 m_PyCubGeomFile << "cyls[" << b-1 << "] = tmp_new" << std::endl; 00779 00780 // copy the new into the cyl array 00781 cyls[b-1] = tmp_new; 00782 00783 } 00784 } 00785 if(nDuctIndex > 0){ 00786 for (int count = 0; count < (int) cp_in.size(); count++){ 00787 cp_inpins[nDuctIndex-1].push_back(cp_in[count]); 00788 m_PyCubGeomFile << "cp_inpins["<< nDuctIndex -1 << "].append(cp_in[" << count << "])" << std::endl; 00789 } 00790 00791 } 00792 cp_in.clear(); 00793 m_PyCubGeomFile << "cp_in[:] =[]" << std::endl; 00794 00795 } 00796 } 00797 // this branch of the routine is responsible for creating cylinders with '0' cells 00798 if(nCells == 0){ 00799 00800 // get cylinder data 00801 m_Pincell(i).GetNumCyl(nCyl); 00802 nCells = nCyl; 00803 cells.resize(nCells); 00804 00805 for(int n=1;n<=nCells; n++){ 00806 00807 // get some cylinder parameters to create the cell material for intersection 00808 m_Pincell(i).GetCylZPos(n, dVCylZPos); 00809 dHeight = dVCylZPos(2)-dVCylZPos(1); 00810 dZMove = (dVCylZPos(1)+dVCylZPos(2))/2.0; 00811 00812 if(m_szGeomType =="hexagonal"){ 00813 00814 m_Pincell(i).GetPitch(dP, dHeightTotal); // this dHeight is not used in creation 00815 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00816 double dSide = dP/(sqrt(3)); 00817 iGeom_createPrism(igeomImpl->instance(), dHeight, 6, 00818 dSide, dSide, 00819 &cell, &err); 00820 #endif 00821 } 00822 m_PyCubGeomFile << "cyls = [] \ncp_in = []\ncells = []" << std::endl; 00823 m_PyCubGeomFile << "sub1 = [] \nsub2 = []" << std::endl; 00824 // if rectangular geometry 00825 if(m_szGeomType =="rectangular"){ 00826 00827 m_Pincell(i).GetPitch(PX, PY, PZ); 00828 // create brick 00829 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00830 iGeom_createBrick( igeomImpl->instance(),PX,PY,PZ, &cell,&err ); 00831 #endif 00832 m_PyCubGeomFile << "cell = cubit.brick(' " << PX << ", " << PY << ", " << PZ << ")" << std::endl; 00833 } 00834 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00835 iGeom_moveEnt(igeomImpl->instance(), cell, dX, dY, dZMove, &err); 00836 #endif 00837 m_PyCubGeomFile << "vector = [" << dX << ", " << dY << ", " << dZMove << "]" << std::endl; 00838 m_PyCubGeomFile << "cubit.move( cell, vector)" << std::endl; 00839 m_PyCubGeomFile << "cells.append(cell)" << std::endl; 00840 cells[n-1]=cell; 00841 // loop and create cylinders 00842 if(nCyl > 0){ 00843 m_Pincell(i).GetCylSizes(n, nRadii); 00844 00845 //declare variables 00846 SimpleArray<iBase_EntityHandle> cyls(nRadii), cell_copys(nRadii), intersec_main(nRadii), intersec_copy(nRadii); 00847 iBase_EntityHandle tmp_intersec = NULL; 00848 (void) tmp_intersec; 00849 CVector<double> dVCylRadii(2*nRadii); 00850 CVector<std::string> szVMat(nRadii), szVCylMat(nRadii); 00851 int nType = 0; 00852 //get values 00853 m_Pincell(i).GetCylRadii(n, dVCylRadii); 00854 m_Pincell(i).GetCylPos(n, dVCylXYPos); 00855 m_Pincell(i).GetCylMat(n, szVCylMat); 00856 m_Pincell(i).GetCellType(n, nType); 00857 00858 00859 // get the index for cp_inpins based on Z-heights 00860 for (int dd = 1; dd <= m_nDuct; dd++){ 00861 if((m_dMZAssm(dd, 2)) >= (dVCylZPos(2)) && (m_dMZAssm(dd, 1)) >= (dVCylZPos(1))) 00862 nDuctIndex = dd; 00863 if (nDuctIndex != -1) 00864 break; 00865 } 00866 00867 for (int m=1; m<=nRadii; m++){ 00868 if (nType == 0){ 00869 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00870 iGeom_createCylinder(igeomImpl->instance(), dHeight, dVCylRadii(m), dVCylRadii(m), 00871 &cyl, &err); 00872 #endif 00873 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ", " << dVCylRadii(m) << ")" << std::endl; 00874 } 00875 else{ 00876 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00877 iGeom_createCone(igeomImpl->instance(), dHeight, dVCylRadii(2*m-1), dVCylRadii(2*m-1), dVCylRadii(2*m), 00878 &cyl, &err); 00879 #endif 00880 m_PyCubGeomFile << "#\n#\ncyl = cubit.cylinder(" << dHeight << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m-1) << ", " << dVCylRadii(2*m) << ")" << std::endl; 00881 } 00882 00883 // move their centers and also move to the assembly location ! Modify if cyl is outside brick 00884 dCylMoveX = dVCylXYPos(1)+dX; 00885 dCylMoveY = dVCylXYPos(2)+dY; 00886 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00887 iGeom_moveEnt(igeomImpl->instance(), cyl, dCylMoveX,dCylMoveY,dZMove, &err); 00888 #endif 00889 m_PyCubGeomFile << "vector = [" << dCylMoveX << ", " << dCylMoveY << ", " << dZMove << "]" << std::endl; 00890 m_PyCubGeomFile << "cubit.move( cell, vector)" << std::endl; 00891 m_PyCubGeomFile << "cyls.append(cyl)" << std::endl; 00892 00893 cyls[m-1] = cyl; 00894 00895 //copy cell nRadii times for intersection with cylinders 00896 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00897 iGeom_copyEnt(igeomImpl->instance(), cells[n-1], &cell_copy, &err); 00898 #endif 00899 m_PyCubGeomFile << "cell_copy = cubit.copy_body(cells[" << n-1 << "])" << std::endl; 00900 m_PyCubGeomFile << "cells_copy.append(cell_copy)" << std::endl; 00901 00902 cell_copys[m-1] = cell_copy; 00903 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00904 iGeom_intersectEnts(igeomImpl->instance(), cell_copy, cyls[m-1],&intersec,&err); 00905 #endif 00906 m_PyCubGeomFile << "tmpunite = cubit.unite(cells_copy[" << m-1 << "], cyls [" << m-1 << "])" << std::endl; 00907 m_PyCubGeomFile << "intersec = cubit.subtract(tmpunite, cells_copy[" << m-1 << "])" << std::endl; 00908 m_PyCubGeomFile << "intersec_main.append(intersec)" << std::endl; 00909 00910 intersec_main[m-1] = intersec; 00911 intersec = NULL; 00912 } 00913 00914 //set tag on inner most cylinder, search for the full name of the abbreviated Cell Mat 00915 tmp_vol1=intersec_main[0]; 00916 m_PyCubGeomFile << "tmp_vol1 = intersec_main[0]" << std::endl; 00917 00918 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00919 if(strcmp (szVCylMat(1).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00920 sMatName = m_szAssmMat(p); 00921 } 00922 } 00923 00924 m_PyCubGeomFile << "tmp_vol1 = cyls[0] \ncp_in.append(tmp_vol1)" << std::endl; 00925 cp_in.push_back(tmp_vol1); 00926 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00927 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00928 sMatName.c_str(), 10, &err); 00929 #endif 00930 m_PyCubGeomFile << "lid =tmp_vol1.id()" << std::endl; 00931 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00932 00933 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00934 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00935 iGeom_setData(igeomImpl->instance(), tmp_vol1, this_tag, 00936 pin_name.c_str(), pin_name.size(), &err); 00937 #endif 00938 std::cout << "Naming pin body :" << pin_name<< std::endl; 00939 } 00940 00941 Name_Faces(sMatName, tmp_vol1, this_tag); 00942 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_vol1) " << std::endl; 00943 00944 // delete the cell as this is the case when no. cell material is specified 00945 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00946 iGeom_deleteEnt(igeomImpl->instance(), cells[n-1], &err); 00947 #endif 00948 m_PyCubGeomFile << "cubit.cmd('delete vol << cells[" << n-1 << "].id()')" << std::endl; 00949 00950 00951 // other cyl annulus after substraction 00952 for (int b=nRadii; b>1; b--){ 00953 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00954 iGeom_copyEnt(igeomImpl->instance(), intersec_main[b-2], &tmp_intersec, &err); 00955 #endif 00956 m_PyCubGeomFile << "tmp_intersec = cubit.copy_body(intersec_main[" << b-2 << "])" << std::endl; 00957 00958 //subtract tmp vol from the outer most 00959 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00960 iGeom_subtractEnts(igeomImpl->instance(), intersec_main[b-1], tmp_intersec, &tmp_new, &err); 00961 #endif 00962 m_PyCubGeomFile << "sub1.append(tmp_intersec\nsub2.append(intersec_main["<< b-1 << "])" << std::endl; 00963 m_PyCubGeomFile << "tmp_new = cubit.subtract(sub2, sub1)" << std::endl; 00964 m_PyCubGeomFile << "sub1[:] = []\nsub2[:] = []" << std::endl; 00965 00966 // now search for the full name of the abbreviated Cell Mat 00967 // int tag_no; 00968 for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){ 00969 if(strcmp (szVCylMat(b).c_str(), m_szAssmMatAlias(p).c_str()) == 0){ 00970 // tag_no = p; 00971 sMatName = m_szAssmMat(p); 00972 } 00973 } 00974 std::cout << "created: " << sMatName << std::endl; 00975 00976 m_PyCubGeomFile << "cp_in.append(tmp_new)" << std::endl; 00977 cp_in.push_back(tmp_new); 00978 00979 // set the name of the annulus 00980 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00981 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00982 sMatName.c_str(),sMatName.size(), &err); 00983 #endif 00984 00985 m_PyCubGeomFile << "lid =tmp_new.id()" << std::endl; 00986 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << sMatName << "\" )" << std::endl; 00987 00988 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00989 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00990 iGeom_setData(igeomImpl->instance(), tmp_new, this_tag, 00991 pin_name.c_str(), pin_name.size(), &err); 00992 #endif 00993 std::cout << "Naming pin body :" << pin_name<< std::endl; 00994 m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \"" << pin_name << "\" )" << std::endl; 00995 } 00996 00997 Name_Faces(sMatName, tmp_new, this_tag); 00998 m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_new) " << std::endl; 00999 m_PyCubGeomFile << "cyls[" << b-1 << "] = tmp_new" << std::endl; 01000 01001 // copy the new into the cyl array 01002 cyls[b-1] = tmp_new; 01003 01004 } 01005 } 01006 if(nDuctIndex > 0){ 01007 for (int count = 0; count < (int) cp_in.size(); count++){ 01008 cp_inpins[nDuctIndex-1].push_back(cp_in[count]); 01009 m_PyCubGeomFile << "cp_inpins["<< nDuctIndex -1 << "].append(cp_in[" << count << "])" << std::endl; 01010 } 01011 01012 } 01013 cp_in.clear(); 01014 m_PyCubGeomFile << "cp_in[:] =[]" << std::endl; 01015 01016 } 01017 } 01018 01019 } 01020 01021 }
