MeshKit
1.0
00001 /********************************************* 00002 Reactor Geometry Generator 00003 Argonne National Laboratory 00004 00005 Contains CParser class implementation. 00006 *********************************************/ 00007 #include <cctype> 00008 #include "meshkit/parser.hpp" 00009 #include <stdlib.h> 00010 00011 CParser::CParser () 00012 // --------------------------------------------------------------------------- 00013 // Function: default constructor 00014 // Input: none 00015 // Output: none 00016 // --------------------------------------------------------------------------- 00017 { 00018 } 00019 00020 CParser::~CParser () 00021 // --------------------------------------------------------------------------- 00022 // Function: destructor 00023 // Input: none 00024 // Output: none 00025 // --------------------------------------------------------------------------- 00026 { 00027 } 00028 00029 bool CParser::ReadNextLine (std::ifstream& FileInput, int& nLineNum, 00030 std::string& szInputString, const int MAXCHARS, 00031 const std::string& szComment, bool bLowerCase) 00032 // --------------------------------------------------------------------------- 00033 // Function: reads the next line skipping over the comment lines 00034 // and converts all alphabets to lower case if requested 00035 // Input: file istream, line #, string to hold the input line, 00036 // max. # of characters expected in each input line, 00037 // comment character(s) at the beginning of a comment line, 00038 // lowercase conversion option 00039 // Output: updated values of line # and the string 00040 // return value is true if successful 00041 // false if an error state is encountered 00042 // Restriction: Cannot read a line over 256 characters 00043 // --------------------------------------------------------------------------- 00044 { 00045 int flag = 0; 00046 int flag1 =0; 00047 bool bWhSpc = false; 00048 int tokenfound = 1; 00049 const int MAXCH = 10000; 00050 char szInp[MAXCH]; 00051 char szTemp [MAXCH]; 00052 std::vector<std::string> tokens; 00053 00054 // enough capacity to read and store? 00055 if (MAXCHARS > MAXCH) 00056 return false; 00057 00058 // comment character(s) 00059 int nCLen = static_cast<int>(szComment.length()); 00060 // read the line (skip over comment lines) 00061 for(;;) 00062 { 00063 ++nLineNum; 00064 FileInput.getline (szInp, MAXCHARS); 00065 // // end-of-file? 00066 // if (FileInput.eof()) 00067 // return false; 00068 if (FileInput.fail()) 00069 FileInput.clear (FileInput.rdstate() & ~std::ios::failbit); 00070 // unrecoverable error? 00071 if (FileInput.bad()) 00072 return false; 00073 00074 // successful read 00075 szInputString = szInp; 00076 GetTokens(szInputString, " ", tokens); 00077 bWhSpc = EatWhiteSpace(szInputString); 00078 if ((szInputString.substr(0,nCLen) != szComment)&& (bWhSpc ==false)){ 00079 szInputString = szInp; 00080 GetTokens(szInputString, " ", tokens); 00081 for(unsigned int i=0; i< tokens.size(); i++){ 00082 std::string const& temptoken = tokens[i]; 00083 if (temptoken == "&") 00084 flag1 = 1; 00085 } 00086 00087 //Filter the comment tokens 00088 // FilterComment(szInputString, szComment); 00089 00090 //if "&" is found continue to read the next line 00091 std::string szTempString = szInputString; 00092 00093 // check if line is continued & 00094 while(flag1 ==1 && tokenfound == 1){ 00095 GetTokens(szTempString, " ", tokens); 00096 for(unsigned int i=1; i<=tokens.size(); i++){ 00097 std::string const& temptoken = tokens[i-1]; 00098 if (temptoken == "&"){ 00099 tokenfound = 1; 00100 flag = 1; 00101 } 00102 else{ 00103 if(flag==1) 00104 flag = 1;//do nothing token already found 00105 else 00106 tokenfound = 0; 00107 } 00108 } 00109 if(tokenfound ==1){ 00110 ++nLineNum; 00111 RemoveToken(szInputString); 00112 //- getting more tokens and add to the existing 00113 FileInput.getline (szTemp, MAXCHARS); 00114 // end-of-file? 00115 if (FileInput.eof()) 00116 return false; 00117 if (FileInput.fail()) 00118 FileInput.clear (FileInput.rdstate() & ~std::ios::failbit); 00119 // unrecoverable error? 00120 if (FileInput.bad()) 00121 return false; 00122 // successful read 00123 szTempString = szTemp; 00124 FilterComment(szTempString, szComment); 00125 szInputString+=" "; 00126 szInputString+=szTemp; 00127 } 00128 else{ 00129 break;//while loop ents 00130 } 00131 flag = 0; 00132 } 00133 // while loop ends 00134 // convert to lower case? 00135 if (bLowerCase){ 00136 for (int i=0; i < static_cast<int>(szInputString.length()); i++) 00137 szInputString[i] = tolower(szInputString[i]); 00138 } 00139 break; 00140 } 00141 } 00142 return true; 00143 } 00144 00145 void CParser::GetTokens (const std::string& input, 00146 const std::string& delims, 00147 std::vector<std::string>& tokens) 00148 // ---------------------------------------------------------------------------- 00149 // Function: Parses the input line and gets the tokens 00150 // Input: string, delimiters 00151 // Output: vector containing the tokens 00152 // ---------------------------------------------------------------------------- 00153 { 00154 std::string::size_type beg_index, end_index; 00155 00156 // clear the vector that will store the tokens 00157 tokens.clear(); 00158 00159 // get location of the first character that is not a delimiter 00160 beg_index = input.find_first_not_of(delims); 00161 00162 // loop while the beginning index is not the end of string 00163 while (beg_index != std::string::npos) 00164 { 00165 // get location of the next delimiter 00166 end_index = input.find_first_of (delims, beg_index); 00167 00168 // if this location is the end of string then adjust the value 00169 // as string length 00170 if (end_index == std::string::npos) end_index = input.length(); 00171 00172 // save the string between beg_index and end_index 00173 tokens.push_back (input.substr(beg_index,end_index-beg_index)); 00174 00175 // get location of the next character that is not a delimiter 00176 beg_index = input.find_first_not_of (delims, end_index); 00177 } 00178 } 00179 00180 00181 void CParser:: FilterComment (std::string& input, const std::string& szComment) 00182 00183 // ---------------------------------------------------------------------------- 00184 // Function: Parses the input line and gets the tokens 00185 // Input: string, delimiters 00186 // Output: vector containing the tokens 00187 // ---------------------------------------------------------------------------- 00188 { 00189 // remove comment from the line obtained 00190 unsigned int i; 00191 std::vector<std::string> tokens; 00192 std::string tempInput; 00193 GetTokens(input, " ", tokens); 00194 for(i=0; i<tokens.size(); i++){ 00195 std::string const& temptoken = tokens[i]; 00196 if(temptoken == szComment){ 00197 break; 00198 } 00199 else{ 00200 tempInput+=temptoken; 00201 if(i!=(tokens.size()-1)){ //indent{ 00202 if (tokens[i+1]!=szComment) 00203 tempInput+=" "; 00204 } 00205 else{ 00206 tempInput+=""; // no indent 00207 } 00208 } 00209 } 00210 input = tempInput.c_str(); 00211 } 00212 00213 void CParser:: RemoveToken (std::string& input) 00214 00215 // ---------------------------------------------------------------------------- 00216 // Function: Parses the input line and gets the tokens 00217 // Input: string, delimiters 00218 // Output: vector containing the tokens 00219 // ---------------------------------------------------------------------------- 00220 { 00221 // remove comment from the line obtained 00222 unsigned int i; 00223 std::vector<std::string> tokens; 00224 std::string tempInput; 00225 GetTokens(input, " ", tokens); 00226 for(i=0; i<tokens.size(); i++){ 00227 std::string const& temptoken = tokens[i]; 00228 if(temptoken == "&"){ 00229 break; 00230 } 00231 else{ 00232 tempInput+=temptoken; 00233 if(i!=(tokens.size()-1)){ //indent{ 00234 if (tokens[i+1]!="&") 00235 tempInput+=" "; 00236 } 00237 else{ 00238 tempInput+=""; // no indent 00239 } 00240 } 00241 } 00242 input = tempInput.c_str(); 00243 } 00244 00245 bool CParser:: EatWhiteSpace (std::string& input) 00246 00247 // ---------------------------------------------------------------------------- 00248 // Function: Parses the input line and gets the tokens 00249 // Input: string, delimiters 00250 // Output: vector containing the tokens 00251 // ---------------------------------------------------------------------------- 00252 { 00253 // remove comment from the line obtained 00254 unsigned int i; 00255 std::vector<std::string> tokens; 00256 std::string tempInput; 00257 GetTokens(input, " ", tokens); 00258 for(i=0; i<tokens.size(); i++){ 00259 std::string const& temptoken = tokens[i]; 00260 if(temptoken != " " && temptoken !="!"){ 00261 return false; 00262 break; 00263 } 00264 else if(temptoken =="!"){ 00265 return true; 00266 break; 00267 } 00268 } 00269 return false; 00270 }
