MeshKit
1.0
00001 // $Id: quadrics.cxx,v 1.5 1997/10/01 14:07:28 garland Exp $ 00002 00003 //#include "qslim.h" 00004 #include <assert.h> 00005 #include "quadrics.h" 00006 #include "3D.h" 00007 #include "primitives.h" 00008 00010 // 00011 // Primitive quadric construction and evaluation routines 00012 // 00013 00014 // 00015 // Construct a quadric to evaluate the squared distance of any point 00016 // to the given point v. Naturally, the iso-surfaces are just spheres 00017 // centered at v. 00018 // 00019 Mat4 quadrix_vertex_constraint(const Vec3& v) 00020 { 00021 Mat4 L(Mat4::identity); 00022 00023 L(0,3) = -v[0]; 00024 L(1,3) = -v[1]; 00025 L(2,3) = -v[2]; 00026 L(3,3) = v*v; 00027 00028 L(3,0) = L(0,3); 00029 L(3,1) = L(1,3); 00030 L(3,2) = L(2,3); 00031 00032 return L; 00033 } 00034 Mat4 quadrix_vertex_constraint(moab::EntityHandle vert) 00035 { 00036 Mat4 L(Mat4::identity); 00037 double v[3]; 00038 mb->get_coords(&vert, 1 , v); 00039 L(0,3) = -v[0]; 00040 L(1,3) = -v[1]; 00041 L(2,3) = -v[2]; 00042 L(3,3) = v[0]*v[0] + v[1]*v[1] + v[2]*v[2] ; // v*v; 00043 00044 L(3,0) = L(0,3); 00045 L(3,1) = L(1,3); 00046 L(3,2) = L(2,3); 00047 00048 return L; 00049 } 00050 // 00051 // Construct a quadric to evaluate the squared distance of any point 00052 // to the given plane [ax+by+cz+d = 0]. This is the "fundamental error 00053 // quadric" discussed in the paper. 00054 // 00055 Mat4 quadrix_plane_constraint(double a, double b, double c, double d) 00056 { 00057 Mat4 K(Mat4::zero); 00058 00059 K(0,0) = a*a; K(0,1) = a*b; K(0,2) = a*c; K(0,3) = a*d; 00060 K(1,0) =K(0,1); K(1,1) = b*b; K(1,2) = b*c; K(1,3) = b*d; 00061 K(2,0) =K(0,2); K(2,1) =K(1,2); K(2,2) = c*c; K(2,3) = c*d; 00062 K(3,0) =K(0,3); K(3,1) =K(1,3); K(3,2) =K(2,3);K(3,3) = d*d; 00063 00064 return K; 00065 } 00066 00067 // 00068 // Define some other convenient ways for constructing these plane quadrics. 00069 // 00070 Mat4 quadrix_plane_constraint(const Vec3& n, double d) 00071 { 00072 return quadrix_plane_constraint(n[X], n[Y], n[Z], d); 00073 } 00074 00075 //Mat4 quadrix_plane_constraint(Face& T) 00076 Mat4 quadrix_plane_constraint(moab::EntityHandle triangle) 00077 { 00078 // const Plane& p = T.plane(); 00079 Plane p=trianglePlane(mb, triangle); 00080 double a,b,c,d; 00081 p.coeffs(&a, &b, &c, &d); 00082 00083 return quadrix_plane_constraint(a, b, c, d); 00084 } 00085 00086 Mat4 quadrix_plane_constraint(const Vec3& v1, const Vec3& v2, const Vec3& v3) 00087 { 00088 Plane P(v1,v2,v3); 00089 double a,b,c,d; 00090 P.coeffs(&a, &b, &c, &d); 00091 00092 return quadrix_plane_constraint(a, b, c, d); 00093 } 00094 00095 double quadrix_evaluate_vertex(const Vec3& v, const Mat4& K) 00096 { 00097 double x=v[X], y=v[Y], z=v[Z]; 00098 00099 #ifndef VECTOR_COST_EVALUATION 00100 // 00101 // This is the fast way of computing (v^T Q v). 00102 // 00103 return x*x*K(0,0) + 2*x*y*K(0,1) + 2*x*z*K(0,2) + 2*x*K(0,3) 00104 + y*y*K(1,1) + 2*y*z*K(1,2) + 2*y*K(1,3) 00105 + z*z*K(2,2) + 2*z*K(2,3) 00106 + K(3,3); 00107 #else 00108 // 00109 // The equivalent thing using matrix/vector operations. 00110 // It's a lot clearer, but it's also slower. 00111 // 00112 Vec4 v2(x,y,z,1); 00113 return v2*(K*v2); 00114 #endif 00115 } 00116 00117 00118 00120 // 00121 // Routines for computing discontinuity constraints 00122 // 00123 00124 //bool is_border(Edge *e ) 00125 bool is_border(moab::EntityHandle eh ) 00126 { 00127 // use nb of triangles connected to check if number of tri is 1 00128 std::vector<moab::EntityHandle> adjTri; 00129 moab::ErrorCode rval = mb->get_adjacencies(&eh, 1, 2, false, adjTri, 00130 moab::Interface::UNION); 00131 if (moab::MB_SUCCESS==rval && adjTri.size()==1) 00132 return true; 00133 return false; 00134 } 00135 00136 bool check_for_discontinuity(moab::EntityHandle eh) //Edge *e) 00137 { 00138 return is_border(eh); 00139 } 00140 00141 Mat4 quadrix_discontinuity_constraint( moab::EntityHandle mbe 00142 /*Edge *edge*/, const Vec3& n) 00143 { 00144 //Vec3& org = *edge->org(); 00145 //Vec3& dest = *edge->dest(); 00146 // to do: Vec3 origin of edge 00147 // is the orientation important for an edge? 00148 const moab::EntityHandle * conn; 00149 int num_nodes; 00150 mb->get_connectivity(mbe, conn, num_nodes); 00151 Vec3 dest = getVec3FromMBVertex(mb, conn[1]); // 00152 Vec3 org = getVec3FromMBVertex(mb, conn[0]); 00153 Vec3 e = dest - org; 00154 00155 Vec3 n2 = e ^ n; 00156 unitize(n2); 00157 00158 double d = -n2 * org; 00159 return quadrix_plane_constraint(n2, d); 00160 } 00161 00162 00163 Mat4 quadrix_discontinuity_constraint(moab::EntityHandle mbedge)// Edge *edge) 00164 { 00165 Mat4 D(Mat4::zero); 00166 00167 /* 00168 face_buffer& faces = edge->faceUses(); 00169 00170 for(int i=0; i<faces.length(); i++) 00171 D += quadrix_discontinuity_constraint(edge,faces(i)->plane().normal()); 00172 */ 00173 // to do : to get the connected faces to the edge 00174 00175 std::vector<moab::EntityHandle> adjFaces; 00176 moab::ErrorCode rval = mb->get_adjacencies(&mbedge, 1, 2, false, adjFaces, 00177 moab::Interface::UNION); 00178 assert(rval == moab::MB_SUCCESS); 00179 00180 for (unsigned int i=0; i<adjFaces.size(); i++) 00181 { 00182 moab::EntityHandle F = adjFaces[i]; 00183 Plane p = trianglePlane( mb, F); 00184 D += quadrix_discontinuity_constraint(mbedge, p.normal()); 00185 } 00186 return D; 00187 } 00188 00189 00190 00192 // 00193 // Routines for computing contraction target 00194 // 00195 00196 bool quadrix_find_local_fit(const Mat4& K, 00197 const Vec3& v1, const Vec3& v2, 00198 Vec3& candidate) 00199 { 00200 00201 Vec3 v3 = (v1 + v2) / 2; 00202 00203 bool try_midpoint = opts.placement_policy > PLACE_ENDPOINTS; 00204 00205 double c1 = quadrix_evaluate_vertex(v1, K); 00206 double c2 = quadrix_evaluate_vertex(v2, K); 00207 double c3; 00208 if( try_midpoint ) c3 = quadrix_evaluate_vertex(v3, K); 00209 00210 if( c1<c2 ) 00211 { 00212 if( try_midpoint && c3<c1 ) 00213 candidate=v3; 00214 else 00215 candidate=v1; 00216 } 00217 else 00218 { 00219 if( try_midpoint && c3<c2 ) 00220 candidate=v3; 00221 else 00222 candidate=v2; 00223 } 00224 00225 return true; 00226 } 00227 00228 bool quadrix_find_line_fit(const Mat4& Q, 00229 const Vec3& v1, const Vec3& v2, 00230 Vec3& candidate) 00231 { 00232 Vec3 d = v1-v2; 00233 00234 Vec3 Qv2 = Q*v2; 00235 Vec3 Qd = Q*d; 00236 00237 double denom = 2*d*Qd; 00238 00239 if( denom == 0.0 ) 00240 return false; 00241 00242 double a = (d*Qv2 + v2*Qd) / denom; 00243 00244 if( a<0.0 ) a=0.0; 00245 if( a>1.0 ) a=1.0; 00246 00247 00248 candidate = a*d + v2; 00249 return true; 00250 } 00251 00252 bool quadrix_find_best_fit(const Mat4& Q, Vec3& candidate) 00253 { 00254 Mat4 K = Q; 00255 K(3,0) = K(3,1) = K(3,2) = 0.0; K(3,3) = 1; 00256 00257 00258 Mat4 M; 00259 double det = K.inverse(M); 00260 if( FEQ(det, 0.0, 1e-12) ) 00261 return false; 00262 00263 00264 #ifdef SAFETY 00265 // 00266 // The homogeneous division SHOULDN'T be necessary. 00267 // But, when we're being SAFE, we do it anyway just in case. 00268 // 00269 candidate[X] = M(0,3)/M(3,3); 00270 candidate[Y] = M(1,3)/M(3,3); 00271 candidate[Z] = M(2,3)/M(3,3); 00272 #else 00273 candidate[X] = M(0,3); 00274 candidate[Y] = M(1,3); 00275 candidate[Z] = M(2,3); 00276 #endif 00277 00278 return true; 00279 } 00280 00281 00282 double quadrix_pair_target(const Mat4& Q, 00283 moab::EntityHandle v1, //Vertex *v1, 00284 moab::EntityHandle v2, // Vertex *v2, 00285 Vec3& candidate) 00286 { 00287 int policy = opts.placement_policy; 00288 00289 // 00290 // This analytic boundary preservation isn't really necessary. The 00291 // boundary constraint quadrics are quite effective. But, I've left it 00292 // in anyway. 00293 // 00294 Vec3 vec1 = getVec3FromMBVertex(mb, v1); 00295 Vec3 vec2 = getVec3FromMBVertex(mb, v2); 00296 if( opts.will_preserve_boundaries ) 00297 { 00298 int c1 = classifyVertex(mb, v1); 00299 int c2 = classifyVertex(mb, v2); 00300 00301 // if both are on boundary, put a high penalty cost 00302 if (c1>0 && c2>0) 00303 return 1.e11;// greater than quality error 00304 if( c1 > c2 ) 00305 { 00306 candidate = vec1; 00307 return quadrix_evaluate_vertex(candidate, Q); 00308 } 00309 else if( c2 > c1 ) 00310 { 00311 //candidate = *v2; 00312 candidate = vec2; 00313 return quadrix_evaluate_vertex(candidate, Q); 00314 } 00315 else if( c1>0 && policy>PLACE_LINE ) 00316 policy = PLACE_LINE; 00317 00318 if( policy == PLACE_OPTIMAL ) assert(c1==0 && c2==0); 00319 } 00320 00321 switch( policy ) 00322 { 00323 case PLACE_OPTIMAL: 00324 if( quadrix_find_best_fit(Q, candidate) ) 00325 break; 00326 00327 case PLACE_LINE: 00328 if( quadrix_find_line_fit(Q, vec1, vec2, candidate) ) 00329 break; 00330 00331 default: 00332 quadrix_find_local_fit(Q, vec1, vec2, candidate); 00333 break; 00334 } 00335 00336 return quadrix_evaluate_vertex(candidate, Q); 00337 }
