MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2008 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2008) [email protected] 00024 00025 ***************************************************************** */ 00026 00027 /** \file DomainClassifierTest.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "UnitUtil.hpp" 00034 #include "DomainClassifier.hpp" 00035 #include "MeshDomain1D.hpp" 00036 #include "MsqError.hpp" 00037 #include "MeshImpl.hpp" 00038 #include "MsqVertex.hpp" 00039 #include "PlanarDomain.hpp" 00040 00041 #include <cstdio> 00042 #include <iostream> 00043 #include <algorithm> 00044 00045 using namespace MBMesquite; 00046 using namespace std; 00047 00048 class DomainClassifierTest : public CppUnit::TestFixture 00049 { 00050 private: 00051 CPPUNIT_TEST_SUITE( DomainClassifierTest ); 00052 CPPUNIT_TEST( test_classify_by_handle ); 00053 CPPUNIT_TEST( test_valid_classification ); 00054 CPPUNIT_TEST( test_classify_by_tag ); 00055 CPPUNIT_TEST( test_classify_skin ); 00056 CPPUNIT_TEST( test_classify_by_geometry ); 00057 CPPUNIT_TEST_SUITE_END(); 00058 00059 public: 00060 typedef DomainClassifier::DomainSet DomSet; 00061 typedef std::vector< DomSet > DomSetList; 00062 MeshImpl myMesh; 00063 DomSetList myDomains; 00064 std::vector< int > domainDims; 00065 00066 void setUp(); 00067 void tearDown(); 00068 00069 void test_classify_by_handle(); 00070 void test_valid_classification(); 00071 void test_classify_by_tag(); 00072 void test_classify_skin(); 00073 void test_classify_by_geometry(); 00074 00075 void check_domain( DomainClassifier& dom ); 00076 }; 00077 00078 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( DomainClassifierTest, "Unit" ); 00079 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( DomainClassifierTest, "DomainClassifierTest" ); 00080 00081 static void print_domain( int i, DomainClassifier::DomainSet& set ) 00082 { 00083 if( PointDomain* pd = dynamic_cast< PointDomain* >( set.domain ) ) 00084 printf( "%d: PointDomain( %f %f %f ) @ %p\n", i, pd->geom()[0], pd->geom()[1], pd->geom()[2], pd ); 00085 else if( LineDomain* ld = dynamic_cast< LineDomain* >( set.domain ) ) 00086 { 00087 if( fabs( ld->geom().direction()[0] ) < 1e-6 && fabs( ld->geom().direction()[1] ) < 1e-6 ) 00088 printf( "%d: LineDomain( x = %f, y = %f ) @ %p\n", i, ld->geom().point()[0], ld->geom().point()[1], ld ); 00089 else if( fabs( ld->geom().direction()[1] ) < 1e-6 && fabs( ld->geom().direction()[2] ) < 1e-6 ) 00090 printf( "%d: LineDomain( y = %f, z = %f ) @ %p\n", i, ld->geom().point()[1], ld->geom().point()[2], ld ); 00091 else if( fabs( ld->geom().direction()[0] ) < 1e-6 && fabs( ld->geom().direction()[2] ) < 1e-6 ) 00092 printf( "%d: LineDomain( x = %f, z = %f ) @ %p\n", i, ld->geom().point()[0], ld->geom().point()[2], ld ); 00093 else 00094 printf( "%d: LineDomain( ? ) @ %p\n", i, ld ); 00095 } 00096 else if( PlanarDomain* pd = dynamic_cast< PlanarDomain* >( set.domain ) ) 00097 { 00098 if( fabs( pd->get_normal()[0] ) < 1e-6 && fabs( pd->get_normal()[1] ) < 1e-6 ) 00099 printf( "%d: PlanarDomain( z = %f ) @ %p\n", i, pd->get_origin()[2], pd ); 00100 else if( fabs( pd->get_normal()[1] ) < 1e-6 && fabs( pd->get_normal()[2] ) < 1e-6 ) 00101 printf( "%d: PlanarDomain( x = %f ) @ %p\n", i, pd->get_origin()[1], pd ); 00102 else if( fabs( pd->get_normal()[0] ) < 1e-6 && fabs( pd->get_normal()[2] ) < 1e-6 ) 00103 printf( "%d: PlanarDomain( y = %f ) @ %p\n", i, pd->get_origin()[0], pd ); 00104 else 00105 printf( "%d: PlanarDomain( ? ) @ %p\n", i, pd ); 00106 } 00107 else 00108 { 00109 printf( "%d: unknown domain type @ %p\n", i, set.domain ); 00110 } 00111 00112 if( !set.vertices.empty() ) 00113 { 00114 printf( " vertices: " ); 00115 std::vector< Mesh::VertexHandle >::iterator vi = set.vertices.begin(); 00116 for( ; vi != set.vertices.end(); ++vi ) 00117 printf( "%lu, ", (unsigned long)*vi ); 00118 printf( "\n" ); 00119 } 00120 if( !set.elements.empty() ) 00121 { 00122 printf( " elements: " ); 00123 std::vector< Mesh::ElementHandle >::iterator ei = set.elements.begin(); 00124 for( ; ei != set.elements.end(); ++ei ) 00125 printf( "%lu, ", (unsigned long)*ei ); 00126 printf( "\n" ); 00127 } 00128 } 00129 00130 void DomainClassifierTest::setUp() 00131 { 00132 myMesh.clear(); 00133 myDomains.clear(); 00134 domainDims.clear(); 00135 // vertex coodinates 00136 const char vertex_data[] = "POINTS 64 float\n" 00137 "0 0 0 1 0 0 2 0 0 3 0 0\n" 00138 "0 1 0 1 1 0 2 1 0 3 1 0\n" 00139 "0 2 0 1 2 0 2 2 0 3 2 0\n" 00140 "0 3 0 1 3 0 2 3 0 3 3 0\n" 00141 "\n" 00142 "0 0 1 1 0 1 2 0 1 3 0 1\n" 00143 "0 1 1 1 1 1 2 1 1 3 1 1\n" 00144 "0 2 1 1 2 1 2 2 1 3 2 1\n" 00145 "0 3 1 1 3 1 2 3 1 3 3 1\n" 00146 "\n" 00147 "0 0 2 1 0 2 2 0 2 3 0 2\n" 00148 "0 1 2 1 1 2 2 1 2 3 1 2\n" 00149 "0 2 2 1 2 2 2 2 2 3 2 2\n" 00150 "0 3 2 1 3 2 2 3 2 3 3 2\n" 00151 "\n" 00152 "0 0 3 1 0 3 2 0 3 3 0 3\n" 00153 "0 1 3 1 1 3 2 1 3 3 1 3\n" 00154 "0 2 3 1 2 3 2 2 3 3 2 3\n" 00155 "0 3 3 1 3 3 2 3 3 3 3 3\n" 00156 "\n"; 00157 // quad connectivity for quads on mesh skin 00158 const int num_quads = 9 * 6; // nine per side 00159 const char quad_data[] = "4 1 0 4 5\n" // -z face (z == 0) 00160 "4 2 1 5 6\n" 00161 "4 3 2 6 7\n" 00162 "4 5 4 8 9\n" 00163 "4 6 5 9 10\n" 00164 "4 7 6 10 11\n" 00165 "4 9 8 12 13\n" 00166 "4 10 9 13 14\n" 00167 "4 11 10 14 15\n" 00168 "\n" 00169 "4 48 49 53 52\n" // +z face (z == 3) 00170 "4 49 50 54 53\n" 00171 "4 50 51 55 54\n" 00172 "4 52 53 57 56\n" 00173 "4 53 54 58 57\n" 00174 "4 54 55 59 58\n" 00175 "4 56 57 61 60\n" 00176 "4 57 58 62 61\n" 00177 "4 58 59 63 62\n" 00178 "\n" 00179 "4 0 1 17 16\n" // -y face (y == 0) 00180 "4 1 2 18 17\n" 00181 "4 2 3 19 18\n" 00182 "4 16 17 33 32\n" 00183 "4 17 18 34 33\n" 00184 "4 18 19 35 34\n" 00185 "4 32 33 49 48\n" 00186 "4 33 34 50 49\n" 00187 "4 34 35 51 50\n" 00188 "\n" 00189 "4 13 12 28 29\n" // +y face (y == 3) 00190 "4 14 13 29 30\n" 00191 "4 15 14 30 31\n" 00192 "4 29 28 44 45\n" 00193 "4 30 29 45 46\n" 00194 "4 31 30 46 47\n" 00195 "4 45 44 60 61\n" 00196 "4 46 45 61 62\n" 00197 "4 47 46 62 63\n" 00198 "\n" 00199 "4 4 0 16 20\n" // -x face (x == 0) 00200 "4 8 4 20 24\n" 00201 "4 12 8 24 28\n" 00202 "4 20 16 32 36\n" 00203 "4 24 20 36 40\n" 00204 "4 28 24 40 44\n" 00205 "4 36 32 48 52\n" 00206 "4 40 36 52 56\n" 00207 "4 44 40 56 60\n" 00208 "\n" 00209 "4 3 7 23 19\n" // +x face (x == 3) 00210 "4 7 11 27 23\n" 00211 "4 11 15 31 27\n" 00212 "4 19 23 39 35\n" 00213 "4 23 27 43 39\n" 00214 "4 27 31 47 43\n" 00215 "4 35 39 55 51\n" 00216 "4 39 43 59 55\n" 00217 "4 43 47 63 59\n" 00218 "\n"; 00219 // hexahedron connectivity 00220 const int num_hexes = 3 * 3 * 3; 00221 const char hex_data[] = "8 0 1 5 4 16 17 21 20\n" 00222 "8 1 2 6 5 17 18 22 21\n" 00223 "8 2 3 7 6 18 19 23 22\n" 00224 "8 4 5 9 8 20 21 25 24\n" 00225 "8 5 6 10 9 21 22 26 25\n" 00226 "8 6 7 11 10 22 23 27 26\n" 00227 "8 8 9 13 12 24 25 29 28\n" 00228 "8 9 10 14 13 25 26 30 29\n" 00229 "8 10 11 15 14 26 27 31 30\n" 00230 "\n" 00231 "8 16 17 21 20 32 33 37 36\n" 00232 "8 17 18 22 21 33 34 38 37\n" 00233 "8 18 19 23 22 34 35 39 38\n" 00234 "8 20 21 25 24 36 37 41 40\n" 00235 "8 21 22 26 25 37 38 42 41\n" 00236 "8 22 23 27 26 38 39 43 42\n" 00237 "8 24 25 29 28 40 41 45 44\n" 00238 "8 25 26 30 29 41 42 46 45\n" 00239 "8 26 27 31 30 42 43 47 46\n" 00240 "\n" 00241 "8 32 33 37 36 48 49 53 52\n" 00242 "8 33 34 38 37 49 50 54 53\n" 00243 "8 34 35 39 38 50 51 55 54\n" 00244 "8 36 37 41 40 52 53 57 56\n" 00245 "8 37 38 42 41 53 54 58 57\n" 00246 "8 38 39 43 42 54 55 59 58\n" 00247 "8 40 41 45 44 56 57 61 60\n" 00248 "8 41 42 46 45 57 58 62 61\n" 00249 "8 42 43 47 46 58 59 63 62\n" 00250 "\n"; 00251 // a few interior quads 00252 const int num_interior_quads = 3; 00253 const char interior_quad_data[] = "4 1 5 25 17\n" 00254 "4 4 5 25 24\n" 00255 "4 16 17 25 24\n" 00256 "\n"; 00257 00258 const char filename[] = "dctest.vtk"; 00259 FILE* file = fopen( filename, "w" ); 00260 fputs( "# vtk DataFile Version 2.0\n", file ); 00261 fputs( "Mesquite Mesh\n", file ); 00262 fputs( "ASCII\n", file ); 00263 fputs( "DATASET UNSTRUCTURED_GRID\n", file ); 00264 fputs( vertex_data, file ); 00265 00266 int num_elem = num_quads + num_hexes + num_interior_quads; 00267 int num_elem_data = 5 * num_quads + 9 * num_hexes * 5 * num_interior_quads; 00268 fprintf( file, "CELLS %d %d\n", num_elem, num_elem_data ); 00269 fputs( quad_data, file ); 00270 fputs( hex_data, file ); 00271 fputs( interior_quad_data, file ); 00272 fprintf( file, "CELL_TYPES %d\n", num_elem ); 00273 for( int i = 0; i < num_quads; ++i ) 00274 fputs( "9\n", file ); 00275 for( int i = 0; i < num_hexes; ++i ) 00276 fputs( "12\n", file ); 00277 for( int i = 0; i < num_interior_quads; ++i ) 00278 fputs( "9\n", file ); 00279 00280 fclose( file ); 00281 MsqPrintError err( std::cerr ); 00282 myMesh.read_vtk( filename, err ); 00283 remove( filename ); 00284 CPPUNIT_ASSERT( !err ); 00285 00286 std::vector< Mesh::VertexHandle > verts; 00287 std::vector< Mesh::ElementHandle > elems; 00288 myMesh.get_all_vertices( verts, err ); 00289 CPPUNIT_ASSERT( !err ); 00290 CPPUNIT_ASSERT_EQUAL( (size_t)64, verts.size() ); 00291 myMesh.get_all_elements( elems, err ); 00292 CPPUNIT_ASSERT( !err ); 00293 CPPUNIT_ASSERT_EQUAL( (size_t)num_elem, elems.size() ); 00294 00295 // define point domains 00296 PointDomain* pdom[8]; 00297 pdom[0] = new PointDomain( Vector3D( 0, 0, 0 ) ); 00298 pdom[1] = new PointDomain( Vector3D( 3, 0, 0 ) ); 00299 pdom[2] = new PointDomain( Vector3D( 0, 3, 0 ) ); 00300 pdom[3] = new PointDomain( Vector3D( 3, 3, 0 ) ); 00301 pdom[4] = new PointDomain( Vector3D( 0, 0, 3 ) ); 00302 pdom[5] = new PointDomain( Vector3D( 3, 0, 3 ) ); 00303 pdom[6] = new PointDomain( Vector3D( 0, 3, 3 ) ); 00304 pdom[7] = new PointDomain( Vector3D( 3, 3, 3 ) ); 00305 size_t pdidx[8] = { 0, 3, 12, 15, 48, 51, 60, 63 }; 00306 for( unsigned i = 0; i < 8; ++i ) 00307 { 00308 MsqVertex coords; 00309 Mesh::VertexHandle h = verts[pdidx[i]]; 00310 myMesh.vertices_get_coordinates( &h, &coords, 1, err ); 00311 CPPUNIT_ASSERT( !err ); 00312 CPPUNIT_ASSERT_VECTORS_EQUAL( pdom[i]->geom(), coords, 1e-6 ); 00313 DomSet set; 00314 set.domain = pdom[i]; 00315 set.vertices.push_back( h ); 00316 myDomains.push_back( set ); 00317 domainDims.push_back( 0 ); 00318 } 00319 00320 // define line domains 00321 LineDomain* ldom[12]; 00322 ldom[0] = new LineDomain( Vector3D( 0, 0, 0 ), Vector3D( 1, 0, 0 ) ); // y=0,z=0 00323 ldom[1] = new LineDomain( Vector3D( 0, 3, 0 ), Vector3D( 1, 0, 0 ) ); // y=3,z=0 00324 ldom[2] = new LineDomain( Vector3D( 0, 0, 3 ), Vector3D( 1, 0, 0 ) ); // y=0,z=3 00325 ldom[3] = new LineDomain( Vector3D( 0, 3, 3 ), Vector3D( 1, 0, 0 ) ); // y=3,z=3 00326 ldom[4] = new LineDomain( Vector3D( 0, 0, 0 ), Vector3D( 0, 1, 0 ) ); // x=0,z=0 00327 ldom[5] = new LineDomain( Vector3D( 3, 0, 0 ), Vector3D( 0, 1, 0 ) ); // x=3,z=0 00328 ldom[6] = new LineDomain( Vector3D( 0, 0, 3 ), Vector3D( 0, 1, 0 ) ); // x=0,z=3 00329 ldom[7] = new LineDomain( Vector3D( 3, 0, 3 ), Vector3D( 0, 1, 0 ) ); // x=3,z=3 00330 ldom[8] = new LineDomain( Vector3D( 0, 0, 0 ), Vector3D( 0, 0, 1 ) ); // x=0,y=0 00331 ldom[9] = new LineDomain( Vector3D( 3, 0, 0 ), Vector3D( 0, 0, 1 ) ); // x=3,y=0 00332 ldom[10] = new LineDomain( Vector3D( 0, 3, 0 ), Vector3D( 0, 0, 1 ) ); // x=0,y=3 00333 ldom[11] = new LineDomain( Vector3D( 3, 3, 0 ), Vector3D( 0, 0, 1 ) ); // x=3,y=3 00334 size_t ldidx[12][2] = { { 1, 2 }, { 13, 14 }, { 49, 50 }, { 61, 62 }, { 4, 8 }, { 7, 11 }, 00335 { 52, 56 }, { 55, 59 }, { 16, 32 }, { 19, 35 }, { 28, 44 }, { 31, 47 } }; 00336 for( unsigned i = 0; i < 12; ++i ) 00337 { 00338 Mesh::VertexHandle v[2]; 00339 v[0] = verts[ldidx[i][0]]; 00340 v[1] = verts[ldidx[i][1]]; 00341 MsqVertex coords[2]; 00342 myMesh.vertices_get_coordinates( v, coords, 2, err ); 00343 CPPUNIT_ASSERT( !err ); 00344 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, ldom[i]->geom().distance( coords[0] ), 1e-6 ); 00345 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, ldom[i]->geom().distance( coords[1] ), 1e-6 ); 00346 DomSet set; 00347 set.domain = ldom[i]; 00348 set.vertices.push_back( v[0] ); 00349 set.vertices.push_back( v[1] ); 00350 myDomains.push_back( set ); 00351 domainDims.push_back( 1 ); 00352 } 00353 00354 // define planar domains 00355 PlanarDomain* sdom[6]; 00356 sdom[0] = new PlanarDomain( Vector3D( 0, 0, -1 ), Vector3D( 0, 0, 0 ) ); 00357 sdom[1] = new PlanarDomain( Vector3D( 0, 0, 1 ), Vector3D( 0, 0, 3 ) ); 00358 sdom[2] = new PlanarDomain( Vector3D( 0, -1, 0 ), Vector3D( 0, 0, 0 ) ); 00359 sdom[3] = new PlanarDomain( Vector3D( 0, 1, 0 ), Vector3D( 0, 3, 0 ) ); 00360 sdom[4] = new PlanarDomain( Vector3D( -1, 0, 0 ), Vector3D( 0, 0, 0 ) ); 00361 sdom[5] = new PlanarDomain( Vector3D( 1, 0, 0 ), Vector3D( 3, 0, 0 ) ); 00362 size_t sdidx[6][4] = { { 5, 6, 9, 10 }, { 53, 54, 57, 58 }, { 17, 18, 33, 34 }, 00363 { 29, 30, 45, 46 }, { 20, 24, 36, 40 }, { 23, 27, 39, 43 } }; 00364 for( unsigned i = 0; i < 6; ++i ) 00365 { 00366 DomSet set; 00367 set.domain = sdom[i]; 00368 for( unsigned j = 0; j < 4; ++j ) 00369 set.vertices.push_back( verts[sdidx[i][j]] ); 00370 for( unsigned j = 0; j < 9; ++j ) 00371 set.elements.push_back( elems[9 * i + j] ); 00372 myDomains.push_back( set ); 00373 domainDims.push_back( 2 ); 00374 } 00375 00376 // for (unsigned i = 0; i < myDomains.size(); ++i) 00377 // print_domain( i, myDomains[i] ); 00378 } 00379 00380 void DomainClassifierTest::tearDown() 00381 { 00382 myMesh.clear(); 00383 while( !myDomains.empty() ) 00384 { 00385 delete myDomains.back().domain; 00386 myDomains.pop_back(); 00387 } 00388 domainDims.clear(); 00389 } 00390 00391 void DomainClassifierTest::check_domain( DomainClassifier& domain ) 00392 { 00393 std::vector< Mesh::VertexHandle > vertices, cverts; 00394 std::vector< Mesh::ElementHandle > elements, celems; 00395 00396 // Check that, for each entity with a domain, the 00397 // DomainClassifier instance returns that domain. 00398 // Also, put all entities with domains into cverts and 00399 // celems for later. 00400 for( unsigned i = 0; i < myDomains.size(); ++i ) 00401 { 00402 for( unsigned j = 0; j < myDomains[i].vertices.size(); ++j ) 00403 { 00404 Mesh::VertexHandle v = myDomains[i].vertices[j]; 00405 const MeshDomain* ptr = domain.find_vertex_domain( v ); 00406 CPPUNIT_ASSERT( myDomains[i].domain == ptr ); 00407 cverts.push_back( v ); 00408 } 00409 for( unsigned k = 0; k < myDomains[i].elements.size(); ++k ) 00410 { 00411 Mesh::ElementHandle e = myDomains[i].elements[k]; 00412 const MeshDomain* ptr = domain.find_element_domain( e ); 00413 CPPUNIT_ASSERT( myDomains[i].domain == ptr ); 00414 celems.push_back( e ); 00415 } 00416 } 00417 00418 // sort cverts and celems so we can do binary_search later 00419 std::sort( cverts.begin(), cverts.end() ); 00420 std::sort( celems.begin(), celems.end() ); 00421 // get all vertices and elements in mesh 00422 MsqPrintError err( std::cerr ); 00423 myMesh.get_all_vertices( vertices, err ); 00424 CPPUNIT_ASSERT( !err ); 00425 myMesh.get_all_elements( elements, err ); 00426 CPPUNIT_ASSERT( !err ); 00427 00428 // For each vertex not in a domain (not in cverts), make sure 00429 // that the domain is NULL. 00430 for( size_t i = 0; i < vertices.size(); ++i ) 00431 { 00432 if( std::binary_search( cverts.begin(), cverts.end(), vertices[i] ) ) continue; 00433 00434 const MeshDomain* ptr = domain.find_vertex_domain( vertices[i] ); 00435 CPPUNIT_ASSERT( NULL == ptr ); 00436 } 00437 // For each element not in a domain (not in celems), make sure 00438 // that the domain is NULL. 00439 for( size_t i = 0; i < elements.size(); ++i ) 00440 { 00441 if( std::binary_search( celems.begin(), celems.end(), elements[i] ) ) continue; 00442 00443 const MeshDomain* ptr = domain.find_element_domain( elements[i] ); 00444 CPPUNIT_ASSERT( NULL == ptr ); 00445 } 00446 } 00447 00448 void DomainClassifierTest::test_classify_by_handle() 00449 { 00450 MsqPrintError err( std::cerr ); 00451 DomainClassifier domain; 00452 DomainClassifier::classify_by_handle( domain, &myMesh, arrptr( myDomains ), myDomains.size(), err ); 00453 CPPUNIT_ASSERT( !err ); 00454 00455 check_domain( domain ); 00456 } 00457 00458 void DomainClassifierTest::test_valid_classification() 00459 { 00460 MsqPrintError err( std::cerr ); 00461 DomainClassifier domain; 00462 DomainClassifier::classify_by_handle( domain, &myMesh, arrptr( myDomains ), myDomains.size(), err ); 00463 CPPUNIT_ASSERT( !err ); 00464 00465 domain.test_valid_classification( &myMesh, err ); 00466 CPPUNIT_ASSERT( !err ); 00467 } 00468 00469 void DomainClassifierTest::test_classify_by_tag() 00470 { 00471 CPPUNIT_ASSERT( !myDomains.empty() ); 00472 00473 MsqPrintError err( std::cerr ); 00474 int def = myDomains.size(); 00475 TagHandle tag = myMesh.tag_create( "domain", Mesh::INT, 1, &def, err ); 00476 CPPUNIT_ASSERT( !err ); 00477 00478 std::vector< MeshDomain* > dom_list; 00479 std::vector< int > id_list; 00480 for( unsigned i = 0; i < myDomains.size(); ++i ) 00481 { 00482 std::vector< int > vtx_data( myDomains[i].vertices.size(), i ); 00483 std::vector< int > elm_data( myDomains[i].elements.size(), i ); 00484 if( !vtx_data.empty() ) 00485 { 00486 myMesh.tag_set_vertex_data( tag, vtx_data.size(), &( myDomains[i].vertices[0] ), arrptr( vtx_data ), err ); 00487 CPPUNIT_ASSERT( !err ); 00488 } 00489 if( !elm_data.empty() ) 00490 { 00491 myMesh.tag_set_element_data( tag, elm_data.size(), &( myDomains[i].elements[0] ), arrptr( elm_data ), err ); 00492 CPPUNIT_ASSERT( !err ); 00493 } 00494 00495 dom_list.push_back( myDomains[i].domain ); 00496 id_list.push_back( i ); 00497 } 00498 00499 DomainClassifier domain; 00500 DomainClassifier::classify_by_tag( domain, &myMesh, "domain", arrptr( dom_list ), arrptr( id_list ), 00501 myDomains.size(), err ); 00502 CPPUNIT_ASSERT( !err ); 00503 00504 check_domain( domain ); 00505 } 00506 00507 void DomainClassifierTest::test_classify_skin() 00508 { 00509 CPPUNIT_ASSERT( !myDomains.empty() ); 00510 00511 MsqPrintError err( std::cerr ); 00512 std::vector< MeshDomain* > arr( myDomains.size() ); 00513 for( size_t i = 0; i < myDomains.size(); ++i ) 00514 arr[i] = myDomains[i].domain; 00515 00516 DomainClassifier domain; 00517 DomainClassifier::classify_skin_geometrically( domain, &myMesh, 1e-6, arrptr( arr ), arrptr( domainDims ), 00518 arr.size(), err ); 00519 CPPUNIT_ASSERT( !err ); 00520 00521 check_domain( domain ); 00522 } 00523 00524 void DomainClassifierTest::test_classify_by_geometry() 00525 { 00526 CPPUNIT_ASSERT( !myDomains.empty() ); 00527 00528 MsqPrintError err( std::cerr ); 00529 std::vector< MeshDomain* > arr( myDomains.size() ); 00530 for( size_t i = 0; i < myDomains.size(); ++i ) 00531 arr[i] = myDomains[i].domain; 00532 00533 DomainClassifier domain; 00534 DomainClassifier::classify_geometrically( domain, &myMesh, 1e-6, arrptr( arr ), arrptr( domainDims ), arr.size(), 00535 err ); 00536 CPPUNIT_ASSERT( !err ); 00537 00538 check_domain( domain ); 00539 }
