MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2008 Lawrence Livermore National Laboratory. Under 00005 the terms of Contract B545069 with the University of Wisconsin -- 00006 Madison, Lawrence Livermore National Laboratory retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2008) [email protected] 00024 00025 ***************************************************************** */ 00026 00027 /** \file DomainClassifier.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "DomainClassifier.hpp" 00033 #include "MsqError.hpp" 00034 #include "TopologyInfo.hpp" 00035 #include "MsqVertex.hpp" 00036 #include <map> 00037 #include <set> 00038 #include <algorithm> 00039 #include <iterator> 00040 00041 namespace MBMesquite 00042 { 00043 00044 /**\brief Helper function for 'find_skin' 00045 * 00046 * Check the vertices on element sides to see if the 00047 * elements are adjacent. 00048 *\param num_vtx Number of vertices in each element side 00049 *\param idx_set_1 Indices into the first element's vertex list 00050 * at which the side vertices are located. 00051 *\param vtx_set_1 Vertex of first element. 00052 *\param idx_set_2 Indices into the second element's vertex list 00053 * at which the side vertices are located. 00054 *\param vtx_set_2 Vertex of second element. 00055 */ 00056 static bool compare_sides( unsigned num_vtx, 00057 const unsigned* idx_set_1, 00058 const Mesh::VertexHandle* vtx_set_1, 00059 const unsigned* idx_set_2, 00060 const Mesh::VertexHandle* vtx_set_2 ); 00061 00062 /**\brief Skin mesh 00063 * 00064 * Find vertices and lower-dimension elements on the boundary 00065 * of a mesh. 00066 */ 00067 static void find_skin( Mesh* mesh, 00068 std::vector< Mesh::VertexHandle >& skin_verts, 00069 std::vector< Mesh::ElementHandle >& skin_elems, 00070 MsqError& err ); 00071 00072 /**\brief Group MeshDomain objectects by topological dimension. 00073 * 00074 * Given an array of MeshDomain pointers and and array of dimensions, 00075 * where each dimension value is the topological dimension of the 00076 * corresponding domain, construct a DomainSet vector containing 00077 * the domains, grouped from lowest dimension to highest. 00078 *\param domains Array of domains 00079 *\param dims Topological dimension of each domain 00080 *\param count Length of 'domains' and 'dims' arrays 00081 *\param results Output 00082 *\param dim_indices Output: index in output at which the first 00083 * domain of the corresponding topological dimension 00084 * occurs. 00085 */ 00086 static void dimension_sort_domains( MeshDomain** domains, 00087 const int* dims, 00088 unsigned count, 00089 std::vector< DomainClassifier::DomainSet >& results, 00090 int dim_indices[4], 00091 MsqError& err ); 00092 00093 /**\brief Classify mesh vertices using vertex position 00094 * 00095 * Classify vertices by distance from each geometric domain. 00096 * A vertex is assigned to a domain if it lies within the domain. 00097 * If a vertex lies in multiple domains, it is assigned to the 00098 * domain with the lowest topological dimension. 00099 *\param mesh The MBMesquite::Mesh instance 00100 *\param dim_sorted_domains The list of MeshDomains, sorted from lowest 00101 * to highest dimension. 00102 *\param num_domain Length of 'dim_sorted_domains' array. 00103 *\param vertices Vertices to classify 00104 *\param epsilon Maximum distance a vertex may deviate from its domain. 00105 */ 00106 static void geom_classify_vertices( Mesh* mesh, 00107 DomainClassifier::DomainSet* dim_sorted_domains, 00108 unsigned num_domain, 00109 const std::vector< Mesh::VertexHandle >& vertices, 00110 double epsilon, 00111 MsqError& err ); 00112 00113 /**\brief Classify mesh elements using vertex classification 00114 * 00115 * Classify elements using vertex classification, according to the 00116 * following rules, listed highest-precedence first. 00117 * Case 1: one or more vertices has no classification -> element has no classification 00118 * Case 2: all vertices classified to domain with dimension < 2 -> unknown 00119 * Case 3: one or more vertices has dimension-2 classification: 00120 * Case 3a: all have same dimension-2 domain -> element assigned to same domain 00121 * Case 3b: different dimension-2 domains -> element has no classification 00122 * 00123 *\param mesh The MBMesquite::Mesh instance 00124 *\param dim_sorted_domains The list of MeshDomains, sorted from lowest 00125 * to highest dimension. 00126 *\param num_domain Length of 'dim_sorted_domains' array. 00127 *\param elems Elements to classify 00128 *\param uknown Elements for which all vertices are classified to 00129 * domains with dimension less than two. 00130 */ 00131 static void vert_classify_elements( Mesh* mesh, 00132 DomainClassifier::DomainSet* dim_sorted_domains, 00133 unsigned num_domain, 00134 int dim_indices[4], 00135 const std::vector< Mesh::ElementHandle >& elems, 00136 std::vector< Mesh::ElementHandle >& unknown_elems, 00137 MsqError& err ); 00138 00139 /**\brief Classify mesh elements geometrically. */ 00140 static void geom_classify_elements( Mesh* mesh, 00141 DomainClassifier::DomainSet* dim_sorted_domains, 00142 unsigned num_domain, 00143 int dim_indices[4], 00144 const std::vector< Mesh::ElementHandle >& elems, 00145 std::vector< Mesh::ElementHandle >& unknown_elems, 00146 double epsilon, 00147 MsqError& err ); 00148 00149 static bool compare_sides( unsigned num_vtx, 00150 const unsigned* idx_set_1, 00151 const Mesh::VertexHandle* vtx_set_1, 00152 const unsigned* idx_set_2, 00153 const Mesh::VertexHandle* vtx_set_2 ) 00154 { 00155 unsigned i; 00156 for( i = 0;; ++i ) 00157 { 00158 if( i >= num_vtx ) return false; 00159 if( vtx_set_1[idx_set_1[0]] == vtx_set_2[idx_set_2[i]] ) break; 00160 } 00161 00162 if( num_vtx == 1 ) return true; 00163 00164 if( vtx_set_1[idx_set_1[1]] == vtx_set_2[idx_set_2[( i + 1 ) % num_vtx]] ) 00165 { 00166 for( unsigned j = 2; j < num_vtx; ++j ) 00167 if( vtx_set_1[idx_set_1[j]] != vtx_set_2[idx_set_2[( i + j ) % num_vtx]] ) return false; 00168 return true; 00169 } 00170 else if( vtx_set_1[idx_set_1[1]] == vtx_set_2[idx_set_2[( i + num_vtx - 1 ) % num_vtx]] ) 00171 { 00172 for( unsigned j = 2; j < num_vtx; ++j ) 00173 if( vtx_set_1[idx_set_1[j]] != vtx_set_2[idx_set_2[( i + num_vtx - j ) % num_vtx]] ) return false; 00174 return true; 00175 } 00176 else 00177 { 00178 return false; 00179 } 00180 } 00181 00182 static void find_skin( Mesh* mesh, 00183 std::vector< Mesh::VertexHandle >& skin_verts, 00184 std::vector< Mesh::ElementHandle >& skin_elems, 00185 MsqError& err ) 00186 { 00187 std::vector< Mesh::ElementHandle > elements, adj_elem, side_elem; 00188 std::vector< Mesh::VertexHandle > vertices, adj_vtx; 00189 std::vector< size_t > junk; 00190 mesh->get_all_elements( elements, err );MSQ_ERRRTN( err ); 00191 if( elements.empty() ) return; 00192 const unsigned elem_idx[] = { 0, 1, 2, 3 }; 00193 00194 std::vector< unsigned > extra_side_vtx; 00195 for( size_t e = 0; e < elements.size(); ++e ) 00196 { 00197 Mesh::ElementHandle elem = elements[e]; 00198 vertices.clear(); 00199 mesh->elements_get_attached_vertices( &elem, 1, vertices, junk, err );MSQ_ERRRTN( err ); 00200 00201 EntityTopology type; 00202 mesh->elements_get_topologies( &elem, &type, 1, err );MSQ_ERRRTN( err ); 00203 const unsigned dim = TopologyInfo::dimension( type ); 00204 const unsigned nsides = TopologyInfo::sides( type ); 00205 for( unsigned s = 0; s < nsides; ++s ) 00206 { 00207 unsigned num_side_vtx; 00208 const unsigned* side_vtx = TopologyInfo::side_vertices( type, dim - 1, s, num_side_vtx ); 00209 adj_elem.clear(); 00210 side_elem.clear(); 00211 mesh->vertices_get_attached_elements( &vertices[*side_vtx], 1, adj_elem, junk, err );MSQ_ERRRTN( err ); 00212 00213 bool found_adj = false; 00214 for( size_t a = 0; a < adj_elem.size(); ++a ) 00215 { 00216 if( adj_elem[a] == elem ) continue; 00217 EntityTopology adj_type; 00218 mesh->elements_get_topologies( &adj_elem[a], &adj_type, 1, err );MSQ_ERRRTN( err ); 00219 adj_vtx.clear(); 00220 mesh->elements_get_attached_vertices( &adj_elem[a], 1, adj_vtx, junk, err );MSQ_ERRRTN( err ); 00221 if( TopologyInfo::dimension( adj_type ) == dim ) 00222 { 00223 unsigned nsides2 = TopologyInfo::sides( adj_type ); 00224 for( unsigned s2 = 0; s2 < nsides2; ++s2 ) 00225 { 00226 unsigned num_side_vtx2; 00227 const unsigned* side_vtx2 = TopologyInfo::side_vertices( adj_type, dim - 1, s2, num_side_vtx2 ); 00228 if( num_side_vtx2 == num_side_vtx && 00229 compare_sides( num_side_vtx, side_vtx, arrptr( vertices ), side_vtx2, arrptr( adj_vtx ) ) ) 00230 { 00231 found_adj = true; 00232 break; 00233 } 00234 } 00235 } 00236 else 00237 { 00238 if( TopologyInfo::corners( adj_type ) == num_side_vtx ) 00239 if( compare_sides( num_side_vtx, side_vtx, arrptr( vertices ), elem_idx, arrptr( adj_vtx ) ) ) 00240 side_elem.push_back( adj_elem[a] ); 00241 } 00242 } 00243 00244 if( !found_adj ) 00245 { 00246 int ho = TopologyInfo::higher_order( type, vertices.size(), err );MSQ_ERRRTN( err ); 00247 // mask mid-element node (because that cannot be on the skin) 00248 ho &= ~( 1 << dim ); 00249 // if element has other higher-order nodes, we need to find the subset on the skin 00250 // side 00251 if( ho ) 00252 { 00253 extra_side_vtx.clear(); 00254 extra_side_vtx.insert( extra_side_vtx.end(), side_vtx, side_vtx + num_side_vtx ); 00255 // get mid-side node 00256 if( ho & ( 1 << ( dim - 1 ) ) ) 00257 { 00258 int idx = TopologyInfo::higher_order_from_side( type, vertices.size(), dim - 1, s, err );MSQ_ERRRTN( err ); 00259 extra_side_vtx.push_back( idx ); 00260 } 00261 if( dim == 3 && ( ho & 2 ) ) 00262 { // if volume element, need mid-edge nodes too 00263 const unsigned nedges = TopologyInfo::edges( type ); 00264 for( unsigned je = 0; je < nedges; ++je ) 00265 { 00266 unsigned tmp; 00267 const unsigned* edge_vtx = TopologyInfo::side_vertices( type, 1, je, tmp ); 00268 assert( edge_vtx && 2 == tmp ); 00269 unsigned idx = std::find( side_vtx, side_vtx + num_side_vtx, edge_vtx[0] ) - side_vtx; 00270 if( idx < num_side_vtx ) 00271 { 00272 if( ( edge_vtx[1] == side_vtx[( idx + 1 ) % num_side_vtx] ) || 00273 ( edge_vtx[1] == side_vtx[( idx + num_side_vtx - 1 ) % num_side_vtx] ) ) 00274 { 00275 idx = TopologyInfo::higher_order_from_side( type, vertices.size(), 1, je, err );MSQ_ERRRTN( err ); 00276 extra_side_vtx.push_back( idx ); 00277 } 00278 } 00279 } 00280 } 00281 00282 num_side_vtx = extra_side_vtx.size(); 00283 side_vtx = arrptr( extra_side_vtx ); 00284 } 00285 00286 for( unsigned v = 0; v < num_side_vtx; ++v ) 00287 skin_verts.push_back( vertices[side_vtx[v]] ); 00288 for( unsigned j = 0; j < side_elem.size(); ++j ) 00289 skin_elems.push_back( side_elem[j] ); 00290 } 00291 } 00292 } 00293 00294 std::sort( skin_verts.begin(), skin_verts.end() ); 00295 skin_verts.erase( std::unique( skin_verts.begin(), skin_verts.end() ), skin_verts.end() ); 00296 std::sort( skin_elems.begin(), skin_elems.end() ); 00297 skin_elems.erase( std::unique( skin_elems.begin(), skin_elems.end() ), skin_elems.end() ); 00298 } 00299 00300 static void dimension_sort_domains( MeshDomain** domains, 00301 const int* dims, 00302 unsigned count, 00303 std::vector< DomainClassifier::DomainSet >& results, 00304 int dim_indices[4], 00305 MsqError& err ) 00306 { 00307 results.clear(); 00308 results.resize( count ); 00309 unsigned idx = 0; 00310 int dim; 00311 for( dim = 0; idx < count; ++dim ) 00312 { 00313 if( dim > 3 ) 00314 { 00315 MSQ_SETERR( err )( "Invalid domain dimension", MsqError::INVALID_ARG ); 00316 return; 00317 } 00318 dim_indices[dim] = idx; 00319 for( unsigned j = 0; j < count; ++j ) 00320 { 00321 if( dims[j] == dim ) 00322 { 00323 results[idx].domain = domains[j]; 00324 ++idx; 00325 } 00326 } 00327 } 00328 for( ; dim <= 3; ++dim ) 00329 dim_indices[dim] = idx; 00330 } 00331 00332 static void geom_classify_vertices( Mesh* mesh, 00333 DomainClassifier::DomainSet* dim_sorted_domains, 00334 unsigned num_domain, 00335 const std::vector< Mesh::VertexHandle >& vertices, 00336 double epsilon, 00337 MsqError& err ) 00338 { 00339 Vector3D pt; 00340 MsqVertex coord; 00341 unsigned i; 00342 unsigned short dim; 00343 const double epssqr = epsilon * epsilon; 00344 std::vector< Mesh::VertexHandle >::const_iterator iter; 00345 for( iter = vertices.begin(); iter != vertices.end(); ++iter ) 00346 { 00347 mesh->vertices_get_coordinates( &*iter, &coord, 1, err );MSQ_ERRRTN( err ); 00348 for( i = 0; i < num_domain; ++i ) 00349 { 00350 // Call DoF function first just to see if it fails 00351 // (e.g. if domain knows which vertices it is responsible for, 00352 // it should fail if this vertex isn't one.) 00353 dim_sorted_domains[i].domain->domain_DoF( &*iter, &dim, 1, err ); 00354 if( err || dim > 2 ) 00355 { 00356 err.clear(); 00357 continue; 00358 } 00359 pt = coord; 00360 dim_sorted_domains[i].domain->snap_to( *iter, pt ); 00361 if( ( pt - coord ).length_squared() <= epssqr ) 00362 { 00363 dim_sorted_domains[i].vertices.push_back( *iter ); 00364 break; 00365 } 00366 } 00367 } 00368 } 00369 00370 static void vert_classify_elements( Mesh* mesh, 00371 DomainClassifier::DomainSet* dim_sorted_domains, 00372 unsigned num_domain, 00373 int dim_indices[4], 00374 const std::vector< Mesh::ElementHandle >& elems, 00375 std::vector< Mesh::ElementHandle >& unknown_elems, 00376 MsqError& err ) 00377 { 00378 // sort vertex lists for faster search 00379 for( unsigned i = 0; i < num_domain; ++i ) 00380 std::sort( dim_sorted_domains[i].vertices.begin(), dim_sorted_domains[i].vertices.end() ); 00381 00382 std::vector< Mesh::ElementHandle >::const_iterator iter; 00383 std::vector< Mesh::VertexHandle > verts; 00384 std::vector< size_t > junk; 00385 for( iter = elems.begin(); iter != elems.end(); ++iter ) 00386 { 00387 int dom = -1; 00388 verts.clear(); 00389 mesh->elements_get_attached_vertices( &*iter, 1, verts, junk, err );MSQ_ERRRTN( err ); 00390 for( unsigned v = 0; v < verts.size(); ++v ) 00391 { 00392 int i; 00393 for( i = 0; i < dim_indices[3]; ++i ) 00394 { 00395 DomainClassifier::DomainSet* d = dim_sorted_domains + i; 00396 if( std::binary_search( d->vertices.begin(), d->vertices.end(), verts[v] ) ) break; 00397 } 00398 // if any vertex in element has no domain, then element has no domain 00399 if( i < 0 ) 00400 { 00401 dom = -2; 00402 break; 00403 } 00404 // if vertex is in curve or point, ignore it 00405 else if( i < dim_indices[2] ) 00406 continue; 00407 // else if we already have a vertex on a different surface, 00408 // element must be in volume (no domain) 00409 else if( dom >= 0 && dom != i ) 00410 { 00411 dom = -2; 00412 break; 00413 } 00414 else 00415 { 00416 dom = i; 00417 } 00418 } 00419 00420 if( dom >= 0 ) 00421 dim_sorted_domains[dom].elements.push_back( *iter ); 00422 else if( dom == -1 ) // all verts on curves or points 00423 unknown_elems.push_back( *iter ); 00424 } 00425 } 00426 00427 static void geom_classify_elements( Mesh* mesh, 00428 DomainClassifier::DomainSet* dim_sorted_domains, 00429 unsigned, 00430 int dim_indices[4], 00431 const std::vector< Mesh::ElementHandle >& elems, 00432 std::vector< Mesh::ElementHandle >& unknown_elems, 00433 double epsilon, 00434 MsqError& err ) 00435 { 00436 if( elems.empty() ) return; 00437 00438 const double epssqr = epsilon * epsilon; 00439 Vector3D pt; 00440 MsqVertex coord; 00441 std::vector< Mesh::ElementHandle >::const_iterator iter; 00442 std::vector< Mesh::VertexHandle > verts; 00443 std::vector< MsqVertex > coords; 00444 std::vector< size_t > junk; 00445 for( iter = elems.begin(); iter != elems.end(); ++iter ) 00446 { 00447 verts.clear(); 00448 mesh->elements_get_attached_vertices( &*iter, 1, verts, junk, err );MSQ_ERRRTN( err ); 00449 coords.resize( verts.size() ); 00450 mesh->vertices_get_coordinates( arrptr( verts ), arrptr( coords ), verts.size(), err );MSQ_ERRRTN( err ); 00451 00452 // get all 2D domains that contain first vertex 00453 std::vector< int > doms; 00454 for( int i = dim_indices[2]; i < dim_indices[3]; ++i ) 00455 { 00456 pt = coords[0]; 00457 dim_sorted_domains[i].domain->snap_to( verts[0], pt ); 00458 if( ( pt - coords[0] ).length_squared() <= epssqr ) doms.push_back( i ); 00459 } 00460 00461 // of the 2D domains containing the first vertex, 00462 // remove any that do not contain all other corners of the element. 00463 for( unsigned i = 1; i < verts.size(); ++i ) 00464 { 00465 for( unsigned j = 0; j < doms.size(); ) 00466 { 00467 pt = coords[i]; 00468 dim_sorted_domains[doms[j]].domain->snap_to( verts[j], pt ); 00469 if( ( pt - coords[0] ).length_squared() <= epssqr ) 00470 ++j; 00471 else 00472 doms.erase( doms.begin() + j ); 00473 } 00474 } 00475 00476 if( doms.size() == 1 ) 00477 dim_sorted_domains[doms.front()].elements.push_back( *iter ); 00478 else 00479 unknown_elems.push_back( *iter ); 00480 } 00481 } 00482 00483 void DomainClassifier::classify_geometrically( DomainClassifier& result, 00484 Mesh* mesh, 00485 double tolerance, 00486 MeshDomain** domain_array, 00487 const int* dimension_array, 00488 unsigned array_length, 00489 MsqError& err ) 00490 { 00491 if( !array_length ) return; 00492 00493 std::vector< DomainSet > domains; 00494 int dim_indices[4]; 00495 dimension_sort_domains( domain_array, dimension_array, array_length, domains, dim_indices, err );MSQ_ERRRTN( err ); 00496 00497 // classify vertices by position 00498 std::vector< Mesh::VertexHandle > vertices; 00499 mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); 00500 geom_classify_vertices( mesh, arrptr( domains ), dim_indices[3], vertices, tolerance, err );MSQ_ERRRTN( err ); 00501 00502 // get elements and types 00503 std::vector< Mesh::ElementHandle > elems; 00504 mesh->get_all_elements( elems, err );MSQ_ERRRTN( err ); 00505 if( elems.empty() ) return; 00506 std::vector< EntityTopology > types( elems.size() ); 00507 mesh->elements_get_topologies( arrptr( elems ), arrptr( types ), elems.size(), err );MSQ_ERRRTN( err ); 00508 00509 // get rid of elements w/ dimension other than 2 00510 size_t w = 0; 00511 for( size_t r = 0; r < elems.size(); ++r ) 00512 { 00513 if( TopologyInfo::dimension( types[r] ) == 2 ) 00514 { 00515 elems[w] = elems[r]; 00516 ++w; 00517 } 00518 } 00519 elems.resize( w ); 00520 00521 // classify elements using vertex classification 00522 std::vector< Mesh::ElementHandle > unknown; 00523 vert_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elems, unknown, err );MSQ_ERRRTN( err ); 00524 00525 // classify unknown elements geometrically 00526 elems.swap( unknown ); 00527 unknown.clear(); 00528 geom_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elems, unknown, tolerance, err ); 00529 00530 classify_by_handle( result, mesh, arrptr( domains ), domains.size(), err ); 00531 } 00532 00533 void DomainClassifier::classify_skin_geometrically( DomainClassifier& result, 00534 Mesh* mesh, 00535 double tolerance, 00536 MeshDomain** domain_array, 00537 const int* dimension_array, 00538 unsigned array_length, 00539 MsqError& err ) 00540 { 00541 if( !array_length ) return; 00542 00543 std::vector< DomainSet > domains; 00544 int dim_indices[4]; 00545 dimension_sort_domains( domain_array, dimension_array, array_length, domains, dim_indices, err );MSQ_ERRRTN( err ); 00546 00547 std::vector< Mesh::VertexHandle > vertices; 00548 std::vector< Mesh::ElementHandle > elements; 00549 find_skin( mesh, vertices, elements, err );MSQ_ERRRTN( err ); 00550 00551 // classify vertices by position 00552 geom_classify_vertices( mesh, arrptr( domains ), dim_indices[3], vertices, tolerance, err );MSQ_ERRRTN( err ); 00553 00554 // classify elements using vertex classification 00555 std::vector< Mesh::ElementHandle > unknown; 00556 vert_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elements, unknown, err );MSQ_ERRRTN( err ); 00557 00558 // classify unknown elements geometrically 00559 elements.swap( unknown ); 00560 unknown.clear(); 00561 geom_classify_elements( mesh, arrptr( domains ), domains.size(), dim_indices, elements, unknown, tolerance, err ); 00562 00563 if( !unknown.empty() ) 00564 { 00565 MSQ_SETERR( err )( "Count not classify all skin elements", MsqError::INVALID_MESH ); 00566 return; 00567 } 00568 00569 classify_by_handle( result, mesh, arrptr( domains ), domains.size(), err ); 00570 } 00571 00572 void DomainClassifier::classify_by_tag( DomainClassifier& result, 00573 Mesh* mesh, 00574 const char* tag_name, 00575 MeshDomain** domain_array, 00576 const int* id_array, 00577 unsigned array_length, 00578 MsqError& err ) 00579 { 00580 TagHandle tag = mesh->tag_get( tag_name, err );MSQ_ERRRTN( err ); 00581 00582 std::string name2; 00583 Mesh::TagType type; 00584 unsigned size; 00585 mesh->tag_properties( tag, name2, type, size, err );MSQ_ERRRTN( err ); 00586 if( type != Mesh::INT || size != 1 ) 00587 { 00588 MSQ_SETERR( err ) 00589 ( MsqError::TAG_NOT_FOUND, "Tag does not contain single integer value: %s\n", tag_name ); 00590 return; 00591 } 00592 00593 std::vector< DomainSet > sets( array_length ); 00594 std::map< int, DomainSet* > idmap; 00595 for( unsigned i = 0; i < array_length; ++i ) 00596 { 00597 sets[i].domain = domain_array[i]; 00598 idmap[id_array[i]] = &sets[i]; 00599 } 00600 00601 std::vector< Mesh::VertexHandle > vertices; 00602 std::vector< Mesh::ElementHandle > elements; 00603 mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); 00604 mesh->get_all_elements( elements, err );MSQ_ERRRTN( err ); 00605 if( vertices.empty() ) return; 00606 00607 std::map< int, DomainSet* >::const_iterator iter; 00608 std::vector< int > ids( vertices.size() ); 00609 mesh->tag_get_vertex_data( tag, vertices.size(), arrptr( vertices ), arrptr( ids ), err );MSQ_ERRRTN( err ); 00610 for( size_t j = 0; j < vertices.size(); ++j ) 00611 { 00612 iter = idmap.find( ids[j] ); 00613 if( iter != idmap.end() ) iter->second->vertices.push_back( vertices[j] ); 00614 } 00615 00616 ids.clear(); 00617 ids.resize( elements.size() ); 00618 if( !elements.empty() ) 00619 { 00620 mesh->tag_get_element_data( tag, elements.size(), arrptr( elements ), arrptr( ids ), err ); 00621 if( err ) 00622 { 00623 err.clear(); 00624 } 00625 else 00626 { 00627 for( size_t k = 0; k < elements.size(); ++k ) 00628 { 00629 iter = idmap.find( ids[k] ); 00630 if( iter != idmap.end() ) iter->second->elements.push_back( elements[k] ); 00631 } 00632 } 00633 } 00634 00635 if( !sets.empty() ) classify_by_handle( result, mesh, arrptr( sets ), sets.size(), err ); 00636 } 00637 00638 void DomainClassifier::classify_by_handle( DomainClassifier& result, 00639 Mesh* mesh, 00640 DomainSet* sets, 00641 unsigned array_length, 00642 MsqError& err ) 00643 { 00644 result.clear(); 00645 00646 // get all vertices and elements 00647 std::vector< Mesh::VertexHandle > vertices; 00648 std::vector< Mesh::ElementHandle > elements; 00649 mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); 00650 mesh->get_all_elements( elements, err );MSQ_ERRRTN( err ); 00651 00652 // sort all arrays so we can merge 00653 std::sort( vertices.begin(), vertices.end() ); 00654 std::sort( elements.begin(), elements.end() ); 00655 for( unsigned i = 0; i < array_length; ++i ) 00656 { 00657 std::sort( sets[i].vertices.begin(), sets[i].vertices.end() ); 00658 std::sort( sets[i].elements.begin(), sets[i].elements.end() ); 00659 } 00660 00661 // build vertex block list 00662 std::vector< size_t > indices( array_length, 0 ); 00663 size_t idx = 0; 00664 while( idx < vertices.size() ) 00665 { 00666 DomainBlock block; 00667 block.firstHandle = vertices[idx]; 00668 block.lastHandle = vertices[idx]; 00669 00670 // find domain 00671 unsigned dom = 0; 00672 for( dom = 0; dom < array_length; ++dom ) 00673 { 00674 const size_t i = indices[dom]; 00675 if( i < sets[dom].vertices.size() && sets[dom].vertices[i] == vertices[idx] ) 00676 { 00677 ++indices[dom]; 00678 break; 00679 } 00680 } 00681 ++idx; 00682 if( dom == indices.size() ) // no domain 00683 continue; 00684 00685 block.domain = sets[dom].domain; 00686 while( indices[dom] < sets[dom].vertices.size() && sets[dom].vertices[indices[dom]] == vertices[idx] ) 00687 { 00688 block.lastHandle = vertices[idx]; 00689 ++idx; 00690 ++indices[dom]; 00691 } 00692 result.vertexList.push_back( block ); 00693 } 00694 00695 // build vertex block list 00696 indices.clear(); 00697 indices.resize( array_length, 0 ); 00698 idx = 0; 00699 while( idx < elements.size() ) 00700 { 00701 DomainBlock block; 00702 block.firstHandle = elements[idx]; 00703 block.lastHandle = elements[idx]; 00704 00705 // find domain 00706 unsigned dom = 0; 00707 for( dom = 0; dom < array_length; ++dom ) 00708 { 00709 const size_t i = indices[dom]; 00710 if( i < sets[dom].elements.size() && sets[dom].elements[i] == elements[idx] ) 00711 { 00712 ++indices[dom]; 00713 break; 00714 } 00715 } 00716 ++idx; 00717 if( dom == indices.size() ) // no domain 00718 continue; 00719 00720 block.domain = sets[dom].domain; 00721 while( indices[dom] < sets[dom].elements.size() && sets[dom].elements[indices[dom]] == elements[idx] ) 00722 { 00723 block.lastHandle = elements[idx]; 00724 ++idx; 00725 ++indices[dom]; 00726 } 00727 result.elementList.push_back( block ); 00728 } 00729 /* 00730 printf("\n"); 00731 for (unsigned i = 0; i < result.vertexList.size(); ++i) 00732 printf("v %2lu-%2lu @ %p\n", (unsigned long)result.vertexList[i].firstHandle, 00733 (unsigned long)result.vertexList[i].lastHandle, 00734 result.vertexList[i].domain ); 00735 for (unsigned i = 0; i < result.elementList.size(); ++i) 00736 printf("e %2lu-%2lu @ %p\n", (unsigned long)result.elementList[i].firstHandle, 00737 (unsigned long)result.elementList[i].lastHandle, 00738 result.elementList[i].domain ); 00739 printf("\n"); 00740 */ 00741 } 00742 00743 static bool next_vertex( Mesh* mesh, Mesh::VertexHandle& vtx, std::set< Mesh::VertexHandle >& unseen, MsqError& err ) 00744 { 00745 std::vector< Mesh::ElementHandle > vtx_elems; 00746 std::vector< size_t > junk; 00747 00748 mesh->vertices_get_attached_elements( &vtx, 1, vtx_elems, junk, err ); 00749 MSQ_ERRZERO( err ); 00750 00751 std::vector< EntityTopology > elem_types( vtx_elems.size() ); 00752 if( !vtx_elems.empty() ) 00753 { 00754 mesh->elements_get_topologies( arrptr( vtx_elems ), arrptr( elem_types ), vtx_elems.size(), err ); 00755 MSQ_ERRZERO( err ); 00756 } 00757 00758 std::vector< Mesh::VertexHandle > corners; 00759 for( size_t j = 0; j < vtx_elems.size(); ++j ) 00760 { 00761 corners.clear(); 00762 mesh->elements_get_attached_vertices( &vtx_elems[j], 1, corners, junk, err ); 00763 MSQ_ERRZERO( err ); 00764 00765 unsigned nedges = TopologyInfo::edges( elem_types[j] ); 00766 unsigned vidx = std::find( corners.begin(), corners.end(), vtx ) - corners.begin(); 00767 00768 // Check mid-edge nodes first, if present 00769 int ho = TopologyInfo::higher_order( elem_types[j], corners.size(), err ); 00770 MSQ_ERRZERO( err ); 00771 // If element has mid-edge nodes *and* current vertex is a corner vertex 00772 if( ( ho & 2 ) && ( vidx < TopologyInfo::corners( elem_types[j] ) ) ) 00773 { 00774 for( unsigned e = 0; e < nedges; ++e ) 00775 { 00776 const unsigned* edge_verts = TopologyInfo::edge_vertices( elem_types[j], e, err ); 00777 MSQ_ERRZERO( err ); 00778 if( edge_verts[0] == vidx || edge_verts[1] == vidx ) 00779 { 00780 int idx = TopologyInfo::higher_order_from_side( elem_types[j], corners.size(), 1, e, err ); 00781 MSQ_ERRZERO( err ); 00782 std::set< Mesh::VertexHandle >::iterator f = unseen.find( corners[idx] ); 00783 if( f != unseen.end() ) 00784 { 00785 vtx = *f; 00786 unseen.erase( f ); 00787 return true; 00788 } 00789 } 00790 } 00791 } 00792 00793 // if current vertx is a mid-edge node 00794 else if( ho & 2 ) 00795 { 00796 unsigned d, e; 00797 TopologyInfo::side_from_higher_order( elem_types[j], corners.size(), vidx, d, e, err ); 00798 MSQ_ERRZERO( err ); 00799 if( d != 1 ) continue; 00800 const unsigned* edge_verts = TopologyInfo::edge_vertices( elem_types[j], e, err ); 00801 MSQ_ERRZERO( err ); 00802 for( int v = 0; v < 2; ++v ) 00803 { 00804 std::set< Mesh::VertexHandle >::iterator f = unseen.find( corners[edge_verts[v]] ); 00805 if( f != unseen.end() ) 00806 { 00807 vtx = *f; 00808 unseen.erase( f ); 00809 return true; 00810 } 00811 } 00812 } 00813 00814 else 00815 { 00816 for( unsigned e = 0; e < nedges; ++e ) 00817 { 00818 const unsigned* edge_verts = TopologyInfo::edge_vertices( elem_types[j], e, err ); 00819 MSQ_ERRZERO( err ); 00820 int idx; 00821 if( edge_verts[0] == vidx ) 00822 idx = edge_verts[1]; 00823 else if( edge_verts[1] == vidx ) 00824 idx = edge_verts[0]; 00825 else 00826 continue; 00827 00828 std::set< Mesh::VertexHandle >::iterator f = unseen.find( corners[idx] ); 00829 if( f != unseen.end() ) 00830 { 00831 vtx = *f; 00832 unseen.erase( f ); 00833 return true; 00834 } 00835 } 00836 } 00837 } 00838 00839 return false; 00840 } 00841 00842 void DomainClassifier::test_valid_classification( Mesh* mesh, MsqError& err ) 00843 { 00844 size_t i; 00845 00846 // Get all mesh entities 00847 std::vector< Mesh::VertexHandle > vertices; 00848 std::vector< Mesh::ElementHandle > elements; 00849 mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err ); 00850 mesh->get_all_elements( elements, err );MSQ_ERRRTN( err ); 00851 std::sort( vertices.begin(), vertices.end() ); 00852 std::sort( elements.begin(), elements.end() ); 00853 00854 // Get contents of each domain. 00855 std::map< MeshDomain*, int >::iterator iter; 00856 std::map< MeshDomain*, int > idxmap; 00857 for( i = 0; i < vertexList.size(); ++i ) 00858 idxmap[vertexList[i].domain] = 0; 00859 for( i = 0; i < elementList.size(); ++i ) 00860 idxmap[elementList[i].domain] = 0; 00861 std::vector< DomainSet > domains( idxmap.size() ); 00862 int idx = 0; 00863 for( iter = idxmap.begin(); iter != idxmap.end(); ++iter ) 00864 { 00865 iter->second = idx; 00866 domains[idx].domain = iter->first; 00867 ++idx; 00868 } 00869 for( i = 0; i < vertexList.size(); ++i ) 00870 { 00871 std::vector< Mesh::VertexHandle >::const_iterator s, e; 00872 s = std::lower_bound( vertices.begin(), vertices.end(), vertexList[i].firstHandle ); 00873 e = std::upper_bound( vertices.begin(), vertices.end(), vertexList[i].lastHandle ); 00874 DomainSet& set = domains[idxmap[vertexList[i].domain]]; 00875 std::copy( s, e, std::back_inserter( set.vertices ) ); 00876 } 00877 for( i = 0; i < elementList.size(); ++i ) 00878 { 00879 std::vector< Mesh::ElementHandle >::const_iterator s, e; 00880 s = std::lower_bound( elements.begin(), elements.end(), elementList[i].firstHandle ); 00881 e = std::upper_bound( elements.begin(), elements.end(), elementList[i].lastHandle ); 00882 DomainSet& set = domains[idxmap[elementList[i].domain]]; 00883 std::copy( s, e, std::back_inserter( set.elements ) ); 00884 } 00885 00886 // guess geometric dimension for each domain 00887 std::map< DomainSet*, int > dimmap; 00888 std::vector< unsigned short > dof; 00889 for( i = 0; i < domains.size(); ++i ) 00890 { 00891 if( !domains[i].elements.empty() ) 00892 dimmap[&domains[i]] = 2; 00893 else 00894 { 00895 dof.resize( domains[i].vertices.size() ); 00896 domains[i].domain->domain_DoF( &( domains[i].vertices[0] ), arrptr( dof ), dof.size(), err );MSQ_ERRRTN( err ); 00897 unsigned short dim = *std::max_element( dof.begin(), dof.end() ); 00898 dimmap[&domains[i]] = dim; 00899 } 00900 } 00901 00902 // group domains by dimension 00903 std::vector< DomainSet* > points, curves, surfaces; 00904 for( std::map< DomainSet*, int >::iterator it = dimmap.begin(); it != dimmap.end(); ++it ) 00905 { 00906 switch( it->second ) 00907 { 00908 case 0: 00909 points.push_back( it->first ); 00910 break; 00911 case 1: 00912 curves.push_back( it->first ); 00913 break; 00914 case 2: 00915 surfaces.push_back( it->first ); 00916 break; 00917 default: 00918 MSQ_SETERR( err ) 00919 ( MsqError::INVALID_STATE, "Invalid domain dimension: %d\n", it->second ); 00920 break; 00921 } 00922 } 00923 00924 // check that each point-domain has a single vertex 00925 for( i = 0; i < points.size(); ++i ) 00926 { 00927 if( points[i]->vertices.size() != 1 || !points[i]->elements.empty() ) 00928 { 00929 MSQ_SETERR( err )( "Point domain mesh not a single vertex.", MsqError::INVALID_STATE ); 00930 return; 00931 } 00932 } 00933 00934 // check that each curve domain has a chain of connected edges 00935 std::set< Mesh::VertexHandle > unseen; 00936 for( i = 0; i < curves.size(); ++i ) 00937 { 00938 if( !curves[i]->elements.empty() ) 00939 { 00940 MSQ_SETERR( err )( "Elements associated with 1D domain.", MsqError::INVALID_STATE ); 00941 return; 00942 } 00943 00944 unseen.clear(); 00945 std::copy( curves[i]->vertices.begin(), curves[i]->vertices.end(), std::inserter( unseen, unseen.begin() ) ); 00946 00947 const Mesh::VertexHandle first_vtx = *unseen.begin(); 00948 unseen.erase( unseen.begin() ); 00949 Mesh::VertexHandle vtx = first_vtx; 00950 // find chain of vertices 00951 while( next_vertex( mesh, vtx, unseen, err ) ) 00952 MSQ_ERRRTN( err ); 00953 // search again from the starting vertex because 00954 // it probably wasn't the first one on the curve 00955 vtx = first_vtx; 00956 while( next_vertex( mesh, vtx, unseen, err ) ) 00957 MSQ_ERRRTN( err ); 00958 // were all vertices in a chain? 00959 if( !unseen.empty() ) 00960 { 00961 MSQ_SETERR( err ) 00962 ( "Curve domain contains vertices not in a simply connected chain.", MsqError::INVALID_STATE ); 00963 return; 00964 } 00965 } 00966 00967 std::set< Mesh::VertexHandle > seen; 00968 std::set< Mesh::ElementHandle > remaining; 00969 std::vector< Mesh::VertexHandle > verts, verts2; 00970 std::vector< Mesh::ElementHandle > stack, vert_elems; 00971 std::vector< EntityTopology > types; 00972 std::vector< size_t > junk; 00973 // if surface contains elements... 00974 for( i = 0; i < surfaces.size(); ++i ) 00975 { 00976 if( surfaces[i]->elements.empty() ) continue; 00977 00978 // Check that any vertices on surface are contained in an 00979 // element on the surface. 00980 verts.clear(); 00981 mesh->elements_get_attached_vertices( &( surfaces[i]->elements[0] ), surfaces[i]->elements.size(), verts, junk, 00982 err );MSQ_ERRRTN( err ); 00983 seen.clear(); 00984 std::copy( verts.begin(), verts.end(), std::inserter( seen, seen.begin() ) ); 00985 00986 std::vector< Mesh::VertexHandle >::const_iterator v; 00987 for( v = surfaces[i]->vertices.begin(); v != surfaces[i]->vertices.end(); ++v ) 00988 { 00989 std::set< Mesh::VertexHandle >::iterator j = seen.find( *v ); 00990 if( j == seen.end() ) 00991 { 00992 MSQ_SETERR( err ) 00993 ( "Vertex on surface domain not in any element.", MsqError::INVALID_STATE ); 00994 return; 00995 } 00996 } 00997 00998 // check that elements form 2D patch 00999 stack.clear(); 01000 remaining.clear(); 01001 std::copy( surfaces[i]->elements.begin(), surfaces[i]->elements.end(), 01002 std::inserter( remaining, remaining.begin() ) ); 01003 stack.push_back( *remaining.begin() ); 01004 remaining.erase( remaining.begin() ); 01005 while( !stack.empty() ) 01006 { 01007 Mesh::ElementHandle elem = stack.back(); 01008 stack.pop_back(); 01009 verts.clear(); 01010 mesh->elements_get_attached_vertices( &elem, 1, verts, junk, err );MSQ_ERRRTN( err ); 01011 // for each edge 01012 for( size_t j = 0; j < verts.size(); ++j ) 01013 { 01014 Mesh::VertexHandle v1 = verts[j], v2 = verts[( j + 1 ) % verts.size()]; 01015 vert_elems.clear(); 01016 mesh->vertices_get_attached_elements( &v1, 1, vert_elems, junk, err );MSQ_ERRRTN( err ); 01017 types.resize( vert_elems.size() ); 01018 if( !vert_elems.empty() ) 01019 { 01020 mesh->elements_get_topologies( arrptr( vert_elems ), arrptr( types ), vert_elems.size(), err );MSQ_ERRRTN( err ); 01021 } 01022 while( !vert_elems.empty() ) 01023 { 01024 Mesh::ElementHandle e2 = vert_elems.back(); 01025 EntityTopology type = types.back(); 01026 vert_elems.pop_back(); 01027 types.pop_back(); 01028 if( TopologyInfo::dimension( type ) != 2 ) continue; 01029 verts2.clear(); 01030 mesh->elements_get_attached_vertices( &e2, 1, verts2, junk, err );MSQ_ERRRTN( err ); 01031 size_t jdx = std::find( verts2.begin(), verts2.end(), v1 ) - verts2.begin(); 01032 if( verts2[( jdx + 1 ) % verts2.size()] != v2 && 01033 verts2[( jdx + verts2.size() - 1 ) % verts2.size()] != v2 ) 01034 continue; 01035 std::set< Mesh::ElementHandle >::iterator r = remaining.find( e2 ); 01036 if( r == remaining.end() ) continue; 01037 01038 stack.push_back( *r ); 01039 remaining.erase( r ); 01040 } 01041 } 01042 } 01043 01044 if( !remaining.empty() ) 01045 { 01046 MSQ_SETERR( err ) 01047 ( "Surface mesh not a single, simply-connected patch", MsqError::INVALID_STATE ); 01048 return; 01049 } 01050 } 01051 01052 // check that sides of volume elements that are on surface 01053 // form simply connected patch 01054 for( i = 0; i < surfaces.size(); ++i ) 01055 { 01056 // build list of sides known to be on surface 01057 std::sort( surfaces[i]->vertices.begin(), surfaces[i]->vertices.end() ); 01058 std::set< std::pair< Mesh::ElementHandle, int > > sides; 01059 for( size_t j = 0; j < surfaces[i]->vertices.size(); ++j ) 01060 { 01061 Mesh::VertexHandle v = surfaces[i]->vertices[j]; 01062 vert_elems.clear(); 01063 mesh->vertices_get_attached_elements( &v, 1, vert_elems, junk, err );MSQ_ERRRTN( err ); 01064 types.resize( vert_elems.size() ); 01065 if( !vert_elems.empty() ) 01066 { 01067 mesh->elements_get_topologies( arrptr( vert_elems ), arrptr( types ), vert_elems.size(), err );MSQ_ERRRTN( err ); 01068 } 01069 while( !vert_elems.empty() ) 01070 { 01071 Mesh::ElementHandle e = vert_elems.back(); 01072 EntityTopology type = types.back(); 01073 vert_elems.pop_back(); 01074 types.pop_back(); 01075 if( TopologyInfo::dimension( type ) != 3 ) continue; 01076 verts.clear(); 01077 mesh->elements_get_attached_vertices( &e, 1, verts, junk, err );MSQ_ERRRTN( err ); 01078 01079 for( unsigned s = 0; s < TopologyInfo::faces( type ); ++s ) 01080 { 01081 unsigned n; 01082 const unsigned* si = TopologyInfo::face_vertices( type, s, n ); 01083 unsigned ns = 0; 01084 for( unsigned k = 0; k < n; ++k ) 01085 { 01086 if( std::binary_search( surfaces[i]->vertices.begin(), surfaces[i]->vertices.end(), 01087 verts[si[k]] ) ) 01088 ++ns; 01089 } 01090 if( ns >= 3 ) sides.insert( std::pair< Mesh::ElementHandle, int >( e, s ) ); 01091 } 01092 } 01093 } 01094 01095 std::vector< std::pair< Mesh::ElementHandle, int > > sstack; 01096 sstack.push_back( *sides.begin() ); 01097 sides.erase( sides.begin() ); 01098 while( !sstack.empty() ) 01099 { 01100 Mesh::ElementHandle e = sstack.back().first; 01101 int s = sstack.back().second; 01102 sstack.pop_back(); 01103 01104 verts.clear(); 01105 mesh->elements_get_attached_vertices( &e, 1, verts, junk, err );MSQ_ERRRTN( err ); 01106 EntityTopology type; 01107 mesh->elements_get_topologies( &e, &type, 1, err );MSQ_ERRRTN( err ); 01108 unsigned n; 01109 const unsigned* si = TopologyInfo::face_vertices( type, s, n ); 01110 01111 // for each edge 01112 for( unsigned j = 0; j < n; ++j ) 01113 { 01114 Mesh::VertexHandle v1 = verts[si[j]], v2 = verts[si[( j + 1 ) % n]]; 01115 vert_elems.clear(); 01116 mesh->vertices_get_attached_elements( &v1, 1, vert_elems, junk, err );MSQ_ERRRTN( err ); 01117 types.resize( vert_elems.size() ); 01118 if( !vert_elems.empty() ) 01119 { 01120 mesh->elements_get_topologies( arrptr( vert_elems ), arrptr( types ), vert_elems.size(), err );MSQ_ERRRTN( err ); 01121 } 01122 while( !vert_elems.empty() ) 01123 { 01124 Mesh::ElementHandle e2 = vert_elems.back(); 01125 EntityTopology type2 = types.back(); 01126 vert_elems.pop_back(); 01127 types.pop_back(); 01128 if( TopologyInfo::dimension( type ) != 3 ) continue; 01129 verts2.clear(); 01130 mesh->elements_get_attached_vertices( &e2, 1, verts2, junk, err );MSQ_ERRRTN( err ); 01131 // for each face 01132 for( unsigned s2 = 0; s2 < TopologyInfo::faces( type2 ); ++s2 ) 01133 { 01134 std::set< std::pair< Mesh::ElementHandle, int > >::iterator side; 01135 side = sides.find( std::pair< Mesh::ElementHandle, int >( e2, s2 ) ); 01136 if( side == sides.end() ) continue; 01137 01138 unsigned n2; 01139 const unsigned* si2 = TopologyInfo::face_vertices( type2, s2, n2 ); 01140 unsigned jdx; 01141 for( jdx = 0; jdx < n2; ++jdx ) 01142 if( verts2[si2[jdx]] == v1 ) break; 01143 assert( jdx < n2 ); 01144 01145 if( verts2[si2[( jdx + 1 ) % n2]] == v2 || verts2[si2[( jdx + n2 - 1 ) % n2]] == v2 ) 01146 { 01147 sstack.push_back( *side ); 01148 sides.erase( side ); 01149 } 01150 } 01151 } 01152 } 01153 } 01154 01155 if( !sides.empty() ) 01156 { 01157 MSQ_SETERR( err ) 01158 ( "Surface mesh not a single, simply-connected patch", MsqError::INVALID_STATE ); 01159 return; 01160 } 01161 } 01162 } 01163 01164 static inline bool operator<( const Mesh::EntityHandle h, const DomainClassifier::DomainBlock& b ) 01165 { 01166 return h < b.firstHandle; 01167 } 01168 01169 static inline bool operator<( const DomainClassifier::DomainBlock& b, const Mesh::EntityHandle h ) 01170 { 01171 return b.lastHandle < h; 01172 } 01173 01174 static inline bool operator<( const DomainClassifier::DomainBlock& b, const DomainClassifier::DomainBlock& c ) 01175 { 01176 return b.lastHandle < c.firstHandle; 01177 } 01178 01179 MeshDomain* DomainClassifier::find_domain( Mesh::EntityHandle handle, 01180 const std::vector< DomainClassifier::DomainBlock >& list ) 01181 { 01182 std::vector< DomainClassifier::DomainBlock >::const_iterator i; 01183 i = std::lower_bound( list.begin(), list.end(), handle ); 01184 return ( i != list.end() && i->firstHandle <= handle ) ? i->domain : NULL; 01185 } 01186 01187 void DomainClassifier::snap_to( Mesh::EntityHandle entity_handle, Vector3D& coordinate ) const 01188 { 01189 if( const MeshDomain* dom = find_vertex_domain( entity_handle ) ) dom->snap_to( entity_handle, coordinate ); 01190 } 01191 01192 void DomainClassifier::vertex_normal_at( Mesh::VertexHandle entity_handle, Vector3D& coordinate ) const 01193 { 01194 if( const MeshDomain* dom = find_vertex_domain( entity_handle ) ) 01195 dom->vertex_normal_at( entity_handle, coordinate ); 01196 } 01197 01198 void DomainClassifier::element_normal_at( Mesh::ElementHandle entity_handle, Vector3D& coordinate ) const 01199 { 01200 if( const MeshDomain* dom = find_element_domain( entity_handle ) ) 01201 dom->element_normal_at( entity_handle, coordinate ); 01202 } 01203 01204 void DomainClassifier::vertex_normal_at( const Mesh::VertexHandle* handles, 01205 Vector3D coordinates[], 01206 unsigned count, 01207 MsqError& err ) const 01208 { 01209 for( unsigned i = 0; i < count; ++i ) 01210 { 01211 const MeshDomain* dom = find_vertex_domain( handles[i] ); 01212 if( !dom ) 01213 { 01214 MSQ_SETERR( err )( MsqError::INVALID_ARG ); 01215 return; 01216 } 01217 dom->vertex_normal_at( handles + i, coordinates + i, 1, err );MSQ_ERRRTN( err ); 01218 } 01219 } 01220 01221 void DomainClassifier::closest_point( Mesh::VertexHandle handle, 01222 const Vector3D& position, 01223 Vector3D& closest, 01224 Vector3D& normal, 01225 MsqError& err ) const 01226 { 01227 if( const MeshDomain* dom = find_vertex_domain( handle ) ) 01228 dom->closest_point( handle, position, closest, normal, err ); 01229 } 01230 01231 void DomainClassifier::domain_DoF( const Mesh::VertexHandle* handles, 01232 unsigned short* dof_array, 01233 size_t num_handles, 01234 MsqError& err ) const 01235 { 01236 for( size_t i = 0; i < num_handles; ++i ) 01237 { 01238 const MeshDomain* dom = find_vertex_domain( handles[i] ); 01239 if( !dom ) 01240 dof_array[i] = 3; 01241 else 01242 { 01243 dom->domain_DoF( handles + i, dof_array + i, 1, err );MSQ_ERRRTN( err ); 01244 } 01245 } 01246 } 01247 01248 DomainClassifier::~DomainClassifier() 01249 { 01250 if( deleteSubDomains ) delete_all_sub_domains(); 01251 } 01252 01253 void DomainClassifier::delete_all_sub_domains() 01254 { 01255 // get unique list of domains 01256 std::set< MeshDomain* > domains; 01257 std::vector< DomainBlock >::iterator i; 01258 for( i = vertexList.begin(); i != vertexList.end(); ++i ) 01259 domains.insert( i->domain ); 01260 for( i = elementList.begin(); i != elementList.end(); ++i ) 01261 domains.insert( i->domain ); 01262 std::set< MeshDomain* >::iterator j; 01263 for( j = domains.begin(); j != domains.end(); ++j ) 01264 delete *j; 01265 clear(); 01266 } 01267 01268 } // namespace MBMesquite
