MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 [email protected], [email protected], [email protected], 00024 [email protected], [email protected], [email protected] 00025 00026 ***************************************************************** */ 00027 // -*- Mode : c++; tab-width: 3; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 3 00028 // -*- 00029 00030 /*! \file InstructionQueue.hpp 00031 00032 Header file for the MBMesquite::InstructionQueue class 00033 00034 \author Thomas Leurent 00035 \date 2002-05-01 00036 */ 00037 00038 #ifndef MSQ_INSTRUCTION_QUEUE_HPP 00039 #define MSQ_INSTRUCTION_QUEUE_HPP 00040 00041 #include "Mesquite.hpp" 00042 #include "IQInterface.hpp" 00043 00044 #include <list> 00045 00046 namespace MBMesquite 00047 { 00048 00049 class MsqError; 00050 class QualityImprover; 00051 class QualityAssessor; 00052 class Mesh; 00053 class ParallelMesh; 00054 class MeshDomain; 00055 class MeshDomainAssoc; 00056 class Instruction; 00057 class MappingFunctionSet; 00058 class TargetWriter; 00059 class VertexSlaver; 00060 class TagVertexMesh; 00061 00062 /*! \class InstructionQueue 00063 \brief An InstructionQueue object gathers Mesquite Instructions and ensures 00064 that the instruction queue is coherent for mesh improvement and/or 00065 mesh quality assessment purposes. 00066 00067 The user can instantiate several InstructionQueue objects to be used 00068 with various MeshSet objects. 00069 00070 The most commonly used functions are: 00071 -# add_preconditioner(...) 00072 -# add_quality_assessor(...) 00073 -# set_master_quality_improver(...) 00074 -# run_instructions(...) 00075 */ 00076 class InstructionQueue : public IQInterface 00077 { 00078 00079 public: 00080 MESQUITE_EXPORT 00081 InstructionQueue(); 00082 00083 MESQUITE_EXPORT 00084 InstructionQueue( const Settings& settings ); 00085 00086 MESQUITE_EXPORT 00087 virtual ~InstructionQueue(); 00088 00089 MESQUITE_EXPORT 00090 void add_target_calculator( TargetWriter* tc, MsqError& err ); 00091 00092 //! Add a tool mark higher-order nodes as slaved. 00093 //! Note: Implies set_slaved_ho_node_mode( Settings::SLAVE_CALCULATED ) 00094 MESQUITE_EXPORT 00095 void add_vertex_slaver( VertexSlaver* slaver, MsqError& err ); 00096 //! Remove a tool mark higher-order nodes as slaved. 00097 //! Note: Implies set_slaved_ho_node_mode( Settings::SLAVE_ALL ) 00098 MESQUITE_EXPORT 00099 void remove_vertex_slaver( VertexSlaver* slaver, MsqError& err ); 00100 00101 MESQUITE_EXPORT 00102 void add_tag_vertex_mesh( TagVertexMesh* m, MsqError& err ); 00103 MESQUITE_EXPORT 00104 void remove_tag_vertex_mesh( TagVertexMesh* m, MsqError& err ); 00105 00106 MESQUITE_EXPORT 00107 void add_preconditioner( QualityImprover* instr, MsqError& err ); 00108 MESQUITE_EXPORT 00109 void remove_preconditioner( size_t index, MsqError& err ); 00110 MESQUITE_EXPORT 00111 void insert_preconditioner( QualityImprover* instr, size_t index, MsqError& err ); 00112 00113 MESQUITE_EXPORT 00114 void add_quality_assessor( QualityAssessor* instr, MsqError& err ); 00115 MESQUITE_EXPORT 00116 void remove_quality_assessor( size_t index, MsqError& err ); 00117 MESQUITE_EXPORT 00118 void insert_quality_assessor( QualityAssessor* instr, size_t index, MsqError& err ); 00119 00120 MESQUITE_EXPORT 00121 void set_master_quality_improver( QualityImprover* instr, MsqError& err ); 00122 00123 MESQUITE_EXPORT 00124 void disable_automatic_quality_assessment() 00125 { 00126 autoQualAssess = false; 00127 } 00128 MESQUITE_EXPORT 00129 void enable_automatic_quality_assessment() 00130 { 00131 autoQualAssess = true; 00132 } 00133 00134 /**\brief Exectute the instruction queue. 00135 * 00136 * Execute all operations in the instruction queue. 00137 * 00138 *\param mesh The mesh to run each instruction on. 00139 *\param domain The domain of the mesh -- may be NULL if no domain. 00140 */ 00141 MESQUITE_EXPORT 00142 virtual void run_common( MeshDomainAssoc* mesh_and_domain, ParallelMesh* pmesh, Settings* settings, MsqError& err ); 00143 00144 MESQUITE_EXPORT 00145 void clear(); 00146 00147 protected: 00148 private: 00149 std::list< Instruction* >::iterator clear_master( MsqError& err ); 00150 00151 std::list< Instruction* > instructions; 00152 00153 bool autoQualAssess; 00154 00155 int vertexSlaverCount; 00156 size_t nbPreConditionners; 00157 bool isMasterSet; 00158 size_t masterInstrIndex; //!< 0-based. Keeping an index instead of an iterator 00159 //!< in case list is reallocated 00160 }; 00161 00162 } // namespace MBMesquite 00163 00164 #endif // InstructionQueue_hpp
