MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retian certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) [email protected] 00024 00025 ***************************************************************** */ 00026 00027 /** \file QuadLagrangeShapeTest.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "QuadLagrangeShape.hpp" 00034 #include "TopologyInfo.hpp" 00035 #include "MsqError.hpp" 00036 #include "IdealElements.hpp" 00037 #include "JacobianCalculator.hpp" 00038 00039 #include "UnitUtil.hpp" 00040 00041 #include <vector> 00042 #include <algorithm> 00043 #include <iostream> 00044 #include <sstream> 00045 00046 using namespace MBMesquite; 00047 using namespace std; 00048 const double epsilon = 1e-6; 00049 #define ASSERT_VALUES_EQUAL( v1, v2, location, bits ) \ 00050 ASSERT_MESSAGE( value_message( ( location ), ( bits ), ( v1 ), ( v2 ) ), ( fabs( ( v1 ) - ( v2 ) ) < epsilon ) ) 00051 00052 static inline CppUnit::Message value_message( unsigned location, NodeSet bits, double v1, double v2 ) 00053 { 00054 CppUnit::Message m( "equality assertion failed" ); 00055 00056 std::ostringstream buffer1; 00057 buffer1 << "Expected : " << v1; 00058 m.addDetail( buffer1.str() ); 00059 00060 std::ostringstream buffer2; 00061 buffer2 << "Actual : " << v2; 00062 m.addDetail( buffer2.str() ); 00063 00064 std::ostringstream buffer3; 00065 buffer3 << "Location : "; 00066 if( location < 4 ) 00067 buffer3 << "Corner " << location; 00068 else if( location < 8 ) 00069 buffer3 << "Edge " << location - 4; 00070 else if( location == 8 ) 00071 buffer3 << "Mid-element"; 00072 else 00073 buffer3 << "INVALID!!"; 00074 m.addDetail( buffer3.str() ); 00075 00076 std::ostringstream buffer4; 00077 buffer4 << "Node Bits: " << bits; 00078 m.addDetail( buffer4.str() ); 00079 return m; 00080 } 00081 00082 class QuadLagrangeShapeTest : public CppUnit::TestFixture 00083 { 00084 private: 00085 CPPUNIT_TEST_SUITE( QuadLagrangeShapeTest ); 00086 00087 CPPUNIT_TEST( test_coeff_corners ); 00088 CPPUNIT_TEST( test_coeff_edges ); 00089 CPPUNIT_TEST( test_coeff_center ); 00090 00091 CPPUNIT_TEST( test_deriv_corners ); 00092 CPPUNIT_TEST( test_deriv_edges ); 00093 CPPUNIT_TEST( test_deriv_center ); 00094 00095 CPPUNIT_TEST( test_ideal_jacobian ); 00096 00097 CPPUNIT_TEST_SUITE_END(); 00098 00099 QuadLagrangeShape sf; 00100 00101 void test_corner_coeff( int corner, NodeSet nodeset ); 00102 void test_edge_coeff( int edge, NodeSet nodeset ); 00103 void test_mid_coeff( NodeSet nodeset ); 00104 00105 void test_corner_derivs( int corner, NodeSet nodeset ); 00106 void test_edge_derivs( int edge, NodeSet nodeset ); 00107 void test_mid_derivs( NodeSet nodeset ); 00108 00109 public: 00110 void test_coeff_corners(); 00111 void test_coeff_edges(); 00112 void test_coeff_center(); 00113 00114 void test_deriv_corners(); 00115 void test_deriv_edges(); 00116 void test_deriv_center(); 00117 00118 void test_ideal_jacobian(); 00119 }; 00120 00121 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( QuadLagrangeShapeTest, "QuadLagrangeShapeTest" ); 00122 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( QuadLagrangeShapeTest, "Unit" ); 00123 00124 // Indices 00125 enum 00126 { 00127 XI = 0, 00128 ETA = 1 00129 }; 00130 // Parameter range 00131 // const double min_xi = -1; 00132 // const double max_xi = 1; 00133 // reparameterize in [0,1] 00134 const double min_xi = 0; 00135 const double max_xi = 1; 00136 const double mid_xi = 0.5 * ( min_xi + max_xi ); 00137 00138 // Some lagrange polynomial terms 00139 // static double l11( double xi ) { return 0.5 * (1 - xi); } 00140 // static double l12( double xi ) { return 0.5 * (1 + xi); } 00141 // static double l22( double xi ) { return 1 - xi*xi; } 00142 // reparameterize in [0,1] 00143 static double l11( double xi ) 00144 { 00145 return 1 - xi; 00146 } 00147 static double l12( double xi ) 00148 { 00149 return xi; 00150 } 00151 static double l22( double xi ) 00152 { 00153 return 4 * xi * ( 1 - xi ); 00154 } 00155 // First derivatives of lagrange polynomial terms 00156 // static double dl11( double ) { return -0.5; } 00157 // static double dl12( double ) { return 0.5; } 00158 // static double dl22( double xi ) { return -2 * xi; } 00159 // reparameterize in [0,1] 00160 static double dl11( double ) 00161 { 00162 return -1; 00163 } 00164 static double dl12( double ) 00165 { 00166 return 1; 00167 } 00168 static double dl22( double xi ) 00169 { 00170 return 4 - 8 * xi; 00171 } 00172 00173 // Mapping function weights. See pg. 135 of Hughes and 'eval' method below 00174 // for an explanation of why we begin with linear element weight functions 00175 // for the corner nodes and a mixture of quadratic and linear weight 00176 // functions for mid-edge nodes. 00177 00178 // Linear quad weights at corners 00179 static double N0( double xi, double eta ) 00180 { 00181 return l11( xi ) * l11( eta ); 00182 } 00183 static double N1( double xi, double eta ) 00184 { 00185 return l12( xi ) * l11( eta ); 00186 } 00187 static double N2( double xi, double eta ) 00188 { 00189 return l12( xi ) * l12( eta ); 00190 } 00191 static double N3( double xi, double eta ) 00192 { 00193 return l11( xi ) * l12( eta ); 00194 } 00195 // Mixture of linear and quadratic weight functions for mid-side nodes 00196 static double N4( double xi, double eta ) 00197 { 00198 return l22( xi ) * l11( eta ); 00199 } 00200 static double N5( double xi, double eta ) 00201 { 00202 return l12( xi ) * l22( eta ); 00203 } 00204 static double N6( double xi, double eta ) 00205 { 00206 return l22( xi ) * l12( eta ); 00207 } 00208 static double N7( double xi, double eta ) 00209 { 00210 return l11( xi ) * l22( eta ); 00211 } 00212 // Quadratic element weight function for mid-element node 00213 static double N8( double xi, double eta ) 00214 { 00215 return l22( xi ) * l22( eta ); 00216 } 00217 // Derivatives of above weight functions wrt xi 00218 static double dN0dxi( double xi, double eta ) 00219 { 00220 return dl11( xi ) * l11( eta ); 00221 } 00222 static double dN1dxi( double xi, double eta ) 00223 { 00224 return dl12( xi ) * l11( eta ); 00225 } 00226 static double dN2dxi( double xi, double eta ) 00227 { 00228 return dl12( xi ) * l12( eta ); 00229 } 00230 static double dN3dxi( double xi, double eta ) 00231 { 00232 return dl11( xi ) * l12( eta ); 00233 } 00234 static double dN4dxi( double xi, double eta ) 00235 { 00236 return dl22( xi ) * l11( eta ); 00237 } 00238 static double dN5dxi( double xi, double eta ) 00239 { 00240 return dl12( xi ) * l22( eta ); 00241 } 00242 static double dN6dxi( double xi, double eta ) 00243 { 00244 return dl22( xi ) * l12( eta ); 00245 } 00246 static double dN7dxi( double xi, double eta ) 00247 { 00248 return dl11( xi ) * l22( eta ); 00249 } 00250 static double dN8dxi( double xi, double eta ) 00251 { 00252 return dl22( xi ) * l22( eta ); 00253 } 00254 // Derivatives of above weight functions wrt eta 00255 static double dN0deta( double xi, double eta ) 00256 { 00257 return l11( xi ) * dl11( eta ); 00258 } 00259 static double dN1deta( double xi, double eta ) 00260 { 00261 return l12( xi ) * dl11( eta ); 00262 } 00263 static double dN2deta( double xi, double eta ) 00264 { 00265 return l12( xi ) * dl12( eta ); 00266 } 00267 static double dN3deta( double xi, double eta ) 00268 { 00269 return l11( xi ) * dl12( eta ); 00270 } 00271 static double dN4deta( double xi, double eta ) 00272 { 00273 return l22( xi ) * dl11( eta ); 00274 } 00275 static double dN5deta( double xi, double eta ) 00276 { 00277 return l12( xi ) * dl22( eta ); 00278 } 00279 static double dN6deta( double xi, double eta ) 00280 { 00281 return l22( xi ) * dl12( eta ); 00282 } 00283 static double dN7deta( double xi, double eta ) 00284 { 00285 return l11( xi ) * dl22( eta ); 00286 } 00287 static double dN8deta( double xi, double eta ) 00288 { 00289 return l22( xi ) * dl22( eta ); 00290 } 00291 00292 typedef double ( *N_t )( double, double ); 00293 static const N_t N_a[9] = { &N0, &N1, &N2, &N3, &N4, &N5, &N6, &N7, &N8 }; 00294 static const N_t dNdxi_a[9] = { &dN0dxi, &dN1dxi, &dN2dxi, &dN3dxi, &dN4dxi, &dN5dxi, &dN6dxi, &dN7dxi, &dN8dxi }; 00295 static const N_t dNdeta_a[9] = { &dN0deta, &dN1deta, &dN2deta, &dN3deta, &dN4deta, 00296 &dN5deta, &dN6deta, &dN7deta, &dN8deta }; 00297 00298 // Mapping function coefficient functions (i<-vertex number) 00299 static double N( unsigned i, double xi, double eta ) 00300 { 00301 return N_a[i]( xi, eta ); 00302 } 00303 00304 // Partial derivatives of mapping function coefficients 00305 static double dNdxi( unsigned i, double xi, double eta ) 00306 { 00307 return dNdxi_a[i]( xi, eta ); 00308 } 00309 static double dNdeta( unsigned i, double xi, double eta ) 00310 { 00311 return dNdeta_a[i]( xi, eta ); 00312 } 00313 00314 // Evaluate one of N, dNdxi or dNdeta for each vertex 00315 typedef double ( *f_t )( unsigned, double, double ); 00316 static void eval( f_t function, NodeSet nodeset, double xi, double eta, double results[9] ) 00317 { 00318 // Initial values are a) linear values for corners, 00319 // b) values for mid edges assuming no mid-face node, 00320 // and c) the mid-face value for a fully quadratic element. 00321 for( unsigned i = 0; i < 9; ++i ) 00322 results[i] = function( i, xi, eta ); 00323 00324 // if center node is present, adjust mid-edge coefficients 00325 if( !nodeset.mid_face_node( 0 ) ) 00326 { 00327 results[8] = 0; 00328 } 00329 else 00330 { 00331 for( unsigned i = 0; i < 4; ++i ) 00332 results[i] -= 0.25 * results[8]; 00333 for( unsigned i = 4; i < 8; ++i ) 00334 results[i] -= 0.5 * results[8]; 00335 } 00336 00337 // if mid-edge nodes are present, adjust values for adjacent corners 00338 for( unsigned i = 0; i < 4; ++i ) 00339 { 00340 if( !nodeset.mid_edge_node( i ) ) 00341 { 00342 results[i + 4] = 0.0; 00343 } 00344 else 00345 { 00346 results[i] -= 0.5 * results[i + 4]; // 1st adjacent corner 00347 results[( i + 1 ) % 4] -= 0.5 * results[i + 4]; // 2nd adjacent corner 00348 } 00349 } 00350 } 00351 00352 // Finally, what all the above stuff was building up to: 00353 // functions to query mapping function. 00354 00355 static void get_coeffs( NodeSet nodebits, double xi, double eta, double coeffs_out[9] ) 00356 { 00357 eval( &N, nodebits, xi, eta, coeffs_out ); 00358 } 00359 00360 static void get_partial_wrt_xi( NodeSet nodebits, double xi, double eta, double derivs_out[9] ) 00361 { 00362 eval( &dNdxi, nodebits, xi, eta, derivs_out ); 00363 } 00364 00365 static void get_partial_wrt_eta( NodeSet nodebits, double xi, double eta, double derivs_out[9] ) 00366 { 00367 eval( &dNdeta, nodebits, xi, eta, derivs_out ); 00368 } 00369 00370 // Pre-defined sample points (xi and eta values) 00371 static const double corners[4][2] = { { min_xi, min_xi }, { max_xi, min_xi }, { max_xi, max_xi }, { min_xi, max_xi } }; 00372 static const double midedge[4][2] = { { mid_xi, min_xi }, { max_xi, mid_xi }, { mid_xi, max_xi }, { min_xi, mid_xi } }; 00373 static const double midelem[2] = { mid_xi, mid_xi }; 00374 00375 static void check_valid_indices( const size_t* vertices, size_t num_vtx, NodeSet nodeset ) 00376 { 00377 // check valid size of list (at least three, at most all nodes) 00378 CPPUNIT_ASSERT( num_vtx <= 9 ); 00379 CPPUNIT_ASSERT( num_vtx >= 3 ); 00380 // make sure vertex indices are valid (in [0,8]) 00381 size_t vertcopy[9]; 00382 std::copy( vertices, vertices + num_vtx, vertcopy ); 00383 std::sort( vertcopy, vertcopy + num_vtx ); 00384 CPPUNIT_ASSERT( vertcopy[num_vtx - 1] <= 8 ); // max value less than 9 00385 // make sure there are no duplicates in the list 00386 const size_t* iter = std::unique( vertcopy, vertcopy + num_vtx ); 00387 CPPUNIT_ASSERT( iter == vertcopy + num_vtx ); 00388 00389 // make all vertices are present in element 00390 for( unsigned i = 0; i < num_vtx; ++i ) 00391 { 00392 if( vertcopy[i] == 8 ) 00393 CPPUNIT_ASSERT( nodeset.mid_face_node( 0 ) ); 00394 else if( vertcopy[i] >= 4 ) 00395 CPPUNIT_ASSERT( nodeset.mid_edge_node( vertcopy[i] - 4 ) ); 00396 } 00397 } 00398 00399 static void check_no_zeros( const MsqVector< 2 >* derivs, size_t num_vtx ) 00400 { 00401 for( unsigned i = 0; i < num_vtx; ++i ) 00402 { 00403 double dxi = derivs[i][0]; 00404 double deta = derivs[i][1]; 00405 CPPUNIT_ASSERT( fabs( dxi ) > 1e-6 || fabs( deta ) > 1e-6 ); 00406 } 00407 } 00408 00409 static void compare_coefficients( const double* coeffs, 00410 const size_t* indices, 00411 size_t num_coeff, 00412 const double* expected_coeffs, 00413 unsigned loc, 00414 NodeSet bits ) 00415 { 00416 // find the location in the returned list for each node 00417 size_t revidx[9]; 00418 double test_vals[9]; 00419 for( size_t i = 0; i < 9; ++i ) 00420 { 00421 revidx[i] = std::find( indices, indices + num_coeff, i ) - indices; 00422 test_vals[i] = ( revidx[i] == num_coeff ) ? 0.0 : coeffs[revidx[i]]; 00423 } 00424 00425 // Check that index list doesn't contain any nodes not actually 00426 // present in the element. 00427 CPPUNIT_ASSERT( bits.mid_edge_node( 0 ) || ( revidx[4] == num_coeff ) ); 00428 CPPUNIT_ASSERT( bits.mid_edge_node( 1 ) || ( revidx[5] == num_coeff ) ); 00429 CPPUNIT_ASSERT( bits.mid_edge_node( 2 ) || ( revidx[6] == num_coeff ) ); 00430 CPPUNIT_ASSERT( bits.mid_edge_node( 3 ) || ( revidx[7] == num_coeff ) ); 00431 CPPUNIT_ASSERT( bits.mid_face_node( 0 ) || ( revidx[8] == num_coeff ) ); 00432 00433 // compare expected and actual coefficient values 00434 ASSERT_VALUES_EQUAL( expected_coeffs[0], test_vals[0], loc, bits ); 00435 ASSERT_VALUES_EQUAL( expected_coeffs[1], test_vals[1], loc, bits ); 00436 ASSERT_VALUES_EQUAL( expected_coeffs[2], test_vals[2], loc, bits ); 00437 ASSERT_VALUES_EQUAL( expected_coeffs[3], test_vals[3], loc, bits ); 00438 ASSERT_VALUES_EQUAL( expected_coeffs[4], test_vals[4], loc, bits ); 00439 ASSERT_VALUES_EQUAL( expected_coeffs[5], test_vals[5], loc, bits ); 00440 ASSERT_VALUES_EQUAL( expected_coeffs[6], test_vals[6], loc, bits ); 00441 ASSERT_VALUES_EQUAL( expected_coeffs[7], test_vals[7], loc, bits ); 00442 ASSERT_VALUES_EQUAL( expected_coeffs[8], test_vals[8], loc, bits ); 00443 } 00444 00445 static void compare_derivatives( const size_t* vertices, 00446 size_t num_vtx, 00447 const MsqVector< 2 >* derivs, 00448 const double* expected_dxi, 00449 const double* expected_deta, 00450 unsigned loc, 00451 NodeSet bits ) 00452 { 00453 check_valid_indices( vertices, num_vtx, bits ); 00454 check_no_zeros( derivs, num_vtx ); 00455 00456 // Input has values in dxi & deta only for nodes in 'vertices' 00457 // Convert to values for every possible node, with zero's for 00458 // nodes that are not present. 00459 CPPUNIT_ASSERT( num_vtx <= 9 ); 00460 double expanded_dxi[9], expanded_deta[9]; 00461 std::fill( expanded_dxi, expanded_dxi + 9, 0.0 ); 00462 std::fill( expanded_deta, expanded_deta + 9, 0.0 ); 00463 for( unsigned i = 0; i < num_vtx; ++i ) 00464 { 00465 CPPUNIT_ASSERT( vertices[i] <= 9 ); 00466 expanded_dxi[vertices[i]] = derivs[i][0]; 00467 expanded_deta[vertices[i]] = derivs[i][1]; 00468 } 00469 00470 ASSERT_VALUES_EQUAL( expected_dxi[0], expanded_dxi[0], loc, bits ); 00471 ASSERT_VALUES_EQUAL( expected_dxi[1], expanded_dxi[1], loc, bits ); 00472 ASSERT_VALUES_EQUAL( expected_dxi[2], expanded_dxi[2], loc, bits ); 00473 ASSERT_VALUES_EQUAL( expected_dxi[3], expanded_dxi[3], loc, bits ); 00474 ASSERT_VALUES_EQUAL( expected_dxi[4], expanded_dxi[4], loc, bits ); 00475 ASSERT_VALUES_EQUAL( expected_dxi[5], expanded_dxi[5], loc, bits ); 00476 ASSERT_VALUES_EQUAL( expected_dxi[6], expanded_dxi[6], loc, bits ); 00477 ASSERT_VALUES_EQUAL( expected_dxi[7], expanded_dxi[7], loc, bits ); 00478 ASSERT_VALUES_EQUAL( expected_dxi[8], expanded_dxi[8], loc, bits ); 00479 00480 ASSERT_VALUES_EQUAL( expected_deta[0], expanded_deta[0], loc, bits ); 00481 ASSERT_VALUES_EQUAL( expected_deta[1], expanded_deta[1], loc, bits ); 00482 ASSERT_VALUES_EQUAL( expected_deta[2], expanded_deta[2], loc, bits ); 00483 ASSERT_VALUES_EQUAL( expected_deta[3], expanded_deta[3], loc, bits ); 00484 ASSERT_VALUES_EQUAL( expected_deta[4], expanded_deta[4], loc, bits ); 00485 ASSERT_VALUES_EQUAL( expected_deta[5], expanded_deta[5], loc, bits ); 00486 ASSERT_VALUES_EQUAL( expected_deta[6], expanded_deta[6], loc, bits ); 00487 ASSERT_VALUES_EQUAL( expected_deta[7], expanded_deta[7], loc, bits ); 00488 ASSERT_VALUES_EQUAL( expected_deta[8], expanded_deta[8], loc, bits ); 00489 } 00490 00491 void QuadLagrangeShapeTest::test_corner_coeff( int corner, NodeSet nodebits ) 00492 { 00493 MsqPrintError err( std::cout ); 00494 00495 double expected[9]; 00496 get_coeffs( nodebits, corners[corner][XI], corners[corner][ETA], expected ); 00497 00498 double coeff[100]; 00499 size_t num_coeff = 11, indices[100]; 00500 sf.coefficients( Sample( 0, corner ), nodebits, coeff, indices, num_coeff, err ); 00501 CPPUNIT_ASSERT( !err ); 00502 00503 compare_coefficients( coeff, indices, num_coeff, expected, corner, nodebits ); 00504 } 00505 00506 void QuadLagrangeShapeTest::test_edge_coeff( int edge, NodeSet nodebits ) 00507 { 00508 MsqPrintError err( std::cout ); 00509 00510 double expected[9]; 00511 get_coeffs( nodebits, midedge[edge][XI], midedge[edge][ETA], expected ); 00512 00513 double coeff[100]; 00514 size_t num_coeff = 11, indices[100]; 00515 sf.coefficients( Sample( 1, edge ), nodebits, coeff, indices, num_coeff, err ); 00516 CPPUNIT_ASSERT( !err ); 00517 00518 compare_coefficients( coeff, indices, num_coeff, expected, edge + 4, nodebits ); 00519 } 00520 00521 void QuadLagrangeShapeTest::test_mid_coeff( NodeSet nodebits ) 00522 { 00523 MsqPrintError err( std::cout ); 00524 00525 double expected[9]; 00526 get_coeffs( nodebits, midelem[XI], midelem[ETA], expected ); 00527 00528 double coeff[100]; 00529 size_t num_coeff = 11, indices[100]; 00530 sf.coefficients( Sample( 2, 0 ), nodebits, coeff, indices, num_coeff, err ); 00531 CPPUNIT_ASSERT( !err ); 00532 00533 compare_coefficients( coeff, indices, num_coeff, expected, 8, nodebits ); 00534 } 00535 00536 void QuadLagrangeShapeTest::test_corner_derivs( int corner, NodeSet nodebits ) 00537 { 00538 MsqPrintError err( std::cout ); 00539 00540 double expected_dxi[9], expected_deta[9]; 00541 get_partial_wrt_xi( nodebits, corners[corner][XI], corners[corner][ETA], expected_dxi ); 00542 get_partial_wrt_eta( nodebits, corners[corner][XI], corners[corner][ETA], expected_deta ); 00543 00544 size_t vertices[100], num_vtx = 23; 00545 MsqVector< 2 > derivs[100]; 00546 sf.derivatives( Sample( 0, corner ), nodebits, vertices, derivs, num_vtx, err ); 00547 CPPUNIT_ASSERT( !err ); 00548 00549 compare_derivatives( vertices, num_vtx, derivs, expected_dxi, expected_deta, corner, nodebits ); 00550 } 00551 00552 void QuadLagrangeShapeTest::test_edge_derivs( int edge, NodeSet nodebits ) 00553 { 00554 MsqPrintError err( std::cout ); 00555 00556 double expected_dxi[9], expected_deta[9]; 00557 get_partial_wrt_xi( nodebits, midedge[edge][XI], midedge[edge][ETA], expected_dxi ); 00558 get_partial_wrt_eta( nodebits, midedge[edge][XI], midedge[edge][ETA], expected_deta ); 00559 00560 size_t vertices[100], num_vtx = 23; 00561 MsqVector< 2 > derivs[100]; 00562 sf.derivatives( Sample( 1, edge ), nodebits, vertices, derivs, num_vtx, err ); 00563 CPPUNIT_ASSERT( !err ); 00564 00565 compare_derivatives( vertices, num_vtx, derivs, expected_dxi, expected_deta, edge + 4, nodebits ); 00566 } 00567 00568 void QuadLagrangeShapeTest::test_mid_derivs( NodeSet nodebits ) 00569 { 00570 MsqPrintError err( std::cout ); 00571 00572 double expected_dxi[9], expected_deta[9]; 00573 get_partial_wrt_xi( nodebits, midelem[XI], midelem[ETA], expected_dxi ); 00574 get_partial_wrt_eta( nodebits, midelem[XI], midelem[ETA], expected_deta ); 00575 00576 size_t vertices[100], num_vtx = 23; 00577 MsqVector< 2 > derivs[100]; 00578 sf.derivatives( Sample( 2, 0 ), nodebits, vertices, derivs, num_vtx, err ); 00579 CPPUNIT_ASSERT( !err ); 00580 00581 compare_derivatives( vertices, num_vtx, derivs, expected_dxi, expected_deta, 8, nodebits ); 00582 } 00583 00584 static NodeSet nodeset_from_bits( unsigned bits ) 00585 { 00586 NodeSet result; 00587 for( unsigned i = 0; i < 4; ++i ) 00588 if( bits & ( 1 << i ) ) result.set_mid_edge_node( i ); 00589 if( bits & ( 1 << 4 ) ) result.set_mid_face_node( 0 ); 00590 return result; 00591 } 00592 00593 void QuadLagrangeShapeTest::test_coeff_corners() 00594 { 00595 // for every possible combination of higher-order nodes 00596 // (0x1F = 11111 : five possible higher-order nodes in quad) 00597 for( unsigned j = 0; j <= 0x1Fu; ++j ) 00598 // for every corner 00599 for( unsigned i = 0; i < 4; ++i ) 00600 test_corner_coeff( i, nodeset_from_bits( j ) ); 00601 } 00602 00603 void QuadLagrangeShapeTest::test_coeff_edges() 00604 { 00605 // for every possible combination of higher-order nodes 00606 // (0x1F = 11111 : five possible higher-order nodes in quad) 00607 for( unsigned j = 0; j <= 0x1Fu; ++j ) 00608 // for every edge 00609 for( unsigned i = 0; i < 4; ++i ) 00610 test_edge_coeff( i, nodeset_from_bits( j ) ); 00611 } 00612 00613 void QuadLagrangeShapeTest::test_coeff_center() 00614 { 00615 // for every possible combination of higher-order nodes 00616 // (0x1F = 11111 : five possible higher-order nodes in quad) 00617 for( unsigned j = 0; j <= 0x1Fu; ++j ) 00618 test_mid_coeff( nodeset_from_bits( j ) ); 00619 } 00620 00621 void QuadLagrangeShapeTest::test_deriv_corners() 00622 { 00623 // for every possible combination of higher-order nodes 00624 // (0x1F = 11111 : five possible higher-order nodes in quad) 00625 for( unsigned j = 0; j <= 0x1Fu; ++j ) 00626 // for every corner 00627 for( unsigned i = 0; i < 4; ++i ) 00628 test_corner_derivs( i, nodeset_from_bits( j ) ); 00629 } 00630 00631 void QuadLagrangeShapeTest::test_deriv_edges() 00632 { 00633 // for every possible combination of higher-order nodes 00634 // (0x1F = 11111 : five possible higher-order nodes in quad) 00635 for( unsigned j = 0; j <= 0x1Fu; ++j ) 00636 // for every edge 00637 for( unsigned i = 0; i < 4; ++i ) 00638 test_edge_derivs( i, nodeset_from_bits( j ) ); 00639 } 00640 00641 void QuadLagrangeShapeTest::test_deriv_center() 00642 { 00643 // for every possible combination of higher-order nodes 00644 // (0x1F = 11111 : five possible higher-order nodes in quad) 00645 for( unsigned j = 0; j <= 0x1Fu; ++j ) 00646 test_mid_derivs( nodeset_from_bits( j ) ); 00647 } 00648 00649 void QuadLagrangeShapeTest::test_ideal_jacobian() 00650 { 00651 MsqError err; 00652 MsqMatrix< 3, 2 > J_prime; 00653 sf.ideal( Sample( 2, 0 ), J_prime, err ); 00654 ASSERT_NO_ERROR( err ); 00655 00656 // for this test that everything is in the xy-plane 00657 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, J_prime( 2, 0 ), 1e-12 ); 00658 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, J_prime( 2, 1 ), 1e-12 ); 00659 MsqMatrix< 2, 2 > J_act( J_prime.data() ); 00660 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( J_act ), 1e-6 ); 00661 00662 const Vector3D* verts = unit_edge_element( QUADRILATERAL ); 00663 CPPUNIT_ASSERT( verts ); 00664 00665 JacobianCalculator jc; 00666 jc.get_Jacobian_2D( &sf, NodeSet(), Sample( 2, 0 ), verts, 4, J_prime, err ); 00667 ASSERT_NO_ERROR( err ); 00668 00669 // for this test that everything is in the xy-plane 00670 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, J_prime( 2, 0 ), 1e-12 ); 00671 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, J_prime( 2, 1 ), 1e-12 ); 00672 MsqMatrix< 2, 2 > J_exp( J_prime.data() ); 00673 J_exp /= sqrt( det( J_exp ) ); 00674 00675 // Matrices should be a rotation of each other. 00676 // First, calculate tentative rotation matrix 00677 MsqMatrix< 2, 2 > R = inverse( J_exp ) * J_act; 00678 // next check that it is a rotation 00679 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( R ), 1e-6 ); // no scaling 00680 ASSERT_MATRICES_EQUAL( transpose( R ), inverse( R ), 1e-6 ); // orthogonal 00681 }
