Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 //------------------------------------------------------------------------- 00017 // Filename : ReadNASTRAN.hpp 00018 // 00019 // Purpose : NASTRAN file reader 00020 // 00021 // Creator : Brandon Smith 00022 // 00023 // Date : 08/2009 00024 // 00025 //------------------------------------------------------------------------- 00026 00027 #ifndef READNASTRAN_HPP 00028 #define READNASTRAN_HPP 00029 00030 #ifndef IS_BUILDING_MB 00031 #error "ReadNASTRAN.hpp isn't supposed to be included into an application" 00032 #endif 00033 00034 #include <iostream> 00035 #include <fstream> 00036 #include <sstream> 00037 #include <vector> 00038 00039 #include "moab/Interface.hpp" 00040 #include "moab/ReaderIface.hpp" 00041 #include "FileTokenizer.hpp" 00042 #include "moab/RangeMap.hpp" 00043 00044 namespace moab 00045 { 00046 00047 class ReadUtilIface; 00048 00049 class ReadNASTRAN : public ReaderIface 00050 { 00051 00052 public: 00053 // factory method 00054 static ReaderIface* factory( Interface* ); 00055 00056 ErrorCode load_file( const char* file_name, 00057 const EntityHandle* file_set, 00058 const FileOptions& opts, 00059 const SubsetList* subset_list = 0, 00060 const Tag* file_id_tag = 0 ); 00061 // constructor 00062 ReadNASTRAN( Interface* impl = NULL ); 00063 00064 // destructor 00065 virtual ~ReadNASTRAN(); 00066 00067 ErrorCode read_tag_values( const char* file_name, 00068 const char* tag_name, 00069 const FileOptions& opts, 00070 std::vector< int >& tag_values_out, 00071 const SubsetList* subset_list = 0 ); 00072 00073 protected: 00074 private: 00075 // read mesh interface 00076 ReadUtilIface* readMeshIface; 00077 00078 // MOAB Interface 00079 Interface* MBI; 00080 00081 RangeMap< int, EntityHandle > nodeIdMap, elemIdMap; 00082 00083 enum line_format 00084 { 00085 SMALL_FIELD, 00086 LARGE_FIELD, 00087 FREE_FIELD 00088 }; 00089 00090 ErrorCode determine_line_format( const std::string& line, line_format& format ); 00091 00092 ErrorCode tokenize_line( const std::string& line, const line_format format, std::vector< std::string >& tokens ); 00093 00094 ErrorCode determine_entity_type( const std::string& token, EntityType& type ); 00095 00096 ErrorCode get_real( const std::string&, double& real ); 00097 00098 ErrorCode read_node( const std::vector< std::string >& tokens, 00099 const bool debug, 00100 double* coord_arrays[3], 00101 int& node_id ); 00102 00103 ErrorCode read_element( const std::vector< std::string >& tokens, 00104 std::vector< Range >& materials, 00105 const EntityType element_type, 00106 const bool debug ); 00107 00108 ErrorCode create_materials( const std::vector< Range >& materials ); 00109 00110 ErrorCode assign_ids( const Tag* file_id_tag ); 00111 }; 00112 00113 } // namespace moab 00114 00115 #endif
