Mesh Oriented datABase
(version 5.4.1)
00001 #include "SplitVertices.hpp" 00002 #include "RefinerTagManager.hpp" 00003 00004 #include "MBParallelConventions.h" 00005 00006 namespace moab 00007 { 00008 00009 SplitVerticesBase::SplitVerticesBase( RefinerTagManager* tag_mgr ) 00010 { 00011 this->tag_manager = tag_mgr; 00012 this->mesh_out = tag_mgr->get_output_mesh(); 00013 } 00014 00015 SplitVerticesBase::~SplitVerticesBase() {} 00016 00017 EntitySource::EntitySource( int nc, RefinerTagManager* tag_mgr ) 00018 { 00019 this->tag_manager = tag_mgr; 00020 this->mesh_out = tag_mgr->get_output_mesh(); 00021 this->num_corners = nc; 00022 } 00023 00024 EntitySource::~EntitySource() {} 00025 00026 bool EntitySource::create_element( EntityType etyp, 00027 int nconn, 00028 const EntityHandle* elem_verts, 00029 EntityHandle& elem_handle, 00030 std::map< ProcessSet, int >& proc_partition_counts ) 00031 { 00032 // Get the global IDs of the input vertices 00033 // int stat; 00034 proc_partition_counts[this->tag_manager->get_element_procs()]++; 00035 if( this->mesh_out->create_element( etyp, elem_verts, nconn, elem_handle ) != MB_SUCCESS ) 00036 { 00037 return false; 00038 } 00039 this->push_back( EntitySourceRecord( this->num_corners, elem_handle, this->tag_manager->get_element_procs() ) ); 00040 this->tag_manager->set_sharing( elem_handle, this->tag_manager->get_element_procs() ); 00041 return true; 00042 } 00043 00044 void EntitySource::assign_global_ids( std::map< ProcessSet, int >& gids ) 00045 { 00046 std::vector< EntityHandle > adjacencies; 00047 adjacencies.resize( this->num_corners ); 00048 std::vector< EntitySourceRecord >::iterator it; 00049 for( it = this->begin(); it != this->end(); ++it ) 00050 { 00051 int num_nodes; 00052 const EntityHandle* conn; 00053 this->mesh_out->get_connectivity( it->handle, conn, num_nodes ); 00054 this->tag_manager->get_output_gids( this->num_corners, conn, it->ids ); 00055 std::sort( it->ids.begin(), it->ids.end() ); 00056 } 00057 std::sort( this->begin(), this->end() ); 00058 for( it = this->begin(); it != this->end(); ++it ) 00059 { 00060 int gid = gids[it->process_set]++; 00061 this->tag_manager->set_gid( it->handle, gid ); 00062 #ifdef MB_DEBUG 00063 std::cout << "Assigning entity: " << it->handle << " GID: " << gid << "\n"; 00064 #endif // MB_DEBUG 00065 } 00066 } 00067 00068 } // namespace moab
