Mesh Oriented datABase
(version 5.4.1)
00001 ! advection: do a one time step transport, using c binding module 00002 ! example of how to do it in parallel in fortran 00003 ! This program shows how to load in parallel in moab from Fortran90, and how 00004 ! to call the transport wrapper. It is a fortran equivalent of intx_imesh 00005 ! driver 00006 ! 00007 ! Usage: advection 00008 00009 #define CHECK(a) if (ierr .ne. 0) print *, a 00010 program advection 00011 00012 use ISO_C_BINDING 00013 implicit none 00014 00015 #include "moab/MOABConfig.h" 00016 #ifdef MOAB_HAVE_MPI 00017 # include "mpif.h" 00018 # include "iMeshP_f.h" 00019 #else 00020 # include "iMesh_f.h" 00021 #endif 00022 00023 ! extern void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle * opEulerSet, int * ierr); 00024 INTERFACE 00025 SUBROUTINE update_tracer ( instance , opEulerSet, ierr) bind(C) 00026 use ISO_C_BINDING 00027 implicit none 00028 iMesh_Instance, INTENT(IN) , VALUE :: instance 00029 iBase_EntitySetHandle, INTENT(IN), VALUE :: opEulerSet 00030 integer(c_int) , INTENT (OUT) :: ierr 00031 END SUBROUTINE update_tracer 00032 END INTERFACE 00033 00034 ! declarations 00035 ! imesh is the instance handle 00036 iMesh_Instance imesh 00037 00038 ! cells will be storing 2d cells 00039 TYPE(C_PTR) cells_ptr 00040 iBase_EntityHandle, pointer :: cells(:) 00041 INTEGER ents_alloc, ents_size 00042 00043 iBase_EntitySetHandle root_set 00044 iBase_EntitySetHandle opEulerSet 00045 CHARACTER (LEN=200) options 00046 CHARACTER (LEN=200) filename 00047 CHARACTER (LEN=200) optionswrite 00048 CHARACTER (LEN=200) outname 00049 ! TYPE(C_PTR) :: vertsPtr, entsPtr 00050 00051 integer rank, sz, ierr 00052 integer lenopt, lenname 00053 integer isList 00054 00055 #ifdef MOAB_HAVE_MPI 00056 ! local variables for parallel runs 00057 iMeshP_PartitionHandle imeshp 00058 IBASE_HANDLE_T mpi_comm_c 00059 #endif 00060 00061 ! init the parallel partition 00062 call MPI_INIT(ierr) 00063 CHECK("fail to initialize MPI") 00064 call MPI_COMM_SIZE(MPI_COMM_WORLD, sz, ierr) 00065 CHECK("fail to get MPI size") 00066 call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr) 00067 CHECK("fail to get MPI rank") 00068 00069 ! now load the mesh; this also initializes parallel sharing 00070 imesh = 0 00071 imeshp = 0 00072 call iMesh_newMesh("MOAB", imesh, ierr) 00073 CHECK("fail to initialize imesh") 00074 00075 call iMesh_getRootSet(%VAL(imesh), root_set, ierr) 00076 CHECK("fail to get root set") 00077 00078 call iMeshP_getCommunicator(%VAL(imesh), MPI_COMM_WORLD, mpi_comm_c, ierr) 00079 00080 call iMeshP_createPartitionAll(%VAL(imesh), %VAL(mpi_comm_c), imeshp, ierr) 00081 CHECK("fail to create parallel partition ") 00082 options = " moab:PARALLEL=READ_PART moab:PARTITION=PARALLEL_PARTITION" // & 00083 " moab:PARALLEL_RESOLVE_SHARED_ENTS moab:PARTITION_DISTRIBUTE " 00084 ! " moab:PARALLEL=READ_PART moab:PARTITION=PARALLEL_PARTITION " & 00085 ! " moab:PARALLEL_RESOLVE_SHARED_ENTS moab:PARTITION_DISTRIBUTE ", & ! options 00086 if (0 .eq. rank) then 00087 print *, "load in parallel file HN16DP.h5m" 00088 endif 00089 lenname = 11; 00090 lenopt = 123 00091 filename = "HN16DP.h5m" 00092 call iMeshP_loadAll(%VAL(imesh), & 00093 %VAL(imeshp), & 00094 %VAL(root_set), & 00095 filename, & ! filename 00096 options, & !options 00097 ierr, & 00098 %VAL(lenname), & ! strlen(filename), 00099 %VAL(lenopt) ) !119) !strlen(options)); 00100 CHECK("fail to load mesh in parallel ") 00101 00102 isList = 0 00103 call iMesh_createEntSet(%VAL(imesh), %VAL(isList), opEulerSet, ierr) 00104 CHECK("fail to create euler set ") 00105 00106 ents_alloc = 0 00107 ents_size = 0 00108 00109 call iMesh_getEntities(%VAL(imesh),%VAL(root_set), & 00110 %VAL(iBase_FACE), & 00111 %VAL(iMesh_ALL_TOPOLOGIES), cells_ptr, & 00112 ents_alloc, ents_size, ierr); 00113 CHECK("fail to get 2d entities ") 00114 00115 call c_f_pointer(cells_ptr, cells, [ents_size]) 00116 00117 call iMesh_addEntArrToSet(%VAL(imesh), cells, %VAL(ents_size), & 00118 %VAL(opEulerSet), ierr) 00119 00120 call update_tracer(imesh, opEulerSet, ierr) 00121 CHECK("fail to update tracer ") 00122 00123 outname = "outF.h5m"; 00124 optionswrite = " moab:PARALLEL=WRITE_PART " ; 00125 lenname = 8 00126 lenopt = 27 00127 call iMeshP_saveAll( %VAL(imesh), & 00128 %VAL(imeshp), & 00129 %VAL(opEulerSet), & 00130 outname, & 00131 optionswrite, & 00132 ierr, & 00133 %VAL(lenname), & ! strlen(filename), 00134 %VAL(lenopt) ) !119) !strlen(options)); 00135 CHECK(" can't save ") 00136 00137 if (0==rank) then 00138 print *, "Done" 00139 endif 00140 00141 call MPI_FINALIZE(ierr) 00142 stop 00143 end program advection 00144
