moab::GeomTopoTool Member List
This is the complete list of members for moab::GeomTopoTool, including all inherited members.
A_is_in_B(const EntityHandle volume_A, const EntityHandle volume_B, GeomQueryTool *GQT)moab::GeomTopoTool [private]
add_geo_set(EntityHandle set, int dimension, int global_id=0)moab::GeomTopoTool
check_edge_sense_tags(bool create=false)moab::GeomTopoTool [private]
check_face_sense_tag(bool create=false)moab::GeomTopoTool [private]
check_geom_tag(bool create=false)moab::GeomTopoTool [private]
check_gid_tag(bool create=false)moab::GeomTopoTool [private]
check_model()moab::GeomTopoTool
construct_obb_tree(EntityHandle eh)moab::GeomTopoTool
construct_obb_trees(bool make_one_vol=false)moab::GeomTopoTool
construct_vertex_ranges(const Range &geom_sets, const Tag verts_tag)moab::GeomTopoTool [private]
delete_all_obb_trees()moab::GeomTopoTool
delete_obb_tree(EntityHandle gset, bool vol_only=false)moab::GeomTopoTool
dimension(EntityHandle this_set)moab::GeomTopoTool
duplicate_model(GeomTopoTool *&duplicate, std::vector< EntityHandle > *pvGEnts=NULL)moab::GeomTopoTool
entity_by_id(int dimension, int id)moab::GeomTopoTool
find_geomsets(Range *ranges=NULL)moab::GeomTopoTool
generate_implicit_complement(EntityHandle &implicit_complement_set)moab::GeomTopoTool [private]
geometrize_surface_set(EntityHandle surface, EntityHandle &output)moab::GeomTopoTool
geomRangesmoab::GeomTopoTool [private]
geomTagmoab::GeomTopoTool [private]
GeomTopoTool(Interface *impl, bool find_geoments=false, EntityHandle modelRootSet=0, bool p_rootSets_vector=true, bool restore_rootSets=true)moab::GeomTopoTool
geoRanges()moab::GeomTopoTool [inline]
get_bounding_coords(EntityHandle volume, double minPt[3], double maxPt[3])moab::GeomTopoTool
get_ct_children_by_dimension(const EntityHandle parent, const int desired_dimension)moab::GeomTopoTool [private]
get_geom_tag()moab::GeomTopoTool [inline]
get_gid_tag()moab::GeomTopoTool [inline]
get_gsets_by_dimension(int dim, Range &gset)moab::GeomTopoTool
get_implicit_complement(EntityHandle &implicit_complement)moab::GeomTopoTool
get_moab_instance()moab::GeomTopoTool [inline]
get_obb(EntityHandle volume, double center[3], double axis1[3], double axis2[3], double axis3[3])moab::GeomTopoTool
get_one_vol_root()moab::GeomTopoTool [inline]
get_root(EntityHandle vol_or_surf, EntityHandle &root)moab::GeomTopoTool [inline]
get_root_model_set()moab::GeomTopoTool [inline]
get_sense(EntityHandle entity, EntityHandle wrt_entity, int &sense)moab::GeomTopoTool
get_sense_tag()moab::GeomTopoTool [inline]
get_senses(EntityHandle entity, std::vector< EntityHandle > &wrt_entities, std::vector< int > &senses)moab::GeomTopoTool
get_surface_senses(EntityHandle volume, int num_surfs, const EntityHandle *surfs, int *senses_out)moab::GeomTopoTool
get_surface_senses(EntityHandle surface_ent, EntityHandle &forward_vol, EntityHandle &reverse_vol)moab::GeomTopoTool
gidTagmoab::GeomTopoTool [private]
global_id(EntityHandle this_set)moab::GeomTopoTool
have_obb_tree()moab::GeomTopoTool
impl_compl_handlemoab::GeomTopoTool [private]
insert_in_tree(const EntityHandle ct_root, const EntityHandle volume, GeomQueryTool *GQT)moab::GeomTopoTool [private]
is_implicit_complement(EntityHandle volume)moab::GeomTopoTool [inline]
is_owned_set(EntityHandle eh)moab::GeomTopoTool
m_rootSets_vectormoab::GeomTopoTool [private]
mapRootSetsmoab::GeomTopoTool [private]
maxGlobalIdmoab::GeomTopoTool [private]
mdbImplmoab::GeomTopoTool [private]
modelSetmoab::GeomTopoTool [private]
nameTagmoab::GeomTopoTool [private]
next_vol(EntityHandle surface, EntityHandle old_volume, EntityHandle &new_volume)moab::GeomTopoTool
num_ents_of_dim(int dim)moab::GeomTopoTool [inline]
obb_tree()moab::GeomTopoTool [inline]
obbGsetTagmoab::GeomTopoTool [private]
obbRootTagmoab::GeomTopoTool [private]
obbTreemoab::GeomTopoTool [private]
oneVolRootSetmoab::GeomTopoTool [private]
other_entity(EntityHandle bounded, EntityHandle not_this, EntityHandle across, EntityHandle &other)moab::GeomTopoTool
remove_root(EntityHandle vol_or_surf)moab::GeomTopoTool
resize_rootSets()moab::GeomTopoTool [private]
restore_obb_index()moab::GeomTopoTool
restore_topology_from_adjacency()moab::GeomTopoTool
restore_topology_from_geometric_inclusion(const Range &flat_volumes)moab::GeomTopoTool
rootSetsmoab::GeomTopoTool [private]
sense2Tagmoab::GeomTopoTool [private]
senseNEntsTagmoab::GeomTopoTool [private]
senseNSensesTagmoab::GeomTopoTool [private]
separate_by_dimension(const Range &geom_sets)moab::GeomTopoTool [private]
set_root_set(EntityHandle vol_or_surf, EntityHandle root)moab::GeomTopoTool [private]
set_sense(EntityHandle entity, EntityHandle wrt_entity, int sense)moab::GeomTopoTool
set_senses(EntityHandle entity, std::vector< EntityHandle > &wrt_entities, std::vector< int > &senses)moab::GeomTopoTool
set_surface_senses(EntityHandle surface_ent, EntityHandle forward_vol, EntityHandle reverse_vol)moab::GeomTopoTool
setOffsetmoab::GeomTopoTool [private]
setup_implicit_complement()moab::GeomTopoTool
updatedmoab::GeomTopoTool [private]
~GeomTopoTool()moab::GeomTopoTool
