Mesh Oriented datABase
(version 5.4.1)
| CleanUp() | moab::ParallelMergeMesh | [private] |
| GetGlobalBox(double *gbox) | moab::ParallelMergeMesh | [private] |
| merge(EntityHandle levelset=0, bool skip_local_merge=false, int dim=-1) | moab::ParallelMergeMesh | |
| myCD | moab::ParallelMergeMesh | [private] |
| myEps | moab::ParallelMergeMesh | [private] |
| myMatches | moab::ParallelMergeMesh | [private] |
| myMB | moab::ParallelMergeMesh | [private] |
| myPcomm | moab::ParallelMergeMesh | [private] |
| mySkinEnts | moab::ParallelMergeMesh | [private] |
| myTup | moab::ParallelMergeMesh | [private] |
| ParallelMergeMesh(ParallelComm *pc, const double epsilon) | moab::ParallelMergeMesh | |
| PartitionGlobalBox(double *gbox, double *lengths, int *parts) | moab::ParallelMergeMesh | [private] |
| PartitionSide(double sideLeng, double restLen, unsigned numProcs, bool altRatio) | moab::ParallelMergeMesh | [private, static] |
| PerformMerge(EntityHandle levelset=0, bool skip_local_merge=false, int dim=-1) | moab::ParallelMergeMesh | [private] |
| PerformRealSort(TupleList &tup, unsigned long left, unsigned long right, double eps2, uint tup_mr) | moab::ParallelMergeMesh | [private, static] |
| PopulateMyMatches() | moab::ParallelMergeMesh | [private] |
| PopulateMySkinEnts(const EntityHandle meshset, int dim, bool skip_local_merge=false) | moab::ParallelMergeMesh | [private] |
| PopulateMyTup(double *gbox) | moab::ParallelMergeMesh | [private] |
| SortMyMatches() | moab::ParallelMergeMesh | [private] |
| SortTuplesByReal(TupleList &tup, double eps2=0) | moab::ParallelMergeMesh | [private, static] |
| SwapTuples(TupleList &tup, unsigned long a, unsigned long b) | moab::ParallelMergeMesh | [private, static] |
| TagSharedElements(int dim) | moab::ParallelMergeMesh | [private] |
| TupleGreaterThan(TupleList &tup, unsigned long vrI, unsigned long vrJ, double eps2, uint tup_mr) | moab::ParallelMergeMesh | [private, static] |
