Mesh Oriented datABase
(version 5.4.1)
| factory(Interface *) | moab::ReadTetGen | [static] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadTetGen | [virtual] |
| mbIface | moab::ReadTetGen | [private] |
| open_file(const std::string &input_file_name, const std::string &input_name_base, const std::string &input_name_suffix, const char *file_type_suffix, const char *file_name_option, const FileOptions &opts, std::ifstream &file_stream, bool file_required=false) | moab::ReadTetGen | [private] |
| parse_attr_list(const std::string &option_str, std::vector< Tag > &tag_list, std::vector< int > &index_list, const char *group_designator=0) | moab::ReadTetGen | [private] |
| read_elem_file(EntityType type, std::istream &file, const std::vector< EntityHandle > &nodes, Range &elems) | moab::ReadTetGen | [private] |
| read_line(std::istream &file, std::string &line, int &lineno) | moab::ReadTetGen | [private] |
| read_line(std::istream &file, double *values_out, int num_values, int &lineno) | moab::ReadTetGen | [private] |
| read_node_file(std::istream &file, const Tag *attr_tag_list, const int *attr_tag_index, int attr_tag_list_len, std::vector< EntityHandle > &nodes) | moab::ReadTetGen | [private] |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::ReadTetGen | [virtual] |
| ReadTetGen(Interface *impl=NULL) | moab::ReadTetGen | |
| readTool | moab::ReadTetGen | [private] |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
| ~ReadTetGen() | moab::ReadTetGen | [virtual] |
