Mesh Oriented datABase
(version 5.4.1)
| _data | moab::SpectralQuad | [protected, static] |
| _glpoints | moab::SpectralQuad | [protected, static] |
| _init | moab::SpectralQuad | [protected, static] |
| _ld | moab::SpectralQuad | [protected, static] |
| _n | moab::SpectralQuad | [protected, static] |
| _odwork | moab::SpectralQuad | [protected, static] |
| _z | moab::SpectralQuad | [protected, static] |
| compatible(EntityType tp, int numv, EvalSet &eset) | moab::SpectralQuad | [inline, static] |
| eval_set() | moab::SpectralQuad | [inline, static] |
| evalFcn(const double *params, const double *field, const int ndim, const int num_tuples, double *work, double *result) | moab::SpectralQuad | [static] |
| initFcn(const double *verts, const int nverts, double *&work) | moab::SpectralQuad | [static] |
| insideFcn(const double *params, const int ndim, const double tol) | moab::SpectralQuad | [static] |
| integrateFcn(const double *field, const double *verts, const int nverts, const int ndim, const int num_tuples, double *work, double *result) | moab::SpectralQuad | [static] |
| jacobianFcn(const double *params, const double *verts, const int nverts, const int ndim, double *work, double *result) | moab::SpectralQuad | [static] |
| reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins, const double *posn, const double *verts, const int nverts, const int ndim, const double iter_tol, const double inside_tol, double *work, double *params, int *is_inside) | moab::SpectralQuad | [static] |
