Mesh Oriented datABase
(version 5.4.1)
| factory(Interface *) | moab::WriteSLAC | [static] |
| fileName | moab::WriteSLAC | [private] |
| gather_interior_exterior(MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data) | moab::WriteSLAC | [private] |
| gather_mesh_information(MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_info, std::vector< NeumannSetData > &neuset_info, std::vector< DirichletSetData > &dirset_info, std::vector< EntityHandle > &matsets, std::vector< EntityHandle > &neusets, std::vector< EntityHandle > &dirsets) | moab::WriteSLAC | [private] |
| get_neuset_elems(EntityHandle neuset, int current_sense, Range &forward_elems, Range &reverse_elems) | moab::WriteSLAC | [private] |
| get_valid_sides(Range &elems, const int sense, WriteSLAC::NeumannSetData &sideset_data) | moab::WriteSLAC | [private] |
| initialize_file(MeshInfo &mesh_info) | moab::WriteSLAC | [private] |
| mbImpl | moab::WriteSLAC | [private] |
| mDirichletSetTag | moab::WriteSLAC | [private] |
| mEntityMark | moab::WriteSLAC | [private] |
| mGlobalIdTag | moab::WriteSLAC | [private] |
| mMaterialSetTag | moab::WriteSLAC | [private] |
| mMatSetIdTag | moab::WriteSLAC | [private] |
| mNeumannSetTag | moab::WriteSLAC | [private] |
| mWriteIface | moab::WriteSLAC | [private] |
| ncFile | moab::WriteSLAC | [private] |
| open_file(const char *filename) | moab::WriteSLAC | [protected] |
| reset_matset(std::vector< MaterialSetData > &matset_info) | moab::WriteSLAC | [private] |
| write_file(const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3) | moab::WriteSLAC | [virtual] |
| write_matsets(MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data) | moab::WriteSLAC | [private] |
| write_nodes(const int num_nodes, const Range &nodes, const int dimension) | moab::WriteSLAC | [private] |
| WriteSLAC(Interface *impl) | moab::WriteSLAC | |
| ~WriterIface() | moab::WriterIface | [inline, virtual] |
| ~WriteSLAC() | moab::WriteSLAC | [virtual] |
